Results 1 to 35 of 43
Thread: Diesel fuel sludge questions
    Jun 2016
    Adelaide, Aust.
    Default Diesel fuel sludge questions
    First off I admit I've never inspected or cleaned out a diesel fuel tank, perhaps because my usage has only ever been light (marina access for daysailing mainly).
    But I've recently been sat down and told about the hazards that lay in wait for me unless I open the inspection hatch and clear away the sludge that will sooner or later cause those said hazards to kick in and ruin my day.
    But...there is no inspection hatch on my tank and asking around it seems that most fellow boaties' tanks don't have them either...or at least have not yet been discovered. And it follows that most confess to having never tackled the dreaded sludge hazard either. Yet none have as yet washed up on some remote rocky outcrop.
    So what's the truth here: is it something to lie awake at night fretting over; should I lift finger pronto and just do the job; or will my filters continue to do the job I thought they were designed to do?
    Default Re: Diesel fuel sludge questions
    Only an anecdotal bit:
    On a very bumpy trip home I had to use the motor a lot (very long story). In 5 hours I went through 3 Racor filters, so I figured it was time to deal with it. I pulled the aluminum tanks & cut holes for inspection. The tanks were about 10 years old with quite a bit of runtime - as the former owner seemed to have motored a great deal. He also bought the cheapest diesel he could & (probably the worst part) the boat sat for 2 years on the hard before I bought her.
    I cleaned out about 1" of gunk on the bottom.
    I've heard of people having luck steam cleaning, but I wanted a way to see/reach in that I could do on my own if needed. I machined a ring for the inside & a plate for the outside. Attached the inside ring with 3 screws through the tank & then drilled & tapped the tank & ring for a bunch of screw for the covers. Got oil resistant gasket material & cut gaskets to fit. While it won't be fun getting in from the top of the tank (about 18" clearance) - at least I can now do it.
    I second what Garret relates. My experience with deisel sludge in a tank is that the problem crops up when it's rough and you shake that crap loose.
    I'll suggest this: your tank no doubt has a sending unit installed; the thing that sends a signal to a fuel gauge? If so, drain the tank, and remove the sender.These generally have five screws set through a 1-3/4" inch diameter flange/ plate
    Then have a look around with a dentist's ( mechanic's) mirror. In fact, there are even small cameras ( ' endocscopes") one can buy that you can drop in and that run off of your smartphone. These cost like 30 bucks US dollars.
    Once you've had a peek, perhaps you'll be more confident in the next steps...whatever road you take.
    Great suggestion on using the sender hole to take a look!
    Jun 2016
    Adelaide, Aust.
    Thanks for the anecdote...very salutary. And for the sender tip also. It is an aluminium tank, only small at 45 litres, and cutting in a hatch wouldn't be too much trouble. But since diesel isn't unkind to nylon (or so I've been told), would an easier way be to fit one of those $20 nylon screw-cap inspection hatches used in dinghies? If they're air-tight they oughta be fluid tight...or is that just being cheap?
    I'd be reluctant to use a dinghy inspection hatch in because they're really not rated for fuel usage. That's putting a of of trust into the quality control of something that's really only designed to keep water out. They O-Rings could be made of nearly anything and you could pretty easily end up with a very expensive and messy leak. Remember...they're really not all that good at keeping water out of dinghies....how 'bout water intrusion into your fuel?
    Oct 2006
    Livin' in Oz
    I struck a problem with it on Grantala during the Sydney Olympics. Imagine the worst marine traffic possible in the channel in Sydney Harbour... and one engine died.
    In dealing with it, I replaced the tanks... which at that stage were over 60 years old. There was over a gallon of sludge in the bottom of each 100+ gallon tank. I cut the built-in tanks out and replaced them. The sludge was like a fine brown mud.
    I'd rather look back at my life and say "I can't believe I did that" instead of being there saying "I wish I'd done that"
    45 liters is like 10-12 gallons...
