The vast amount of natural light in your shop will be invaluable when it comes time for fairing the hull. There's nothing like natural daylight to point out all our flaws.
Don - feel free to use any of the photo's I have posted to the forum and let me know if you have any special requests.
Tom, many thanks for allowing use of your photographs and to start with I think the 'sharp end' view, below, is a good start just to show the simple, clean and streamlined shape of the hull.
One question here : I can figure out all the fittings on the foredeck except for the extra pulley block. The two side by side will be for the sail and the gaff halliards but what is the third one for...just forward of those two?
Extra block for topping lift or for a gaff downhaul which I rigged when I had a catboat and handled the halyards from the cockpit.
Thanks for that info, Ben, and showing me yet another way to spell halyards. Yours is the correct way of course but, I would just like to cite Mark Twain who once said that it was an unimaginative man who could not find at least two ways of spelling a word. I rest my case.
just another correction, may be nit picking, but the two blocks are both "gaff halliards" one for the throat and one for the peak, there is no "sail halliard" as such as the sail is laced to the gaff and the gaff raises the sail.
what I want to know is what is the gigantic eye and ring for near the bow...? mooring line? can you imagine scrambling out along that deck to get a mooring in a little choppy sea?!
Forestay?what I want to know is what is the gigantic eye and ring for near the bow...?
Hi Jim, Don,
I want to provide some background information on Smith and the collection. I got this second hand and believe It to be true. Al Terry, who pasted a few years ago, was big Smith fan. He had several of his boats and helped the museum with their collection as a trustee. Somehow he was able to get the Smithsonian Museum - Library of Congress to provide assistance to document several examples of Gil Smith boats. Smith always worked from half models and by eye so they took measurements and developed a table of offsets and line drawing for Lorelei, Pauline (a plumb stem cat) and Kid (a P class sloop).
Back in 2003 The Smithsonian also provided he Museum with a grant to build a replica of a plum stem Gil Smith Catboat. The hull was started in the winter of 2003 2004 and was it brought down to display in D.C. During a summer festival on Museum grounds. The lofting for this boat as well as the patterns and jigs are in the Penney boat shop. I have have been able to sail this boat a number of times and she is fast and nimble.
please excuse any typos as I am doing this on my phone.
Tom, Could you also add something about the Lorelei history? I can't locate the text I saved last year but seem to remember that she did not get her bottom wet very often.
You will note that I have not said anything about the rear end on this boat so far. I gave up trying to include the dummy transom as I can't get round the back. All I have done is set
two blocks at the right angle for when I do make an attempt at fitting it. This photo gives some idea of things but you will have to bear with me until I get my head around it.
[QUOTE=Daniel Noyes;5271811]the bolt and ring would not be a good way to anchor a forestay, I think we're seeing the forestay tang just ahead of that eye bolt and just behind the stem head, edge on so it's tough to tell.[/QUOTE
Exactly, the ring is for mooring or a dock line. Notice the bronze strips on the toerail.
[IMG][/IMG]
While not the Lorelei, this is the boat just to the side of it that I photographed. It has the same mooring ring and the forestay tang that Daniel pointed out, just seen from a better angle.
Could be, but as Ben said, that chunky keel, the skeg, and I dare-say the head-ledges tying the upper case to the skeg make for a very strong structure. It is not a case of the CB twisting the case off of its bed logs, but of the skeg twisting that flat bottom off of the keel.
Well folks, you will see that all 'my' photographs have been 'zapped' by Photobucket (almost akin to ransomware!). They seem to be demanding that I pay $399 to have the photos reinstated. Well, I am not going to do that and intend to remove all of my photographs from their website. I take note that some photographs still remain on this thread that have been placed there by others. I would be pleased if anyone could suggest an alternative method of uploading pics to this site. As for the photos that have been removed, I can only apologise for the inconvenience. I JUST FEEL A LITTLE BIT GUTTED BY ALL THIS. I will attempt to upload photos direct from my PC but that has not worked in previous attempts.
The text above is redundant now but I have left it here to show the trauma caused. It has happened once again with 'Postimage' so this is the second time round in an effort to repair the damage caused.
Got into all sorts of trouble when trying to include the sharply angled transom so I removed it and just let the strips find there own position. I will now tailor a preliminary transom to fit the strip using those prepositioned blocks to set it at the correct angle.
Nick : I think I should have enough stock left over to use your idea of using the same material as the strip for the fillet that fairs the skeg to the bottom of the boat...bed logs did you call it?
Yes Rich, I am pleased to say that all my original photo files are held on external hard drives but, as you say, it's a great pity that photobucket have pulled the plug and let so many website visitors down. The ploy is not far short of 'ransomware' and their given reason for disabling (stated to be overuse) is a downright lie. The reason is greed and I have a feeling they will suffer from it. If I could find a way, I would remove all my photo albums from the photobucket website and I am sure that a lot more folks would do the same.. This text is also redundant but left here, just for the record.
The bed logs go on the inside, they create the "fillet" or flange that the cb case sides attached to and through which the bolts that hold the entire shebang down to the keel pass through.
What you are doing is replicating the thick structural sprung keel of the original, and providing the corner fillet that is stabilising the case/skeg. It needs a new name as it is only now possible with the advent of wood reinforced epoxy.
Having looked at developments concerning the photobucket fiasco on Jim Ledger's thread 'Lofting the Brewer Catboat' I have downloaded my files from photobucket and then deleted them. They are no use to anyone if they can't be seen in this thread. All I can say is that I will look for another photographic 'host in the sky' at which point I will come back here.
Jim Ledger is the prominent 'victim' in this sordid episode having had many years work spoiled by what can only be described as 'ransomware' tactics on behalf of photobucket.
All I can say folks is, vote with your feet and abandon photobucket...don't pay the ransom!
Once again...left here for the record as I can not erase other member's references to the problem.
Deleted my pictures and account last night.
I feel like a bit of a pioneer here! This is another copy and paste exercise, this time using the free service POSTIMAGE.
I use the word 'free' very loosely as there may be a great movement of 'photo hosts' ready to turn their free services into cash cows on the back of photobucket's recent money grabbing exercise!
I DO HOPE THE LATTER ARE ABOUT TO SLIDE DOWN THE PAN...you know the one I mean.
No picture showing in that last post, Don.
I'm using SmugMug and like the site. I've signed up for their lowest tier membership, which is $13/mo. I have my doubts that anyone will follow PB's example, as I think it will become a disaster for them.
BTW, I find it easy to size the photos when linking, and find that the "large" format works well.
Well Nick, I have just spent the last couple of hours trying to up load from DROPBOX and it seems to be working...for me!
I would be pleased if someone comes on here to say that my time wasn't wasted. I must say that I enjoyed the exercise and it was
relatively easy work once I got the hang of it.
Jim, I am very pleased that you have dug your heels in and ploughed forward through this disaster !
This wont accept the URL tags
https://www.dropbox.com/s/kr2pwagkfhn0fnb/2015-11-12%2020.17.25.jpg
But the link might work for you.
Yes it did.![]()
