My confusion about deadrise is in modern powerboats it seems to only refer to the angle of slope at the transom. The sheer is a point on a boat such as rocker, the sheer clamp is a part of the boat. The chine can be either.
Yep, 3/4" pine ply for the workbench top. The curvy structure is a building form for John Welsford's SCAMP. The building form sets the rocker for the large bottom panel. I can't take Jo Jo to oyster roasts anymore because he likes to chew on oyster shells. What are those crazy dogs thinking? I wonder sometimes. Good luck with the rest of your build.
Deadrise is certainly seen most easily at the transom, but on a vee-hulled boat there's deadrise from the stern all the way forward to where the chine logs join the stem. The deadrise might be uniform throughout, or it may be relatively flatter back aft to make it easier for the boat to plane, and to increase load carrying capacity, and then the deadrise angle might increase further forward, so that the bow doesn't slam into seas. Building a vee-hull is a lot more work and expense than a flat bottom, and for a given length, beam, and draft, the hull has less carrying capacity and initial stability. On a work-platform hull like a barge (or an oyster tonger), initial stability is a really good thing.
I understand deadrise now, it was about the only boat shape I was unclear about. thank you. I am putting some "V" in this hull for strength and hopefully some better handling in a chop. The "V" will definitely add strength to the hull. With my own experience and observing projects that other people have built, with a completely flat bottom it ends up with a concave area athwartship especially with a beam of this size. I wanted to avoid that and these barges get ebbed out and the flat bottom makes them stick to the mud more. This boat does not have much "V" as you can see in the photo of the model and it is greater forward than aft. I should have called this boat something other than a barge even though that's what it is. It will be powered by an outboard.
Walt,
Deadrise is certainly a misunderstood term. It means different things to different people. What it really means is simply a "dead" rise from one point (the main log, or kelson) to another point (the chine). A straight line with no curve. In other words, a round bilge, round bottom or soft chine boat isn't "deadrise" because it's curved.
The first time I ever heard someone call a boat a "Deadrise", I thought, Do you mean a skiff or a 40' workboat? He meant a workboat with a cabin up front. That's what deadrise meant to him.
I looked at a set of plans drawn in 1935 of a proposed "Deadrise" skiff a few weeks ago. The boat was flat-bottom. UUGH!
Eddiebou,
Sorry, don't mean to evesdrop (or derail the thread). I sense you may be looking for a Ches. Bay type deadrise skiff. Have you seen Doug Hylan's new concept? He calls it a Point Comfort Skiff based on the Chesapeake Bay style workboats. Just passing that along if that is what you are considering.
Regards,
Dave
Eddie thanks for that treatise on Dead-rise. I never was certain what it meant.
Someday I'm going to build a Jon boat that I can Row and it's gonna have a dead-rise of about 0.5" out to the sides.
I don't want it to tip on me. Or under me!
Eddie, that's where my confusion comes from. In your area and mine they refer to a boat with extreme angle of the bottom in the bow as a "deadrise boat". And now in center consoles and offshore fishing boats they state the angle of deadrise but they are refering to it at the transom.
Going back to the first planing hulls, they were quite flat back aft, which allowed them to plane easily, and then the deadrise angle increased as they went forward. Made them steer better, kept them from pounding in a chop. As hull construction and engines got lighter, boats began going fast enough to leap right out of a wave, and come slamming down on their flat after sections. So deadrise was carried further aft, reaching its greatest development with the Bertram "Moppie" ocean racers, which carry a lot of deadrise (23º?) All the way aft. These hulls were remarkable able, but are gas hogs, and have some quirks, like riding around on one chine unless they're perfectly trimmed.
I remember being hired to deliver a 33' Scarab from Norfolk to Maine, with the owner and a couple of his friends on board. It burned fuel at a rate of about 1.2 gallons per mile, and in a chop it would go 20 knots, but it was not a smooth ride.
As people become a little more realistic about what they want their boat to do, deadrise angles aft are flattening out, for the sake of fuel economy, ease of handling, etc.
Right. It just means V-bottom or deadrise as opposed to flat bottom. The deadrise is everywhere along the bottom, steep at the bow and shallower at the stern. A flatbottom boat has no deadrise. Of course this is only side to side, not fore and aft. The fore and aft curvature is "rocker".
I remember some boat manufacturer years ago bragging about "variable degree deadrise". Uh, well, it pretty much has to have variable degree in order to have an up and down stem and a flatter stern, doesn't it?
I certainly am no naval architect, and don't know all the terminology, but it's really just a matter of usage. I know what it means where I come from. I don't feel like it's my place to go around correcting people's language.
