Results 1 to 7 of 7
Thread: Solar Battery Charger Recommendations
    Mar 2001
    Bath, Maine
    Default Solar Battery Charger Recommendations
    I need a basic solar setup to keep AGM batteries maintained while on a mooring. I'm bleary-eyed looking at Amazon etc. Anyone have a specific recommendation? Thanks. Ben
    Feb 2010
    Reedville, VA
    Default Re: Solar Battery Charger Recommendations
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I just bought this one from Amazon. Before that I had a smaller Gann (sp?) 10 watt charger that was about 9 years old. I think the controller that comes with this new one is pretty slick and the overall price was only a little more than the Gann charger. It may be too much for your needs, but I was happy with it.
    Aug 2016
    Hobart, Tasmania, Australia
    I have a Sun Saver 6. It's quite sophisticated but only cost around $80 AU.
    Mar 2005
    Toronto, Canada
    http://www.ebay.com/itm/MPPT30A-Sola...-/352016294681
    I bought this unit 2 years ago - the 30 amp version - when I was planning to have 250 watts of solar panel. That plan was scrapped in favour of a single 100 watt panel, so the 30 amps is way overkill. However, the 30 amp controller with the 100 watt panel keeps both my house and engine batteries at near 100% all the time. I'm in Toronto and we likely get about the same amount of sun as you do. The secret is the MPPT technology. Very efficient.
    Norm
    I second the Morningstar/Sun Saver line. I went with the Sun Save Duo as it is designed to charge 2 separate battery banks (e.g., house and start) and allows you to set preferences for which is charged preferentially. So in my instance I have it set to always charge start battery first and then when that is topped off, switch the current to the house. It also comes with a remote meter option so it is easy to check solar panel performance and state of charge etc. I've only had it about a month but so far it has been "set it and forget it". But I'm not using AGMs, so check to verify that it has a charge profile designed for them.
    Good luck!
    Mar 2001
    Bath, Maine
    Good info - thanks, everybody. Another question, though: If my house battery (group 27) and my starter battery (group 24) are connected to each other (short black cable connects the negative terminals of the two batteries to each other), then will charging one battery automatically charge the other? Or will I need to connect solar to each battery separately? Sorry, I'm a total loser when it comes to electrical stuff.
    Ben
    I'd highly recommend getting a copy of one or more of Don Casey's boat maintenance books and reading about electrical issues. I am certainly no expert but from what I have gleaned the simple answer is it depends on what the rest of your circuit is like. In general most folks want some way to choose whether to isolate or combine the house and start batteries. With my charger and a battery isolation switch, I run one pos/neg set from the solar panel to the charger and then 2 sets of pos/neg from the charger to the batteries, one to each. Make sure to put fuses on the battery cables as close to the batteries as possible. A Blue Sea battery fuse block is a very simple way to accomplish this. They make nice battery switches too and their tech support is very helpful.
