Page 4 of 4 FirstFirst ... 34
Results 106 to 137 of 137
Thread: White Salmon build
  1. #106
    Nov 2010
    Wellington, NZ
    Default Re: White Salmon build
    First coat of varnish on.
    [IMG]20170821_130219 by Craig Slack, on Flickr[/IMG]
    [IMG]20170821_130207 by Craig Slack, on Flickr[/IMG]
    The thwarts and knees were done with varnish that was well thinned with Turps and it all got soaked up.
    I've got 2 coats on now.
  2. #107
    Mar 2015
    Dunedin, New Zealand
    Looks awesome varnished. You don't have to paint it.
    Ian
  3. #108
    Nov 2010
    Wellington, NZ
    Today I gave it a light sand to knock the nibs off the thwarts and knees. Third coat of varnish was then applied. No photos sorry.
  4. #109
    Nov 2010
    Wellington, NZ
    Another light sanding was done yesterday then 4th coat.
    I've been using a foam roller to get the build coats on for speed and lack of drips, but the finish isn't that great so the last couple of coats will be done with a brush.
    I had a dig in my paint box as well to see what I have.
    I'm using 2 pot International paint and need to get a 1/2 litre of undercoat to go between the epoxy primer and the Royal blue topcoat.
    There is some scraping, filling and sanding to be done on the outside before that gets used though.
  5. #110
    Nov 2010
    Wellington, NZ
    5th coat done.
    [IMG]20170903_131540 by Craig Slack, on Flickr[/IMG]
    I got bored with varnish so I flipped it over and sanded the hull.
    [IMG]20170904_140510 by Craig Slack, on Flickr[/IMG]
    I then started fairing the outside for paint.
    No photo of this sorry, I had to dash.
  6. #111
    Nov 2010
    Wellington, NZ
    Fill, sand, fill, sand, fill.
    [IMG]20170913_150044 by Craig Slack, on Flickr[/IMG]
    Sand and then probably a final bit of fill (and sand) before paint.
  7. #112
    Nov 2010
    Wellington, NZ
    I'm still at the same stage, getting my big boat ready for the racing season became more important.
    It rained for most of the 2 weeks I allowed, so the things on the bottom of the list didn't get done.
    I'm also researching how to make a rope bow pudding as I found it is called. This is needed to protect the big boat from the bow clunking it.
    It seems simple enough, just got to follow the youtube instructions I found.
    I'll document it as well as possible while tangled up in a mountain of rope.
  8. #113
    Jun 2017
    spicewood, texas, usa
    just found this and glad i did. nice work. sure wish the earlier pics showed up, but still interesting dialoque.
    jim
  9. #114
    Nov 2010
    Wellington, NZ
    Your wish has been granted MADOC1.
    I've been through and added all the photo's that I could find. The very early ones seem to have been lost, but I have one more place to look for them.
  10. #115
    Jun 2017
    well thx slacko. i went back over the pages and glad i did. much better with the pics.
    jim
  11. #116
    Nov 2010
    Wellington, NZ
    I made a floating keyfob as a practice project for the bow pudding.
    youtube is definitely your friend for these things.
    Oops, Upside down. I guess it was posted in NZ though.
  12. #117
    Mar 2015
    That's very neat, Slacko, even in New Zealand!
  13. #118
    Nov 2010
    Wellington, NZ
    A quiet long Weekend Monday, so I collected together the bits to make the bow pudding.
    [IMG]20171023_134439 by Craig Slack, on Flickr[/IMG]
    I put a light line through the twist at the middle of the piece of rope I'm going to use as the Gunwale protector.
    I then cut a series of pieces off some smaller rope that I had for the filling.
    [IMG]20171023_134849 by Craig Slack, on Flickr[/IMG]
    I then bound it on using the line I had threaded through the twist.
    [IMG]20171023_143434 by Craig Slack, on Flickr[/IMG]
  14. #119
    Nov 2010
    Wellington, NZ
    The next trick is to wrap the bundle in the nice soft cotton rope. I was a bit worried that it was too big at this stage.
    A simple twist is used to get it started.
    [IMG]20171023_143809 by Craig Slack, on Flickr[/IMG]
    Then 1/2 hitches are tied setting up the stitch size and tension. The keyring trial told me that it needs to be looser than I imagined.
    [IMG]20171023_144807 by Craig Slack, on Flickr[/IMG]
    1/2 done, the end is left on after tucking into the twist to hold it in place.
    [IMG]20171023_153009 by Craig Slack, on Flickr[/IMG]
    I'm going to use the ends to tie it in place using some holes drilled in the bow.
  15. #120
    Nov 2010
    Wellington, NZ
    Starting again in the middle with the other half of the line showing the path of the fid through each knot.
