Page 46 of 210 FirstFirst ... 364546475696146 ... LastLast
Results 2,251 to 2,300 of 10452
  1. #2251
    Default Re: Oz Connection
    Mine is the one on the left.
    No. 75 was designed for drilling small holes, up to about 1/4", and it will also drive small screws provided it is fitted with a tapered ended type brace bit with a screwdriver tip adapter. The model No. 75 was call a push brace, since it has a brace like chuck. Also, you can see it has an a concealed spiral shaft as it is fully extended. The spiral shaft and spiral mechanism is what makes the spiral system work, so when you push the handle in, the bit that is locked into the chuck turns in either the clockwise or counterclockwise motion depending on the setting of the slide switch on the side of the drill.
    In a World full of wonders, man invented boredom. (Terry Pratchett)
  2. #2252
    I have a small one Greg , you're welcome to it if you would like it . I'm a total convert to battery drivers now .
    I've given up on the battery drivers, too expensive to replace the batteries and they seem to die on me of I don't get enough consistent use out of them. I do use the drill and tech gun a lot but when I don't want the trouble of getting that out I reckon the yankee drivers would be very handy.
    Peter and Jeff, if you are serious about giving yours up I'd be very interested in buying them off you. The one that dad had was a large flat head, which would have been handy driving the bronze screws into my floors this arvo, but I could see myself using a couple of different sizes if I had them.
  3. #2253
    Quote Originally Posted by snow(Alan H) View Post
    Correct re the name - i bought this one (Stanley Yankee) on trademe 3 weeks ago for NZ$15
    Little ripper - can not understand why they no longer make them - power tools?
    That's it Alan.
  4. #2254
    Second and sixth from the left I think.
  5. #2255
    Mine is quite small and certainly wouldn't drive much of a screw ,a small 8g would do it I'd say. it has a hollow plastic handle to keep bits in so quite a nice design .Greg i have a brace with a few cunning adaptions for big screws , roof screws and batten screws .A universal hex tool mount brazed onto an old brace bit .It works beautifully and gives heap of slow speed torque.
    Greg with those 3" X 12 G bronze screws do you think it might be worth running in an identical steel screw to cut the thread first then backing it out to replace with the bronze one? Bronze is very easy to twist off if you really heave on it .
    Battery drills ? I reckon my 12v Makita might be my most used tool . A mate recently repacked the batteries with NiMH cells replacing the old NiCads .It SO much better and saved me buying a shiny new LiIon job !
    Perfect is the enemy of good.
  6. #2256
    Second from the right top with a chromed top on the handle.
  7. #2257
    I use an old hand brace with a screwdriver bit for big stuff. I haven't used the Driver for so long I forgot I had it! Greg if it's working OK you can have it for the mailing costs.
  8. #2258
    Thanks Jeff, that'd be wonderful!!
    Peter, bloody good idea re pre screwing those things. I had a couple today that I was getting a bit worried about, I'd torque them up with a spanner on my screw driver shaft (square shaft) then leave them for ten minutes to cool down, back them off a few turns and then have at it again. Those that I've done so far went in OK eventually but I did worry that I'd snap one off.
  9. #2259
    Oct 2007
    I'm back and Looe is mostly in the shed now. There were a few little dramas that pushed the stress levels up a tad, but the deed is done, and we're all very happy! I feel a little bit like a stunned mullet right now, but hot food is going down a treat, as is my third beer! I'll start a new thread up in B&R and post a few of the same tales and shots here, but that won't happen until tomorrow. If I feel up to it I'll get one up here shortly, before I fall over.
    A very, very big thank you to Rick and Tracy for being enormously generous and gracious last minute hosts when we knew we weren't going to make it all the way up to Sawtell to lob at my mate's place there.
    Rick's report is very good, but I'll add more:
    The shape's good. The rudder's missing - I think. The rudder tube etc. doesn't look too good. Several frames are shot. Iron keel bolts look shot but it's not always easy to tell. I think the ballast needs to come off anyway. A few floors are shot. The ply deck is mostly okay but you'd want to renew that anyway. Nearly all the planking looks really good. Certainly has great potential I reckon but I don't think you could just patch it up and put it back in. It does need substantial work but with that, I reckon it could be a really fantastic boat.
