Results 1 to 28 of 28
Thread: heating a boat with candles and flowerpots for 8p a day - and the home office too
    Jun 2008
    Default heating a boat with candles and flowerpots for 8p a day - and the home office too
    Introducing the forkandlepothead TM
    For the past few years I have been sailing through the winter
    I use tealight candles from Ikea at 1p each and put them on a metal plate
    I have heard about people using flower pots to make the heat from candles more effective
    I was deeply cyncial
    how can that work?
    however, having been through the coldest October for a decade I thought I would experiment a little
    It does seem to keep the room warmer than four candles just burning in the dish
    maybe the two pots with the air gap help to move the air around more efficiently
    if you notice I have filled the hole on the inner pot
    Of course you kill all the light
    I will try to do some comparative tests on the boat
    in the meantime it allows me to avoid putting the central heating on in the house
    the running costs is 8 pence a day
    http://www.youtube.com/watch?v=brHqBcZqNzE
    you can buy a porper job for $30
    http://www.tacticalintelligence.net/...dle-heater.htm
    and during ww2 the Uk govt was promoting the idea as well
    http://media.iwm.org.uk/iwm/mediaLib...6335/large.jpg
    and talking of four candles
    http://www.youtube.com/watch?v=Cz2-ukrd2VQ
    Barrie, Ontario, Canada
    Default Re: heating a boat with candles and flowerpots for 8p a day - and the home office too
    Very cool -- I mean warm!
    You're breathing the by-products of the burning wax of course, but I wonder if the heat of the inner chamber makes that better in some way...
    Dave
    are they vented? smokestack?CO?
    May 2009
    pretty cool, I'll have to give that a try.
    Jun 2008
    whizzbang and Dave,
    I am a bit concerned about co2 - but I am not sleeping in there, I come and go all day opening and closing the door, it is an old house and drafty
    it is a thatch so I am obviously concerned about fire
    I have to say that two flower pots on a boat would be a nightmare
    flower pots have a high thermal inertia - but it is not really working that way - I think that two concentric metal cones - cut down metal funnels could would work just as well
    then you could have it on the boat -
    I think that using one with the bigger air flow than you get from four naked tealights
    might stop your feet from freezing
    I think that the hot surfaces are moving more air than the hot flame better heat circulation - not so many cold spots
    not so many hot ones either
    Dylan
    May 2009
    you can always get a co2 monitor
    Sep 2004
    Ohio
    It's not CO2, carbon dioxide, it's CO, carbon monoxide that's the worry.
    Are we really to worry about the CO produced by a just quartet of tree lights? If so, than every Catholic Church, New Age store, and Witches Coven would have patrons passing out in droves.
    Jun 2008
    I live an old drafty house
    I come and go all day from the room
    so my guess is that the air change in the room is fairly high
    I do not sleep in there
    my main concern is setting light to the house
    although four tealights in a bread tin shuld be fairly safe I reckon
    D
    Northeast
    In the small cabin of a boat where air volume is more of a concern, it's not bad to be prudent regarding anything that burns fuel.
    -William A. Ward
    Oakland, CA
    now Dylan
    I love an eccentric
    but the diction
    are you lazy
    or are you
    a poet
    Savannah, GA
    It's not just the CO2, there is a lot of soot emitted by candles. Unless IKEA has come up with a soot-free version you are breathing a lot of soot from a single candle in a small space.
    I used to use one of those large-sized ionic air purifiers and over a period of a year or so I learned how much stuff it caught and how often it had to be cleaned. Then one day we had some sort of event here and had a couple candles burning for the atmosphere. They were only burning for a few hours in a very large space--great room, dining room and kitchen, with a 24 foot ceiling over the great room. The next day I pulled the guts of the ionic "filter" and found it 99 percent coated with black soot.
    I have never lit another candle in the house except in the rare event of a power failure.
    and here:
    "All kings are not the same."
    @ Dylan,
    that "Four Candles"(fork handles) gag from the 2 Ronnies is great! but does anyone from outside the UK understand it?
    Hoping you will keep on "turning left."