I know one fellow who referres to the "soffit" on a house as- " 'sophagus". I didn't understand what he meant at first, but over time I did. I see no need to correct him.![]()
There are quite a few hulls that are flat-bottomed aft, and by the time they get to the bow they have vee sections. Even a "model-bow" (pointy ended) barge has deadrise in its forward sections. A Holland 38 lobster boat, which is much admired for its speed and seaworthiness, is almost flat bottomed, with a round chine, aft, and then gradually transitions to a very sharp bow. Mount one of these with a 900 HP MAN engine, and you have the ultimate New England Tuna boat, able to work a couple hundred miles offshore, and capable of 30+ kt of speed.
It often surprises me what a good boat can be built with a flat bottomed hull. My friend Grant Gambell has a flat bottomed skiff that he uses as a dinghy that rows and tows quite well, and some flat iron skiffs actually sail pretty well on a reach or run. Boats with narrow flat bottoms and flared sides, like a Gloucester Gull or an Adirondack Guide Boat are famously good rowboats. Francis Herreshof designed a flat bottomed skiff for his world cruiser "Marco Polo," and I've rowed and sailed one. Pretty good boat.
I've read that in the old days there were flat bottomed schooners that carried hay on San Francisco Bay, and that running home empty with a quartering breeze they would walk right by a racing sloop.
Seo, I agree with what you said about flat bottomed boats. I built a 16' sailboat called the flatiron and won several races with it and came in second place at the MASCF one year. And it was definitely the boat not my sailing skills. If you see my reasons for putting a slight "V" in this hull in posts #54, I think it makes sense.
I have made some progress on this boat, but I am having problems posting pictures. I thought I had that down. I posted pictures and narrative the other day and when I went to post it the message said the time had expired and I needed to go back to retrieve it. I could not get it back and decided to do something less frustrating. This happened one other time but I got it back. Anyone has ideas on this please advise.
Back to the boat. I have installed the bow assembly and I am working on the stern at this time. I promise pictures will be coming, but might have to wait until younger family comes to visit to help me with this. There will be more to see by then.
Pictures of progress. Completed bow assembly in shop
The bow installed. Cargo strap worked good to pull the chines in.
More pictures.
I made this platform to hold the bow at the correct height; it looks like overkill but it was under much stress with the chines and sheer clamp pulling in different directions. It worked good.
This is a pattern for the stern. It helps me get the correct size, bevels, and the rake. Next few pictures are building the stern transom, setting up and cutting off the chines and sheer clamp.
Okay, so the pictures are a little out order.
It is being painted to prevent checking not for looks or rot prevention. The weather was very dry and the wood started to dry out too fast.
The floors are treated 3 x 12 's. They were about 2 1/2" thick and we planed them to 2 1/4" so they could be cut with a circular saw. I wanted something thicker than 1 1/2" because the bottom ply runs athwartship and the seam between sheets breaks on the floors.
Pattern of floor.
Four floors installed.
Moving along nice...
Very nicely done! I am enjoying the pictures greatly!
Just out of curiosity, did you do any type of weight study to estimate how deep she will float and how much freeboard you'll end up with?
Keep up the good work!
Thank you.
I am keeping track of the weight of all the materials used in it to roughly determine how deep it will float. I am fairly sure it will float high but a concern is the fore and aft angle in the water.
Looks very nice..... Heavy...... But nice.
And I'm very jealous of your lawn....
Thanks also, it must be the photos that make the yard look good because it really doesn't. That is a wheat field about 60 feet away from the boat and that looks good
The next framing phase for this boat will be either notching the stringers into the floors or installing the frames between the chines and the sheer clamp. I don't think it matters which one is done first.
The stringers are 2 x 6's flat- spaced about 14" apart depending on where they are located. The stringers will run parallel to the centerline and the chine is farther apart amidships so the distance between the outer stringer and the chine will vary. At this time I think the outer stringer will not go to the bow; it will end on a floor about 7 feet from the bow. It will be so close to the chine at this point it will not be necessary structurally and will lighten up the bow. The frames are oak and the spacing has not been determined but about 16 to 18 inches apart.
We have installed the last 2 floors and generally cleaned things up such as removing ply mock-ups of certain stations and battens that are not needed. It is starting to come together. We are now scarfing the stringers.
I am a house carpenter so most of the material like ply for patterns and the mold lumber came from other projects. Most of it has been used more than once and probably will be again.
This building was a cover for a portable sawmill that I had for awhile. That pile in the background is leftover from the milling. I milled the lumber for this building with the sawmill. I then used the building as a place to do a major repair to the decks and house of a 27' boat which took about a year. And now for this project.
This is a building that I built for my wife. It is mostly from recycled wood and all of the siding, cornice and trim is cypress. All of material except the roof came from structures I dismantled. It is her workshop.
looking great! I am thinking of building a work barge down here in florida for setting piles so I am going to follow your posts carefully so I might learn something.
