Page 4 of 5 FirstFirst ... 345 LastLast
Results 106 to 140 of 144
Thread: LYS Build Plans #582
  1. #106
    Jun 2015
    Lakeland, Florida
    Default Re: LYS Build Plans #582
    For what its worth, I finally did some scarfs for the rub rail and they were not that hard, but there was extra work and tooling etc. At the point in the build where the side skins are joined, I was not ready to take on scarfing. Also this is a place where the plans are pretty clear and straightforward. Give Walter a call, he may have some ideas on the subject. I am pretty sure the butt joint is truer to the workboat/fast-build heritage, but you are building Your Boat, so you get to decide.
    John
  2. #107
    Quote Originally Posted by ririzarry View Post
    Thanks for the feedback. I'm at the "do I scarf or do I butt joint" step in a build so I was curious. I've read all the "scarfs are easy" posts but they still make me a bit nervous.
    And remember, scarfing uses up material. If you do an 8:1 scarf in 1/2" plywood, you will lose 4 inches when you combine to two 8' long panels. Since the design is premised on the side panels being 16' long, this will change the shape of the boat. If you want to avoid the butt blocks, a Payson joint would be a better option.
  3. #108
    Jan 2015
    Damascus, OR
    Quote Originally Posted by Christopher Morgan View Post
    I agree on the butt block statement. Although you can see dimples in low angle light where the screws are there is no hard spot and the curve is fair. I am sure if I had spent more time on finishing effort it would be invisible.
    Good luck
  4. #109
    Apr 2014
    Anchorage, Alaska
    Everybody loves a good joint
    http://seascull.blogspot.com/2014/02/scarphing-101.html
  5. #110
    Aug 2017
    Conroe,Texas,USA
    I went with the butt joints and am pleased. Those plywood scarf joints still don’t seem as strong to me. One thing I consider is that the joint in the side panels is pretty much at the widest beam position and is therefore under the heaviest load during the bending of the panels. A butt makes a lot of sense there
  6. #111
    Jul 2005
    st.louis mo.
    With a scarf you are adhering all layers of the plywood. With a butt joint, unless you are using mechanical fastening as well as epoxy your bond is only to the outer ply.
    Simmons Sea Skiff build photos here:
    https://photos.app.goo.gl/vxuQDZI0Dz7qjzAx1
  7. #112
    Jun 2015
    Lakeland, Florida
    Good point Figo.
    In the case of the LYS side skin butt joints, the plan calls for glue and screw, so there are mechanical fasteners as well. In mine there were 10-20 screws in the butt joint as well as sikaflex adhesive. I am comfortable with the strength of the joint. About the only issue I have/had with the butt joint is possibly that it may look smoother without the butt plate on the inside. It is a work boat, so this is minor to me.
    John
  8. #113
    Aug 2017
    Conroe,Texas,USA
    I second that Figo. I didn’t mention that my joint was screwed as well thereby providing a pretty strong connection given the foot of available gluing and screwing surface. Cosmetically it might be covered up with a storage compartment in that area.
  9. #114
    Jul 2005
    st.louis mo.
    That works! I always prefer a mechanical connection, but I actually like making scarf joints.
    Five minutes or less with a sharp block plane.
  10. #115
    Jun 2015
    Lakeland, Florida
    Nice looking scarf Figo! Fun discussion as well. I always learn stuff here.
    Now that I have done some scarfed joints, they will play a part in future projects for sure.
    John
  11. #116
    Apr 2014
    Anchorage, Alaska
    Quote Originally Posted by sandbarboats View Post
    I second that Figo. I didnít mention that my joint was screwed as well thereby providing a pretty strong connection given the foot of available gluing and screwing surface. Cosmetically it might be covered up with a storage compartment in that area.
    Screws bad. They can wiggle loose allowing a path for water intrusion, like mine did. If poxy/painted over, you will probably see their shadow on the surface in the future, like I do. You will run into them during future maintenance/modifications, like I am. If stainless and sealed in poxy, a nice oxygen-starved environment, they can corrode...scroll down in this link http://www.boatus.com/magazine/2017/...d-warnings.asp
  12. #117
    Aug 2017
    Conroe,Texas,USA
    Yeah that thought has haunted me throughout the Build. The challenge is that the entire boat is held together with screws by design. I bedded each screw with sikaflex and will hope for the best. In the end it’s a work boat.
  13. #118
    Blue Marble 3rd Rock From Sun
    I wouldn't worry about it. It was designed to be built that way. Besides, a lot of us know about boats that are held together with bubble gum and duck tape.
  14. #119
    Jun 2015
    Lakeland, Florida
    Good point Ben. I remember a thread pointing out that a lot of boats don't even last long enough to have corrosion problems. I will be glad to get 5-10 years and maybe pass it on to someone.
  15. #120
    Quote Originally Posted by shuffjb View Post
  16. #121
    Apr 2014
    Anchorage, Alaska
    I will be glad to get 5-10 years.
    Ain't nuthin wrong with building a short-life boat. Done it a few times meself.
