Page 1341 of 1407 FirstFirst ... 34184112411291133113401341134213511391 ... LastLast
Results 46,901 to 46,935 of 49239
  1. #46901
    PS, Jeff I'm not sure of the practicalities of collecting that boat. It's heavy, not on a trailer and quite fragile. I wouldn't want to turn up at your place with a bundle sticks.
    I have bailed, If I could have gone to get it myself I have a suitably fitted trailer, a few blokes and an old sail to lift etc. But I think not, I've given away 3 boats this year and still have 3…………...
  2. #46902
    Good decision Jeff, I reckon! But please keep looking ....
  3. #46903
    Happiness is lots of firewood.
  4. #46904
    Love firewood. This came down last night.
  5. #46905
    Good day for working inside today. Before and after. Probably do the second coat on Sunday. I think I should have taken more care about paint fumes.
  6. #46906
    No firewood for us so far, but we have a couple of years supply already stacked.
  7. #46907
    Some time back I borrowed that recording from the local library, actually come to think of it that was maybe 25 years ago and it was pretty ancient then, but nevertheless, see what you can dig up in your library to regain the stories not working on your cassettes.
    Just discovered why it went blank, the tape snapped...out with the stickytape.
  8. #46908
    Feb 2012
    Sorrento Australia
    Shake the tape around a bit and wind it forward with a biro to see if its moving freely. If all is ok fast forward one side completely before playing. To check if the tape is shredding check the tape heads after playing for 50 sec or so. If there is some gunk on the heads the tape will need baking. Most likely after re tensioning it will play fine. Ive just baked a reel of tape from a live recording i did of Mick Rudd's Ariel.
  9. #46909
    Quote Originally Posted by Hallam View Post
    I'll need to pull it apart first and splice it. What does baking meal? Just played the other tape and there is a fair bit of static so this idea may not be worth it. I see Amazon and Ebay have 2nd hand copies of the book quite cheap.
  10. #46910
    Feb 2012
    Sorrento Australia
    I'd go with the Amazon option but for your info, when a tape is old they can take in moisture. It depends of the formulation but the result is the tape shreds when played and on the larger reel to reel machines they simply stop. When you look at the heads the capstan and guides there is brown gunk or flakes on them that needs to be cleaned off. You use isopropyl alcohol on the heads and metal guider but not on the rubber of the capstan as it will melt the rubber. You remove the moisture by baking the tape for 24 hours on very low temp. A gass oven is no good as there is moisture released when gas burns, so something like a food de humidifier or light bulb in a box.
    Sticky-shed syndrome - Wikipedia
  11. #46911
    Another question on something different. I need to replace the flashing around my flue where it exits the roof. At present I have the flue (chimney) and an outer flue which has always had a problem leaking between the two...they don't make the seal that goes between them anymore. I'm wondering if I can do away with the outer flue and just use one of those chimney boots on the chimney itself?
  12. #46912
    On ours the hat covers the inner and outer so no water gets between.
  13. #46913
    Same here, there is no seal between them.
    Big hail squalls with intermittent sunshine and a strong southerly here. About 7c in the shade.
    (Thereis agitation amongst the Regatta committee to move our meetings to the pub till the weather improves. One member in Wales at present and another in Italy agree, they'll find a local pub as well. Skype will do the rest)
  14. #46914
    That is possible cut I’d have to cut them down. I’d prefer to just trim the outer down close to the roof and just have the boot on the chimney flue itself. I just wondered how the boot rubber would go in contact with the hot chimney.
  15. #46915
    We spent the morning testing new auto inflation life rings over distances ranging from 5m to 15m. We had to throw them as close to a floating fender as possible. I hit the fender a couple of times.
  16. #46916
    Not well I'd say, even season by season.
  17. #46917
    I had one that was a ball undeployed. Easy to throw accurately, but a one use only device. I had occasion to throw it to a struggling child.
    http://myboatsgear.com/2017/01/07/th...ation-devices/
    Throwstick looks good.
