Results 36 to 70 of 86
Thread: Francois Vivier Creizic, sail and oar 15' lightweight construction 110kg
    Nov 2007
    Default Re: Francois Vivier Creizic, sail and oar 15' lightweight construction 110kg
    Andrew the Whilly boat is a brilliant but 'smaller' boat: the LWL, WL beam, sail area and projected designed displacement puts it in the same category as Arctic Tern and Walkabout which have very similar numbers.
    http://forum.woodenboat.com/showthre...ar-Boats/page2
    Creizic's construction without needing so much centreline structure, floors and boards etc means she is the same weight as an AT but with full sheer level side decks. These will greatly reduce down flooding and stiffen the oarlocks and the boat against twisting. Arguably the construction method is lighter.
    The lack of 'ends' compared to say AT will further reduce parasitic weight and windage in row mode and permits building it in a shorter build space. Creizic transom could also allow a normal tiller with an offset mizzen arrangement. Creizic will also have less inverted stability to assist recovery, compared to a longer LOA boat on the same LWL with the same deck arrangement.
    An AT owner can point to greater forward flare (dryness), motion comfort from balanced above WL buoyancy, WL extention as it heals (though the apparent displacement wave will also elongate as creizic's transom immerses with heal) and LOD spar storage length, that the greater total LOA permits.
    Ed
    Nov 2007
    From another Vivier, an Ilur in Ireland.
    http://ilur.tumblr.com/image/72871504659
    Is that gentleman driving, perchance you, John?
    No-I haven't set foot in an Enterprise in years.
    Nov 2007
    When I open the pdf link Ed posted earlier using my IPad
    http://www.chasse-maree.com/images/s...er/CREIZIC.pdf
    it opens all distorted. Squashed in the horizontal plane and stretched in the vertical. The lines drawing looks terrible.
    does it open correctly on other platforms?
    i was trying to compare the lines drawing with Clint's CIY 19' footer. CIY's lines are very sweet, very sail and oar, low wetted surface. Just cannot see the lines correctly on Creizic.
    Brian
    Jun 2013
    Taking a stab at translating it...
    Longueur de coque 4.60 m (Overall length)
    Longueur flottaison 4.34 m (waterline length)
    Largeur hors bordé 1.60 m (Beam)
    Largeur flottaison 1.32 m (Beam at waterline)
    Tirant d'eau dérive haute 0.16 m (draft with centerboard up)
    Tirant d'eau dérive basse 0.89 m (draft with centerboard down)
    Creux sous sole 0.55 m (depth from sheer to keel?)
    Déplacement eau de mer 400 kg (displacement, seawater)
    Coefficient prismatique 0.575 (prismatic coefficient)
    Espacement des lignes d'eau 50/100 mm (waterline spacing)
    Espacement des longitudinales 150 mm (spacing of longitudinals)
    Espacement des couples 300 mm (station spacing)
    Dec 2015
    Dorset, UK
    Sweden,Scilly Isles, Siberia
    Im convinced good photos sell boats......
    Aug 2016
    Oisterwijk, the Netherlands
    I hope that the thole pins on the boat can easily be taken out of their sockets when sailing: they get in the way of hiking and may cause injuries when sailing, they may damage your sail when lowering it into the boat and the pins may get caught under a jetty whereby the forces will be at one pinpoint.
    Like the boat a lot.
    Nov 2007
    http://www.vivierboats.com/en/creizic-for-sale/
    stitch an tape
    4.60 long
    108kg hull weight
    buid plans this year, contact FV, who describes her as lighter than his earlier designs and very easy to build.
    Nov 2007
    Jul 2015
    Ocala, FL
    What is up with those oar locks? Just a pin and a hole to wallow in?
    I have driven a 6.5l Dodge with diesel Cummins and it was glorious....