    Once built a POS scow to haul lumber to a remote cabin building site. Used screws to secure the plywood sheathing to the frames. She leaked bad. My mate had to man a hand pump constantly to remove the water that leaked in thru the screw holes. http://moremotecabin.blogspot.com/20...ove-cabin.html
    Planned to burn her after I no longer needed her but my brother took her, flipped her, put her on stilts and created a tool shed.
    But "pass it on" is not the way I roll.
  17. #122
    Quote Originally Posted by Mo 'Poxy View Post
    I've built a few knock together boats like the one pictured and canoes too, just so I could reach areas of small lakes and ponds to catch the good fish.
  18. #123
    Aug 2017
    Conroe,Texas,USA
    Yeah I’ve don’t quite a few quickie boats with low expectations for longevity. I built Hanna’s Dug. With zero hardware or fiberglass using only one sheet of plywood and a tube of PL Premium. http://hvartial.kapsi.fi/oss3/oss3.htm
    It came out surprisingly well.
  19. #124
    Jun 2015
    Lakeland, Florida
    Update with more progress pictures...
    Drill, fill, drill for 1 inch drain tube. Had a void on the outside, but the wood-flour filled resin is solid through the drilled hole. Will just fill the void with quick fair.
    Sand, prime, sand, fair, sand, fair, sand, fair, sigh. Seems to go on forever, but finally have both colors painted where they can be seen together. First coats, but I am happy with the color scheme and paint system. Pettit EasyPoxy, the interior and decks are grand banks beige, the hull is ocean blue. Wide shot showing the transom.
    Narrow shot of port rub-rail and transom (still a bit of blue painters tape on the starboard edge of the rub-rail). Both shots are the same paint, for the narrow shot I lowered the garage door a bit to kill the direct sunlight. Really changes how the color looks.
    continuing with prime, sand, fill cycles on the interior until I am ready for color everywhere, then prime, sand fill the rest of the exterior, and my reward will be getting to apply color everywhere.
    John
  20. #125
    Aug 2017
    Conroe,Texas,USA
    You got the gloss looking nice. Mine doesn’t have near as nice of a finish. I just added shiny metal objects to distract the eye.
  21. #126
    Jun 2015
    Lakeland, Florida
    Sandbar,
    Good looking finish! I have that same (or a very similar) bollard, so we will be the same there. I like the side navigation lights. One less thing to clutter the decks. Your boat looks ready for the water! looking forward to seeing splash pictures.
    John
  22. #127
    Aug 2017
    Conroe,Texas,USA
    Thanks John, I’m hanging the motor on it this Saturday. That and installing the steering. Then it’s off to Texas Parks and Wildlife to prove that I paid taxes and get it legal!
  23. #128
    Jun 2015
    Lakeland, Florida
    Long time no post. It seems a lot of build threads sort of trail off near the end and I see why now. Once the boat is in the water, you don't have the time or inclination to sit in front of the computer daydreaming about the build. So, here are some final thoughts on the build and some spash pictures.
    Mask and Paint the rest of the topsides:
    Still have the pink scooter.
    Continued next post...
  24. #129
    Jun 2015
    Lakeland, Florida
    Painting is really quick compared to all the prep.
    Outside finished except for rub rails (still working on rigging inside the console):
    Console setup, cooler seat, motor rigged:
    Continued ...
  25. #130
    Jun 2015
    Lakeland, Florida
    Splash Day:
    Here she sits in a local lake:
    and a different lake a few days later:
    This splash was to fix the trailer bunk setup. I had the bunks way to high and I needed to tie them together so they would stay flat.
    Still to do:
    - Increase propeller pitch (currently 11 and it overrevs, so going to 12 or 13)
    - Install Rub Rail (tessilmare R30)
    - Finnish rigging Navigation lights
    - Attach cushions for cooler seat and front of console
    Then it is time to ride in the boat instead of working on it, yeah!
    Thanks for all the help and knowledge you guys and gals have provided.
    John
  26. #131
    Aug 2017
    Conroe,Texas,USA
    Looks great John! I've been looking at that cooler seat for my boat. How does it fit back there? I know space is tight between the console and the transom if you placed the console according to plans. Right you are about being too busy playing with the boat to bother posting. I'm on the water most weekends now.
  27. #132
    Pinnacle, NC
    Awesome. Glad to see it on the water! makes me more anxious to start my build.
  28. #133
    Jun 2015
    Lakeland, Florida
    Thanks for the kind words!
    I actually moved the console forward a bit. The aft face of the console is 6" in front of the rear 2X8 butt block. I have the cooler seat 5" behind back edge of the butt block, this gives me approximately 18" between the seat and the console which turned out to be a bit tight when standing. Very comfortable when seated. I should have allowed another 3-4" because the wheel is on the aft face instead of on an angle as my first design had it. There is still room to turn around and face the motor, you just have to watch where you put your feet (fuel hoses, control cables, etc.). The seat is sitting up on 2x4 blocks that I epoxied to the sole. This makes it level with the 2x8 butt block so that your feet don't sit too high, plus it gives me something to attach the seat to (don't want to run a lag bolt through the bottom of the boat).