I did some dock building here but the regulations and getting a permit were so difficult I stopped doing it. i will let you know when I launch this one if it would be good for setting piling.
Nope, it didn't work for me. I tried it and I still have the same old crappy chisels!when you replace { } with [ ] you will get:
This is a great project, thanks for taking the time to post it and the photos!
Regarding wood preservatives, long ago there were problems using treated wood around livestock, as they would lick the wood for the salts and die. That has probably been remedied by now I would suppose. The "Timbor" brand borax insecticide/fungicide is cheap, 25lbs of powder for $80 - $90. 1 1/2 lbs powder makes 1 gallon which covers 200 sq feet. The polyethylene glycol mentioned before in "BoraCare" borax products, I believe acts as a hydroscopic surfactant, it "makes water wetter" and so it doesn't just dry out like Timbor and leave the powder on and just below the surface, but allows it to soak in more initially and then keep getting drawn in over time until penetration is much deeper if not all the way through in boards like 2x stuff.
Some try and make Timbor into BoraCare by using anti-freeze (ethylene glycol) and I can't see how it wouldn't work as far as hydroscopic, surfactant properties, but I don't know for sure. One thing for sure is the anti-freeze version of glycol is highly toxic , which works well as far as an insecticede even by itself without the borax. The main problem though is it's sweet and everything likes it, from dogs to kids. You probably can't paint over it either. But if someone wanted to use it, I can't see why used antifreeze wouldn't work. It's free and quik oil change auto places must have a lot they would love to get rid of.
Plywood. At the school there was a sheet left over from construction that laid on the ground for a year. It was perfectly flat when I picked it up and brought it home, and never did warp as it dried. It was 3/4" fir, made up of 7 equally thick layers. I traced it to the local lumberyard and found out it was BC Ext. fir, I would guess Douglas fir. AC ply is mainly useless nowdays, the A side being a very thin veneer and then usually 5 layers of crummy mystery wood. We used to get concrete "form ply" from the lumberyard that was excellent plywood, stable, 7 or 9 plys (3/4" or maybe 7/8") and no voids, but it was oiled, which would eliminate glue, fiberglassing etc. It is possible though that it was oiled at the lumberyard, and could be gotten clean if you told them to "hold the oil".
Polyester on plywood works, it's been done a lot. The price difference with epoxy used to be extreme, but not so much anymore. Being thrifty (My wife says 'cheap', but then I don't have 109 pairs of shoes, so what do I know) I never considered epoxy, but I might now. I remember reading of a NE fish boat maker who still used polyester with success. From what I remember an important part of his procedure was exposing new wood with a light overall grinding of 50 grit, vacuuming and then immediately laminating. I wish I could tell you more, as the first interface between the wood and glass is the most critical, but I don't remember.
It wouldn't cost much at all to do some small test panels trying different processes and see which works best. I would think whichever one was the hardest to peel apart would be the best.
Some people lay the glass on dry wood and go from there. I always have problems with the glass gelling enough to become unworkable and resin won't penetrate anymore, but the ply can/will still pull resin from the laminate and leave dry spots. So I always resined the wood, let that set and then came at it with the laminate. You have a fairly heavy laminate at 32 oz, I guess it's a layer of 1 1/2 oz mat and one of 18 oz woven roving. I'm not sure if you can wet that out from one side if it's stitched together or something. If they're separate it's no problem. If you thin the resin to try to get penetration into the wood, use styrene instead of acetone. The acetone flashes off, cools the resin down and leaves it thick, the styrene is more compatible and gives it more of the 'hydroscopic, surfactant' properties. Some say wiping the bare wood clean with acetone "contaminates" the surface. Or maybe "seals" it somewhat. I don't know. You'd think after 60-70 years there would be definitive cut and dried answers, but it seems like it's a mixture of alchemy, politics and hope.
Aside from all that, what sort (like bolts, nails or screws-stainless, galvanized)of fasteners are you using? How will you fasten the ply skin? What kind of glue? Will this boat have a cabin or flush decks and such? Thanks again.
I really laughed at the 109 pairs of shoes. I am called cheap also.
I am using West epoxy on the scarf joints but otherwise not much other glueing. I bolted the bow and stern assemblies with 3/8" galvanized bolts. Most of the other fasteners will be screws. I am using screws made by a German co.- Altenloh, Brinck & Co. They are called HCR for High Corrosion Resistant. The Man. says they are tested to a high salt level. They are steel but with a coating on them that seems to be very durable. I am using some #14 by 3 1/2" screws in the framing which is really a large screw. I am using some stainless screws where the size was not available in the HCR screws. Also most of these screws will be buried in the structure and I know they will still be subject to corrosion but with the boat glassed it should be mainly fresh water in the bilge. I sheathed and glassed a 32' barge many years ago and it is dusty in that bilge- almost no moisture.
