Page 757 of 1259 FirstFirst ... 2576577077477567577587678078571257 ... LastLast
Results 26,461 to 26,495 of 44043
  1. #26461
    Feb 2014
    Sunshine Coast, QLD
    You could host a cocktail party on that deck!
    The red brackets mark the extent of the worm tunnels in this plank. Another guy at the yard says he ran a wire through the worm tunnel along that whole length and it stayed in the one plank.
    She has opened up a fair bit, and definitely wants fresh putty. The cotton caulking was replaced a couple of years ago.
    This one also shows the aft end of that worm-chewed section:
  2. #26462
    Feb 2014
    Sunshine Coast, QLD
    There are two planks on the other side with worm holes, just one each. That would need exploration too.
    She's really strongly built. The steamed frames look about 2" wide and on 6" centres.
  3. #26463
    Feb 2014
    Sunshine Coast, QLD
    Matt, next time you're nearby could you measure the draft ? The vendor said 6 foot and if that's right .... and it looks very likely, she would be too deep to moor easily in the Tweed.
    Yep. Will do.
  4. #26464
    Good question Looks like those chainplates must have been moved, which might cause moisture problems, engine is definitely too small, and I would be concerned with the extended rudder cheeks not being strong enough in a heavy sea way . The forces created by a strong out flow tide on WB rudder never seize to amaze me.
    Thanks for the feedback on the awning battens Guys.
    What makes you think the engine is too small?
  5. #26465
    Yep. Will do.
    Thanks Matt.
    She looks about right for wooding and a cold moulded overlay or 3, that would inspire confidence.
  6. #26466
    Gold Coast Australia
    Rather looked like the old QM 8 to me, if it's the QM I5 I stand corrected.
  7. #26467
    Feb 2014
    Sunshine Coast, QLD
    Thanks Matt.
    Perhaps... Though the way she was originally made was very good. The necessary plank repairs and then refastening and she'd be good for another fifty years as long as the worms don't find her again.
  8. #26468
    It's a twin so that would be the 15 or 20hp ?
  9. #26469
    We went and checked out Balias new berth this afternoon. It's a cracker. Really easy access, well protected. The afternoon sea breeze would be the main challenge in North Haven, but where the berth is, it's beam on, and will tend to blow us onto the berth, so getting in will be easy, just motor in, stop, and drift sideways onto the berth. Getting out, hit reverse and allow the stern to fall off, pull out a bit further and we are aimed toward the sea. Clear water forever out I to the basin, well, several hundred metres anyway. Couldnt be much better. Very happy with it.
  10. #26470
    Adelaide, South Australia
    Sounds excellent Phil. Is it accessed through a private property or a public access gate?
    Sent from my GT-I9505 using Tapatalk
    Paperback E-book
  11. #26471
    Oct 2007
    That's the plan I use too, except for the last bit, and I often delete the first bit too.
    I space all four judiciously.
    Jarndyce and Jarndyce
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  12. #26472
    Randomly rather than judiciously, for me.
    Happy berth day Phil!
  13. #26473
    Theres a public gate a few houses along the way. We are out right near the end of Gulf Point Drive.
  14. #26474
    Thanks, yes and many happy returns.
  15. #26475
    Returning to the place of one's berth is always good .....
    Congratulations Phil, that sounds very convenient !
  16. #26476
    If the Tweed's not suitable, there's always the Brocade.
    As long as they'd let you through, like that.
  17. #26477
    Feb 2014
    Sunshine Coast, QLD
    Pete, I have to work full time this week. I'll be back at the boat yard next weekend and I'll measure her up for the tweed then.
  18. #26478
    Sorry, that double ended looks badly dried out and worm damaged and there's some nasty looking stuff around the fasteners. Big big rebuild job I'd guess.
  19. #26479
    Feb 2014
    Sunshine Coast, QLD
    Yep. It is all of that.
  20. #26480
    I suppose it depends whether you consider replacing fastenings, a few planks and the caulking of a Colin Archer is worth the effort if the price is right - ie no more than $5k, definitely not $15k, as opposed to the work involved in a new build
  21. #26481
    As I said earlier, multiple layers of veneers would seem a good idea but she looks a bit big for my use .... but I'm not decided yet. There would be an in depth inspection first.
  22. #26482
    Most definitely !
  23. #26483
    I'd suggest there are any number of boats in good condition on the market which would work out to be a better deal almost any way you look at it. Even putting little or no value on your time.
  24. #26484
    A very rational response but just occasionally a boat seems to appeal disproportionately .... but she's VERY old and just a wee bit bigger and deeper than I want.
  25. #26485
    there you go Peter, 2 pointy ends and only 2500
    http://yahoo.boatsales.com.au/boats-...=0&pss=Premium
  26. #26486
  27. #26487
    Nice but outside my price range unfortunately.
  28. #26488
    But then so is an old fixer upper, by the time you get it seaworthy, decent engine, electrics, rig and sails....
  29. #26489
    I guess we better lighten up, half the fun is looking and thinking what might be.
  30. #26490
    Feb 2014
    Sunshine Coast, QLD
    Exactly!
    That little Rozinante, for example, is very cute. I am already repairing an old boat not vastly unlike her, but I can still look and admire.
  31. #26491
    Yep, but at least you get to put into it what you want and we get to be opinionated about what that should be.....
  32. #26492
    And said with such a straight face.
    Just had some reasonably serious rain here.
  33. #26493
    May 2014
    Exactly!
    it's not really a rozinante though is it? i was looking at images a while ago, and it's nothing like the same hull shape. herreshoff seems like a generic description for a lot of wooden boats with unknown history.
    Same as this one http://www.ebay.com.au/itm/21-Timber...0AAOSwhcJWHeQ3 - which looks like a scaled down alerion 26 in terms of keel, but that's about it. i'd be interested to know what design both of them were, because the cabins on them at the moment are fairly unfortunate looking in appearance, and surely not as per plan.
  34. #26494
    Feb 2014
    Sunshine Coast, QLD
    Quote Originally Posted by pelagos View Post
    Quite true. That last one isn't harmed too much by the cabin for some reason, but 'Scud' looks a bit wrong. I don't know if that photo of Scud in profile is a really bad angle, or her sheer is really quite straight. Rozinante has a lovely sweep to the sheer.
  35. #26495
    And also there is the time aspect.
    Do you want to spend your time working on a boat , or sailing , and maintaining it ?.
    Rob J.
    That's what I reckon at pushing 73 Rob. When christmas is over I'll look about for a wooden skiff in reasonable order, and find a club where I can store it so I'm not messing about with trailers. Something just a bit safer, more predictable and more easily recoverable than the Macgreggor.
