Page 15 of 17 FirstFirst ... 5141516 ... LastLast
Results 491 to 525 of 572
Thread: Argie 15 with balanced lug build in Vancouver, BC
  1. #491
    Nov 2016
    Southampton, Hampshire, United Kingdom
    Default Re: Argie 15 with balanced lug build in Vancouver, BC
    That looks really smart. I always wondered why we launch boat backwards.
  2. #492
    Utopia
    It doesn't get better than that. Surely one of the nicest projects ever.
  3. #493
    Jun 2002
    Vancouver, BC
    Thanks for the kind words Andrew. I've been away for a month and today was the first day back in the workshop. I managed to cut the parts for my boom and yard and they are now clamped up and gluing. I've added the angle guide pieces on the launch dolly so that is now complete. I'm not at all happy with the mast I made and so I plan to build a new one. I've committed to launch on April 30th at our club Commodore's sail past so she is going to get wet, finished or not. Most people won't notice the difference anyway.
  4. #494
    Nov 2016
    April 30th? That's not too far away now. I hope you get plenty of launch day pictures of your pretty boat.
  5. #495
    Jun 2002
    Vancouver, BC
    I know what you mean. April 30th will be here in no time. Today I glued up the boom and tomorrow I hope to glue up the yard. Then some eight siding, sixteen siding and rounding followed by several coats of varnish. It should be finished in time and there should be plenty of launch pictures as our annual sail past is always well attended and photographed.
  6. #496
    Jun 2002
    Vancouver, BC
    Glued up the yard this morning so I should be able to start cutting off the corners of the boom and yard tomorrow. Only problem is the rain. Working in my workshop with the boat still inside makes it rather cramped. However, she's getting closer to being finished. I'll take some more pictures when the rain stops and I can get the boat on the driveway.
  7. #497
    Jun 2002
    Vancouver, BC
    It's raining but I decided that the inside of the hull could do with a rinse so out it went. I the unclamped the yard and here it is alongside the boom.
    I ran them both through the planer to square them up.
    And then took off the corners on the table saw so that they're now eight sided.
    The rest of the work I'll do with a hand plane. These are not too large so I'm hoping to have them finished by the end of the day.
  8. #498
    Nov 2016
    I'm so jealous of your workshop space :-(
  9. #499
    Jun 2002
    Vancouver, BC
    And here are the spars rounded with a plane. Tomorrow I'll finish by sanding them and then offer up the sail so that I can drill holes in the right places. Then a few coats of varnish. April 30th? Yes, I think I'll make it.
    Sorry Nikky. I don't think I have enough space. On the other hand my wife thinks I take up too much space!!!!
  10. #500
    Nov 2016
    Nice work on the spars. You're so close now. Is there ever enough space for boat building? You need a warehouse just to store all the clamps.
  11. #501
    Jun 2002
    Vancouver, BC
    My, how the time flies. I have just over two weeks left to get everything ready for launch. I've finally finished the launch dolly (after several changes to get it "just right"). The yard and boom received their first coat of varnish today and I also touched up several spots where the varnish had received a small hit because of working in such a confined space. Tomorrow I'll add another coat of varnish to the spars and put a final coat of paint on the side benches and the inside of the planking. That only leaves a gazillion small jobs.
  12. #502
    Jun 2002
    Vancouver, BC
    No paint on the side benches yet but the spars now have three coats of varnish. The mast currently just has a base coat of epoxy. I'll smooth this down and give it just one coat of varnish because I don't like it. It will do for the launch on April 30th but I will be building a new mast that meets my rather persnickety standards.
    I'll give the spars a couple of days to dry properly and then bend on the sail. If the weather cooperates I'll take her out on the driveway, hoist sail for the first time and take a few pictures.
    For now, Happy Easter everyone.
  13. #503
    Nov 2016
    Exciting times.
  14. #504
    Jun 2002
    Vancouver, BC
    A good day. Weather was dry and sunny so I spent a lot of time doing yard work. However, the spars are now ready to receive the sail and that will be my focus tomorrow. I'll take some pictures while I'm doing that and more pictures on Sunday when I take the whole thing outside and raise the sail for the first time (weather permitting).
  15. #505
    Jun 2002
    Vancouver, BC
    Finally, a picture. I managed to get the sail bent on to the yard and boom today. Tomorrow will be the big day when I hope to raise the sail for the very first time.
  16. #506
    Nov 2016
    I can feel your excitement Roy. Im so looking forward to seeing your dream become a reality. I bet she'll look a picture dressed up.
  17. #507
    Jun 2002
    Vancouver, BC
    Driveway sailing!!!
    It obviously needs some tweeks and adjustments before I try this on the water. Appropriate leathering of course and both the halyard and downhaul need some small pulleys to make setting up easier. I would appreciate comments from one and all as to what else I can/should do to optimize this rig. I'm very much a novice and I know there are many experts on this site. I'm happy with the look of the boat but I want to be equally happy or more than happy with performance.
