Page 7 of 8 FirstFirst ... 678 LastLast
Results 211 to 245 of 268
Thread: Plywood boat rebuild
  1. #211
    Jun 2017
    spicewood, texas, usa
    Default Re: Plywood boat rebuild
    i see no reason a competent welder couldn't cut and insert an extension to your at the same time he (or she) is adding the protection for the prop and rudder.
    good looking speedster ned!
    jim
  2. #212
    Jan 2013
    Lakebay, WA
    Quote Originally Posted by MADOC1 View Post
    jim
    I still can't picture tang extension........do you have any picture/sketch of your idea Jim ?
  3. #213
    Jun 2017
    i would just cut the existing tongue behind the coupler-hitch and insert a piece of similar sized tubing. might be able to find a piece of tubing the could either go over the existing tubing or slip in side of it. then either weld it up or if it is a snug fit you could just drill a hole and bolt it up. like the hitch on you truck.
    jim
  4. #214
    Adding a swing-away requires little more than a sawzall and a drill...
    https://www.amazon.com/dp/B001F0IELG...=3Q4BKNE2VD1BF
    The hinges are sturdy and available for several tongue sizes. Installation looks simple and to the point.
    Install video: https://www.youtube.com/watch?v=2l4kYCtYJ4c
  5. #215
    Jan 2013
    Lakebay, WA
    this is a very interesting idea here Mr. Switzer !
    Today I was talking to my friend contractor about the tongue extension as we were looking over my "new" trailer. We discovered that the tongue is a piece of 3x4" that is mounted to the rest of the body with two bolts....so I could get longer 3x4" tube and have an instant extension!!!
    Have to call around and see if I can get galvanized 3"x4" and 1/8" wall thickness tube 10' long......
    2017-09-11_10-47-52
  6. #216
    Wojo I think you need this:
    http://www.xtend-a-hitchnorthwest.com/
    - Chris
    https://fvpetrel.wordpress.com
  7. #217
    2017-09-11_10-47-52
    My last trailer was a dog....a Harbor Freight POS that was barely adequate and the tongue was too short, so when I commenced on my current build, which is going to be a trailer queen, my shallow (21 foot) garage and the desire for a longer trailer tongue led me to the idea of a swing-away.
    There's also the option of retro-fitting an eztension. Here's a link to a few kits on goofle: https://www.google.com/search?q=exte...w=1536&bih=710
  8. #218
    Jan 2013
    Lakebay, WA
    So saga of fitting new trailer continues......the latest is to use my lifting contraption to get Fontana off old trailer into new one.
    The set up I have here was working great on Glen L15 but Fontana is a heavier boat. From my calculation must be about 1700 lbs.
    Roof trusses are 2 x8", the chain hoist is 1t rated, chains are 1000 lbs rated. Week point is the trusses - I think.
    I would love to hear from knowledgeable people here on this subject.
    My contractor told me to support both hoist mounting points with 4x4 s...I was wandering what size a metal equivalent of wood post 4x4 would have to be.....??
    Have to run to work, will post more information's if needed.
    2017-09-14_12-44-50
  9. #219
    I can't help with the engineering Wojo, but another thought - how about just take the boat on the current trailer to a place that can pick it up with a forklift and put it in the water? Do a test run and then tie it up and come back with the new trailer. I imagine there must be a place in Gig Harbor that could do it? Sure, it's a bit of a drive and a shuffle with the trailers but probably still less time and cost than coming up with some sort of brace for your lifting setup and moving Fontana over yourself.
    - Chris
  10. #220
    Nov 2016
    Everett, WA, USA
    Hi Wojo,
    Propping a couple 4x4s or steel posts under a 2x8 rafter is probably not the best approach here. I'm not liking those thin spreaders either - that chain angle is pretty shallow and may buckle the spreader under heavier load (Fontana). It's probably not worth the risk to you or Fontana.
    Fabricating a gantry system is certainly possible but seems like a lot of effort/expense for just swapping trailers.
