Page 19 of 20 FirstFirst ... 9181920 LastLast
Results 631 to 665 of 683
Thread: Welsford Sundowner build
  1. #631
    Rushworth Australia
    Default Re: Welsford Sundowner build
    Hi Mal, I think the overall height is an inch less on Nanni even with the shallow sump on Beta, but I will double check before purchase. Maybe the height from mounts to top is different. I wil check. I have made a wooden dummy engine. One Yanmar and one Beta, but both require some raising of cockpit sole which I will turn into a bridge deck.
  2. #632
    Hi Mal,
    Always enjoy seeing the updates on your thread. Got a question for you with regard to shop clearance. How tall is it from the floor of the shop, to the top of the deckhouse? What headroom do you have in your shop?
    Thanks,
    Ryan
  3. #633
    Aug 2011
    Brisbane QLD,Australia
    Quote Originally Posted by rtowner8820 View Post
    Hi Mal,
    Thanks,
    Ryan
    Hi Ryan. The door at the front is 3m wide with 3.3m clearance at the top. The shed itself is huge, over 4m at the sides and 4.5m at the very peak. I will measure floor to cabin top for you, but by my calculations there is 75mm or 3inches clearance at each of the sides when I need to get the boat out. BUT I will check before I put the rubbings strakes on!
    Mal
    Quest
    Moving slowly towards a Welsford Sundowner.
    Hobart Wooden Boat Festival 2017, or maybe 2019ish??
  4. #634
    Tuscon AZ
    That is a beautifully shaped rudder!
  5. #635
    Hi Mal, she's coming along beautifully!
  6. #636
    Thanks Mal,
    I'll look forward to that measurement, and thanks for sharing about the shop. I have a barn with an inside ceiling height of 10 feet...so sort of has me curious...
  7. #637
    Rushworth Australia
    Quote Originally Posted by Quest View Post
    Mal
    Coulda built a bigger one
  8. #638
    Aug 2011
    Quote Originally Posted by donald branscom View Post
    Thank you, it was the first thing I made off the plans and the size of it gave me my first near heart attack/what have I done moment.
    Thanks Peter. Good to see you back in the shed with a positive result from your treatment.
    Thanks Mal, I'll look forward to that measurement, and thanks for sharing about the shop. I have a barn with an inside ceiling height of 10 feet...so sort of has me curious...
    I went out with a string line and took a measurement. Roughly 2770mm or 9ft 2 or 3 inches to the floor, with 70mm or just under three inches of space between the bottom of the keel I made (which I think is a little bit deeper) and the slab floor.
    So, looking forward to another Sundowner build starting soon maybe ????
    Andrew, I would like to go sailing at some stage! At the rate this one is progressing my son will have to finish it..........
    Mal
    Quest
  9. #639
    I have bought the study plan, and find myself looking through the building steps document frequently. And then add your blog and I'm pretty much addicted to the design. Can't wait to see your boat in the water and sailing. Other than Charlie's have there been other completed Sundowners?
  10. #640
    Aug 2011
    Mr Welsford may chime in but from memory there is a stretched one similar to mine somewhere on the water as well.
    If you want extra photos of the original build have a look throught the old blog of Mr Wipple at http://tokyowest.typepad.com/charlie.../10/index.html
    EDIT starts at 9-7-05.
    Mal
    Last edited by Quest; 04-06-2018 at 03:30 AM. Reason: Added date to help review of blog
    Quest
  11. #641
    Rushworth Australia
    I just had a look at that blog and there’s a clever bit of writing at Sept 2010 under ”English Fun”
    took a little while to figure it, but to see more boat stuff in that blog use the “back” and “fwd” arrows at top of pages.
  12. #642
    Aug 2011
    Thanks Andrew, should have added a reference date which I have done now. I have looked at it so much I know where stuff is and forgot.
    Mal
    Quest
  13. #643
    Aug 2011
    After much hand wringing, and further sanding/fairing I got to the point where I could not avoid painting any longer. Been worried about how it will look, but you got to stop sanding sometime. Decided to go with International Interprotect two part epoxy sealer/primer, and thinned the first coat about ten percent. Other than the smell, seems to be working okay so far. I decided to do the bottom surface (which is flatter than many other boats) and everything on deck first. This was due to only having to removed part of the cradle supporting the boat, and being a chicken and wanting to start underneath where only the fish will be looking at my first attempt. Cut in the edges with a brush and rolled the vast majority of it with a 160mm or 180mm wide cloth roller.
    Looking underneath from the bow to aft:
    From the aft:
    Looking aft on the deck part way though before I did the cabin and cockpit:
    Cockpit from the side:
    The transom from the side (reminds me of Mr Whipple's similar shot!)
    A final shot looking forward down the port side. Sorry, the light was failing but you get the idea.
    I was pleasantly surprised with the finish, particularly on the deck and rear quarter deck where I went a bit thicker. But I have put a second coat in the anchor well and it seems to cover well anything still visible. I will do at least two coats, possibly three. I've used a four litre can (with the hardener as well) so far.
    Feeling a little better about the process and finish I must say, but a few things to tidy up here and there.
    Mal
    Quest
  14. #644
    Rushworth Australia
    Great stage to be at Mal, all power to your brush hand.
  15. #645
    Aug 2011
    I am still grinding along, I have been running electrical wire throughout the boat and connecting lights, fans, charging sockets and putting in a couple of batteries. No pictures of that yet, thought I had some but must not have.
