Page 38 of 38 FirstFirst ... 283738
Results 1,296 to 1,304 of 1304
  1. #1296
    Sep 2002
    Sonoma County
    Just question on engine sizing.. the Nanni N4-50 is rated at 36.8HP . Don't know if anyone has spoken to you, or you've read up on sizing the engine to the hull?
    I don't know the lines/ displacement of your hull, but you CAN put in too much engine. The hull shape, how easily it's driven at hull speed, displacement, prop diam, prop pitch and blade count and a few other variables all contribute to essentially a "fixed load" the engine will "see" given the speed you choose to cruise at. I got lectured on this from the Forum 10 years ago in repowering my 5 ton 26' full keeled Cutter. It's nothing like a planing hull where it's almost impossible to have too much horsepower.
    There's nothing like a good WoodenBoat Forum brow beating to make an impression on you....
    Anyhow, the long and short of it is if a diesel is oversized for the fixed load it will never get into the fat part of it's performance curve. It can unbelievably fail to run hot enough which has efficiency implications. An overloaded diesel will overheat and blow headgaskets like tissues.
    So.. you may have already been tanned and hided, or are simply replacing like-for-like in terms of the Perkins' ratings and this engine. If it's like-for-like, pull out the performance curves of both engines (Torque vs RPM) and make sure they overlap. I'll be they won't as the Kubota is a "modern high speed" diesel which means it turns at nearly 3000RPM.. i"m betting the Perkins stays under 1500.. but all this is just conjecture...
  2. #1297
    May 2012
    UK. Cornwall, Suffolk.
    Arabella is 10 tonnes ballasted? Rule of thumb for sailing boat aux engines is 3 horse @shaft! Per tonne.
    Most manufacturers put fairy dust HP ratings on the plate, and in any case do not know gearbox losses at the time of writing it.
    I have been going backwards in a 'rule of thumb' rated horsepower sailing boat. With tired crew, getting dark, wind starting to screech, and only shipping lanes behind me. More HP is good sometimes, and will only need to save the boat once. Up to each to decide what fuel consumption and weight to put up with.
  3. #1298
    Mukilteo, WA
    The Ingrid is about 25000 lb so 11-12 tons depending on your units. I have a 4-107 and feel that is just about right. I cruise at 1500-1800 rpm with plenty of reserve if needed.
    Its rated at 38 hp continuous, 45 max according to google. Take that with a grain of salt I'm sure.
  4. #1299
    May 2016
    Ottawa, Canada
    I would say engine / transmission / prop selection is a bit of an iterative process. The prop diameter may limit everything else based on clearance, or you add blade area, or you have greater slip, or you change transmission ratio .......
    We ended up with a spread sheet based on Dave Gerr's propeller handbook to play around with the options.
  5. #1300
    Sep 2002
    Sonoma County
    I got away with only having to repitch my prop once with the repower (new Kubota based 26HP 3 cylinder, 1 liter, replacing an Albin AD-2, two cylinder, 20HP, 1 liter).
    The first "guess" was not bad (using above mentioned method) so we got pretty close.
    "Close" meant I could hit about 80% of Redline, but not quite.
    A minor adjustment a year later (for next haulout) and it was perfect. Engine could be spun to max RPMs when needed and noticed about 1/2 Knot increase averaging the with the tide and against the tide speeds.
  6. #1301
    Mar 2014
    Ronneby, Blekinge, Sweden
    I'm sure I missed it if it was mentioned just wondering about the decision to have square rivets.
    I have never heard of, read or talked about using round shafted nails when riveting.
    /Mats
    Yes the avatar depicts me; yes I drew the comic boat pic, it's a joke on the pop song I'm Not a Robot by Marina and the Diamonds.
    Swedish Yourneyman of the Year 2019
  7. #1302
    Aug 2014
    Westchester, NY
    Steve discusses round vs square rivets in one of the videos about rivets.
    My Goat Island Skiff Project Photos:
    https://www.flickr.com/photos/999065...7648295059621/
  8. #1303
    Congratulations to the Arabella Crew on reaching the 100,000 Subscriber mark on YouTube!
  9. #1304
    Mar 2014
    Granby (lit. spruce village in swedish) seems to be of spitting distance from Amherst, where I spent a year as an exchange student 30 years ago.
    /Mats
