Page 330 of 1424 FirstFirst ... 2302803203293303313403804308301330 ... LastLast
Results 11,516 to 11,550 of 49821
  1. #11516
    Yes, that's the problem, it's very hard to be sure and essentially your life depends on what's under 150mm of immovable concrete and of course the stuff needs to be absolutely tight onto the timber or you'll get fresh water down there and a right little swamp.
    Pass.
  2. #11517
    My absolute favourite boat in the world at the moment is a concrete boat, as it happens. But I guess thats not the same is it.
  3. #11518
    No problem, there's no wood under the concrete ... just more concrete.
  4. #11519
    Whoa, hang on there! You're not getting away with THAT without an explanation! What boat and ....... why?
  5. #11520
    She's an Adelaide boat, was owned by a well known Adelaide yachtsman with zillions of Sydney Hobarts under his keel. She was his retirement boat. NZ designed and built-I hear they do boats fairly well over there. I've lusted after her for a while-I actually thought she was strip planked and glassed until I saw her advertised for sale. Looking at her you'd say there is no way in the world that she's concrete. She's quite big. I reckon there's nothing better than mass to make a sea voyage comfortable. The asking price is a little out of my range. Well a lot really. But a concrete boat, in this market. Seriously? I actually made an offer just for fun, which was rejected. I said thats fine, let me know if that changes.
  6. #11521
    Looks rather nice, 'make a very comfortable live aboard cruising boat
    I'm not surprised:
    . HULL IS PLASTICISED FERRO CEMENT ENCAPSULATED IN FIBRE GLASS
    I don't know much (anything) about this method of construction but it would seem to overcome many of the (perceived) problems with ferro while maintaining the benefits
    or...has the ferro been encapsulated in FG recently to save it? "REFURBISHMENT DURING THE PAST 4 YEARS, INCLUDING A MAJOR HULL RESTORATION"
    might be priced to try and recover the expense of that
  7. #11522
    Adelaide, South Australia
    To continue this off-topicness, one of Adelaide's old boaties died very recently. He had a project boat on the go based on a biggish ferro hull, well made, which he took on after the original builder died having made the hull. Our chap did masses of work on fitting her out before he too passed away. If anyone is not superstitious this one will soon come onto the market, probably cheaply, with not much more to be done to complete her and reap the rewards of two fine boat builders' labours of love. Let me know if you want me to find out more.
  8. #11523
    continued from the Boomerang Challenge ,
    RodB's original boat.
    and sans deck and cabin, this is an improvement !
    As I said previously, food for thought..... but where do you find rotted glass boats with decent hulls ? edit to add GOOD hulls .
  9. #11524
    Apr 2011
    Brisbane, Australia
    Peter, this is my experience of owning the Hood. Many boats built back around the 60s (which is also when a lot of very nice hulls were designed) were well built with much heavier glass, and again, many of them, including the Hood, were not prone to osmosis to any significant degree.
    They were from the era of boats recently converted from wood designs, with modern efficiencies.
    But they often had a problem. Their decks were two skins of fibreglass over ply or foam, so you got a moulded interior and exterior, not like the modern gelcoat numbers. Of course, with through deck fittings, most of them, thirty years down the track, get very spongy decks. Their hulls however are almost as good as new. Of course, they are not worth much now, because such decks are a total pain to stiffen. Unless of course you want to pull it off and build in wood.
    That's why I keep looking at a lot of these mooring minders and similar.
    Edit: of course you have what I don't have and envy you for..a nice big yard/shed...unless I did it up at Poona.
  10. #11525
    We have a friend with a big cement boat - Illywhacker. Lives at Kettering now. It's cruised extensively, including Alaska and the Japanese inland sea. I sailed on it to Sydney. A very comfortable boat but wallows a bit. Cement boats have a bad name as so many bad, home- built ones were done on the cheap.
  11. #11526
    Our little 2.5 kva genny is seriously ill...burns oil and large amounts of blue smoke. So I had a look on Ebay and found this.
    http://www.ebay.com.au/itm/DIESEL-GE...item20be03418e
    All I have to do is sell the ute.
  12. #11527
    15 years or so ago I had a big old trimaran, which is probably still rattling around the Port somewhere. The guy I bought her from had moved up to a big steel boat. Then I got my first job in PNG. We came back for a holiday, I went to check on the tri, which was on the marina down at North Arm. Stopped in to say G'day to the guy I bought it from. His boat was looking a little dejected, which was odd as he lived aboard. I asked around. Turned out he'd been down to KI, got on the piss, as he was wont to do, and ended up in the drink with the inevitable sad result. On hearing this i immediately thought "That probably means I can buy Vulcan cheap". Call me a softy. And thats what happened-so quickly I didn't even have time to tell felicity before it was a done deal.
  13. #11528
    Peter the thing about the Dun/Compass, apart from just being solid and seaworthy, is that they are quite narrow-which is pretty handy if you want to put it on truck and take it home every year. They might even be just on the magic 8', I'm not sure. No flags, no permits. Just Load N Go.