    The rudder we have but it was hanging from lower pintle and gudgeon when it was pulled and the tangs that come off the rudder post were both sheared. We have a box of winches, some self tailing and a couple of bronze ones (non-ST) where you can fit the handle on the top or bottom. The ones on the boat you fit the handles on the bottom. There were about five sails in bags in the forepeak when the boat was pulled, so when it's a sunnier up here I'll hang them out to dry and see what we have and what condition they're in. The boat is not hogged at all: The shear is just about perfect and very easy on the eye. There's a bit of rot around the topside planks at the transom and a few other little soft spots. We're going to sit down next weekend and start drawing up a restoration plan, including a needs list, listing out what's been spent by whom and hour many hours have been spent and continue this through the whole restoration process.
    We'll use the roof beams, truck straps and blocks and chains to hoist Looe off the trailer on Saturday and make some stands from some of the slash pine I have, once the stacks have been rearranged and re-stacked off to one side. I've taken some shots of Rick's jack-stands-from acrows and we'll make up seven or eight of those to replace the slash pine stands. The ballast keel will be dropped using trolley jacks with a channel welded to take the shape of the foot. Details... Details...
    I'm munted, but happy!
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  10. #2260
    Lovely Duncan, Lovely
  11. #2261
    Well done Duncan and Simon! Glad to hear Looe's home in the shed and hosed!
  12. #2262
    Oct 2006
    Dooral Dooral, Eastern Oz
    Congratulations Duncan.
    Fun, isn't it?
    Peter... I snorkelled with Manta Rays off Komodo Island... a few kays off actually. They are amazing. One looped underneath us when we were following it... came up behind us then. Feeding behaviour I believe. There's a photo or two in my thread.
  13. #2263
    Oct 2006
    Fun, isn't it?
  14. #2264
    Munted???
  15. #2265
    Oct 2007
    Here you go! In the shed with munted Dunc!
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  16. #2266
    Congratulations Duncan !!!! Well done ...she is lovely !!
  17. #2267
    Oct 2007
    Here's a good profile view from this morning at Rick's:
    With boaty chaps in front:
    And one in front of Rick's Twister for good measure:
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  18. #2268
    Greg ... to make the driving of a big steel screw easy how about Migging a nut to the top so you could use a ratchet socket to wind it in ?
    Ian ..I'm jealous mate .I'd love to dive with mantas , they are simply glorious !
  19. #2269
    Apr 2011
    Brisbane, Australia
    and she fits!!!! terrific..see my post above! cheers
    John
  20. #2270
    Jan 2007
    Ah , so you had a tray Triton to tow with , how did it go ?.
    I'll bet you are relived to have the boat home.
    Well done.
    Rob J.
  21. #2271
    Or I could get all chippy and use my tech' gun and a batten screw.......but that'd probably just keep going through...I like your idea better.
    Congratulations Duncan, she's a nice fit in the shed there.
  22. #2272
    Oct 2007
    Thanks for the compliments guys! The Triton was great Rob, but we had a trouble going down. New truck under warranty so the Narrabeen Mitsubishi dealer looked at it straight away and a turbo hose was disconnected. Hooked back up and the beast was reborn. Not only that, the cruise control worked then as well! The cruise cut out a few times going up some of the steeper hills so a bit of manual throttle helped it along, but otherwise it didn't miss a beat. I was expecting a couple of wobbles to happen a few times, maybe lose traction on the rears with all that weight in the trailer. Never happened.
    I am relieved!
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  23. #2273
    Are a batten screw and a bronze 12g the same thread pitch Greg ? If so go for it .
  24. #2274
    Apr 2011
    Brisbane, Australia
    So are we!!!!!
  25. #2275
    Wet roads, new ute , very long load ...worried ? Us ? Just a little .
  26. #2276
    Congrats Duncan, you're looking just a tad happy mate.
  27. #2277
    South Australia and Tasmania and Papua New Guinea again
    Munted? is that when your belly button starts to leak? Boat looks good-they are a classic arent they?
  28. #2278
    A Kiwi word I believe meaning r**ted.
  29. #2279
    Mar 2008
    Devonport, Auckland NZ
    Correct
    "Old boats are like teenage girlfriends: there is a certain urgency to their needs & one neglects them at one's peril"
  30. #2280
    Jan 2007
    Duncan , funny that the dealer knew where to look !.
