Results 71 to 105 of 142
Thread: 1961 Chris Craft constellation refit/repower long term project.
    Jul 2002
    Default Re: 1961 Chris Craft constellation refit/repower long term project.
    Looks like you have it handled, bud, so I won't trouble you anymore. Since I have done boat restoration for 35 years, some people think my views are at least worth considering. Some of your choices you will likely regret, but good luck.
    Jul 2016
    Stockton, Ca, USA
    So has the guy helping do the repairs. 40 years...... I hear this every day from people that never agree on how to work on and maintain wooden boats.
    Again what seam compound? The interlux is not for this application, it's to hard, and the petti is no longer available. Do you have a linseed putty recipe? Any advice other than a generic term like seam putty.
    Plastic wood filler? Why? Is there some reason it works well below the water line? I used this on the topside and every single one poped out the following season. I have been a carpenter for 20 years and this stuff is **** for most applications. I welcome advice but it needs to be explained and be followed with specifics.
    Sorry if I was stand offish. But your response was vague.
    Why not use dynaglass in an area I will be replacing in a year or two? Especially since there was a leak?
    And for the record the one doing the repair has been maintaining this boat for 30 years. Her hull and bottom are in fantastic shape considering she went 12 years between haul outs before I got her. So the guy knows his ****. Some of his repairs from 20 years ago are still like new.
    Jul 2016
    Stockton, Ca, USA
    Anyway.....
    I got time inbetween rain showers to remove the inner chine.
    It did rot the edge of the bottom plank and the plywood so I plan to remove one plank and take a look and make repairs as needed.
    This is the inner chine. The V cut changes angle and width as you go forward. Should be an easy cut assuming my hand is still strong enough to run the circular saw with the angle lock off and to smoothly get the angle to change. I only need to get t close and I can finish it up with a chisel.
    This is how it fits into position.
    I had to take it out in pieces and I saved them in order to pull measurements and angles from where they are not totally rotten and useless.
    Dec 2013
    Los Gatos, CA
    It's a bit hard to tell from the pictures, but is her bottom an inner layer of plywood that is then covered with an outer layer of planks? Or the other way around?
    Jul 2016
    Stockton, Ca, USA
    Inner layer of plywood then planking.
    Dec 2013
    Los Gatos, CA
    Quote Originally Posted by Hill160881 View Post
    wow, she is built just like my little 17ft Chris Craft (inner was originally diagonal plank covered by outer of straight plank but I replaced the inner with plywood when I restored her) but she is just a lot bigger boat! Were they still putting canvas soaked with linseed oil in between the two layers of her bottom when she was built? That's what they had done on my little runabout. I was glad to be rid of it. Really promoted rot after the oil dried out and water took its place.
    God all this rain must suck for you. Will they let you work on her under some plastic and an easy up at least??
    Jul 2016
    Stockton, Ca, USA
    It looks like they just set the planking in white led putty. No canvas. I was sure it had canvas but no. Not even any gap between boards. Just led putty and but them together. Dry as a bone between the two layers.
    The rain will give me a 5 day window and I should be able to get it done in that time with the help I have. A lot will happen in a short time now. Starting with tomorro and continuing until she hits the water next week.
    I am excited to get her wet and hook up the engines. Also to get her back in her slip and get the decks and rails I paid for done.
    Jul 2016
    Stockton, Ca, USA
    Working on the chine. Test fitting it before I replace a plywood strip. My friend doing the chine is having fun. Haha
    Dec 2013
    Los Gatos, CA
    does your friend want a job in Napa. Looks like he does nice work. What kind of wood are you using? Did you get it locally ?
    Jul 2016
    Stockton, Ca, USA
    Haha He is old and slow and shows up at 1..... but yes he does good work. When you can get him on site Nailed that piece on the first try. His experience is evident. Honestly nothing I cant do. The number of times we get asked for a card it's a good thing neither of us has one. He is more interested in his 80 something footer he is working on on the east coast. He is just helping me out in a pinch. There is no way I can get this done fast enough by myself with all that is getting done.
    Jul 2016
    Stockton, Ca, USA
    The lower inner chine is done. That's the hard one.
    It was done in two pieces to accommodate the bends and such.
