Results 71 to 105 of 119
Thread: Mill Creek 13 Build
    Jan 2013
    Lakebay, WA
    Default Re: Mill Creek 13 Build
    another early departure for work today - noon -
    .....but had enough time to stain the decks and take a picture.
    It's a usable kayak at this point, does not everything that designer intended, but it will do the job!
    Now is time to continue work on my kayak - first installing the decks.
    Jul 2008
    Ct.
    Quote Originally Posted by C.BlackHand View Post
    Cuts done, Na Zdrowie!!
    Work hard and play hard, if you can't have fun doing what you're doing there ain't no point in doing it, nice job.
    Jan 2013
    Lakebay, WA
    Working on it with my son is a great fun. .....
    .....and building wood floating stuff is humbling for sure
    thank you Woodpile!
    Jan 2013
    Lakebay, WA
    only 3 days left to have both kayaks in floatable stage.
    ....working on fitting comings on mine.....
    Jan 2013
    Lakebay, WA
    we have made it !
    Both kayaks are fantastic! Both are going very straight - very happy with overall characteristics.
    This one has no coamings yet - no time, plus wanted to know what coaming design my son would want......
    Mine is pretty much done......
    Jan 2013
    Lakebay, WA
    There is one problem..........the varnish that we have used is still tacky in spots...it's been 48 hrs after applying.....we do live by the ocean inlet so the humidity could be a factor - just wander to what extend. I got this kind because it its said that is for outdoor use.....wander what went wrong .......
    "The whole is greater than the sum of it's parts".
    How fresh was the epoxy before you put the varnish on Wojo?
    That stuff wants to go on in very thin coats. The first is always slowest to kick.
    Jan 2013
    Lakebay, WA
    Thank you for response Bruce !
    The epoxy was plenty "old", at least a week - maybe two .........but I am thinking that the tacky spots are where I applied a very tick coat - also on Damian's kayak I have applied 2 coats - second one 4hrs after first - as they say in application instruction - but maybe they meant: if is dry - because it sure was not after 4 hrs.
    The question is: what to do now - remove it with paint remover and start over? Because the tacky part is not getting any better.....
    wait
    Jan 2013
    Lakebay, WA
    waiting
    Jan 2013
    Lakebay, WA
    Jan 2013
    Lakebay, WA
    Jan 2013
    Lakebay, WA
    Kayak hauling
    Jan 2013
    Lakebay, WA
    Here is why this design is great - one adult + two kids, floating happily - while grandpa is zooming ( relatively speaking) in the background on Glen L15
    Jan 2013
    Lakebay, WA
    Not regretting it !!!!......but all this summer family fun came with a price - the question is how big the price is.
    Copper coated nails from HD - from not enough varnish on them - in contact with salt water started corroding. Wander if I should just warmish over it, or some kind of special treatment will be required to get the copper rust out of the wood ????
    Too far inland.
    Not enough varnish?
    Did you not glass the deck over onto the hull?
    Jan 2013
    Lakebay, WA
    yes, definitely not enough varnish - just put one coat to seal the plywood, and get it out on the water.....did not glass the deck - didn't think that there is a real need for it - it would sealed the nails way better than varnish though
    As I said, we had great time with kids and grandkids, now is time to add more varnish and finish it........just varnished it, and will have to live with blemishes - will remind me of great summer with the kids
    Bruce, just checked the varnish and looks like is drying way better than first coat!! Applied with a roller - to give more uniform covebr />
    Jan 2013
    Lakebay, WA
    Went kayaking around Lakebay Marina.......love it
    Too far inland.
    That sounds about right.
    Jan 2013
    Lakebay, WA
    after first euphoria of having the kayaks kind of ready for the water , now comes the part of finishing it to designer standards.
    .....and I am getting concerned about the glassed part of it. There are spots where the fiberglass looks like is not fully saturated (but is) - white spots.
