Page 3 of 13 FirstFirst ... 234 ... LastLast
Results 71 to 105 of 451
Thread: A Whiily Tern in Oz
    Default Re: A Whiily Tern in Oz
    It's fun isn't it Peter ?
    Aug 2002
    Sydney, Australia
    Absolutely addictive. And thanks for the pic of Masina - another beauty.
    I did have one question about the gains. I have had a good look at your build pages and was wondering about the length of the gains. IO says between 8 and 15 inches depending on plank thickness and size of boat. There are 4 planks per side on the Whilly Tern and planking is 1/4" (6mm). I have been working with small battens and also by eye so far. I was also wondering if the gains start smaller (sheer plank) and progressively get a bit longer working down to planks 2, 3 and 4. Or is each gain of each plank approx the same length. Thoughts?
    PeterW
    A hard one .... my planking is 9.5mm and I made the gains about 500 long if I remember correctly and all the same.
    Aug 2002
    Sydney, Australia
    Default Re: A Whilly Tern in Oz
    Plank 3 ( no 2 on the starboard side) went on today. A good process with plenty of the peg clamps to hold everything down.
    This shot is of the plank with a thin batten to assist with final clean-up.
    Plank installed.
    PeterW
    Aug 2002
    Sydney, Australia
    Had an 'oops' moment today. Found that I had missed a chine point on Station 3. Easy fix - just drew up the missing section on the full sized patterns and transferred the missing shape to a piece of 1/2 inch mould ply and glued it on.
    PeterW
    Aug 2002
    Sydney, Australia
    4th plank (2nd on port side) attached today. Made a better job of cleanup inside on this one.
    PeterW
    Wide planks = fast progress !
    Gold Coast Australia
    [QUOTE=PeterWidders;4952968]Tom - I purchased the plans from NIS Boats in Sth Aust. My understanding is that Iain Oughtred modified the initial design in 2003. Some of my plans have a date of '92 while others have '03.
    Is this what you meant?
    I was thinking more about wether you are planning to sail the Tern independently or combine with your other boats cruising plans.
    Aug 2002
    Sydney, Australia
    Tom - sailing plans are for mostly solo sailing (with a crewmember at times) . Maybe some sailing in company - depends who is around at the time.
    PeterW
    Aug 2002
    Sydney, Australia
    Pattern for plank 5 made today. This is number 3 (of 4) on the starboard side. Plank also cut and scarphed ready to attach tomorrow.
    PeterW
    Aug 2002
    Sydney, Australia
    A boat-like object is beginning to appear. Plank No 3 on the starboard side (5th of 8 ) was attached today.
    PeterW
    Jan 2016
    Canberra, ACT, Australia
    Great progress! Looking more like a boat.
    Graeme
    Looking good Peter.
    Dec 2012
    Providence, RI USA
    Your build is really nice so far. Bringing back good memories. I built a Whilly Boat recently, and have been enjoying her immensely this summer.
    Here's my build thread http://forum.woodenboat.com/showthre...+build+in+prov
    Yours is looking much neater than mine though! Keep up the good work.
    Mike
    Aug 2002
    Sydney, Australia
    Thanks Graeme, Tom and Mike.
    Mike - I have seen both of your threads( Whiily Tern and Ilur) and enjoyed them both. Always good to see how others have done it/are doing it.
    Keep the pics coming.
    PeterW
    Aug 2002
    Sydney, Australia
    More work today with the next plank glued up on the floor. This is #3 on the port side. Also started bevelling the 3rd plank on the starboard side and cutting the gains at bow and stern.
    A view 'midships - plank 3 stbd side:
    Here's a view from closer to the bow:
    And here's the gain at the bow:
    The plan is to finish the outside of the last plank on each side with a clear coating, with the last 2 planks inside with the same clear coating (poly varnish on clear epoxy.
    PeterW
    Aug 2002
    Sydney, Australia
    A bit more work in the last few days: last plank on the starboard side is getting ready to go. Dry fitting at the moment.
    Stern section of the plank shown here before sheeline was cut.
    Another inside shot showing seams and the 'fail' on clean-up of the garboard glue line.
