Page 729 of 1279 FirstFirst ... 2296296797197287297307397798291229 ... LastLast
Results 25,481 to 25,515 of 44746
  1. #25481
    Rushworth Australia
    Jeff what sort of wood, slow burning stuff?
  2. #25482
    Use rubber grease on o-rings
    Do you have a good layer of Vaseline or grease around the o-ring Peter? Definitely don't use silicon (unless it's silicon grease)
    if you have it, if not vaseline..... .
    Thanks, I'll try to find some silicon grease although I have to admit the other type crossed my mind . Although I have made up gaskets out of silicon formed between sheets of cling wrap.
  3. #25483
    Thanks Rick, Bunnies here I come. Does varnish then go over that, or do you do the wax last? I'm assuming wax last.
    No, you just varnish over the wax. It's really just a filler.
  4. #25484
    A photo for Bruce .
  5. #25485
    New Zealand's Far North
    I have re-used Unobtainable O-rings with a smear of automotive gasket sealant used sparingly in the grooves the o-ring seats in.
  6. #25486
    Auckland ,N.Z.
    Re the flooring , I've used carbon black in epoxy to fill up the worm damage and nail holes before , hard work actually . A commercial guy I talked to once uses plaster tinted with the same , then sands it off easily in one hit. The plaster isn't under stress and you just poly over it. I would have done it myself , but I wanted to seal off a bathroom floor. I wanted the epoxy for a full seal.
  7. #25487
    That sounds hopeful, I even have the stuff in my workshop.
  8. #25488
    Thanks-I just thought varnish might not adhere to wax. Off to Bunnies shortly.
  9. #25489
    Hmm, carbon fibre bathroom floors.
  10. #25490
    Ive really got to focus at Bunnings. I need another 10 litres of CFP, and have to try to get furniture restorers wax. Not carbon fibre, not vaseline, not silicone grease, not gasket sealant. I do have some really filthy looking black tractor grease in the shed.....Good luck to me.
  11. #25491
    The wax sort of sinks a bit, so, with the varnish over it, it looks more like ancient build-up of varnish rather than filler. I should think any filler would do though; I just like the look of the wax. It's a patina thing ....
  12. #25492
    I'd still go with the builders bog coloured with oxide for a hard wearing filler in a floor.......but I guess it may not suit an older floor......... anyway hey, what do I know?
  13. #25493
    Oct 2006
    Livin' in the Golden Triangle
    Bog would be a LOT quicker to do
  14. #25494
    So Bunnies didn't have the wax. I got a water based wood filler instead. Available in various flavours. I went for ebony for the rust stained holes, which is most of them, and something the name of which I have forgotten, for some new sections, supposed to match Baltic pine. Bitch of a job in the end. I already had 2 coats of varnish on, which I had hoped would make it easy to wipe or sand the excess filler off. Not so. Still enough raised grain, even after spending all yesterday afternoon on the floor with an orbital sander smoothing down the first coat, to hang onto quite a bit of black stuff all around each hole. Tried sanding first, but settled for a damp cloth eventually, which with much rubbing and rinsing ultimately did a passable job of removing all the unwanted dark matter. Sounds easy enough, but it was a bloody long time on hands and knees.
    The ebony is pretty much the perfect colour for the stained holes, and the lighter stuff matches the new sections well enough. Just for fun I did one stained hole with the lighter stuff, which is what I would have done by default if not for Ricks wisdom. Looks awful, like a really nasty pimple. Thanks Rick for saving me from that. I'd never have thought of using black filler on a pine floor.
    Couple more coats of varnish tomorrow, then it's time to knock some bloody great big holes in 3 walls to insert some huge bifold doors into. Let there be light!
  15. #25495
    Oct 2007
    I blame Rick for making me notice our floor's pimples.
    Peter, I have silicon grease here. But you can get small yellow tubes of it at Budds. I'm not sure how much I have in the tube, but you shouldn't need heaps. Might save you the additional 7km into town. I'm out after 2.30pm though.