The ply is A-B Marine fir and I got a good deal on the 3/4". It will go on the bottom and 1/2" on the sides and both fastened with screws. The marine ply is very flat and that is one thing I like about it. I have a complicated fastening schedule for the ply because of different framing members have different thicknesses. I am using about 5 different length screws and 2 diameters.
I like your little building, Walt. What does the queen do in her workshop? Don't forget to cut limber holes in the bottom frames 'for you lay the plywood.
I thought about the limber holes early on but forgot about them so I appreciate the reminder. In my wife's little house she does crafts, dries herbs and flowers and gets away from me.
Have you seen the Buyboat being worked on in Urbanna? I have been over twice to see it. It should be on this site.
"A man builds the best of himself into a boat- builds many of the memories of his ancestors." -Steinbeck
Nice Job! I will be watchingKeep the pictures coming!
Eddie-I came by land. It is 30 miles by water and 145 miles by land. I don't fish.
Potomac- Since you mentioned the little buildings foundation, it came an old house that was torn down. After the house was demolished there was a small foundation inside the main foundation and it was not supporting the structure. I used the brick from that small foundation for this building.
Wely- Thanks for the encouragement and I am trying to keep it rolling.
The most recent progress is working on the stringers. After scarfing together 4 stringers the notching of the floors took place to make them flush on the bottom. The stringers will give some longitudinal stiffness and provide more support for the plywood. They will also tie the floors together. Here are a few shots of the first stringer installation.
Very nice!...... But...... How do you know that those are the stringers, and not something else?...... And how do you know which side of the barge they go on, and which side is up (or down)?![]()
And on a more serious note: I would strongly recommend that you not use automobile anti-freeze, or ethylene glycol as a vehicle to dilute borate. The Bora-Care product uses polyethylene glycol, which becomes inert (IE: non toxic), and hydrostatic when cured. Ethylene glycol never becomes inert, and stays hydroscopic until it leaches out of your lumber and into the water or soil under it.
I know there are stubborn old cusses that'll argue that they've used it for years and years, and it's never killed them, or their dog, but I'll point them to the chain smoking 80 Y/O man with the baggy 15 Y/O mutt..... Some people get lucky..... Most of us.....Not.
Okay, I thought someone might say something about all my notes but I labeled my block to test the housings as I cut them because the stringers measure 1 3/8" x 5 3/8" and I have many 2 x 6 blocks laying around and did not want to mix it up with one of them.
Thanks for the info, I would not use ethylene glycol but I do want to try borate. Since I am using treated for the framing the inside of the plywood should be the only concern about rot.
Both Tim-Bor and Bora-Care work very nicely.... A few weeks ago I pulled out a gallon of Bora-Care concentrate that I bought 18 years ago, and found that the borate had separated from the polyethylene glycol solution..... I turned the jug over and yesterday I took a look..... It's going to need a few more flip cycles, but it looks promising. 1 gallon of concentrate makes 2 gallons of solution, and covers a lot of raw lumber. A lot, like several hundred square feet.....
Completed notching the floors and installing the 4 stringers. The first one took me 3 hours to notch the floors and the fourth one took 1 1/2 hours. I guess that is about how it should be. The next step is to bevel the chines and install the frames, the last pic is milling the frame stock.
Keep it coming. Looking good.
I've been looking for that sock! How'd that get down there!?
Looking very good!
That's not a sock, that's a Starrett Pro-Site Protractor carrying case!
Ah...... My mistake! I have a sock (just the one) that looks almost exactly like that!.... Now I know where they got the idea from....![]()
Installing frames is the latest job. There are 30 of them and about 26 are fitted and 4 are fastened. They go fairly fast except for the many trips to the shop.
There is a large machine too close to my boat!
All of the frames are installed. I left them long at the sheer because I am not certain how they will tie in with other deck framing. They are cut even with bottom framing. I am close to laying some plywood on but I have a few other things going on. When I start the ply I want to work on it fairly consistently.
This is my son installing the frames.
On the end of the building there is a tarp to block the west sun. It works great but it makes it difficult to take pictures from that angle.
Here is what I have done during this very hot weather. Installed oak center frame in bow to fasten boweye to and to provide more support for transom ply.
Here I am using my pattern that used for the bow framing for the finish ply .
This is the 3/4" ply cut and in place.
WOW! That is a "Large Barge".
I hope someday to get over that way and ride out with you on an Oyster Barge trip.
I'd like to know what you do out there with a Jon boat that big?![]()
It does seem pretty big and I think it will look larger when I turn it over with a beam of almost 12'.