    How about using a better/steeper launch ramp - launch Fontana off, tie her up and go get the other trailer and put her on. Can't you just coordinate a high tide launch right there at Lakebay Marina?
    Travis.
  11. #221
    ^^ I'm with Travis on this one. If you can get Fontana in the water at high tide that's the easiest plan for sure. If not, then I still think a forklift or similar option is your best bet even if you have to go to Gig Harbor to get it done.
    - Chris
  12. #222
    Jun 2017
    the one piece extension is an easier solution than cutting and inserting a piece as i suggested earlier. as far as switching trailers, how about just launching from the old trailer and have a friend bring the new trailer and picking it up? is that too complicated? maybe even your wife handle it.
    jim
  13. #223
    Jan 2013
    Lakebay, WA
    Tom wanted to bring the boat to BoatShop in Gig Harbor. Use their boat lifting "hoist". Their rate is - $100 / hr
    The new trailer does not fit the boat - needs new hardware for the bunks, so I didn't want to get the boat to Gig Harbor ( about 40 min drive) and most likely live it there until trailer parts will arrive. Don't think that BoatShop would let me live it there for a week or so.
    After chewing on your thoughts I think the best idea is to take the boat to the ramp ( 10 min drive) launch it ( roll it down with long line attached to the truck until boat floats) and set it on new trailer - prop it to make the drive home, and then figure out what's needed to make a perfect support.
  14. #224
    Jan 2013
    Lakebay, WA
    Just discovered a gantry in my newly constructed roof - an addition to the shop.
    The boat will be supported in the aft area by two stands. Two chain hoist, one on each side, located in motor mounting area. Lift. Roll an old trailer out, roll the new trailer in.
    2017-09-15_08-23-01
  15. #225
    Jan 2013
    Lakebay, WA
    setting the stage for tomorrow....hopefully things will not go sideways
    2017-09-17_10-18-19
  16. #226
    Jun 2017
    that's a great idea. good luck..
    jim
  17. #227
    Jan 2013
    Lakebay, WA
    Monday morning. Boat and a trailer in position.
    IMAG1274
    Two stands at the last frame before transom. Two lift slings, each rated1250 lb - I like overkill
    Lifting and wiggling the trailer - back support little higher then front of the trailer....
    IMAG1275
    And old trailer is out!
    IMAG1277 by Wojo Walczak, on Flickr
    Bringing new trailer....
    IMAG1282
    After few hours of moving, pushing, lifting, lowering, overthinking, anticipating, etc, etc......
    IMAG1285
    Tom from GPBW stopped by to check things out and declared the new trailer a good fit! Need to add a support aft and fine tune thing or two and we are all set !!
  18. #228
    Nice job Wojo. The new trailer looks great! Looking forward to launch trials...
    - Chris
  19. #229
    She looks really good there!
  20. #230
    Jun 2017
    good looking duo you have there. i am envious!
    jim
  21. #231
    Jan 2013
    Lakebay, WA
    jim
    thank you Chris, Ned and Jim !
  22. #232
    Jan 2013
    Lakebay, WA
    Sooooo......went to the gravel place with an old trailer to check the weight - 780 lb
    Trailer with the boat on it................................................ .....................2360 lb
    Boat weight...............1580 lbs
    New trailer weight........600 lbs
    Total for new setup.....2180 lbs
    2017-09-19_12-25-01
    weight at the tongue is 150 lbs. According to the rule there supposed to be 10 - 15% of the total weight of the boat and trailer.....means 218 to 277 lbs
    there is plenty of room to move the boat forward on the trailer frame.....which would be good , because right now the boat is not even touching the roller on the winch stand, and there is no room to bring it more aft....
    DSCF0049 (1)
    ...................but as usual there is a problem....
  23. #233
    Jan 2013
    Lakebay, WA
    well, maybe not a problem but a concern......the skeg was build not to the design, was made longer and at the end connected to the rudder - to strengthen/protect the rudder - my guess. Right now the part of the skeg that does not connect with the bottom of the boat is resting on trailer frame ( maybe few inches from the connected part) - if I move the boat forward on the trailer - to increase the weight on the tongue and to reach the roller on the winch stand - the boat will move forward 6" to 10".