    Thanks.
  18. #508
    Nov 2016
    Bloody well done that man! Absolutely stunning.
  19. #509
    Jul 2010
    northeast Ohio
    That boom looks awfully low to me..............
  20. #510
    Nov 2016
    The plans call for a metre clearance from the boom to cockpit sole. Maybe the camera angle is making it look lower. If not a couple of turns around the boom should be enough to raise it for launch day. Then see what needs adjusting maybe?
  21. #511
    Jun 2002
    Vancouver, BC
    The boom is definitely too low and I already have some wood to build a new mast about 18" longer that will take care of the problem. I will still launch on April 30th although wearing a hard hat might be advisable!
  22. #512
    Nov 2016
    The good news is that there's plenty of room in the boat to lie down in when tacking. It'll bring a whole new meaning to the technique of the roll tack. Could you not extend the mast temporarily with a piece of metal tubing at the bottom?
  23. #513
    She looks wonderful. Great job.
    Since you asked for feedback: it seems to me you have too many sail ties (through the grommet at the reef points). Half of what you have on both reefs should suffice. The sail ties through the reef points also seem twice the length necessary.
    She looks like a fun and fast boat.
  24. #514
    Jun 2002
    Vancouver, BC
    Thanks for the feedback Rik. The sail maker's Canadian representative wasn't able to answer my question as to why there were so many reef points especially as you need to move quickly when reefing and too many reef points has the potential to slow down the process, increasing the possibility of a mishap. I have other issues that I won't go into but from my experience with Lee Sails I certainly wouldn't recommend them although their website has many positive reviews from satisfied customers. I do plan to remove some of the reef lines and shorten the ones that remain. As for performance, there are several Youtube videos of this design and she does seem to be able to lift her skirts with a good wind. I'm looking forward to getting her on the water.
  25. #515
    Aug 2013
    Valnesfjord, Norway
    Congratulations with your progress. Looks awesome!!! Good luck with maiden voyage!
  26. #516
    Jun 2002
    Vancouver, BC
    How to stretch a mast part one - buy a length of aluminum tube. Done. Tomorrow the mast will go into surgery and I'll have a longer mast worthy of Rube Goldberg!
  27. #517
    Nov 2016
    I shouldn't worry about the amount of reef points. You don't have to use them all if you're in a hurry and it'll keep things neat if you do use them all. Better too many than to few I'd say. Had to google Rube Goldberg. Ingenuity is the great pleasure in this boat building caper.
  28. #518
    Jun 2002
    Vancouver, BC
    How to stretch a mast - step two - cut off the top of the mast
    Place top piece of mast "A" into end of aluminum tube "B"
    Step three - go back indoors, it's starting to rain.
  29. #519
    So where will you lunch it the first time?
  30. #520
    Jun 2002
    Vancouver, BC
    Ambleside beach, West Vancouver.
  31. #521
    Jun 2002
    Vancouver, BC
    And here is the "stretched" mast, now 16 feet long. I think it will be fine at this length and will certainly work for the launch on April 30th. Once I've had a chance to see how she sails I will make a new mast either this height or shorter/longer based on the expert opinion of my fellow club sailors.
    Something else I hadn't considered. When I made the launch dolly I carefully figured out where the centre of gravity would be so that I could locate the wheels properly. However, when the mast and sail are in place there is more weight at the front of the boat and the centre of gravity moves. So, after stretching the mast I did something similar with the launch dolly and added another foot behind the wheels so that everything is nicely balanced once again.
  32. #522
    Jun 2002
    Vancouver, BC
    Bugger!!!! The April 30th launch has been postponed. First, the weather has not been cooperating and I need it dry so that I can wheel the boat onto my driveway and have working space in my garage. Second, my wife thought it would be a good idea to spend Saturday morning (when it was dry and I could have worked on my boat) getting some compost for the garden. Later, after by back was killing me from shovelling manure, the rain started again!!!! The forecast for the next few days isn't very promising either. So, I'm not making any more promises. She'll be finished when she's finished because I refuse to take shortcuts to meet a deadline and do something less than my best. Sorry folks. I'll keep you posted.
  33. #523
    Utopia
    Good days will come. I remember trying to build to a launch schedule and then dropping that plan because it's not worth it. In this kind of project, sacrificing quality for time isn't a good idea.
  34. #524
    Nov 2016
    Two things! Firstly, I thoroughly support your decision. Much better to postpone and finish the boat how you want it. You are after all building her for yourself not us. Secondly it's always best to keep the wife happy.
  35. #525
    Jun 2002
    Vancouver, BC
    Thanks gentlemen. The last piece of advice is particularly important and must be followed without question! I'll keep you posted on the progress. This morning for example the sun was shining even while the experts said it was raining. So out she went onto the drive and I finished sanding my new oars ready for varnishing. Now I have to work on my to do list for the afternoon. C'est la vie.