    After I have run it a bit more, I may extend the 2x4 blocks and move the seat back a bit further if the tight quarters while standing still bothers me. The backward facing mode is mostly for fishing and I don't do that every time, so if I have to choose tighter seating for backwards fishing vs. more comfort standing at the helm, I am good with that.
    John
  29. #134
    Jun 2015
    Lakeland, Florida
    One more report on performance:
    I have not weighed the boat/motor fully rigged boat, but I guess it is 750-850 or so. Call it 1000 lb. with me on board.
    The motor is a 25hp Mercury 2 stroke with an 11 pitch aluminum prop. It gets on plane well and zips right along.
    The prop overrevs, but when I keep it at 5500, I can get 20 knots. I am hoping to get up to at least 25 with a properly pitched prop. More on that as I get results.
    John
  30. #135
    Jan 2015
    Damascus, OR
    Well done getting it in the water - it looks great. It's really interesting to watch how people solve different problems for the same situation. I opted for removable swiveling chairs so I can pick and choose how much seating I need. I found I rarely sit down unless drifting around on a lake in the sunshine. Crabbing keeps me on my feet so I opted for no seating behind the console.
    I too should have gone with a 20" instead of 24" console. An extra couple of inches on either side would have been appreciated. Your build has really turned out nice and you will definitely enjoy fooling around in her. I launched mine last August and have had it out in the rivers and bays several times since then and actually put her to work:
    I am also curious if you have experienced any motor splash/wash at full throttle into the stern? I am thinking my motor is sitting a tad low. It's not really a big deal as it doesn't contribute any more water than a crab pot but wasn't sure if this was common. I am running a two stroke, long shaft Evinrude 25.
  31. #136
    Jun 2015
    Lakeland, Florida
    Thanks PNWCrabber!
    Good looking catch there, makes me hungry! We do blue crabs here in florida, I am inspired to go try for some.
    As for motor splash, I have not had any so far. I am running 20" (long shaft) 25 hp Mercury. It has some of those hydrofoils on the anti ventilation plate, maybe that tames the splash into the transom. My transom height is 20" and the anti ventilation plate sits less than an inch below the bottom of the transom.
    I am considering making the cooler seat easy to remove so that if I am fishing/crabbing and need the deck space it will be easy to get. Just sit on a bucket when I need to. The rear seat eats up a lot of deck, but returns more storage for life jackets, etc. As you say, the seat is for cruising around which is my main mission for now.
    John
  32. #137
    Jan 2015
    Damascus, OR
    I think the hydrofoil is the answer on that issue. I am curious, where did you put your battery (if you have one) and how did you route your controls? I think there are a number of ways to do this but always interested in how others manage. My motor was old enough I had to use the standoff steering bracket but it worked out well.
  33. #138
    Jun 2015
    Lakeland, Florida
    The Battery is sitting in the console. I struggled with the design of this. My original plan was to put the 6 gal. portable tank there figuring that longer fuel lines do not cause a loss of power the same way that longer wires do with a battery. After looking at the output of the alternator on my motor (9 amps) I decided that 8 ft. of #8 wire would deliver that current sufficiently to start and charge (plus I always plan on using a smart/trickle charger when she is in the garage). Putting the fuel forward also changes weight as it gets used (around 6 lb. per gallon). In the end, fuel is by the transom, battery in the console.
    The controls are routed down the center under the cooler seat. I struggled with this also and I am not sure I have it right even now. My first plan was PVC conduit, but I worried about getting water trapped in there that I couldn't drain. I think I am just going to bundle the controls (separate bundle for the electric) and strap them in place every 18 inches or so. At the moment they are just sort of laying there. I wanted to get them up off the sole so that they wouldn't get wet from small amounts of standing water. I think I will accomplish that by putting them up on starboard where they are clamped. As for steering, I am using the standard Teleflex push/pull through the tilt tube. It has a big radius loop out of the motor down to the bottom of the transom, then another turn to go down the centerline to the console. I will get some closeups and post them later.
  34. #139
    Jun 2015
    Lakeland, Florida
    Update on performance:
    I tried a 13 pitch prop and found it to be too much. With 2 people on board I could not get above 5000 rpm and about 12 knots. Ordered an 11 pitch prop to replace the one that came with the motor (which had lots of dents and dings on the edges and seemed worn down). When the 11 pitch prop arrived, put it on the boat and performance was much better than the original 11 pitch. I have not run it solo with the new prop yet, but with 4 folks on board I am getting 13 knots and 2 folks I am getting 16 knots, so much better.
    I have put the rub rail on and it is a big help for all the bouncing against the dock. I use fenders too, but some bumps still happen.
    I will be doing salt water trials soon in Tampa Bay and the Banana River, so more reports when I have had a few more runs.
    John
  35. #140
    Pinnacle, NC
    Awesome to see her on the water. Looks great and sounds like it performs well. Now get out there and enjoy it!