    Take the tank out drain it, clean it with some solvent shake ot up and drain it again. I wouldn't think you need to cut any holes in it.
    Jun 2016
    Adelaide, Aust.
    Thanks to all. I'm probably keenest on the 'take it out and shake it' idea - (which, conveniently, would be the easiest) - and reckon should dislodge the gunk since it is the shaking at sea that is said to cause the problem.
    But a solvent for diesel sludgy tarry deposits...what might at be? I guess I could google but since you fellas are on a roll...:-)
    Oct 2006
    Livin' in Oz
    Use the universal solvent. You are not dealing with tar, you are dealing with the bodies of dead beasties that lived in the boundaries of the fuel and water in the tank. It's mud.
    You may be able to sieze a rag to a dowel and "scrub" it a bit through the fill port. Look in there with a little flashlight, you might be pleasantly surprised. A few cups of mineral sprits/paint thinner as a flush after the scrub should do it. New fuel with a bit of biocide added and you should be good for years.
    Sep 2004
    Munich, Germany
    I had my lesson last year. I left the dock when the engine died 100m from shore. Could't get it running again, so I driftted back and started looking for the cause. Turned out, that the fuel lines where clogged. Turned our also, that I didn't have nor a tank inspection hatch nor a fuel pre filter before the pre injection pump filter. What resulted from this was a nearly 2 day cleaning action that included the disassembly of the fuel pump as well as changing over the fuel lines, cutting a hole into the wood/epoxy fuel tank and lots of cleaning of a deep, dark tank with long sticks with rags attached to the ends and many liters of solvents.
    My lesson is:
    1. Use sluge preventigin additive regularily
    2. Have a fuel prefilter and check regularily from brown stuff and pieces
    3. Have an inspection opening in the tank, than can be used when the time comes.
    Thomas
    panta rei
    Jun 2016
    Adelaide, Aust.
    Thanks to all for your advice. Since it's a small tank I'll choose to remove it, add solvent and shake it clean. Bigger or more inaccessible tanks I can understand would need a good sized access port but I'm expecting I'll be able to get away without one. Cheers
    Oct 2006
    Livin' in Oz
    Just stick a Karcher nozzle in it.
    Feb 2011
    U.K
    Being as you don't even know if you have a problem yet, i would suggest polishing your fuel, either get someone to do it for you or make up a pump and filter rig and do it yourself.
    i would also have twin pre-filters, with a change over valve. i have never understood the mentality of a single pre-filter on a single engine boat. if one filter clogs up simply flip the valve and change the it at your leisure.
    Quote Originally Posted by Asap View Post
    Nov 2006
    If you can remove the sender, take a small engine oil pump and run a hose down into the deepest part. My huge tank has no easy access and I got curious after 15 seasons of no filter problems beyond normal changing. Plenty of violent shaking along the way.
    The samples I pulled from the deepest corners, showed clean fuel with a tiny bit of sediment. I used plastic bottles for easy viewing. I only use a Cetane booster type additive. Tanks are left over winter, full or half full. Beats me why some have problems with fuel tanks, and some don't.
    Dec 2015
    Dorset, UK
    Clean fuel and maintaining a fully charged starter battery should be your obsession with a diesel engine.
    The fuel tank is likely to have sludge produced by micro organisms and potentially water from condensation forming on the walls of a half empty tank, as it will have a vent somewhere.
    If I buy a big boat, I always replace the starter battery and clean out the tank, then refit with new hoses and stainless hose clips, preferably two at 180 degrees to each other. Check the seal on the filler cap isn't letting water past. Check the welds on a stainless tank for any sign of corrosion. Check any plastic fuel lines aren't abraiding due to vibration. Check copper fuel lines are secure.
    At the same time replace the filters on the prefilter and the engine. The diesel bug will be sent back into the tank, as there is a return pipe taking unused diesel back to the tank.