  18. #46918
    These inflate, so once used you have to replace the cylinder and the activation cap. We went through six lots today. Very compact and easy to throw.
  19. #46919
    I think it would fail. Why not do it the way it's meant to be done? Sorry, I'm back on the flue.
  20. #46920
    That is why I'm asking questions, I don't know how it should be done.
  21. #46921
    Does anyone think I can live a fulfilled and worthy life without this? Currently at $79 on Gray's Online but it has a few days to run yet.
  22. #46922
    I think on mine the inner and outer flues are the same length, or maybe the inner is a tad taller, and the hat just slips into the inner, and has a lower fringe, below the actual hat, which extends out beyond the outer.
  23. #46923
    Adelaide, South Australia
    That looks as dangerous as hell! Of course you should buy it.
  24. #46924
    Bay of Islands,N.Z.
    We're sitting in a solid 20 knots + and we're fairly close to the beach. Offshore thankfully. But it has been sunny and the water is transparent. Maybe another day of breeze and we'll be back to toasting.
  25. #46925
    The cat that flipped wasn't the one I feared it may have been. I'm glad about that but it's tragic nevertheless.
  26. #46926
    I don't suppose you know the name of the cat that did flip do you? I tried to get the name from a news photo but I couldn't work it out.
  27. #46927
    I've rigged a couple of old exhaust fans which have been in the shed for years because they might come in handy one day. Increase my chances of survival putting a second coat of paint on the underside of the deck.
  28. #46928
    Sorry, no. I'll ask around.
  29. #46929
    Jun 2013
    Reminds me of the one I used to work at. You could spend all day cutting S curves into blocks of wood 2" by 2" x 5", following a pencil line with your hands within an inch of the blade. One slip and that's it.
  30. #46930
    Jul 2017
    Toodyay, Western Australia
    I wonder why the cat did flip? It doesn't sound like there were unusually big seas.
  31. #46931
    Normally they land on their feet.
  32. #46932
    Too soon.
  33. #46933
    I know.
  34. #46934
    Jun 2013
    From what I can find out, it's the second of that design to have an "unassisted" capsize - a third fell over after hitting a container. Seems to be quite a high-powered design for a cruiser, with a notably big rig. We've had a couple of cruising cats in the family and I've done a bit of offshore and inshore stuff on various big multis as well as our own small cats, and one thing that has always struck me is that the squaretop mainsails can increase the already very heavy mainsheet loads, to the stage where getting rid of the mainsheet in a hurry can be problematic. While I don't think cats kill more people, the propaganda that says that cruising cats don't flip is just rubbish - plenty of them do. The strangest one I know also happened not far from Sydney, when a cruiser/racer around 40 feet long capsized (again, in a winter westerly, I think) not far from shore in a shorthanded race and was abandoned. The weird thing is that it was found months or years later, back upright. I still haven't heard the full story.
    My brother's 38 foot cat has a smaller roach than many other cats do, and a wishbone boom. The sheet loads are incredibly light for a boat of that type, and you could if you wanted to play the mainsheet easily. The loads on some of the other cats I've sailed are enormous. We had a "cat style" mainsheet on the J/36, by which I mean it was led to a winch each side. I found it slow and cumbersome to use unless you were doing nothing but working the main. I replaced it with the old mainsheet system off our Hobie 20, which works reasonably well (although it needs a fine tune). The fact that a tackle can come off a 20 foot beach cat and go onto a 36 foot fractional cruiser/racer says something about the mainsheet loads on cats!
  35. #46935
    Thanks Chris! All speculation now, of course, but if I had to guess, I'd be suggesting a jammed or slow mainsheet, or a sudden shift that put them a little higher. Those westerly gusts can hit hard here without much warning. People seem to be wondering why they were out in those conditions but I don't think there was really much swell and while it was forecast to be windy, it wasn't all that windy. That's not to say there weren't any wild gusts - there probably were
