Page 1376 of 1376 FirstFirst ... 37687612761326136613751376
Results 48,126 to 48,146 of 48146
  1. #48126
    Okay boat content: I have an annoying leak around the mast.
  2. #48127
    I'm getting along OK fitting cleats and fairleads and jib tracks. But you know how in your head you measure and line up and drill and check and then slather parts with butyl tape and butyl In a tube and duralac, and just slot the bits together? And in real life the holes don't quite line up? Im getting a lot of that. And I just noticed someone obviously needed 2 of my fenders more than I do, even though I paid for them. They were tied securely on the berth. One was a really handy ladder fender. Bumner. I hope they put them to good use. Maybe as life preservers when their sh!tty little tinnie flips out at sea.
  3. #48128
    I hate thieves.
    Phil, a tip on lining up hardware fittings. Make up a block at home, about 30 mm thick and mark the hole positions using the hardware item. Then drill the holes using a drill press. Back at the boat, use the block template to drill straight, correctly spaced holes.
  4. #48129
    How is it sealed?
  5. #48130
    I've always reckoned they can't be using a very good iron if the roofing comes out corrugated.
  6. #48131
    I hate thieves.
    Great idea thanks. I'll do that for the stanchion bases. The problem is where I have holes already in the beam shelf or a deck beam and I'm drilling up through that, through the new deck, and hoping the new hole will line up with the holes, or in some cases bolts, in the relevant deck fittings. They should, but often they don't. Close, but 4 or 5 mm error in a 10mm hole leads to some dissapointment.
  7. #48132
    How is it sealed?
    I don't think it is.
  8. #48133
    I've had that happen. I found it happened when I was reluctant to use a bigger drill, so I'd use a smaller one and found I'd drilled a crooked hole. If you use a drill that fits snugly into the hole, then it's more likely to come out somewhere near where you want it to appear.
    If you have fittings where you just have, say, one hole in a beam, you can always just drill one hole with the snug drill from below then mark the other holes using the fitting, then drill from above. It doesn't really matter if you end up with an extra hole underneath as it can be filled.
  9. #48134
    How is it not sealed?
  10. #48135
    I wonder whether it's a good thing or a bad thing that we no longer need to use Air Mail for these conversations?
  11. #48136
    It was, if is not raining in morning I'll have a closer look topside, it appears to be one of the through bolts holding the collar down.
  12. #48137
    I'm tempted just to shift everything to a new spot and ignore the old holes. But it's too late for that really. I've done most of them fairly badly now. Davits and stanchions will possibly be easier. All new holes for them I think. The pulpit will be a nightmare. Difficult access. And no flexibility on position.
    I've been using same size or tiny bit bigger drills, so it's not that.
    Bloody frustrating. It'll turn out OK I'm sure.
  13. #48138
    Adelaide, South Australia
    I'm following the progress of my mate as he brings his boat round the coast. He has AIS tracking on so I get to see his location and speed as well as all the other vessels using AIS tx. I'm at the point of being a concerned observer.
    The boat is at the point of Wilson's Prom heading West in following wind, doing between 7 and 8 knots. There's nowhere much for them to aim for now except Portland in my view. The wind is tipped to strengthen over the next 30-36 hours that it will take to get that far, with a 25-30 knot broad reaching wind for the final section from LJP Island.
    I'm hoping there is some crew on board as well as the skipper. If not I'll be awake and stressed for a couple of days watching progress. This part of the trip isn't for the timid.
  14. #48139
    Local dinghy sailing blown out yesterday, a gale from NW till about 3am. Dead still now (7.30am) but thunderstorms and squalls forecast later in the day. Rain on Monday.
    Prom forecast
    https://www.willyweather.com.au/vic/...romontory.html
  15. #48140
    Bruce broad reaching in 25 to 30 should be a doddle for him. Autopilot on, sails reefed. AIS alarm on. Relax and enjoy the ride. When we brought our big steel boat home we had similar conditions but a bit stronger. 8 metre waves. Autopilot blew a couple of fuses. And we almost hit an island due to me setting it as a waypoint. But other than that it was a fine sail. Autopilot makes a huge difference to life on board. Particularly single handed. So worry all you like but it's probably wasted energy.
  16. #48141
    It's definitely a good thing. In fact we couldn't have these discussions by airmail. I think Adrian, who we don't see here much, gets together in a pub with some local boat builders on a regular basis, and maybe has similar meandering and sometimes practical conversations about boats and other things.
  17. #48142
    Bright sunshine and a good morning for drying stuff out...It's going to be a hot one.
  18. #48143
    The leak was a couple of loose collar bolts. Sweat poured off me from just tightening them, sauna anyone.
  19. #48144
    I agree. And I agree with Adrian's approach too. I think you should all move to Port Stephens.
  20. #48145
    I think we should all move to Tasmania.
  21. #48146
    I'd be in that!
