Page 449 of 1416 FirstFirst ... 349399439448449450459499549949 ... LastLast
Results 15,681 to 15,715 of 49539
  1. #15681
    Quote Originally Posted by suzyj View Post
    Is it really worth double the cost to buy AS2272 hoop pine ply, plus freight to Geraldton, when the local Bunnings has BS1088 marine ply of heaven knows what source...
    Ditto for timber for really everything else. Bunnings has western red cedar and it's cheap, and doesn't necessitate freight from Perth.
    Hi Suzy, The Bunnings marine ply seems to vary quite a bit in quality and, as mentioned, it depends on what you want it for. I certainly wouldn't use it for any hull or hull planking, but for interior fit out it'd be fine I used some recently and it was very splintery so was difficult to cut without getting a whole lot of chipping along the edges, the only way to "partially" avoid it was to cut the line with a sharp blade first. It did also have more voids than you want on a boat build. And as Duncan said, don't go the exterior grade ply for anything that will get wet, again OK for fit out .
  2. #15682
    Jun 2012
    Quote Originally Posted by HS View Post
    Eeeek, no flames! Peter, has your mate exhibited any behavioural changes since he burnt the antifouling off? I wonder what he took in thru all that exposed skin.
    I'll be taking the boat home in spring so that I can work undercover at any time and leave all my tools laying around at the ready...something you can't do in more public places. I will speak to the club's resident master boat builder re the implications of flipping a 60 yo boat. I know how much more convienient it is to have 'em hull up, we once built a TS-16 flipper that plugged into the bow and transom fittings and allowed the hull to be spun single handed.
    i'm with you Hans on flames; never worked well for me but that could be technique, or lack of it. And fire scares me anywhere near wood :-0. Re the query about flipping, my take would be that if I didn't feel comfortable flipping it I sure wouldn't be going to sea in it :-(. The TS16 flipper was a brill idea by the way; never heard of that but would be very popular among racers. Have you got any pics or plans showing details?
  3. #15683
    I've been using those tungsten scrapers for over 20 years, and they're really good. But the Bahco, 2-handed one I mentioned above is much better for big surfaces. It also uses replaceable tungsten (I think it's tungsten) blades. Worth checking out. I also agree with Mitziel - if at all possible, I'd be tipping the boat over, as I really hate doing this kind of work overhead. Even Pipsqueak's lower planks are a right PITA. But, of course, it depends on the boat .....
    Peter, the heat gun wouldn't touch Pipsqueak's antifoul, or the Twister's. I wouldm't use a burner on any hull that wasn't hardwood either, especially a clinker hull. I think it'd be pretty much impossible to avoid burning the edges.
    Thanks for all your suggestions...I'm off to check out those Bahco scrapers.
    Hans
    No behavioural changes ! Perhaps the antifoul he uses is heat sensitive but the idea is to heat the paint , not the wood. His planking is white beech and it has no burn marks . We both have a lot of practice at this having burned the paint off a few houses. Wooding a couple of hundred square metres of house is good practice.
    To each his own.
  4. #15684
    I think you may be right Hans, there can be a huge difference in how well various types of paint respond to heat, on the house I mentioned before the 70 year old oil based enamel came off easily but some sections of modern "latex" ? were a right pain in the bottom.
    A remote air supply is an absolute must for any nasty ,fumy, dusty work.
  5. #15685
    Oct 2007
    Hans, I reckon if you hit any patches that are tough to remove, based upon your objectives for the exercise in the first place, I wouldn't worry about trying to be super thorough in getting back to bare timber... Unless you're worried about what the fish will think, or you intend to use a hard (self-polishing) antifoul like Micron Extra.
    Jarndyce and Jarndyce
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  6. #15686
    That makes good sense Duncan but, unfortunately, the layers of 'good' AF build up and the hull starts to get too lumpy, which then causes further problems. Really, the smoother the better. Clinker hulls are the worst really, as the shape is popular with all sorts of critters anyway.
    Peter, clinker is much harder to clean up with a heat gun, let alone, a flame gun. The edges of the planks burn really easily. I've done all my topsides with the heat gun and even though I'm a bloody world champion heat gun hand, I still get the occasional scorched edge. AF needs a lot more heat - I really don't think you could get AF off a clinker hull with a burner without doing a lot of damage to the plank edges.
    That Micron AF that Duncan mentioned is really good stuff. Our neighbour gets a couple of years on his glass boat. I think being able to use that quality of AF is reason enough to sheathe a wooden boat. I know we've talked about it a lot already but I really would like to sheathe Pipsqueak - I just don't think it's feasible though.
  7. #15687
    Rick ,agreed ,a clinker would be a pain but I think I'd be using a metal mask against the square edge.
  8. #15688
    Adelaide, South Australia
    one of my weekend days today. I'm now working 3 day weeks, 4 day weekends.