    I'd only fill up from sources that use alot of fuel, or even from a jerry can from a car forecourt if I didn't use much diesel so it was clean.
    Ideally you have a main tank and a seperate day tank that is transparent and you can fill and inspect the fuel visually before the filters. Ideally you have two Racor water fuel filters in parrallel so that when one full of water or material you can switch to the other. And keep the tanks full, well secured, baffled, with low sumps, close to the center of the boat, and add diesel additive to reduce sludge build up.
    Replace the starter battery every 3-4 years, and have a solar trickle charger charging it between uses. Fully charge it with an automotive intelligent charger when you can off the boat. Don't run the battery anywhere near flat ever.
    Dec 2016
    EU
    Remove it and pressure wash it inside. Use engine washing detergent to get it really clean. That will work better than any solvent. Rinse with gasoline to get the water out. Then fill from 20L jerrycans from your favorite gas station to always ensure clean fresh diesel. You fill the tank at the end of the day after sailing so that you always leave the boat with a full tank. That way water can not condensate inside the tank (not much that is). If you leave the boat sitting for longer or use very litlle diesel per sailing day, use biocide.
    After a while you develop a rutine. On the way to the boat stop and fill the jerrycan. Take it to the boat and leave it in the dock box. Come back from sailing, fill tank to the brim, take the jerrycan to the car. Any leftover diesel goes into the car tank. If you don't have a diesel car or friends that have one approximate the diesel needed for a typical daysail and use a smaller jerrycan (5L).
    Good luck amd keep us posted.
    Nov 2009
    Searsport, Maine
    We used to have a good bit of gunk in our tank that would clog the filters after being in a lively seaway. We stopped at a yard where they could run the fuel through a couple of large filters for a few hours. We hooked up their intake to an outlet on our tank bottom for just that purpose (the engine supply line is a bit higher,) and had the inlet on a wand that could be used to spray around anywhere a baffle wasn't blocking. Got rid of our troubles. Since then, I always add the recommended amount of BioBor JF when refilling the tank at the end of the season to cut down on condensation. We also try and use a full tank each year which generally involves more motoring then we might like, but the engine needs to get its workout too. Haven't had any problems since and have been through quite a few lively seaways.
    West Boothbay Harbor, Maine
    We have fuel tank filtering/polishing businesses that make the rounds of boatyards and civil aviation airports pretty regularly with mobile equipment. I'd be surprised if there aren't any such businesses in AU. They can filter and polish the fuel through the sender fitting.
    You can also test for water and perhaps sludge in the tanks with a paste: https://www.youtube.com/watch?v=WsdIrpyMUcA
    If you need to install an inspection hole (or new tanks) these are new to the market and can be combined with sending units, vents and fill tubes: http://www.vetus.com/news/inspection-port-ilt.html
    "And so the seasons went rolling on into summer, as one rambles into higher and higher grass." Thoreau, "Walden"
    Barrie, Ontario, Canada
    I don't do this often enough and got caught by it last year. Had to scrub our Northern cruise.
    http://forum.woodenboat.com/showthre...ed-ketch/page8
    Nov 2010
    Wellington, NZ
    My engine stopped in the middle of "The Rip" off the south coast of Wellington last month.
    I continued travelling out of the rip with sails and the 5 knots of current going in the right direction.
    I have a 20 micron plastic prefilter fitted to the tank outlet hose.
    This was changed in 5 minutes, and the electric lift pump cleared the fuel lines of air after being left running for a minute before I restarted the engine no problem.
    As we continued home, I cracked each injector supply line just to check.
    I'm sure glad I carry 2-3 of these $5 filters.
    I need to get some treatment snake oil for the tank, some of which profess to clearing the sludge as well.
    Sep 2002
    Sonoma County
    I cut a hole and built an inspection hatch into my tank.
    One lesson learned.. it must be EASY to access this hatch, or you'll never use it.