    Dec 2015
    Dorset, UK
    Quote Originally Posted by wsgilliam View Post
    North Breton tradition. Rocky coastline, large tidal flow and headlands creating inshore chop for working shellfisherman. Sea oarlocks are by tradition here captive to prevent the oars lifting out of the oarlock as the boat heals in waves. The pin is cheap and easily procured, replaced and even floats if wood. Traditionally you put a round pin into a square hole so if it breaks you can still pull it out. Using the hardwood pads attached to the oar shaft reduces wear compared to softwood and leathers/ is replaceable. The twin holes allows you to vary the inboard to outboard ratio for loaded and unloaded rowing gearing, and also to adjust to the fore and aft inter oarlock half beams.
    With a weighted inboard end, when tending crab pots the coukd just let go of the oars and they stay in the boat ready for action. They dont slip in the oarlock like a modern one can.
    The Portland Lerret on the other side of the Channel working a similar tidal eddy off Weymouth used the same system.
    The breton fishermen developed simple but sophisticated boat systems where they could.
    Open oarlocks as we now use are a flat water racing oarlock, not traditionally used on sea boats. The obsession with bronze oarlocks is also misplaced. The iron age followed the bronze age for good reason. Bronze oarlocks are prone to snapping if imperfectly cast. Its a durable but quite weak material in small small boat scantlings.
    Nov 2007
    On a similar theme,some while ago we had a local small boat builder whose literature stated "no castings are used on our boats".A good casting may have it's place but how many of us can identify a good one?
    Jul 2015
    Ocala, FL
    That is excellent information, thank you for posting.
    Nov 2007
    Nov 2007
    Nov 2007
    Nov 2007
    Nov 2007
    Nov 2007
    Nov 2007
    nice comparison of Ilur and Creizic rowing home
    Bainbridge Island WA
    Creizic doesn't compare to Ilur very well, at least to my eye. I had been admiring the design too, right up to the last picture.
    R.D Culler
    Nov 2007
    Huge dif in weight. one about half the other, so it's good you could see the dif.
    Aug 2009
    New Hampshire
    Looks like that last picture was probably taken with a telephoto lens, which will bring the aft boat forward in a way that doesn't do justice to the amount of space between the boats...and therefor distorts the comparison. There's an eye thing going on there that actually makes it less useful for comparison, I think. Can't speak to it on technical terms, maybe someone else can.
    Nov 2007
    Ilur light weight 245kg
    http://www.vivierboats.com/en/product/clinker-kit-ilur/
    Creizic hull weight 108kg , fully rigged 140kg.
    So, if you launch from tow car and weight no issue, Ilur is fine, however her weight at 245kg, is too heavy to be launched comfortably from a trolley from a dinghy park as we typically launch from Keyhaven dinghy park. The lighter Creizic really helps that process, of being able to handle, move, and put her away, after sailing, when using only a trolley.
    Brian
    May 2015
    Edinburgh, Scotland
    Quote Originally Posted by callsign222 View Post
    I matched their scale - obviously it's not accurate to any actual size difference, and i can't speak to whether the shape comparison is accurate either but it might help
    Didn't mean to send you guys too far down the rabbit hole with my not very well expressed comment.
    I'm sure both boats are fine for their intended purpose (Mr Vivier is quite talented) what I was trying to convey was that "I" find Ilur to be a much better looking boat than Creizic.
    R.D Culler
    Vermont
    To my eye, the Ilur has more freeboard and much firmer bilges, and is a much bigger boat volumetrically. Compare this image to the one in post #55:
    [/URL]
    Nov 2007
    John, Ed really prefers Ilur, just concerned about this issue of launching at Keyhaven using a trolley. Pulling her out of the water is a stuggle - we owned a Cornish Cormorant about the same weight and one pal can manage, another has to use the car. Ed is wondering if by building an Ilur as light as possible, ie making each choice the lighter weight might work. Any idea what such a weight an Ilur might be?
    Obviously a Creizic solves the launch weight problem, perhaps not as well defined plank lines etc, but still a very nice design, and many good features.
