Page 58 of 58 FirstFirst ... 8485758
Results 1,996 to 2,010 of 2010
  1. #1996
    Steve, I installed a new motor recently. Did all my calculations and mocked it up in CAD. When I dropped it in, I only had a centimetre each side of the fly wheel. Enough but bloody close. I hadn't thought of it at all.
    just looking at how your engine logs taper in toward the back. It might be worth a double check while access is easy.
    deck; glassed ply. You'll go with laid I'm sure, but eventually Arabella will have a ply deck sheathed in glass - cause it works and lasts. Laid decks are all well and good if keeping your bronze shinny is your bag. I'd do it now while it's in the shed and you can do a good job. But, if what you really want is to be chasing leaks while anchored in some nook off the coast of Patagonia.......
  2. #1997
    May 2010
    Near Oslo, Norway
    Hi Steve,
    My first comment to your thread here, but I am a regualar on your facebook posts and on Youtube.
    It is a great project, and the type of vessel is similar in lines to what I have been building up here in Norway.
    I say it is similar in lines, but the construction is different!
    I would also go for a traditionally laid deck IF you have bolts that secure the sheerstrake to the carlins or you can install a recessed plank just inside the covering board, to take the strain from the caulking, and prevent forcing the boat wider as you caulk.
    I think the scantlings on the timbers you are using will not allow a half-inch recess of such a plank without weakening it substantionally either, so bolts would be preferable.
    You know what there is to chosing the right planking stock for a laid deck, so careful selecton is of great importance.
    Love following your videos, and will try to keep up with you here as well.
    Ole
    Svaap
  3. #1998
    Southern Maine
    Not much action on on this thread.
  4. #1999
    Southern Maine
    Another viddy. Man, they are overbuilding
  5. #2000
    Sep 2003
    Somewhere in South Central PA
    How is the main mast step going to be fastened to the floors? Right now it looks like it is just notched over the floors.
  6. #2001
    Dec 2019
    Westford MA & Milfjörd NH, USA
    Quote Originally Posted by Brian Palmer View Post
    I commented on this on the YouTube video but not here, until now. You (Brian) have described it properly, and IMO it's a mistake for A2A to do it that way. There is real estate between the bronze floors to add suitable wood-of-choice to further spread the load and reduce the stress concentration(s). So long as limber holes are added, there should be no harm.
    The bronze floors main purpose to to transfer & balance the load from the (upward) buoyant forces on the hull to the downward force caused by the lead ballast keel. That occurs everywhere along the length of the hull except for the small overhangs in the bow and stern. The mast adds downward force in a similar manner to the lead ballast, and similarly the shroud loads coupled to the chainplates provide an additional upward force into the frames --- much like the buoyant forces. BUT the up- and down-loads occur in a distributed manner through many frames and many keel bolts. The mast, on the other hand, sits atop the step. The step, as designed presently, does spread the load but then it abruptly rides atop the floor transverse braces. That's a problem waiting to happen, and it's wholly avoidable: use the space between floors to fill with wood to more smoothly distribute the compression load AND to provide fore-aft-stability to the transverse floors.
    I'll add that this is an easy thing to add now. To fix it later, when it's needed, costly and aggravating. IMO, HTH.
  7. #2002
    Shubenacadie NS
    Would a simple narrow blocking between the floors, say 6" wide along the CL of the underside of the mast step do the job do you think xkdrolt? I don't think it needs to be the full width of the step, just a few inches along the middle to resist compression and help provide more support than that narrow top edge of each floor, while eliminating any chance of wracking movement of the frames under the pressure of the mast.
    -Henry David Thoreau-
  8. #2003
    Dec 2019
    Would a simple narrow blocking between the floors, say 6" wide along the CL of the underside of the mast step do the job ... ?
    I'm sure that would help, but if room allows I would still make it as wide as possible while allowing for limber holes.
  9. #2004
    @ 18:20, Mention is made of the mast step staying dry, water will not come up that high.
    It is sweet water ,(rain) dripping down from canvas mast boots or through mast checks that may get in there , not saewater splashing around.
    I've seen it dozens of times.
    @14:18, When Alex mentions Atkin puts the mast step on the keel...wtf ! I'm shocked .
    I'm not quite following what xdrolt is trying to say. You think they should fill in the step with solid wood to the keel?