    PeterW
    I see you're doing your scarfs on the boat , how do you find that ? Easy ? I wasn't game and made the full length planks on the bench first.I found a heat gun and scraper made cleaning up runs very easy.Good going Peter.
    Aug 2002
    Sydney, Australia
    Thanks Peter. Actually to date all scarfs have been done off the boat - I am tossing up whether I will have a go 'on the boat' with the last 2: possibly not as they join on mould 4 - an area of high curvature and therefore stress . Also I want to get the scarf as spot-on as possible as both sides will be clear finished. Probably stick with joining on the floor with a board under the join area and good visibility of the outer side of the finished join.
    PeterW
    That's what I did, it seems much more satisfactory and guaranteed to give a good result. I frankly can't see how I could get a good job on the boat !!
    Aug 2002
    Sydney, Australia
    2nd last plank glued on today. The scarph turned out well both on the inside and outside of this plank which will be clear finished on both sides.
    Scarph cleaned up.
    Bow view.
    Stern.
    PeterW
    You're moving along quickly Peter.
    Aug 2002
    Sydney, Australia
    Nice milestone - the last of 8 planks went on today. When I was building the 34 ftr the 'good oil' was that the hull was 25% of the job done. I suspect this may still apply with this one.
    Here's a pic of the bow showing the plank. Access to this side became increasingly tight with ply stored alongside.
    PeterW
    Rushworth Australia
    Well done Peter. Only 25%, Geez I reckon at times it feels like 50. Or is that wishful thinking.
    The hull planked is certainly a milestone, whatever the percentage .
    Aug 2002
    Sydney, Australia
    Recent work has included getting the sheer planks trimmed at bow and stern, as well as in between. Also cleaning up the planking lines: a bit to do on this part - no matter how much you try to fair them off the boat, there is still lining-off to be done once they are on the boat. A job today was to create a newspaper pattern for the 'glass cloth to be laid on the garboard planks. This will be continuous across the boat and have the keel and stems installed after glassing.
    Rough taping of the newspaper pattern
    Pattern cut to size.
    PeterW
    Rushworth Australia
    How come you're not just laying glass on Peter? Then just wet out, wait for it to get firm then run a sharp stanley knife around it. Way easier
    Aug 2015
    Sydney, Australia
    Dont you end up cutting into the ply that way?
    Jul 2010
    northeast Ohio
    If I were doing this I think I would just take the glass up to the lap line and trim it off there.
    The hull is looking great.
    Rushworth Australia
    Quote Originally Posted by imagineero View Post
    Yes there is that risk, but if you use a light touch and keep a slight pull on waste side of cloth it comes away pretty easily. you have to keep trying for that timing of when the epoxy is at the correct stage of drying. keep replacing blade when it gets gunked/blunt = frequently.
    Aug 2002
    Sydney, Australia
    The template issue for me was a case of trying to avoid any trimming after applying the resin. I am expecting the pay-off to be in applying the resin and then walking away. I also wanted to avoid any issue with the glass catching on the smallest sliver of wood when laying the glass in position. The 6oz cloth will not be as 'touchy' as the 4oz I used on the kayak, but I think making the template was worth the time.
    Thanks for the kind words Timo.
    PeterW
    Aug 2002
    Sydney, Australia
    More work on the stem templates and pieces. These will be in celery top pine. I should be able to get away with just one join with the recycled pieces I have on hand. The join will be glued with 2 dowels in the same timber to support the joint.
    Template in 1/8"(3mm) MDF. Still a bit of work to do on the final fit.
    This piece of celery top was once a window sill in a house in Hobart, Tasmania. Very nice colour just off the saw.
    PeterW
    That's nice bit of timber Peter !
    Aug 2002
    Sydney, Australia
    Another nice step today with the glassing of the garboard planks. This was the alternative to using 9mm ply for the garboards. I went with 6mm ply for all planking and will also glass the inside of the garboard planks. Main spreader of resin was a 4 inch plastic "squeege" made from an ice cream container. A brush also helped in some areas.
    Cloth was laid on dry to make positioning easier.
    Wet-out completed and just a few heavy spots to attend to.
    PeterW
    Plastic Gyproc spatulas work really well too.