    Lifted the engine into place on the beds with a pulley system and 4WD winch:
    Sitting in place:
    And have three coats on the underside of the hull (right under the bottom), and topsides (anchor well, deck, cabin sides and top, cockpit and rear quarterdeck). Now I have put the supports back under the hull with an extra one each side, tied it back to the shed and removed side of the cradle. First coat of sealer/undercoat is on, two more to go.
    From the front before:
    And after:
    Port side before:
    And after:
    CONT:
    Quest
  16. #646
    Aug 2011
    Couldn't leave out this shot, shows a bit of the deck but light is poor.
    More photos of the electrical fit out and the deck finish (even three coats of sealer looks good to me) to follow once I finish rolling it all on.
    Still alive!
    Mal
    Quest
  17. #647
    Brilliant!!! The engine pulley set up looks interesting....
  18. #648
    Yep, looking great Mal!
  19. #649
    What goes over the engine Mal, or does it slide back from where it's sitting now?
  20. #650
    With the paint she looks nearly done. Beautiful lines.
  21. #651
    Aug 2011
    Greg, the rope work was the product of my engineer brother in law. Worked well but I was a sceptic as we set it up.
    Rick the engine basically sits about where it is. When I stretched the plan and tried to get the shaft tube angle set out it is a bit more horizontal than it should be. This means the coupling circumference dictates how far back I can go. BUT, it was always my plan to box it in (I have the frame already made) and use it as a table and step from the cabin seats out onto the bridge deck. Will also make maintenance very easy, sides will be removable.
    Rik, it is really starting to show the final shape now it is one colour. It was raining so I could not leave the shed doors open with wet primer for light. Better photos, with a cleaner shed, to follow.
    Mal
    Quest
  22. #652
    Sounds really good Mal! Such a great thing to have really good access to the sides and top of the engine. I can actually enjoy working on engines when I can actually get to them!
  23. #653
    Aug 2011
    I didn't know you were allowed to enjoy working on them. It certainly will make me more likely to look it over and service it more regularly with the built on oil sump pump and the ability to reach things without having to have arms that bend five different ways to get at something.
    Have to post some photos I promised, standby....
    Quest
  24. #654
    Aug 2011
    Photos promised.
    Storage for house battery under the foot of the cabin berths which go back under the cockpit.
    Lights and double USB charging point in the main cabin (same both sides).
    Forward cabin port side, double USB, reading light and then fan.
    Better shot forward showing the fan.
    Few more on the blog, but you get the idea. Minimalist LED's, I cannot see much point in too many gadgets when they are all so mobile and portable these days.
    CONT with outside shots.
    Quest
  25. #655
    Aug 2011
    Cockpit looking aft with three coats of sealer.
    Cabin sides and top looking aft:
    A better shot of the port side looking forward, sides with second coat of sealer:
    And sat a few stanchions in place to get a feel for the final look.
    This thing is starting to get close................
    Mal
    Quest
  26. #656
    Adelaide, South Australia
    Awesome in every way.
    Paperback E-book
  27. #657
    Blue Marble 3rd Rock From Sun
    She gonna be a sleek looking vessel when she hit the water.
  28. #658
    You are close to the water now...
  29. #659
    Very nice Mal! Bright and airy inside - just what you want!
  30. #660
    Well done Mal, very, very soon!
  31. #661
    Aug 2011
    The great paint-a-thon continues. Decks and side down to the waterline are done. Put down some kiwigrip which turned out not too bad, prepped:
    Underway:
    And finished looking aft down the stb side:
    I continue to sand and prep the keel for sealer and then undercoat, a work in progress. While hiding from that I have attached the forward deck locker lids and the external covers on the cabin vents:
    I am having a go at making some wooden handrails for the quarterdeck and forward to the rear of the cockpit combing. Uprights and top are 35mm Tasmanian Oak (uprights notched in and epoxy glued/screwed), the lower cross piece 25mm Merbau/Kwila (notched in and epoxy glued).
    Feet are 20mm x 70mm hardwood, again notched for the uprights.
    CONT
    Quest
  32. #662
    Aug 2011
    Temporary screwed and glued while the feet set:
    Sitting in place after adjustment:
    The plan is to come forward following the hull to uprights bolted through the combing. The holes drilled oversize and epoxy filled:
    And the uprights having 8mm threaded rod epoxied 80mm into the wood.
    Waiting on butyl tape to final fit the portholes and storage locker hatches in the cockpit, while I grind on with the keel prep and handrails.
    Mal
    Quest
  33. #663
    Great to see the progress Mal!
    I can't help but advise against timber handrails. Handrails really need to be unbreakable. They should bend but not break. You never know when someone might hit them very hard and be reliant on them not to break. I think they'll look great but not really do the job that handrails are there to do. Just my opinion, of course!
  34. #664
    Rushworth Australia
    Hi Mal, great to see you’re nearly done, way ahead of slack ask me.
    I’m fearful for you with those rails, while they may pass the initial test I’m thinking 12 months down the track and a sudden lurch with an outstreched hand....... think in terms of your body weight times multiple G’s
    While SS ones may not pass a similar test they will at least probably stay attached to the boat and just bend under this sorta strain.
    If you must go with wood then at least return the top rail around to the side decks to give some extra bracing to the setup and continue the rail all the way across the aft deck. Like a real push pit setup.
  35. #665
    I too have to caution against those handrails. Your attention to detail throughout the build is very impressive, but those rails give me pause. Would you run and throw your full weight at one, and expect it to hold? Because that's at least how strong a rail needs to be.