    The question is: will they be gone after second coat of epoxy, if not what to do to make them disappear ?
    Too far inland.
    Air bubble. It's saturated, but it's lifted off the surface of the wood. Second coat won't change that.
    If you REALLY want them to go away, cut them away with a razor knife, feather the edge and lay some new cloth.
    Jan 2013
    Lakebay, WA
    ....that's what I was afraid will need to be done.
    thank you Figment
    Too far inland.
    It's not so bad, really. Especially if you shave-down the edge of the new patch while epoxy is only green-cured.
    Or so I'm told. No personal experience of course.
    Jan 2013
    Lakebay, WA
    ........the air bubbles were not there at first....they are appearing while kayak is being used.....that's not good.
    Anyway, I will cut out the bubble and see if I can repair it
    Too far inland.
    oh. very not good.
    After you cut open a bubble, grab the cloth edge with some pliers and do a peel-test.
    I cringe as I type this, but..... do I recall that you applied a stain to this wood prior to epoxy & cloth, or was that someone else?
    Aug 2008
    Sweden, Växjö/Öland
    .....so I've stained a piece of plywood, let it dry for 24hrs, then applies fiberglass tape with epoxy, let it dry for 24 hrs.......in few minutes I am going to the BoatShed to see if there is a reason to celebrate
    just went to the BoatShed and I am very pleased to find the tape stuck to the plywood for good
    There was a POC of the stain/epoxy combo
    Probably the greatest thread in the history of the WoodenBoat Forum.
    Probably the greatest post in the history of the WoodenBoat Forum.
    -~: Roughshod Riding Rabble Rousing Rebel :~-
    Peer of The Most Ancient and Noble Order of the Lauging Polar Bear
    Jan 2013
    Lakebay, WA
    ...no time to work on kayak today - but my kayak was NOT stained Figment.
    Ryden - what's POC ?
    I think it has to be a combination of few little things: corner radius ( too big or too small), slow curing epoxy good for flat surfaces, but not the best for corners, edges, transitions from one surface to another, etc etc.
    Having this great forum helping - I am sure I will fix it.
    Would like is bring it to next year Port Townsend wooden boat festival and kayak around drooling over real boats
    .............time to go to work
    Jan 2013
    Lakebay, WA
    couldn't wait any longer, and had to check the fiberglass situation.....here is first picture.....bubble can be seen and whiter spot is from prying with the box cutter trying to see if the cloth will peel off....
    .....well it did...looks like cloth is peeling off from the top of layer of epoxy.......this spot was coming off just by pulling on fiberglass cloth - not very easy !!, never less did come off.....
    I will just feel the spots with fiberglass cloth and epoxy and go from there.
    Most fiberglass air bubbles had small holes that epoxy didn't cover and water/sand was getting underneath. Fortunately the plywood was cover with epoxy so the water wasn't saturating plywood...
    Aug 2008
    Sweden, Växjö/Öland
    Proof Of Concept
    Jan 2013
    Lakebay, WA
    ....started to finishing kayak....layer of epoxy, next more varnish.
    ....however I have started to think about the next build.
    Would like to have small, fast motorboat. Started to look for one that is more of traditional appearance.....unfortunately can't find anything.
    The closest to what I am looking for is Silver 333 by Italian designers.
    Length 10.9' beam 4.9' - planing hull - for 15-20 HP outboard short shaft
    Jan 2013
    Lakebay, WA
    few coats of Topside for those rocky PNW beaches........
    Jan 2013
    Lakebay, WA
    thinking about building this..........
    Complete buiding kit at the PTWB (minus oars and slider) goes for little over $1000-
    Too far inland.
    Have you priced the oars and slider?
    Jan 2013
    Lakebay, WA
    yes I did
    That's when I have stop considering getting the kit.
    Sliding unit $650-
    Oars around $500-
    ....sooooo, the whole set would cost $2200 + tax
    But it would be nice to have efficient rowing boat.
