Page 1389 of 1447 FirstFirst ... 38988912891339137913881389139013991439 ... LastLast
Results 48,581 to 48,615 of 50625
  1. #48581
    I thought I had some but I must have used it. I'll keep an eye out for some locally, Bruce.
  2. #48582
    Back syphoning is something I have thought about. The wet exhaust outlet is above the waterline. The sink and manual bilge pump are well above the waterline so that only leaves the electric bilge pump. My thoughts there were either loop the hose high, fit a non return valve or some form of syphoning breaker.
    KISS
  3. #48583
    KISS
    Indubitably.
    The only one that might back siphon would be the electric but if I loop the hose high under the deck it won't be able to.
  4. #48584
    Today I tried KISS to connect my new fuel tank but only managed the last S. I already had the new fuel line set up to go and all I had to do was undo the old line and put on the new one. But, of course, I muddled up which was what and cut the new fuel line so that it would be the right length to connect to ..... the return outlet! What a FWIT! So now the new line is short and already pinned down nicely with saddles etc. so not only would I need a new line but I'd also need to undo all the saddles, cable ties and brackets it goes through. However, all is not lost! I now intend to install a valve just below the engine fuel inlet, which makes sense anyway, as a safety measure, so the shortened line may prove to be a good move after all.
  5. #48585
    Good save
  6. #48586
    Indubitably.
    Was it Peter whose signature here was along the lines that you can't teach what someone doesn't want to know?
  7. #48587
    I mean lets just say your bilge outlet gets blocked. Oh sh!t, thats the only outlet.
    Lets say one bilge pump is running, and the other has a failed/blocked non return valve. Oh bugger.
    Probably wont happen hey.
  8. #48588
    Good save
    God did it to stop the flow of awful things I was saying about His Son and myself.
  9. #48589
    I have a bucket.
  10. #48590
    You ain't going to learn what you don't want to know.
    If one of the bilge pumps blocks it's going to be at the inlet strum box. The outlet is 40mm diameter.
  11. #48591
    You have a different God than me.
  12. #48592
    Hold my beer and watch this....he said. I'm 99% sure I know what I am doing.
  13. #48593
    Speaking of boats, I picked up 8 used solar panels for $200 yesterday. 2 for the boat. A couple for the paddock bar, a couple for my sons camper van. A couple spare.
  14. #48594
    What voltage? I have 6 X 48 volt I plan to do something with sometime. And I was offered 6 x 36v for $40 last week.
  15. #48595
    Watt did you mean?
  16. #48596
    I've got a spare panel, i keep meaning to do a project with my older son - make his bedroom passive, convert it to 12v. We have a few small 12v deep cycle batteries (from house alarm systems i think) that we picked up here and there.
    I also have a very old wind generator.........
  17. #48597
    Fart
  18. #48598
    Can't remember. I think if you connect them to a mppt charger the output is 12, or 14.8 or whatever the charger thinks the battery needs. Tell me I'm right?
  19. #48599
    An MPPT regulator will give you 12v or 24v.
  20. #48600
    Cheers
  21. #48601
    I think the media is saying all kiwis are required to self isolate within 48 hours. Presumably the same here by next Monday. Double up your mooring lines.
  22. #48602
    The Mt Warning Hotel was giving away free beer right up until the shutdown...and I didn't know about.
    They had to empty the barrels apparently.
  23. #48603
    Last 'outing' tomorrow, delivering a 2nd hand fridge.
    This job is usualy done by a volunteer who is in quarantine after testing positive after a cruise.
  24. #48604
    Success!
    Fuel flows.
    Lean and nosey like a ferret
  25. #48605
    Mar 2016
    Newcastle NSW, Australia
    Hi Rick,
    Managed to find 2lts of metho this morning
    Bruce
  26. #48606
    Don't drink it all until I get there!
    That's good! Do you need any more than that?
  27. #48607
    Went for a wander around the paddock and collected 3 x 25 litre buckets of well rotted cow manure. Some of which had gold top mushrooms...I ignored them. So I now have one long raised garden bed ready for planting and a concrete tub. Also have half a 44 with Kipfler potatoes planted. My vege seedings are looking good but they won't be big enough to plant out for a week or so.
  28. #48608
    Well done Rick. And Bruce. And Gary.
  29. #48609
    During the war they were called Victory Gardens...not sure if Virus Gardens has the same ring to it.
  30. #48610
    Mar 2016
    2lts will do us for about 5 to 6 weeks as preheating. I did find a small butane gas blow torch that we could use.
    Bruce
  31. #48611
    Bay of Islands,N.Z.
    Midnight tonight. You can travel for food etc. I'll be going to check on the boat, do something on it if weather permits.
    Otherwise it'll be cutting nuisance trees and generally tidying up stuff at the house and surrounds. Dig out that ginger (noxious weed).
    Maybe I should go fishing.
  32. #48612
    Make ginger beer.
  33. #48613
    Probably a very bad idea: https://images.app.goo.gl/QoogUTsa1PkSBNq68
  34. #48614
    Bay of Islands,N.Z.
    Noooo, I mean from the dinghy or the boat, that's isolated.
  35. #48615
    What? You mean not all Kiwis form a crowd along river banks to go fishing!!!?
    Going out fishing on your own in a little boat at present sounds wonderful to me right now!
