Page 4 of 4 FirstFirst ... 34
Results 106 to 121 of 121
Thread: Warana 11 Blairgowrie Victoria
  1. #106
    Feb 2012
    Sorrento Australia
    Default Re: Warana 11 Blairgowrie Victoria
    Two top coats of semi gloss enamel. I used base white with two drops of brown and one of yellow added as a tint. I read somewhere that to pick up the tones of the space add a drop or two of those tones to the white so as the cabin sides and trim is wood i went with those tints. I was aiming to push the white towards a cream and I think it worked well.
    I used a different paint for the bilge
    All done except for under the engine and aft. That's for this year after the engine is removed in a week or two.
    Bruce Cockburn
  2. #107
    Feb 2012
    Sorrento Australia
    Interesting bit of history...I found this paper clipping behind the lining above the bunk with a funeral notice from 1954. I was told the boat was built in 1956, maybe that was launch date, or the paper was a year old of the boat was built a year or two earlier. What it does indicate though is that it has never been cleaned or repainted behind the lining since it was built!
    Bruce Cockburn
  3. #108
    Feb 2012
    Sorrento Australia
    Another detail I was given about Warana that was incorrect. is that she was planked with Tallowood. I had my doubts when I bought tallowood flooring to repair the deck. I am now convinced the planking is Iroko. I read that Jack Gutierrez used Iroko and as the Wooden Boat Shop uses Iroko, i bought some to do deck repairs.
    I sanded and painted the inside cabin top as well.
    There were a couple of holes to fill were the dunny had been plumbed so i filled them with bog!! Joking! I got someone who knew what they where doing to do that job.
    Wayne Parr cut some plugs from Iroko with a step in them.
    Bruce Cockburn
  4. #109
    Feb 2012
    Sorrento Australia
    The instrument panel and upright console in the center of the companionway is disconnected and removed and shaft etc decoupled ready to lift the engine out on Saturday morning.
    I wont put the console back as its removal have opened up the space. I think i will make an instrument panel on a sloping panel at the back of a remade engine box.
    Bruce Cockburn
  5. #110
    You may have already mentioned it but I can’t see where: what engine are you gong for?
  6. #111
    Feb 2012
    Sorrento Australia
    I was lucky enough to be offered a replacement for my trusty and slightly rusty old Perkins 4108. The new 4108 has only done about 500 hours and was the pump engine on a fire fighting boat Crib Point Engineering built for the port at Hastings. Regularly serviced and when Crib point engineering bought the boat back I was told about the engine and offered it for a very good price by them. The owner, Ted Banks did the last trip to Hobart for the WBF on Jane Kerr when I was on Storm Bay and that’s how the engine found its new home, over a chat with Ted, Tim Phillips and I. So I have an exact replacement engine so no need to re engineer engine beds etc. And as there was nothing major wrong with the current 4108 except oil leaks and getting a bit tired, I now have a full kit of spare parts. I will be putting on the Walker air sep filter that gives negative pressure in the sump. So what I have saved in the re engine of the boat I have been able to put to other areas that need to be covered like standing rigging etc, new shaft bearings and drip less seal, and some new fuel tanks under the cockpit floor to increase the range. The existing tank is 40 litres and I’m thinking of adding two more 40 litre tanks for a total of 120.
    Bruce Cockburn
  7. #112
    Feb 2012
    Sorrento Australia
    Engine removed with no problems encountered. The yards forklift made short work of it as it has an attachment that can be maneuvered into the boat through the companionway.
    We will clean the engine with degreaser and high pressure wash down then take it to my home garage where we will remove the gearbox, give it a clean and paint and put it on the replacement motor.
    Bruce Cockburn
  8. #113
    Feb 2012
    Sorrento Australia
    With the lockdown I have not been able to work at the boatyard until now so work has resumed and I'm stripping paint from the cabin top and sanding the deck during good weather and have been cleaning up the Borg Warner gearbox ready for a paint.
    Bruce Cockburn
  9. #114
    Feb 2012
    Sorrento Australia
    the shaft is made uo of two sections. Aft is stainless and then theres a joiner with the next a mild steel. The clamp joiner was a bit rusted and so I applied diesel to soak the nits and bolts etc for the past few weeks then got the heat gun onto it and got it apart with a bit of not so gentle persuasion. There are four bolts that pull the disks tight over the sleeve clamping the two sections of the shaft together. I will cleen up the steel section and sand blast then paint with coal tar epoxy. I need a new stainless steel shaft section as this one is pitted.
    Bruce Cockburn
  10. #115
    Good to see you back at it
  11. #116
    Feb 2012
    Sorrento Australia
    Thanks Larks. It's worked out every two years I get another lot of work done. This haul out I'm determined to get the mast and rigging done and get her sailing along with the new motor and a paint job on the cabin top.
    Bruce Cockburn
  12. #117
    What is 'coal tar epoxy'?
    Lean and nosey like a ferret
  13. #118
    Okay, I looked it up! I've actually seen it used quite a lot but didn't realise that's what it was. I wonder how it compares to a good rust converter? I find engine mounts seem to rust readily if they get any saltwater on them at all so I'm considering alternatives for protecting them.
  14. #119
    Feb 2012
    Sorrento Australia
    An expensive alternative I just came across is Rustbullet but I haven’t heard of anyone recommending it. I think theCoal tar epoxy can go directly onto the bare metal. I will check if needed, what to use as a primer after sandblasting but if it’s suitable under the epoxy I will use my tin of Penetrol as the primer. You can tell I’m making it up as I go along!
    Bruce Cockburn
  15. #120
    I’ve used coal tar epoxy before and the biggest concern was the prep’ of the surface before application. It was a commercial job so we had to have a NACE 2 inspector on site immediately prior to application of the product to confirm the prep’ and to cover off on product warranty. No primer used and I’m pretty sure that’s because the coal tar epoxy/steel interface is integral to the rust protection, two coats applied and the NACE inspector had to inspect application thickness on each coat.
  16. #121
    Feb 2012
    Sorrento Australia
    Great! Thanks for that. So I will apply straight onto the metal. I will warm it up a bit with the heat gun first.
    Bruce Cockburn
