Page 10 of 10 FirstFirst ... 910
Results 316 to 343 of 343
Thread: Plywood boat rebuild
  1. #316
    Lake Champlain, Vermont
    Default Re: Plywood boat rebuild
    Nice piece of work. Very nice...
  2. #317
    Jul 2010
    northeast Ohio
  3. #318
    Jan 2013
    Lakebay, WA
    thank you Tim,
    I don't know why such a poor video quality. My phone always takes good pictures and videos - Android of course
    Here is a picture from I-phone
    not sure about the quality, but is lying on the side.....
    "Little Bear" 1955 Fontana 18' - 1958 Atomic 4
    2016 kayak Mill Creek 13
  4. #319
    Little Bear looks great Wojo. Congratulations on getting her out and running!
    - Chris
  5. #320
    LPBC, SC USA
    Very nice. I left a comment and like on your video.
  6. #321
    Jul 2010
    northeast Ohio
  7. #322
    Jan 2013
    Lakebay, WA
    Redneck's boat in South Sound
  8. #323
    Jan 2013
    Lakebay, WA
    My retirement date has been set by the "management", so I am thinking about my boat projects when that happen. I will be using Fela for sure, but I am really looking forward to button up Little Bear and even do some interior improvements.
    Lately I have been considering designing some sort of outboard bracket on Little Bear - in case Atomic will breakdown. Recently bought 1959 Mercury Mark 35 AE. It's a 4 cylinder, 35 HP. electric start outboard that I would like to restore and use on Little Bear. So I am looking for an outboard bracket design I could add to the transom. Don't want to cut the transom, especially that the Mark35A is a short shaft motor.
  9. #324
    Aug 2019
    Paisley UK
    Engine looks amazing for it's age. You gonna paint it up in two pack? Or just a good clean.
  10. #325
    That will never be a reliable kicker.
    It wants fresh non alcohol gas, for starters.
  11. #326
    Jan 2013
    Lakebay, WA
    Quote Originally Posted by lexi View Post
    Thank you lexi.....yes, it will be painted. Just got it so didn't even take the spark plugs out to take a peek inside cylinders or to check compression numbers.
    Came from Arizona - so no salt water use
  12. #327
    Jan 2013
    Lakebay, WA
    I am thinking of using it as a main motor on Little Bear or on smaller, faster boat I would like to build - like Merry Maid......
    Thank you for the info Bruce - writing it down!
  13. #328
    Jan 2013
    Lakebay, WA
    Starting to work on projects to get the boat ready for the summer. This year I want little Bear to be my main boat.
    1. Installing position lights + wiring.....( designing a light - as seen here on Fela)
    2. Looking for a design for 2 single, foldable plywood seats........to replace the one in the picture here
  14. #329
    Jan 2013
    Lakebay, WA
    working on electrical
  15. #330
    Jan 2013
    Lakebay, WA
  16. #331
    Jan 2013
    Lakebay, WA
    Reassembly
  17. #332
    Jan 2013
    Lakebay, WA
    New stool
    20200530_092503.jpg tti[ATTACH=CONFI
  18. #333
    Oct 2014
    SW Washington/ At Sea
    That looks fantastic. Atomic fours are great engines...that is such a cool little boat. Some day when the quarantine is over and I'm up in Puget Sound visiting an old friend (who lives on Jackson Lake) I'd love to see it.
    I heard the lakebay marina was purchased by the Recreational Boating Association and Marine Parks Conservancy. Hopefully they can keep it going - it's such a cool spot. Little Bear would look perfect motoring up to get fuel.
  19. #334
    Jan 2013
    Lakebay, WA
    Thank you Powerwagon ! Absolutely stop by when you are in the area. Jackson Lake is probably 10 minutes away from where we live.
    Had a burst of energy today. Finally drained motor oil - used little oil pump builded in my motor - and pour in 4 quarts of clean one, replaced choke linkage, rearrange battery cables. Want to have the boat in the water for second week of June.
    Need to run wires to position lights, and looking for something to hang the wires. Here is the original one. I was thinking of staple it over a piece of plastic. I want the wires to be tight and straight, not hanging loose......any ideas??
  20. #335
    LPBC, SC USA
    Nylon P clamps.
    https://www.amazon.com/Clamps-R-Type...language=en_US
    There are also assorted types of plastic and metal ones as well.
    https://www.amazon.com/s/ref=as_li_s...language=en_US
  21. #336
    Jan 2013
    Lakebay, WA
  22. #337
    Nice!
    (As a note of pickyness, ..... running lights are USCG approved when using the 'original' type of bulb. Technically speaking, .... putting LED bulbs in running lights that weren't designed for them makes the lights 'not' USCG approved. ....... I know, picky.
  23. #338
    Jan 2013
    Lakebay, WA
  24. #339
    Jan 2013
    Lakebay, WA
    Installed a lit to flush cooling system, also to run the motor on trailer.
  25. #340
    Jul 2010
    northeast Ohio
    Not a bad idea IMO, but aren't you missing a couple clamps there?
  26. #341
    Jan 2013
    Lakebay, WA
    Kit works for 3/4 5/8 and 1/2" hoses, only one size hose clamp though. Trying to find a right size clamp turned out to be bery difficult. Went to 3 different stores.....no luck.
    Run the motor a little today......turned out that need to run the motor in order for the water to go through. Water pump is in a way. Also need to get an extra on/off valve so i don't need to adjust the volume at the hydrant.
  27. #342
    Jan 2013
    Lakebay, WA
    Little Bear is alive and well.....need to practice to drive the boat and operate a drone
    https://www.youtube.com/watch?v=pgXviLd9qno
  28. #343
    Jan 2013
    Lakebay, WA
    taking advantage of low tide to work on shaft stuffing box