    After my first service , I had that problem , has that ute just had its first 5,000 km service ?.
    You would have less trouble with sway than a tub ute , because the tow ball is closer to the axle on a c/c than the tub utes.
    But it did the job , thats the main thing.
    Regards Rob J.
  31. #2281
    Well it just cost me $60 to turn and exhaust hose though 90 degrees. Made me realise that i could have saved a few bucks by using a smaller ID hose. I think mine is a bit overkill.
  32. #2282
    Jan 2007
    I've just visited Garry Stewart , the ships boat is progressing nicely .
    He also gave me a lend of a monster book "Traditional boats of Ireland" , it looks like a good read.
    Rob J.
  33. #2283
    Sydney Australia
    Congrats Duncan, a good day for you and a good day for me - the oncologist has promoted me from 3-month checks with CT scans to 6-month checks without scans. Owning two boats is looking feasible again.
    Arguably, as the initiator of this latest exploit of yours I really hope it turns out well.
    Chris.
  34. #2284
    Excellent news Chris - a great day indeed!
  35. #2285
    That is good news. I have a couple of employees up here who, given the state of the state, are in the process of hearing the news that they have cancer and it is way too far gone to do anything about it.
  36. #2286
    I 2nd or is it 3rd'd the good news Chris.
    My upholstery foam is ordered, I pick it up on Friday. Sadly I have to go North of the Gateway to get it. To Geebung.
  37. #2287
    Chris.
    Well done Chris ...very good news !
  38. #2288
    Oct 2007
    Brilliant news Chris! I look forward to hosting you aboard Looe!
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  39. #2289
    Oct 2006
    Superb news Chris. Must be time we had a beer again? I'm booked out for the next month... but what say a WBA Meeting EBS in April?
  40. #2290
    Apr 2011
    Brisbane, Australia
    Okay Duncan, how do we pronounce it properly, and what's it mean? The Cornish town? Still don't know how to pronounce it.
  41. #2291
    It's Looe the flyer
  42. #2292
    That is great news Chris, a load off your mind as well as some freeing up of time to find more cheap Dragons....
  43. #2293
    Oct 2007
    The builder of the yacht was born in Looe (Cornwall). I've got a few shots of Looe from the 1970s as well, but here's a little bit of Looe the town:
    Ship Happens!
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  44. #2294
    Oct 2006
    Water everywhere here... at 2,000 metres... and not a Wooden Boat in sight. Ian hasn't even put his bum on his motorcycle. I might stay put today and do some WOODEN BOAT photos up for my travel thread. I'm thinking it needs a few more Wooden Boats in it before I move it into People and Places or Misc Boating Related.
  45. #2295
    Iwas just about to post a bit of a "ramble" on income hunting and a relationship to the advancement of my WOODEN BOAT restoration, but came on here and realised that there are far more important issues to address:
    DUNCAN!!! Where's your thread on Looe and the trip up from Sydney? Shake a leg sunshine, you've been back for two days now!!
  46. #2296
    Oct 2006
    Dunc's still munted
  47. #2297
    Jan 2007
    Well , I have just taken a WOODEN BOAT out !.
    I'm really sore from arthritis , but its a beautiful day , so I thought stuff it , I'm going out.
    As I came around the north shore I was surprised at the hight of the swell , it was well up , but it was very regular , on a low tide.
    When I got down to the beach , I got talking to a couple of women in a mobile home there , and invited them out trolling.
    One got sea sick and didn't come , the other took me up on it.
    I still didn't try sailing , she had no experience , and I was just too sore.
    And we didn't catch a bloody thing .
    But we had some fun with the waves.
    The town reef , and out from it was awesome , huge waves breaking well out before it.
    We stayed well away from there , but still managed to do some surfing , on HS.
    Coming in , we had to wait for a big woodchip ship , and the tugs and pilot boat to go out , and I though it best to stay clear of the big cat supplying the oil rig coming in , but it was good to be out on the water again.
    The woman enjoyed it too , and was impressed with "my little WOODEN boat".
    Rob J.
  48. #2298
    You rascal Rob, out crusing for chicks eh??
  49. #2299
    Rob J.
    You sure it was the swell rocking the boat?
  50. #2300
    Jan 2007
    Its the boat thats the magnet , not me !.
    Its good to have company , and she was good company.
    Regards Rob J.