    Alan
    True that. But he's heating a room in his house.
    Northeast
    Quote Originally Posted by MiddleAgesMan View Post
    Beeswax tealights. "Pure beeswax candles give off little, if any, smoke as they burn. They don't emit any soot whatsoever." Not sure I fully believe that, but, whatever.
    -William A. Ward
    Nov 2006
    Alameda, CA
    I use ikea tea lamps with a ikea hurricane leaded glass lamp in my 28' boat. I light it up and hang it. it changes ambient temperature by 15 degrees or more making it toasty in 10 mins, removes the dampness from the air, cushions and sleeping bag. I blow it out before I go to sleep. Relight it in the morning to heat it up and once again remove moisture and dampness of sleeping in a closed boat. In fact I do have another one I use as a cockpit light which serves almost ldoubles as at anchor light.
    hard to imagine a cheaper, better, simpler solution for multi purpose light/heater. quaint too. 5 dollars for the lamp and 3 dollars for a carton of 20 tea candles.
    Jun 2008
    Quote Originally Posted by sailoar View Post
    now Dylan
    I love an eccentric
    but the diction
    are you lazy
    or are you
    a poet
    I was a BBC hack for a couple of decades
    so it must be the latter
    as for the beeswax tea lights
    bit too pricey for KTL
    D
    Feb 2005
    Abbotsford, B.C.
    The inverted plantpot radiates the heat. A red brick will do the same job. You could switch on your stove (cooker), set a
    red brick or two and it is the same effect as a cast iron hot water radiator in a home.
    Make some sort of a "cage" which you can put over the candles and place a brick or two on top, so you'll still have the light.
    The inverted plant pot trick is quite common round these parts.
    basil
    Feb 2005
    Abbotsford, B.C.
    Could get yourself one of these: http://www.go2marine.com/product/831...at-heater.html for an arm & a leg. Available in Kerosene, Diesel or Propane.
    basil
    Jun 2008
    Quote Originally Posted by goodbasil View Post
    I think that there is something more subtle and sophisticated than just a brick going on here
    there is a lot of air flow - more than just from the candles
    the two flower pots are acting like a chimney for warmed air
    so I think the heat radiation is much less important than convection
    Dylan
    Thanks Dylan!!
    Sep 2008
    Sarasota, fl
    Cheap scented candles give off lots of soot. I had one in college, and thought it was cool to study by. It turned the inside of my computer black.
    I wonder how a paraffin lantern would compare. That stuff burns clean.
    Jun 2008
    Quote Originally Posted by zertgold View Post
    paraffin smells bad to me
    I really do not like the smell of the stuff
    nor the meths I burn on the stove on the boat
    I am worried about filling my lungs with crud
    however, the inner pot has been on for about seven sets of candles
    no sign of soot in there yet
    so maybe it is not that bad
    Dylan
    I once met a bloke in France who heated his house with rabbits kept in the basement.................... Any space in your bilges?
    Jun 2008
    No rabbits
    but lots of hares
    from a distance they look like rabbits
    did you hear abiout the blad man who pout rabbits on his head
    the reason
    from a distance they looked like hares
    Dylan
    Sep 2008
    Sarasota, fl
    When I speak of cheap scented candles, I am referring to the big ones which smell like something you thought you wanted your house to smell like. Stinky candles are a big industry, and the "Chinese drywall" versions soon hit the market with fun flavors like toluene, xylene, and yes even lead. Most of the tea lights I come across burn very clean, and I have had no problems. Although I have heard talk of paraffin being bad because it is petroleum based, but beeswax and soy candles are okay. I guess everything will kill you, that's why no on has lived forever.
    San Francisco Bay
    Ah, the old flower pot trick. Been around for ages. Guys used to put an upturned flower pot on their kerosene or alcohol galley stove to serve as a heater. It does radiate the heat, but the laws of physics apply. A candle only puts out so many BTU's. The flower pot won't increase the heat output any.
    Feb 2010
    Freeland, WA
    Old houses can easily have 4-5 air changes per hour. But it's prudent to be prudent about CO.
    Gerard>
    ​Freeland, WA