    Helped a mate put up a gutter on his house in the morning, and it went so well we had hours and hours left, so we went sailing. Sorted a few things out with Nanjera's outboard, sailed along at about 4.5 knots upwind in 5 - 8, and downwind at around 5 - 6 in 10 - 12 on a very broad reach, almost running. Now everything's put away and I'm into a beer. Blissful.
  9. #15689
    We've had rain ! It seems to be over now .... well maybe a little more will arrive yet but we had 165 mm over the last 24 hours and about 250 over the last 4 days . Wonderfully welcome and the dam is now full and overflowing ! Happy, happy .
  10. #15690
    Sailing on one of the old 18s tomorrow. Should be fun! Hope it's windy .....
  11. #15691
    Rain eh?. About 23 mm since christmas here.
  12. #15692
    Oct 2001
    Canberra
    That much in the last day here. Most unlike Canberra, which at the moment is looking more and more like Melbourne....
    (Not that I don't like Melbourne, mind. It's just that Canberra is sunnier.)
    Mike
  13. #15693
    Oct 2007
    Apparently the flood/weather telemetry gauge 700 metres down the road got 314mm overnight. I was stuck all day.
    Oh well...
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  14. #15694
    Quote Originally Posted by Wooden Boat Fittings View Post
    Mike
    Canberra is looking increasingly gloomy.
    Oops, wrong thread...
  15. #15695
    Jeepers, you guys complain about not getting rain, then you get a much in a day as Largs gets in a year. It's a funny country.
    Wooden boat.
    I'm looking for a crew to sail Nanjera with me today and tomorrow. Light wind and fishing in the morning, 10 - 15 knots SW when the tide turns after a picnic lunch on board for a bit of a bash and splash, home for dinner, or a twilight cruise along the beaches if not sick of the sea by then. Sheila is crook with flu so I can't drag her out, however she has considerably shifted her ground about not sailing ever again
  16. #15696
    Bruce I'd be there, except we have 60 people coming to our place for an Earth Hour dinner tonight, and I have to pick up one of my cars from the airport in the middle of tomorrow.
  17. #15697
    I'll save you a seat for the future Phil.
  18. #15698
    Oh well...
    That's interesting Duncan... I just had a look at my rain gauge and it overflows at 170 mm so the 165 mm I quoted was probably completely full and splashing out, so who knows what we got .
  19. #15699
    Jeepers! There can't be any wind where they sail!!
  20. #15700
    Today, out of the blue, I made a mast ram for a cherub.
  21. #15701
    I dont even know what that means!
  22. #15702
    Me neither! Yesterday I coodunt evun spel mast ram enguneer, now I are wun!
    It's an adjustable brace between the foredeck to a point a little bit above deck height on the mast, that allows some mast bend to be induced, to enable the crew to power up or de-power the mainsail. Bend forward = tighten the leech and vice versa. I think. Someone who actually knows will cerreck me. I juss make 'em.
  23. #15703
  24. #15704
    Apr 2011
    Brisbane, Australia
    I thought he meant a sheep that runs between the main block and the goose's neck.
  25. #15705
    That would be the main sheep
  26. #15706
  27. #15707
    Had a few hours crewing on someone else's Paper Tiger on out of Rye today. New boat for him and he'd never sailed anything bigger than a Sabot. Light winds, so he had time to get the process sorted. Did a forced part capsize before we went in just so he could see what will inevitably be in store. Getting out the sea kayak tomorrow. I've got a bit of boating time as we seem to have reached a point of hiatus in the garden at present, it'll all start up again when winter hits.
    Mastram??
    https://www.youtube.com/watch?v=LBBgv0N3Vck
  28. #15708
    Define "need"
  29. #15709
    I thought someone needed one but couldn't remember who .Tasmania might be convenient for you Phil.
  30. #15710
    A new build coming up, I paid for the ply for my tender yesterday. Should have it next Thursday.
    I took a chance with the weather this morning and did a bit of sanding and varnishing. I have a feeling I may end up slapping a bit of paint on some of it before long...oh and wiping mould off the cabin top. It doesn't pay to stay away from the boat too long.
  31. #15711
    That Nutshell looks great! It would cost close to that price to build one. I have the plans for one.
  32. #15712
    went sailing with daughter and son-outlaw. No wind. Made around 2 knots average. Caught no fish. Somehow managed to have a fantastic day on the water
    AND WE SAILED WITH A SCAMP
  33. #15713
    Gold Coast Australia
    Define "need"
    Good looking and Sexy with nice curves and a shapely transom , besides being useful she also present's as a desirable model.
  34. #15714
    Yep-I have looked at one or two for sale here, and have plans for one too. Need, hmmmm...
  35. #15715
    If that was a fair working definition of need I'd be divorced, many times over!