  14. #11529
    Quote Originally Posted by johnno View Post
    This is what I envisage if I went this way, a complete strip back to a hull and a new ply deck and cabin structure. As I said earlier the thing I find most unattractive in fiberglass boats is the interior and in particular ... carpet! This of course is a gross generalisation and some of the larger and more expensive glass boats are beautifully finished but not usually in the range I can afford or imagine sailing, from a size point of view.
    Could someone offer a bit of advice on the dreaded osmosis? That is certainly something I hope to avoid, it appears to be the primary reason to avoid glass. What do you look for ?
  15. #11530
    Look for bubbles. Grind them off. Fill the holes. Roll on some epoxy over the whole boat. Compared to what you have in mind doing its a doddle. Personally I'd put up with the carpet and go sailing.
  16. #11531
    Have a look at the interior of this one peter-no carpet to speak of. if you really wanted you could line the cabin roof with timber, but I suspect that would look a bit tacky. http://yachthub.com/list/yachts-for-...nson-29/128367
    OK-Declaration of interest-I've really wanted a Dunc 29 since I was about 12.
  17. #11532
    I can see why, very nice except for the inside of the cabin structure forward.
  18. #11533
    Osmosis is massively overrated. The theory was that once moisture got in, it would wick along the glass fibres and collapse the structure. But it didn't. As Phil says, look for blisters - if there are a whole lot, then don't buy it. If only a few, maybe okay. More important to look at keel integrity and quality of bulkhead fixing and positioning. Try to find a moulded keel.
  19. #11534
    This is answering my osmosis questions .http://www.nautica.it/info/maint/osmosi_e.htm
  20. #11535
    That looks like a very good deal!!
  21. #11536
    Oh very nice!!!
  22. #11537
    Don't forget you have to load a diesel up to about half output Gary, a smaller unit might be better for your use?
    http://www.ebay.com.au/itm/5-KVA-Sin...e7070a6&_uhb=1
  23. #11538
    Equally nice Peter. I started the genny this morning and it blew a mass of blue smoke and then settled down to just being rather noxious. I think it will hang in for a bit longer. Just let me get past getting the new car and fingers crossed the outboard for Redwing.
  24. #11539
  25. #11540
    Thanks Greg I've bookmarked that one.
    Just finished part 2 of the Redwing story and sent it to my editor daughter to caste her eye over. I've also sent and email to CH to see if they might be interested in publishing a version of the story. Looking for ways to make some $$ that don't involve shovels or lifting rocks.
  26. #11541
    I'll buy a copy!
  27. #11542
    Another author amongst us!! And I thought the days of men of letters was passed
  28. #11543
    Me too!
    Okay, here's a way to get this thread back to boats - call it a segue!
    Background: Rick knows sfa about things with motors in them. Also prone to dropping things in the water.
    I'm thinking of buying a generator so that I can run power tools out on the boat/s. Sanders, grinders, vacuum cleaner - that's about all, I think. What should I buy and why?
    Grateful for any suggestions!
  29. #11544
    This is something that I've been thinking about for the H28 for cruising, ie having a decent onboard genset that won't drive me and everyone else up the wall with noise. They seem to be getting better by the year so I've not researched the new diesel whisper gen's yet, (which I'd prefer but which I'm planning to look at closer to when I might want one) but my first thoughts, if you can afford one, would be to look at a Honda "super quiet": http://powerequipment.honda.com/gene...iet-generators or a Yamaha whisper: http://www.ncpw.com/process/catalogu...ategoryId=5273
    quiet and good stable power frequency so that you could use it on the boat for anything else as well while cruising (TV, microwave, kettle etc)
    Having had to "kick start" a 75hp engine at sea before due to dead batteries, I've always since had in my mind that I'd invest in a genset for my H28 or any other larger boat that I might end up with. I also like the flexibility that it offers of being able to add a few comforts like a small microwave and entertainment system.
  30. #11545
    Masina's Bukh 24 has a crank handle! One day I'm going to see how `easy' it is to use. I'm not confident!
  31. #11546
    Over $2000? Yikes!!
  32. #11547
    I had to create a rip cord ...... and be very careful, prior to that we'd tried to charge the battery by setting up an outboard motor with a belt to try and spin it (we had plenty of time on our hands and no reason to not try).....I had been looking at ways to pull start it by throwing the boom over but in the end I was actually able to pull start it by using the tiny bit of charge that we'd been able to create with the outboard to decompress the engine while I took a really big pull (and avoided wrapping the cord around my hands/fingers.... )
  33. #11548
    Over $2000? Yikes!!
    Which one? I'm seeing 1150.00ish for the Honda - still yikes but not so loud
  34. #11549
    That was the Yamaha. $1150 sounds much better! I wonder if an inverter connected to our engine would be capable of running the tools? I haven't looked at this at all but maybe I should.
  35. #11550
    No reason why it shouldn't, but from what I gather it'd cost just about as much to set up as it would to buy a decent genset. I haven't looked at it myself but have discussed it with one of the guys who used to be here here, who is an electrical engineer and went through the process for a 40'er that he built himself. He ended up choosing a genset (can't remember which type) and building a "soundproof" box for it in the lazarette. I don't know how quiet he was able to make it but he seemed happy with it.