    Gold Coast Australia
    Just came across this thread and am hoping for some feedback on a Kobuta 15 hp marine engine that keeps randomly shutting down when hot with problem getting progressively worse.
    Tank has been emptied CAV filter changed stop selonoid disconected as well as add on aircraft type transfer pulse pump and injectors just checked .Prior to checking the injectors I hooked up some clean fuel and new fuel line directly to the injector pump and it still cut out after about one hour.
    Generally the engine will start straight after shutting down but will generally require cracking the last injector in order to bleed air out of system. After that it will shut down more frequently and is harder to keep running which presented some nightmares on my recent East Coast trip
    Oct 2006
    Livin' in Oz
    Maybe the fuel is frothing a bit when returned to the tank... and when it comes back through, it's got air in it? I know when I built the tanks for Grantala, I had to take particular care to ensure the return line for the DDs ran the fuel to the bottom and against the edge of the tank, in order to avoid it doing that.
    Jan 2015
    Mystic, CT
    Just for another opinion: I pulled the 32 gallon Monel tank out of our 45 year old sailboat that started life with a gas engine switched to diesel. It had no access hole or sending unit just the fill line and vent line so I asked around about what to do. The local 'boat whisperer' recommended 'marine clean' from POR:
    http://www.por15.com/POR-15-Cleaner-Degreaser_p_14.html.
    It is clear, mixed 50/50 with water and I added it to the tank, rolled it around for a few minutes and poured it out after 15 minutes What came out looked like butterscotch. It was clear on the 4th try and I could see the shiny bottom of the Monel tank. I let it dry for a few days then added a bit of acetone to suck up any remaining water.
    Woodinville, Washington
    I don't know anything about Kubota troubleshooting. However, one thing you can check is whether your pickup tube in the fuel tank has a hole in it, or, is broken off at the top. thereby allowing air to get sucked into the system, when the fuel level drops below the defective pick up tube. thus killing the engine.
    your symptoms are very similar to pick up tube problems I've faced previously. Something to check. If not, a call to the Kubota dealer might be a good solution.
    glenn
    My guess would be air as well. As said, check the pickup, but also any fuel line connections, the filter, etc.
    Putting a push pump close to the tank can help - but that may mask the problem.
    Southampton Ont. Canada
    Air leak into the CAV is my guess.
    Instrument of the devil, like Lucas and 5200.
    R
    Edit
    If you connected a fuel line with new fuel directly to the injection pump,did you gravity feed it or hand pump or something?
    Sleep with one eye open.
    Thanks guys for all the helpful hints. Not so sure about the frothing fuel Ian since the fuel tank installation has not changed recently.
    Pulling the tank while not impossible would be difficult ,the only access to the inside of the tank might be accomplished using the fuel fill pipe using a telescoping miniature camera, inspecting the condition of tank and possibly the pick up pipe if it exists.
    In my latest test a seperate new fuel line was hooked up between a jerry can and the injector pump eliminating the filter, which effectively rules that out.
    A tractor post that - with a little deciphering - might help? Return line issues: http://www.ssbtractor.com/wwwboard/v...bota&msg=27916
    Thanks Garret I had not considered the fuel return line. A possible problem ,might just have a closer look at that today.
    My logic would suggest then a fault in the injector pump, as it would appear to be sucking air, somewhere after the fuel line meets the pump. I imagine new injector pumps cost about as much as a small car, but if you can find your engine details on a plate on the rocker cover, and go to a place that services small earthmoving equipment, you are likely to find that they have a stack of dead engines out the back and you might get one for a reasonable price. I think there might then be a black art involved in getting the pump timing just right.
    Thanks Phil Quite right But before I start ripping out the injector pumps I want to be absolutely certain that it is indeed the problem.
    And yes there appears to be some degree of black art involved in removing and reinstalling such a device .I have been reasearching Kubota D722 injection pumps lately and the whole process is still mysterious.