    Are you going to make the mast tenon LONG !!!? 2 inches deep is dangerous for an ocean basher, especially a gaffer with loose rigging. God forbit she ever gets knocked off the top of a giant wave, the rig can stretch a few inches and the mast can escape a shallow notch. In fact, I make the notch in steps go all the way through if I can.
  10. #2005
    May 2012
    UK. Cornwall, Suffolk.
    A bolt through the mast (somewhere) to keep the foot in its step would do the job of keeping it down no?
  11. #2006
    Mukilteo, WA
    The main mast step on my Ingrid is sitting on top of the floors and does not reach the keel. I believe this is normal. All wood construction in my case.
  12. #2007
    Sep 2005
    seattle
    Seems to me that a bronze angle frame tabbed to the floors to cradle the wood step would work well. As far as I can tell, all the wood between the slots is just taking up space. My boat has wood floors and a wood step resting on the floors; the floors are cut away at the step; not an ideal arrangement but typical. I've always thought that a bronze weldment for the step and floors in that area would be superb. I seem to remember an S&S locally that was repaired in that manner.
  13. #2008
    Mar 2015
    Granby, Massachusetts
    Sorry I have been MIA here for a while.
    In all honesty, I got super demoralized with the thread when the older pictures on the thread went poof. A big part of posting here is to add another level of documentation to join the videos and other social media posts. Without pictures that documentation is less than helpful.
    But, you all talking about the mast step in the video made me realize that maybe the videos could supply the images and so long as a video is linked anyone in the future could watch the video and follow the commentary here.
    YouTube comments are kind of like that but more Mad Max style than what I think people trying to learn would find useful.
    Atkin did indeed spec the main mast to sit on what looks like a tiny metal mast step, between the floors, directly on the forefoot. That is also how Victoria was set up, her bronze step was directly on her keel.
    The mast step will get bolted down and more surface area added to the floors at some point in the future.
    Once the top of the mast step gets shaped to meet the rake of the mast we will finish it all up. I'll likely weld up a few 90* bronze brackets that will get bolted to the vertical plates on the bronze floors and I will drill down through the mast step in probably 2 places and bolt the step to the flange that the 90* bracket makes.
    So the mast step will notch over the vertical plate and sit on a bronze shelf bolted to the plate and a bolt will go through that bracket and the mast step.
    First I want to see how the top turns out, I might remove some meat from the bottom if we don't carve much into it, or take it from the top. That might change the location of the bracket support and will absolutely change the length of bolt needed to join step to bracket. Hence leaving it unfinished for now.
    I probably should have articulated that better in the video but almost anytime we have tried to explain some future thing, we make more issues than we solve. haha
    Bruce, the point about the long tenon is taken! I don't see any reason we can't make a substantial one. Both mast steps are plenty deep enough for it.
    This Friday is the mizzen step I believe. It just spans two floors since it's such a smaller sail/stick and is above all the massive deadwood. It also notches over the floors and is carved from one big hunk of white oak. It almost looks like a musical instrument body after it was carved to fit the curves of the floors.
    I'm also chugging along on making laminated bulkhead panels. They are essentially 3 ply plywood, glued with epoxy (Thanks Total Boat) They are made from oak and cedar. Some are oak, cedar, oak and some are oak, cedar, cedar and some all cedar. All cores are cedar and faces that will be lived with and subjected to bumps and scrapes will be oak. Inside lockers, the head... will be cedar to help keep the weight down.
    Alix has been making progress on re-sizing and truing Victoria's mast to become Arabella's mizzen mast. It appears to be tight grained fir and seems to be in spectacular shape so far.
    As you can see we are a little ahead of the videos and are into some fun stuff!
    ACORN TO ARABELLA
    www.acorntoarabella.com
  14. #2009
    Feb 2003
    Merrimack NH
    Steve - thanks for continuing to post here. I agree the loss of pictures is frustrating, but I think your observation on the YouTube linkage is good. The only other solution I could make is if you host your own pictures (on your own domain) you can link them out to discussions like this. Tons of work to go back and fix, though (just ask Jim Ledger!)
    regarding the maststep - good luck navigating all the comments - both on YouTube and here. I'm sure you'll read too many and hopefully be able to parse the good advice from noise. I know you've been dealing with that this whole project!
  15. #2010
    Quote Originally Posted by sdenette View Post
    I enjoy updates on the gram when I’m posting doodles. She is looking amaze-balls! Just, absolutely lovely. Keep grinding!
