Page 701 of 1441 FirstFirst ... 2016016516917007017027117518011201 ... LastLast
Results 24,501 to 24,535 of 50424
  1. #24501
    Tom, no borers. Underfloor insulation would be good, but a bit too hard. Larks, yes, water based. Have used the satin version before with good results. Going gloss this time.
  2. #24502
    Our floor is supposed to be Baltic pine. It's too far gone - the joists need to be levelled, the seams are too wide, there are lots of cuts etc., so we're replacing it with blackbutt. We'll run chipboard flooring under it for insulation. But before it's laid, I have to underpin one of the house's main supporting posts, so that's going to mean digging down to bedrock. I'm hoping that's not too far as it can only be done by hand through a hole in the floor. Our friend David did the last one while we were away and his wife had to hose him off in our yard at the end of each day as he was covered in mud. So, as I have to dig this one, he's hoping it's at least as deep as his.
    Blowing here! Been hot but cool now. Lovely sail last Saturday.
  3. #24503
    I'll be visiting soon Rick and I'm smaller than you and from a mining heritage .......
  4. #24504
    So, you think if we put you down there and throw in the occasional sandwich ..... ?
  5. #24505
    Reasonably happy ......
    A man's got to pay for his bed somehow.
  6. #24506
    In between visits to the tip, no more burning this summer, another winters wood 'volunteered', steering itself between the tree house, various fruit trees and the edge of the fern gully. And I cannot give away what I've got already!
    So now I have to be creative with a wood stack…………… grrrr!
  7. #24507
    Feb 2014
    Sunshine Coast, QLD
    Build a wooden wood shed to keep all this wood in.
  8. #24508
    I've docked up all or nearly all of the heads of those gums I felled and now my woodshed is very close to full, nothing by Jeff's standards, but a close stacked 7' x 7' x 6' and another small log to go.
  9. #24509
    How can a man whinge about too much firewood? You need help. Go see someone.
  10. #24510
    Hey Rick, what specifically would you use for filler in the very rusty dark stained nail holes? Some are quite big, maybe 1cm diameter.
  11. #24511
    I'd experiment in the corner of the room.
  12. #24512
    I have, it's 2.5x4.5x2.4m and it is FULL.
    And the bl00dy stuff is heavy too.
    Enough already.
  13. #24513
    Slightly weird, but interesting
  14. #24514
    Well if you want a perfect colour match you're going to have to try the filler with a smear of sealer over it, if it's not perfect you can drill it out and add a bit more pigment 'til you're happy with the result.
  15. #24515
    Perfect? I don't even know what that means. Hopefully Rick will chime in before morning. I guess I could run a whole bunch of tests of some sort of glue with charcoal, cow poo, black powder, mushroom compost, kids paint powder. But really I want it all done by about 11.00 so I can start knocking down walls to install the new bifold windows. Oh, had to take the kitchen out to do a decent job on the floors ,so there's another little job to do.
  16. #24516
    Phil, builders bog and either wood stain or cement oxide colouring
  17. #24517
    A minor pressure pump problem. I have a pressure pump under the cabin for showers and the thing has developed a slow leak around the the O ring seal that fits between the impeller housing and the motor half and every time the pressure drops the switch is activated and the pump comes on for a few seconds .... it is very annoying through the night over the last few days.
    Today I pulled it apart and cleaned the grooves for the O rings and reassembled it, it was good for perhaps 3 hours and then on it came, perhaps every 40 minutes ? I've bypassed the automatic switch tonight so we have peace but can anyone suggest a fix ? I've thought of bedding the O ring in silicon then reassembling but that sounds as if it could make an unrepairable mess too.
    Are there any compounds or methods you would suggest, short of a new pump.
  18. #24518
    About 180mm OD, how common is that ?
    and the O ring appears to be in good condition, not damaged or flattened .
  19. #24519
    Do you have a good layer of Vaseline or grease around the o-ring Peter? Definitely don't use silicon (unless it's silicon grease)
  20. #24520
    Use rubber grease on o-rings
    if you have it, if not vaseline..... .
  21. #24521
    You can buy sticks of wax which are used in furniture restoration. Bunnings have them and they come in many colours. Quite hard - you melt the stuff into place. Use a dark colour because light filler in a dark patch of wood looks really bad. Alternatively, use a dark wood filler but I think the wax looks good in an old floor.
  22. #24522
    Melbourne mostly, Australia
    Enough already.
    jeff(?) whereabouts are you? Is it hardwood, I might be Interested in a 8x5 trailerload
  23. #24523
    Thanks Rick, Bunnies here I come. Does varnish then go over that, or do you do the wax last? I'm assuming wax last.
  24. #24524
    Grantville, on the way to Phillip Island Andrew.
  25. #24525
    Jeff what sort of wood, slow burning stuff?
  26. #24526
    Thanks, I'll try to find some silicon grease although I have to admit the other type crossed my mind . Although I have made up gaskets out of silicon formed between sheets of cling wrap.
  27. #24527
    No, you just varnish over the wax. It's really just a filler.
  28. #24528
    A photo for Bruce .
  29. #24529
    New Zealand's Far North
    I have re-used Unobtainable O-rings with a smear of automotive gasket sealant used sparingly in the grooves the o-ring seats in.
    Tact is the ability to tell someone to go to hell and have them look forward to the journey.
    Winston Churchill.
  30. #24530
    Bay of Islands,N.Z.
    Re the flooring , I've used carbon black in epoxy to fill up the worm damage and nail holes before , hard work actually . A commercial guy I talked to once uses plaster tinted with the same , then sands it off easily in one hit. The plaster isn't under stress and you just poly over it. I would have done it myself , but I wanted to seal off a bathroom floor. I wanted the epoxy for a full seal.
  31. #24531
    That sounds hopeful, I even have the stuff in my workshop.
  32. #24532
    Thanks-I just thought varnish might not adhere to wax. Off to Bunnies shortly.
  33. #24533
    Hmm, carbon fibre bathroom floors.
  34. #24534
    Ive really got to focus at Bunnings. I need another 10 litres of CFP, and have to try to get furniture restorers wax. Not carbon fibre, not vaseline, not silicone grease, not gasket sealant. I do have some really filthy looking black tractor grease in the shed.....Good luck to me.
  35. #24535
    The wax sort of sinks a bit, so, with the varnish over it, it looks more like ancient build-up of varnish rather than filler. I should think any filler would do though; I just like the look of the wax. It's a patina thing ....