    This area looked bad so I took the outer chine off and it's only on the surface and some epoxy should do the trick.
    Jul 2016
    Stockton, Ca, USA
    For those who think I am doing something wrong with the sikaflex let me explain the logic behind it for this application. We simply can not get the tolerances needed with this repair for seam compounds or putty to do its job. If you look at the many changing angles and the bends with this chine there is no way me or Chris can get it that close. Can we get it close? Very as evident by the pics but not enough the make a water tight seal guaranteed. Some may disagree but I feel this is simply admitting the limitations of the situation and not sticking to old methods that would take much longer than we have and with a much higher likelihood of a leak. What most won't accept is this is a double planked lower and a board and baton up top design and that differed from most sail boats that need different methods and materials. If you disagree that's fine
    Inner chine done! Just bolts and final faring. Tomorrow we will set the plywood and lower planking.
    The lower angle is still off by a small amount but it was as close enough.
    Jul 2016
    Stockton, Ca, USA
    Lower planking ready to screw up. Should be ready to paint by tomorrow evening if all goes well.
    Also got the sikaflex done on all the problem areas. Tomorrow I will sand the lines then dynaglass all the screw holes.
    Jul 2016
    Stockton, Ca, USA
    Almost there. Just one more board and the lower outer chine. Hopefully the weather does not go to total **** and add another week for the last days work. It most likely will
    No leak construction.
    Then lots of screws
    Very close.
    Jul 2016
    Stockton, Ca, USA
    Today was a long day but productive. Tomorrow is the day. I have some dynaglass and some sikaflex to do but it's all small stuff that won't take more than an hour or two.
    At the very back of the keel it had a leak after it rained. I was sure I fixed this but no. Glad it rained. So I carved out a 1/4 inch by 4 inch notch between board joints where the keel ends and the bottom planking begins. I am sure there is a term I don't know. Since it would not dry out i decided to use a technique with water activated expanding wood glue. Gorilla glue Then I made a plug and pounded it in. No more drip which means no more leak.
    The hole I carved out.
    The tapered plug I made.
    Then pound it in with lots of glue and let it set up.
    Then once it's dry tape it off and sikaflex the area. I made the plug 1/8" receded to leave room for the sikaflex. No more leak or drip from inside. This repair was made while it was dripping wet and was solid as a rock.
    Jul 2016
    Stockton, Ca, USA
    The outer chine is done.
    During the process.
    The port side is sealed up with no leaks. Ready for its final paint.
    Dec 2013
    Los Gatos, CA
    Two questions. As I recall you were using family wood to seal screw holes above the water line. Why not just use dyna-glass both above and below the water line? Is there a big cost difference?
    Also can you tell me where you got your wood and how much it cost?
    Looks good, though it would have been fun to come help ��
    Jul 2016
    Stockton, Ca, USA
    Dynaglass or bondo glass is a different hardness and sands at a different rate than the wood. So above the water line it makes for for issues. Also it is two part where the famowood is apply right out of the can and sands similar to the wood. Had to drive to Berkeley to get the wood. MacBeath hardwood.
    She is ready to hit the water. Like it never happened.
    The yard operator asked me how long I would need to leave it in the sling and both me and Chris laughed out loud. No time at all. Just put it in and move it over to the dock. I doubt there will be much leaking. Hell it full of water and not leaking out now.
    Dec 2013
    Los Gatos, CA
    LOL, yea but the water is on the inside! It's no wonder with this constant rain we have had. I suppose you could have run the bilge pumps , water's water right!
    The repair looks great and is really solid, that much is clear.
    McBeth does seam to be the go-to place around here for nice mahogany, but I like to ask people because experience is the final word on which vendors offer the best service price and quality.
    So do you leave the Dynaglass just a bit proud to avoid sanding too much of the wood around it off. I mean it's under the water line so who cares right.
    I am looking forward to seeing how the engines, and especially that new gauge package perform for you. I noticed in the pictures that there is what looks to be a Keel cooler on the skeg. Is that for her propulsion engines, or something else. I don't see the keel coolers on the faster boats and always wondered why.
    Well congratulations on getting her down so fast, and getting out of the rain. I just hate working in the rain because it makes even the easiest jobs a PIA.