    Brian
    Vermont
    Brian, I haven't ever weighed Waxwing, but I know she would be too heavy to hand launch by trolley! On my modestly sloped gravel dooryard I can manouver her on a trailer with a dolly, but only just. Aesthetically, I also prefer lapstrakes to multichined stitch and tape hull shapes, but I'd guess the biggest functional difference between the two boats would be the half decks of the Creizic--they'd give you a moment of grace when hit by a hard puff before the boat started to take a sip, but they would also inhibit the ability to sit on the floorboards, leaning against the curve of the hull, ensconced down low in a most comfortable and stable spot....here, a frame grab from an Off Center Harbor video where Waxwing got a brief cameo appearance:
    [/URL]
    Nov 2007
    http://voileaviron.org/wp/wp-content...in_FVA_n16.pdf
    could someone translate page 6 and 7 from french to english please, thanks.
    Nov 2007
    May 2012
    SP,ID
    Google Translate is your friend! (Translation may not be perfect, but close I hope, and there may be a couple of photo captions included in the text so watch out for them).
    Edit: I should have read the translation before I posted it! Hopefully you can make it through some of the mis-translated words. Personally, I've always liked a boat with a "well rounded brion"
    Bill
    By François Vivier, naval architect
    Creizic is a sail-rowing designed to meet the
    Contest launched in 2011 by the Chasse-Marée and
    The Village Bois du Grand-Pavois "a plan to navigate
    lightweight". The first sailing-rowing I drew there
    30 years were inspired by traditional boats,
    Robust, with frames reminiscent of the
    Old building techniques, flooring
    Solid wood, many benches ... This results in a beautiful
    Authenticity but an important weight that gives a
    Stability at sea but makes it more difficult for
    Ground handling. L'Ilur - except the latest version
    "Kit clin" designed for digital cutting - illustrates
    This approach.
    With Creizic, the idea is to design a sail-rowing
    Responding better to a current boat demand
    Lightweight and easy to use as well as to build. Like the
    Other plans, this new boat is intended for
    Individual construction as well as construction
    professional. As a result of the competition, I did not
    The opportunity to see a first copy built.
    It was not until October 2013 that I decided to
    Order a first copy at the site of my
    Son Nicolas, Icarai, who was then broken
    Order. Unfortunately, Icarai could not
    To overcome this particularly harsh period for
    Small shipyards. These circumstances
    Forced to wait until June 2014 to buy the boat
    At auction. The time to order a sail, the
    Boat was able to do its first tests in September.
    The shapes of Creizic are characterized by a flat bottom
    And a relatively broad picture, better for the
    Stability, which compensates for light displacement. A
    Well rounded brion makes it easier to
    Trailer and also the laying of the plated, less severe.
    A lateral bridging enables the crew
    Make a better reminder, on the other hand to repel
    The angle of invasion. It is narrow enough to
    Do not obstruct the movement of the oars, while
    For stowing oars like rigging in
    . The buoyancy is constituted by a caisson
    Watertight at each end, accessible through a hatch.
    There is no foam, which is allowed by the standards
    European Union, subject to verification of the leakage
    Pressure loss measurements that are very difficult to
    Implementation. In practice,
    Capsize on both edges but this does not conform to
    The letter of the norm.
    The objective of lightness requires a
    Okoumé plywood of 6 mm. Preferably,
    Stitched-laminated construction that involves
    Integral lamination of the shell plating and therefore a
    Resistant to such ill-treatment.
    Boat can undergo. The floor and the gangways are laminated
    Both inside and outside. On the other hand,
    Of the top are not internally laminated. There is only
    Bands at the level of the chines. The sole and the
    Galmords are in 9 mm but the galbord was difficult to
    implement. Indeed, in cousuestratified construction,
    Without dummy, the links in copper wire or
    Other can not oppose too much effort
    Important. In the future it will be necessary to remain in 6 mm,
    Strengthen stratification. Apart from that, we checked
    That the construction from plywood in cutting
    Digital is simple and very accessible to amateurs.
