Page 3 of 18 FirstFirst ... 23413 ... LastLast
Results 71 to 105 of 625
Thread: Dark Harbour Knockabout Build
    Feb 2014
    Central Florida
    Default Re: Dark Harbour Knockabout Build
    Thanks all!
    Will add microballons to the shopping list.
    Finished up the last planks/ centerboard gap today.
    Plus lots of planing on the second side.
    "what could go wrong?"
    Feb 2014
    Central Florida
    Quote Originally Posted by Reynard38 View Post
    That is a lot of pugs!
    Pug Rescue fosters / foster failures.
    Anyone want to adopt a pug? Most of them can see.
    A few are even house trained.
    I got some boxed up ready to mail!
    Feb 2014
    Central Florida
    Have been sanding & sanding and starting the filling/fairing process.
    Reminds me of spreading Bondo years ago.
    Hard to tell with the contrasting colors but slowly getting quite smooth.
    UPS dropped off 25 yards of 10oz cloth today and 6 more gallons of epoxy due tomorrow.
    Last edited by Measures Once Cuts Twice; 06-24-2014 at 05:24 PM. Reason: me no spell good
    Feb 2014
    Central Florida
    Finished up with sanding & fairing and moved onto glassing.
    Went with the 6 oz cloth. Will save the 10 oz for the next boat [ a pseudo-Dragon, plans in hand]
    About 4 hours later.
    And the transom sanded and epoxied too.
    Sep 2009
    Marietta, GA
    Lotta progress!
    Jun 2011
    Montreal, Canada
    good job!!
    ''The work is teaching you the work'' : Bernard Moitessier.
    Single-handed Sailor, 1968-1969 Golden Globe Challenge, 1st around the world sailing race.
    Dec 2012
    Providence, RI USA
    Nice! It's coming together.
    Feb 2014
    Central Florida
    Live shots; survived the hull flip.
    More sanding... Happy Happy Joy Joy....
    Bailing practice (for when enroute to Bermuda)
    Feb 2014
    Central Florida
    Flying!
    (What could go wrong???)
    Mountain lakes of Vermont
    Will the boat have any sort of deadwood/skeg to go along with the centerboard? In the original design, was the rudder mounted on the full keel? What will be your rudder arraingement?
    Feb 2014
    Central Florida
    Making a new cradle.
    The new right side up home.
    Is stepping out and staring at your work and day dreaming for minutes normal?
    Feb 2014
    Central Florida
    You're right, original has a rudder post at an angle from rear of cockpit to rear of keel. I plan (term used v. loosely as I've NO plans) on a vertical rudder post at same location at frame 7 which, in theory, will be the end of the waterline.
    I'm thinking of a kick up rudder on a pivot with an elastic cord keeping it down in deeper water.
    Feb 2014
    Central Florida
    Lovingly hand sanded 1/2 the inside with sandpaper wrapped around a pvc pipe; took days and days...
    Oops, wrong picture, not sure how the grinder got there.
    Feb 2014
    Central Florida
    Had fun figuring the position for the cockpit arrangement. Plans call for way too many straight lines.
    Sep 2013
    Milwaukee, WI
    How fun! Keep the pictures coming!
    Feb 2014
    Central Florida
    Started work on the deck, was a little scared to start cutting into the hull.
    But cut a dozen or so notches out of the sheer; cut 4 saw lines, hammered the bits out with a chisel and smoothed with a file. It all went much easier than expected.
    Steam bent some deck beams; 2 layers of 1.5" by .75"
    Thought i was going to have to do lots of math to figure the ends but ended up just using the cut outs as guides
    Rinse lather repeat....
    Just resting in place at the moment but was happy to get the technique down without much trouble, might add a third layer on top to round up the deck a bit more.
    Question on cockpit plans: when sitting on the cockpit edge when the boat is heeled over; is sitting over the combing better than sitting on a ledge inside the combing? The combing then keeps you from sliding downhill on the slick varnish?
    Southern Maine
    Coaming are really uncomfortable on the thighs if you are hiking out. I've seen special seeats that cn be moved around that sllot over the coaming and sit on the deck (( a sort of letter "F" profile). I'd have seats inside and provision for sitting on the deck.
    Dear Cut it twice and it is still too short , (or , whatever you call yourself),
    You know you are freaking folks here out right?
    Not spending enough time , not spending enough money , not enough experience, not good enough materials,not enough perfection in the sail .
    You just can't DO that man!!!!
    Fiddletown, on Vineyard Lane
    All those armchair boatbuilders who have never actually built a boat but have so much advice will have to abandon their excuses and actually do something if guys like this keep popping up.
    Feb 2014
    Central Florida
    My sail is perfect, it's Physics that's screwed up!
    While the boat is looking OK so far, my concern is the design change from ballast keel to centerboard. That's a huge change for one not trained in naval architecture. But, I wish him well.