    Jarndyce and Jarndyce
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  16. #25496
    I have to go in anyway for the weekly shop Duncan, but thanks for the offer.
  17. #25497
    Adelaide, South Australia
    Boating (rowing) with a school all this week, coaching the kids. As soon as I was out of range of getting back in time, Joan died. That's such a relief.
    Sent from my GT-I9505 using Tapatalk
    Paperback E-book
  18. #25498
    Feb 2014
    Sunshine Coast, QLD
    and
    Sorry to hear that, and I understand your relief.
  19. #25499
    Oct 2006
    Best wishes, Bruce
  20. #25500
    Yes, you were lucky to have each other, Bruce!
  21. #25501
    Farewell Joan, sorry for your loss Bruce. Is Romanas birthday party still on?
  22. #25502
    Rushworth Australia
    It's probably a relief for her too Bruce, condolences
  23. #25503
    All is well and commiserations for the part of you that needs that ... it can certainly be a relief for all parties.
  24. #25504
    Another photo for Bruce.
    https://www.flickr.com/photos/dale_s...n/photostream/ You'll enjoy the album.
  25. #25505
    What a lovely photo!
    I expect there'll soon be little Scamplets running around!
  26. #25506
    Feb 2014
    Sunshine Coast, QLD
    I thought the same. They are rather a cute couple.
  27. #25507
    Yep, most certainly.
    Paperback E-book
  28. #25508
    Somebody built a half-scale SCAMP, I think as a tender for their SCAMP.
    I'm not the only looney one. Back home from a rowing camp. Millions of phone calls to make, things that have to be done. It was a bit of a drive coming across town on a hot Friday afternoon in peak hour traffic. I'm hopping into a bag of soft licorice and a beer, sort of a metaphor for my state of mind right now. Life gives me the schmidts, so i'm drinking a pale ale to make it better.
    Many thanks for the condolences and wishes. Joan was very special, and will be missed, but she was in dire straits at the end and nobody could/would do anything to help her leave. As usual she had to do it all for herself. That's a lot like what her life was like.
    Paperback E-book
  29. #25509
    Sorry to hear of Joan's departure Bruce. My sympathies.
  30. #25510
    Feb 2014
    Sunshine Coast, QLD
    I just finished a glue-up of a pair of deck beams. (I'm putting in a small bridge deck to make the replacing of the removed decking areas easier).
    They're 1.8m long curves, with about 40mm chord depth, each laminated in seven 12mm thicknesses of oregon.
    It's my first try at such a thing. Wish me strength for when I open the shed door in the morning for a look.
    It's the FIRST fabrication of new parts for Vamp! I feel like I've turned a corner.
  31. #25511
    That's great Matt, good to be constructing rather than deconstructing.
  32. #25512
    Oct 2007
    Sorry for your loss Bruce, but glad Joan's suffering is at an end too.
    Keep going on Romana and dedicate something on her to Joan.
    Finally sorted the trailer for TMP (mostly) and have a few things to tidy up, but all looking good for a relaunch on Sunday!
    Better call that Hill fellow too!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  33. #25513
    Good stuff Matt !
  34. #25514
    Just while I have access to my computer. here is the pimple effect
    And here is the dark filler on stained nail holes, and light filler on new wood.
    Not really happy with the finish, but not sure how to make it better. This is 5 coats. I sanded with the big floor sander, 24, then 80 then 120 then 240. Then applied 1 coat. The went over it all with a small random orbital with 80 then 120, recoated, random orbital 180. My feeling is that the CFP stays a bit soluble, and is soaking into the old dry timber, raising the grain. I have a bit less than half a tin left, enough for one more coat. Im inclined to leave it for now, and do that coat after a couple of other projects are done-new bifold doors and paint walls. Hopefully then the finish will be harder and it will gloss up a bit better.
  35. #25515
    Most attractive, Phil. Not sure what look you're after, but that's what your floor is. I like it.
    Paperback E-book