    Holes for mounting links are also drilled
    By the machine, which contributes even more to the ease
    Of assembly. Nicolas also used tapes of Kevlar
    To replace soft protective strips. This
    Done on the kayaks and it seems to be very efficient.
    There is no provision for a storage compartment, on the one hand in
    Because of the weight it entails, and because
    Experience shows that it is easier to land
    Sealed bags only to contort to extract
    Objects of a safe. A small equip-
    Stow some objects under the side deck. The drift is
    Of the same type as on Morbic 12 and Bounty, that is to say
    That it can be extracted like a drift saber. A
    Sandow maintains it either in raised position, or in
    low position. Since there is no floor, the
    Funds receive a non-slip paint
    agressive. Note also that it is possible to sleep in
    The boat by placing a pneumatic mattress
    Directly on the floor, on either side of the shaft
    derivative. But I'm not sure I'll try it!
    THE FILE: CONSTRUCTION
    The oars are of the type to the eye, according to my habit,
    But this time with shovels in two folds of
    6 mm plywood, glued to a mold for
    Spoon shape. They are thus even lighter and
    Of a trial too brief gave satisfaction.
    Initially, I had planned a yawl rig one-third,
    That is to say with a small tape-ass. It allows
    Keep hoisted to rowing, and stabilize the boat. And
    The overall look of the boat wins! The disadvantage
    That it adds 3 spars and leads to retreat drift, and
    The well becomes more bulky. That's why I
    Finally opted for the "balanced lug" (there is no
    Satisfactory term in French), that is to say sailing at
    Third. The sail is even battened, for a
    Better efficiency but also because the bridge plane
    Imposes a limit on the length of spars to store
    The sail under the side deck I tried to find a
    A more satisfactory solution for the sail fabric, ie,
    Ie lightweight, flexible and ensuring good resistance to
    The assembly of the clinks in sewn-together.
    Form and hollow. Indeed, the Clipper-Canvas, fabric
    Polyester which is soft and has the appearance of cotton, does not
    Not below 300 g / m², which is very heavy.
    I had found a rather promising, lightweight and
    (Square of Dimension Polyant), but the
    Manufacturer had just removed from its catalog the variant
    flexible. Finally the sail was cut into Dacron B
    140 g / m², used for Optimist sails. It's light
    But too loaded with resin for my taste! On the other hand,
    Sail is well hollow and seems to stand very well.
    Another test topic is the liquid ballast. A ballast
    Is very useful in solo sailing on a boat
    very light. In order not to impair the simplicity of the boat,
    His weight estimate and the ability to sleep on board,
    I gave up caissons built into the structure. He had me
    Seemed also to fill a ballast with traps and
    On a very light boat is not very practical.
    So I chose to use simple waterproof bags. I have
    Bought two 40-liter bags at Décathlon. He is very
    Easy to fill the bag of sea water. But the first and
    Only test was negative: the bag is waterproof when the
    Pressure comes from outside but not at all when
    Fill it with water! The solution is to close the
    Bag around the front swim bench. I have not yet done
    Try but I think it will work well. In addition,
    Is sure not to lose the bags in a capsize.
    The Creizic under sail. It remains to optimize the position of
    Ballasts so that it is perfectly in its lines.
    As a naval architect, I used to make
    Personal boats a means of experimentation. At this
    Day I did only two outings with the boat, one per
    Time, another under conditions clearly
    More toned. Only a few aspects require
    Development, but this Creizic gives
    And I hope to enjoy much more in 2015. Note
    That I also have a cabin boat (Pen-Hir). So I
    Can make my Creizic available to those
    Who would like to participate in Gulf Week or
    Other sailing-rowing appointments.
    As indicated, I need a few days of work
    To make available a file of plans
    For amateur builders. I am ready to
    Priority if there are candidates for construction.
    Last edited by wlitsch; 01-15-2017 at 11:44 AM. Reason: Should have read the translation before posting!
    Dec 2015
    Dorset, UK
    Thanks Bill, much appreciated. I do rather like Creizic.