    Aug 2011
    Hi from my observations
    i think he will need 150% ballast depending on its position more if inside less if outside. He deep was the full keel and what weight?
    You should be able to approx ballast with keel shoe and add rest internally.
    I would want to make sure you have adequate floors in particular if you have weighted center board or outside ballast.
    James
    Jun 2011
    Central New Jersey
    Quote Originally Posted by EFHeath View Post
    The Selway-Fisher Safe Harbor is a strip-built boat inspired by the DH 12 1/2, with a fin keel and separate rudder. The Calm Harbor is a variation on that with keel-centerboard modification.
    So, here's a twist, since this boat is an experiment. If you do not like the performance or initial stability with the centerboard you could modify and add a fin and bulb keel later. It could be mounted on a track so its position could be fine-tuned for the best position down the centerline. Kinda kills the trailer-sailer idea unless there is a hoist near by...
    As a more serious comment, this is a very interesting build and your speed is impressive! This is a thread that many will follow to launch day and want to see how she sails. Then the follow-up of how she gets modified to improve performance. I hope to see those posts in the future.
    Steamboat
    Feb 2014
    Central Florida
    Thanks all for the comments and input! I'm sure I've "raised the bar" just by having posted the progress here. I promise to put the first sail videos, good or bad,(bad or disasterous!) up here.
    I'm sure I'll have all sorts of trim issues, I'm really leaning towards a watertight floor with room for ~50 gallons (400 lbs) under it; Not quite sure how to measure the volume without putting a tarp in the bottom and pouring in 50 gallons and marking the level and building the floor there.
    Then use my ~200lbs of steel placed for final trim.
    Or just add hydrofoil wings to the CB and rudder and fly away!
    But first, tomorrow, another glamorous day of sanding....
    Just caught up on this one. Looks like a fun build.
    Jan 2011
    Clear Lake, Texas
    Noob question and suggestion:
    1. How do you saw the strips to fit each other? Since they get wrapped in cloth, obviously not going for water tight, but there appears to be some amount of an angle going on there. Do you just set the band saw/table saw to a few degrees and rip all forty-leven strips the same? Different per strip, same full length? Lay on the preceding strip and run a pencil down it?
    B. For the goopy hands, and for the future adventures you will have, how bout a gopro or some other sort of camera, set to time lapse on the work space? I'd love to see one on the Ideas shed, and might have to consider doing a kickstarter to get them one. Because they don't take enough pictures already...
    Feb 2014
    Central Florida
    Quote Originally Posted by gotcha640 View Post
    Hi! On my prior kayaks I bead/ coved the edges but here they are all cut square. I envisioned plane-ing them to fit but with lots of bar clamp use I only ended up needing to plane the aft ends of the planks at the bottom twisty corners of the transom.
    I had a gopro for track days but it was last seen in the Bahamas while scuba diving, probably has some excellent shark and crab selfies on it now.
    May 2013
    Houston, Texas
    Had you used the bead/cove method, do you think it would have resulted in less time spent fairing?
    I hate fairing BTW. :-)
    Feb 2014
    Central Florida
    At Sebring, 8 hours of unlimited track time (3 fillups and $200 in brake pads later...)
    And since disaster footage is funnier... going thru a turn ass end first at 90ish.
    Feb 2014
    Central Florida
    Quote Originally Posted by Junkyard Dog View Post
    I don't think so, the planks go thru up to 90 degrees of twist during their run that I don't believe the bead / coving would have hid that any more than what i did.
    i'll absolutely reinforce my molds on the next one to allow better clamping of the twisted areas while the epoxy dries which will reduce the fairing / sanding time.
    also my other 'disaster' footage (and not just because i had to video a tv playing a dvd recording that i could never get my computer to open) they were not in the same year...
    Aug 2010
    Belgium
    The guts, pure guts!
    Feb 2014
    Central Florida
    last off topic post for now, courtesy of the turn 7 hairpin
    fighting a summer bug so spent the day napping under a pile of pugs and looking thru a pile of design books (both how to design and books full of designs)
    Feb 2014
    Central Florida
    Quote Originally Posted by maarten View Post
    funny, my spouse says 'the stupidity, pure stupidity!'
    [unrelated; car for sale, only driven to church on sundays....]
    Feb 2014
    Central Florida
    Should be my motto, or a tattoo...
    Finished interior sanding and laid out the cloth.
    Then spent this afternoon spreading ~a gallon of epoxy. Thanks to whomever I stole the small foam roller idea from, doing the vertical areas would have been much harder without that.
    Diagon Alley at Universal Studios
    not really the Dragon I aim to build but still cute.
    Sep 2009
    Marietta, GA
    Quote Originally Posted by Measures Once Cuts Twice View Post
    Seen drilled rotors do that, but not solid ones. Good thing it didn't lock the wheel up.