    Not sure if that matters.....?
    [url=https://flic.kr/p/XASikG]2017-09-19_01-21-05[
    for this area will need to get a bracket with a keel roller
    DSCF0050
  24. #234
    Jan 2013
    Lakebay, WA
    to take my mind off the trailer saga, I was working on installing new (to me) wet sharpener/grinder.....still need to bolt it down, but the electric motor was fitted and the set up is working
    2017-09-19_04-43-28
  25. #235
    I really like you wet wheel!
    As to your keel (or skeg) dilema, I would agree that I wouldn't want to bear too much weight on it another 10" or so aft. I think if you can equally distribute the weight of the boat at all the support points you will be fine. Or, as an alternative you could lay something like a 2x10 or 2x12 on the flat below the boat so it is sprung to match the curve of the bottom of the keel and then shim and fasten that to the trailer. That would give you about 100% support below the keel, and it will make no difference where the trailer supports land.
  26. #236
    Jan 2013
    Lakebay, WA
    thank you Ned - wheel needs still some work, it's out of round. Most likely need to get some diamond wheel dressing fixture.
    As far as the keel support - I am all ears, but can't quite picture your idea just yet.......
  27. #237
    Wojo, I think Ned is talking about creating something like a center bunk to support the full length of the keel. I like the thought but I might do it with two or three rollers rather than trying to spring a flat bunk to the shape of the keel. But for a simple - if possibly temporary - solution, could you just fasten a 4x4 crossmember to the frame with u-bolts a bit further forward? If it sits underneath the frame rails it looks like it would clear the bottom of the keel, or worst-case you might have to shim it down a bit. That would given you another support point under the keel and remove the concern about putting a load on the skeg.
    - Chris
  28. #238
    Jan 2013
    Lakebay, WA
    Don't want to have anything in the center of the trailer frame (length wise) because can not lift the boat by bottle jacks if I want to do some adjustments or trailer work. I have to install a keel roller here....
    [url=https://flic.kr/p/XCYsi6]DSCF0050
    and Tom suggested for support to install 4x4 across the frame, 3-4' aft from the winch mount.....
    [url=https://flic.kr/p/XCYsxp]DSCF0049 (1)
    starting my work week, so I will chew on it ....
  29. #239
    ^^ Yes, the 4x4 support is what I was thinking as well.
    - Chris
  30. #240
    Lake Champlain, Vermont
    I wold strongly recommend raising the winch so that the pull on the boat would be neither up or down as you winch it on, this would make it necessary to move the boat forward by only a few inches and that may be enough to satisfy your 10%
  31. #241
    Jan 2013
    Lakebay, WA
    Quote Originally Posted by Oldad View Post
    ....I can see the light....
    Would have to raise the whole winch, is out of adjustment now.....
  32. #242
    Jan 2013
    Lakebay, WA
    ................totally changing subject...
    Need new Hull Identification Number plate made for my boat - anyone know place that can make it here in WA ??
  33. #243
    I would think that any local trophy shop will make what you want. Once I finish my build and receive my HIN from the DNR, I was considering having a plate made identifying the year of build, plans, estimated HP, builder, etc.
    There's a guy here in St Louis that does them https://stlouis.craigslist.org/bpo/d...259574550.html and he seems above board. I am 99% sure though that you can do your own with some aluminum or brass from the hardware store and a letter stamp set from amazon https://www.amazon.com/s/ref=nb_sb_n...tter+stamp+set
    Another possible option might be to have your HIN engraved on a dog collar blank. Amazon has some nice brass ones here in several sizes: https://www.amazon.com/Warner-Brand-...s=plate+id+tag
  34. #244
    Oct 2014
    SW Washington/ At Sea
    The local sign masters makes them in Longview, WA.
  35. #245
    Jan 2013
    Lakebay, WA
    thank you both for ideas.....right now I am leaning toward getting the stamp set, as I would like to make another plate with information's about the designer, dimensions and weight of the boat.....but work week is steel young , I may change my mind
