Page 20 of 20 FirstFirst ... 101920
Results 666 to 697 of 697
Thread: The UNA Project
  1. #666
    Aug 2007
    Dedham, MA
    Default Re: The UNA Project
    Isn't it for everyone?
    yes
  2. #667
    Looked real good with that bow slice through the water. Once the sail gets squared away I suspect she will be pretty quick.
    The halyard geometry is a real puzzler. I wonder what adding a part to the peak would do, balance the loads on both part of the halyard? A downhaul at the tack could tension the luff more if needed.
  3. #668
    Jan 2007
    North Shore, Massachusetts
  4. #669
    Aug 2007
    Dedham, MA
    At last shots of UNA on the water!! What a great time at the Small Reach Regatta. She sailed admirably, a bit of a problem Saturday when we had cracks develop in the step section of the mast. The solid core swelled and stressed the staves of the bird' mouth- we never made it to the second beaching. Just reefed the sail and headed back to Atlantic Boat.
  5. #670
    Looking very nice.
  6. #671
    Aug 2007
    Dedham, MA
    Mast damage.... dry it out for a couple of weeks, rework with hose clamps.
  7. #672
    ^Find out why first, you don't want a repeat performance.
  8. #673
    I would want to reglue and then put an old school steel band around the base. A band formed a bit small and heated to get it in place.
  9. #674
    No need for iron Silicone bronze will be fine and can be silver soldered. That butt needs a bit of taper to make the band snug when driven on. Needs a drain hole too! G/flex epoxy is your friend!
  10. #675
    Nov 2001
    Seattle
    Quote Originally Posted by G.Sherman View Post
    Beauty! Looks like not too much pressure on the helm, as well.
  11. #676
    Aug 2007
    Dedham, MA
    That's just my crew 20 pounds overweight and standing too far forward....
  12. #677
    This.
  13. #678
    Is she floating on her lines?
    Seems down by the head to my eye.
    SHC
  14. #679
    Aug 2007
    Dedham, MA
    Quote Originally Posted by SHClark View Post
    SHC
    Very close to the waterline I anticipated. Still soaking up and I'm not sure if the 275 lbs. in lead ballast is too much. Captain and crew weighed in at approx. 425 lbs. She's got a drain hole.
  15. #680
    Sep 2005
    new zealand
    How much of a tight fit is the butt of mast in the step, and how long is the plug in the mast?
    It doesn't really look like the plug would absorb water, as the end grain appears well sealed. I'm wondering if the splitting might be due to a combination of a short plug with a tight fit in the step, getting torqued sideways in the mast as the rig loads up?
    Pete
  16. #681
    Nov 2010
    Wellington, NZ
    She looks slippery in the water, but I was going to say that guy needs to step back a little in the boat!
  17. #682
    Aug 2007
    Dedham, MA
    Pete
    Fit is loose, but snug enough to remove the mast. The plug is 20 inches long and extend up and beyond the partner by four inches. The partner was shifting on the deck and pushing out bedding compound. Perhaps the use of six through-bolts and not four 4" bronze screws will help. The splits are nearly vertical. Those shims seem to indicate that the original placement of thickened epoxy while the mast was being assembled migrated to the lowest points. At least 2/3 of the rest seem starved. Very difficult to spot after the fact.
  18. #683
    Jul 2003
    USA
    Nice photos!!!
    " Be all that you can be"
  19. #684
    Nov 2001
    Seattle
    Or, if that's the comfortable way to use the boat, maybe move some ballast aft.
  20. #685
    Aug 2007
    Dedham, MA
    Please do not encourage my crewman Steve Honan....
  21. #686
    Nov 2001
    Seattle
    I always encourage crewmen .
  22. #687
    Aug 2007
    Dedham, MA
    Mast repair continues.... final finishing task- four silicon bronze bands for reinforcements.
  23. #688
    Those "silicon bronze bands" look an awful lot like hose clamps...
    Sounds as though it'll be plenty rugged!
  24. #689
    Aug 2007
    Dedham, MA
    CART BEFORE THE HORSE... Clamps to be replaced with bronze strapping.
  25. #690
    I figgered - just had to give you some grief...
  26. #691
    Jan 2007
    the base o' the mans' mast just turned into a birch broom he's got plenty o' "grief"... not that you missed out on a particularly stellar sailing day Gary, the wind was pretty dead all day.
  27. #692
    Aug 2007
    Dedham, MA
    Great to finally meet you.... Just a couple of construction errors. I really enjoyed the SRR. Happy to sea trial UNA among friends. All and all, a good outpouring of cash. I'll be back. My Russian twin says hello.
  28. #693
    Jan 2007
    the SRR is a awesome place to sail a new boat, with all the chase boats around and other sailors looking out for each other, Having Una there was cool, love the look of that big gaff sail and long boom on the sliver o' a hull.
    no need to mention it to you Russian buddy (I think he was a little tippsy) but the dude was a bit of a creeper.
  29. #694
    Aug 2007
    Dedham, MA
    Small Reach Regatta 2018 People!!! I am looking for any photos of UNA underway in Herrick Bay. Any contributions will be greatly appreciated. Hopefully ones without Steve Honan holding a brewski. Thanks
  30. #695
    Aug 2007
    Dedham, MA
    Mast and partner repair continues. A bronze ring is on order at Mystic River Foundry, in the meantime I've reworked the partner and replaces screws with through bolts. That should contain further movement above deck. A little grinding to remove a proud washer edge may be required.
  31. #696
    Jul 2003
    USA
    Even with the bronze bolts, I think the deck mast collar may possibly still twist. I think the collar needs to be wider.
  32. #697
    Aug 2007
    Dedham, MA
    Quote Originally Posted by Ocean Spray View Post
    working on it...
