Results 36 to 52 of 52
Thread: Technique to weigh small boats
    May 2012
    Central Ohio
    Default Re: Technique to weigh small boats
    Quote Originally Posted by Damian James View Post
    Back when I weighed <90kg myself, I checked the bathroom scale was good for 200kg. I weighed myself first, then picked up the boat and stepped (okay, staggered) back on... That was for a very lightweight rowing dory though.
    Little boats will balance on their nose on a bathroom scale. Padding and weight distribution recommended, of course. But they'll stay up long enough to read the scale.
    Deer scales that hang from a tree will also work for 400 lbs. or so. For more than that, I use the proportional method with a bath or spring scale, or break out my trailer tongue (hydraulic) scale from Sherline and use a car jack on each end in sequence.
    Mar 2005
    Saco, ME
    My customer, Nick, @PhillySailor of the infamous thread Building the Calendar Islands Yawl, use the method in post #14 and came up with what seems to be reasonable results, I would say within +/- 10lbs
    Clinton B. Chase
    http://tinyurl.com/myboats
    I have gone to the local dump, they have a drive-on scale. Weigh the trailer, then both. They do it free.
    But none of my boats are big enough to worry about.
    Mar 2012
    Adirondack Mts, New York State
    Big game scales from Dicks.
    If you can hang it from a single point, by wrapping a strap around the middle, you can also find the center balance point.
    Mar 2018
    Annapolis, MD, USA
    Quote Originally Posted by Peter Gottlund View Post
    On the other hand if you have the boat in hand you might try using purchase power.
    Brilliant! Get out your credit card and have someone else weight it for you. :-)
    Jul 2018
    Portland, OR, USA
    A couple of years ago I weighed my Thistle to see how close it was to minimum weight for the class. I happen to have 400# Parcel scale with a remote read out so that made it a little easier. I started with the boat on the trailer and put the scale under each pneumatic wheel and the tongue wheel in sequence. When doing this it is important to keep the 3 trailer wheels at the same elevation so I put a block the same height as the scale under any two wheels when I weighed the other wheel. The weight of the boat and trailer is the sum of the three weights. Then launched the boat, and repeated the same thing with the empty trailer after letting the water drain off of it. Subtract the weight of the trailer from the first you have the boat weight.
    I'm sure it is not as good as a single weight using a crane scale but I expect I was within +_ 10 lbs on a 515# boat.
    Nov 2001
    Seattle
    They use this in the Snipe class, with a sling in which they carefully balance the boats. Minimum class weight is 381 lb., if memory serves, so it's right in the ballpark for the weight you're tying to measure.
    Mar 2001
    FL
    We have a certified scale weighing station locally to do legal weights. For smaller backyard stuff I use bathroom scales. Most Experimental Aircraft Association (EAA) chapters have scales too...those scales are on wheels and portable.
    Aquitaine
    I used the bathroom scales (checked against my medic's ones...) to do the wheels and hitch method. Then checked the trailer with the boat off. Both of them weigh close to 70kg. Good enough.
    Jan 2005
    Deepest Darkest Wales
    Some people get incredibly fussy about weights in small boats..
    Google Lamboley Pendulum - hours of fun
    Mar 2005
    Saco, ME
    The method in #14 seems to be doing well
    Clinton B. Chase
    Dec 1999
    Oriental, NC USA
    I cannot take credit for originating this method Clinton. I had heard of it previously but could not find the source when I needed to take some successive weights during a building process in order to predict the final weight of a new boat design. Probably most builders have run into the sometimes large difference between calculated and actual weight of their boat or project. I just made some calculations based on seldom used college statics to regenerate the formula. I have found it both very useful and accurate with the added benefit of being applicable in the home shop without need of any special equipment or outside help.
    Tom L
    Benfleet Essex UK
    The method on the windmill site works, http://windmillclass.com/static/weigh.html, I have used it several times on boats from 175lds to 700 lds in weight. It is quick & easy.
    May 2005
    Bradford, VT
    This reminds me of the story about the student given the exam question challenging him to use a barometer to find the height of a building
    Nov 2001
    Seattle
    Quote Originally Posted by David W Pratt View Post
    Dropped it and timed the fall?
    Mar 2015
    Victoria BC Canada
    I suspect it involved carrying the barometer to the top of the building, quickly.
    Mar 2017
    Waterbury Center, Vermont
    With an accurate waterline marked on the hull and some forgotten calculus, I’m sure I could have figured it pretty closely.