    [IMG]20171023_162115 by Craig Slack, on Flickr[/IMG]
    Finshing the second end showing the tuck under the twist. This shot also shows dropping of stiches as the bundle gets smaller. I've built this with a definite front and back, The bundle was built with a flat back as well.
    [IMG]20171023_164210 by Craig Slack, on Flickr[/IMG]
    All done ready to go on. Not up to the standard of stuff you see online, but a good first attempt and fine for a boat that will be used.
    [IMG]20171023_164658 by Craig Slack, on Flickr[/IMG]
  16. #121
    Nov 2010
    Wellington, NZ
    To protect the hull I've glued a batten to both sides of the hull to screw some brass rubbing strip onto for paint protection when on the hard.
    I've filleted and sanded these and filled the little pinholes in the filler, so hopefully I'll get some paint on next week.
    I'm going to bring it home to paint as there is no airflow in the boatshed.
    Not a good combination with Isocyanic paint!!
    This will be the 3rd shed I've used during the build.
  17. #122
    Jul 2010
    northeast Ohio
    That is cool. Can't wait to see it installed. And I've got to try something like this for myself, some fenders maybe.
  18. #123
    Mar 2015
    Looks really good, Slacko. Thanks for the illustrated guide.
    Some interesting stuff on your links, Timo.
    Ian
  19. #124
    Nov 2010
    Wellington, NZ
    I sanded the filling that I did for pinholes in the filler, dusted off then masked the gunwale and transoms.
    First coat of 2 pot epoxy primer on.
    [IMG]20171030_133546 by Craig Slack, on Flickr[/IMG]
    I'll roll another coat of primer on, then give it a light sand to see what it's going to come out like.
  20. #125
    Nov 2010
    Wellington, NZ
    I got one coat of International perfection undercoat on this morning.
    It is semigloss so really shows the bits that need more work ideally.
    It's a long way from perfect, but I'm happy with how it has turned out so far.
    [IMG]20171101_122814 by Craig Slack, on Flickr[/IMG]
  21. #126
    Nov 2010
    Wellington, NZ
    I've got 2 topcoats of Royal Blue on now.
    I'm not sure yet whether it needs a 3rd coat or not yet. I have the paint left over.
    Once it is dry, I'll see if there are still any spots that the colour is a bit thin.
    [IMG]20171103_114018 by Craig Slack, on Flickr[/IMG]
  22. #127
    Nov 2010
    Wellington, NZ
    Yesterday I gave it a quick sand with 180 grit RO sander and put a 3rd coat of topcoat on. The colour is deeper blue with no hints of holidays in the colour.
    I also changed from using a foam roller to a very short nap roller and the surface finish improved markedly.
    I'd used them recently for painting internal doors in the house and the finish came out much smoother with no tipping off at all.
    [IMG]20171104_125808 by Craig Slack, on Flickr[/IMG]
  23. #128
    Nov 2010
    Wellington, NZ
    Back up the right way with 2 of the 3 brass strips attached underneath. I'm waiting for the 3rd piece to arrive at suppliers.
    [IMG]20171108_154321 by Craig Slack, on Flickr[/IMG]
  24. #129
    Nov 2010
    Wellington, NZ
    On the home stretch now.
    I got the bow pudding and rope rubbing band attached today.
    [IMG]20171111_161129 by Craig Slack, on Flickr[/IMG]
    I also spliced a painter to the eye at the front.
    I epoxy glued the rope into the groove I routed into the gunwale applying the glue with a big syringe, and taping to hold in place until it sets.
    [IMG]20171111_161137 by Craig Slack, on Flickr[/IMG]
  25. #130
    Nov 2010
    Wellington, NZ
    I finished the transom ends of the rope rubbing strip today, and attached them with silicon bronze flat head ring nails.
    [IMG]20171112_113245 by Craig Slack, on Flickr[/IMG]
    I also got the last piece of brass strip attached to the bottom.
  26. #131
    Nov 2010
    Wellington, NZ
    All done, just got to get it wet now.
  27. #132
    Jun 2017
    wow! beautiful boat. the paint work is very nice.
    jim
  28. #133
    May 2017
    North Bend, OR. USA
    [QUOTE=Slacko;5398143]All done, just got to get it wet now.
    Very nicely done, enjoy the stares!
  29. #134
    Nov 2010
    Wellington, NZ
    Last photo of "Muri" in the water.
    [IMG]20171219_205809 by Craig Slack, on Flickr[/IMG]
    Thanks for all the comments and visits.
  30. #135
    Jun 2011
    Central New Jersey
    Yuri looks great, love the rope work, an excellent final touch.
    Steamboat
  31. #136
    Mar 2015
    Very pretty. Well done!
    Ian
  32. #137
    Augusta, Georgia
    Great job it looks beautiful!