    Leo
    Jul 2016
    Stockton, Ca, USA
    I do leave the dyna glass a bit proud and then knock it down with an angle grinder prior to paint. Remember it's below the water line and not seen.
    Actually thats not a cooler on the keel. It's for strength as best I can figure. There is a pipe cooler like this for the old refrigerator down by the keel. I wanted to remove it but forgot this haul out.
    In total this all took 6 days if not for that winch Mother Nature and her rain.
    Jul 2016
    Stockton, Ca, USA
    Something else I did that made a huge difference on that port side was to take a members, pcfords, advice and pulled the screws and I found some #10s with bigger heads that were 1/2 inch longer and I replaced all the leaking screws with the longer ones. Then after the smiths cpes had set up I pounded in tapered plugs with gorilla glue. Then dynaglassed the rest. Not one leak from inside anymore.
    The wood cost was 3grand.
    Jan 2017
    Henryetta, Oklahoma
    Wonderful work. It is incredible for you tackling such a large beautiful project.
    May 2000
    St. Louis, MO
    good progress!
    Dec 2013
    Los Gatos, CA
    $3K! are you serious?
    Jul 2016
    Stockton, Ca, USA
    Then another 500 for stainless screws. The silicone bronze were $1500 and I said screw that.
    Jan 2011
    You might want to edit that last post before the moderator sees it.
    Jul 2016
    Stockton, Ca, USA
    Oops I thought the filter would get it. Working in a boat yard for a while you develop a certain language
    She is home and the pump has only kicked on once. So in a day or two she will be tight. The repair is dry.
    Dec 2013
    Los Gatos, CA
    Yea, I was going to ask you about the screws being SS instead of SB, but I knew the answer so I didn't bother. But the wood, that really surprised me. When I go to Asia I see people building pallets out Mahogany.
    I would really like to see more threads and information devoted to some of the more harsh realities of building and maintaining wooden boats. When a shipwrights is doing the work it makes sense not to skimp on material. But if your boat had been owned by a 20 year old could it really be justified telling him to spend $3k on wood, versus $500 on wood and to then be prepared to do it again at 30. It could be the difference between saving a boat or scraping it, and at the same time making a young guy happy and helping him feel empowered to build stuff.
    Anyway, I'll be spending a lot of work, and I personally don't want to do the work again in 10 years so I better suck it up I guess.
    Jul 2016
    Stockton, Ca, USA
    There is a saying. Don't try to make an old woody new again. A lot of people will try to make an old boat new again at the expense of reason. I try to find a realistic middle ground. I Do what is within my abilities and price range and be glad another old wooden boat is not on the chopping block.
    Jul 2016
    Stockton, Ca, USA
    Quote Originally Posted by leop View Post
    I helped a guy three years ago do some similar work and we used some thin 3/4 marine ply wood. Cut it into planking sized strips and scarfed them together. Looks great and is still leak free. Looking at her you will never know and I guarantee the repair I made will out last the boat. Replaced 200' of planking half of it below the water line and it was something like 500 bucks for supplies. Boat was going to be cut up due to a 20 grand repair estimate. Less than 3 grand later she launched and is still going.
    Like I said. Don't make them new. That old boat was beautiful inside amd out and was going to be cut up because it was cheaper to do that than fix it the right way. It now will last another 20 years.
    Dec 2013
    Los Gatos, CA
    That's a great example and idea. But how did you get that much marine plywood for $500??
    Yes, this sounds like a really good idea for a few planks I have commingled up.
    Thanks, maybe you just saved another one!
    Leo
    Jul 2016
    Stockton, Ca, USA
    One sheet makes like 40-60 feet of planking.
    This next week or two I will take to get the engines hooked up and running.
    May 2000
    St. Louis, MO
    Any update? Been almost a month!
    Jul 2016
    Stockton, Ca, USA
    No working. It's almost boating season. So evrone amdnthere mom wants stuff done. Soon though.
    Jul 2016
    Stockton, Ca, USA
    Remember how my marina shut me down saying I was not allowed to do this kind of work on my boat in its slip?
    This is an old house boat from the early 80s they stripped to the deck in the slip next to me. Rules only apply to me I guess.
    Stripped to the decking. Never once protected the water or a damn thing.
    All this whole telling me to cover up mine or get evicted.
