Page 1340 of 1458 FirstFirst ... 340840124012901330133913401341135013901440 ... LastLast
Results 46,866 to 46,900 of 51017
  1. #46866
    Balia's new deck paint is in the middle of the red bit in the middle of this. I was very impressed when I saw how the deck paint has come up. Maximum kudos to Phil
    Looks like Robe really copped it.
  2. #46867
    Feb 2012
    Sorrento Australia
    We haven't had the rain yet but its blowing a gale from the north! 30 to 40 knots in the bay! A nice wooden boat broke its mooring a few days ago when the wind was only 15 knots from the north west and luckily drifted between my boat and my mates dingy and rested in shallows protected from wave action by the marina. It's going to be a rough week.
    Bruce Cockburn
  3. #46868
    Also does anyone know what Peter paid for the bronze bilge pump? It’s one of the things that will be sold.
    Only about $40. They were being sold off by the wife of the maker.
  4. #46869
    I think wow is the right word.
    It’s a beautiful bit of gear.
  5. #46870
    My my, it’s a chilly morning here. Cutting firewood this morning so that should warm me up.
  6. #46871
    Define chilly
  7. #46872
    Shed work. Cleaning up Samson posts, cleats, lazarette and sheet tracks ready to go back on. The underside of the sheet tracks is fairly ghastly. Although they look a bit better without all the grotty sealant. I don't think I can afford to replace them. Any ideas to prevent/slow corrosion where the anodising is compromised? Yeah I know I should tidy up my shed and finish those dinghys in time for the Haul of Mirrors. I'm busy OK. And inherently messy.
  8. #46873
    Oh and another thing. What paint for under the deck? I'll leave the beams varnished, but I want the underside of the ply white. There's marine single part polyurethane. Or there's Bunnings. Water based paint lacks gloss and is too soft. I think. Has someone mentioned Berger floor paint? Oil based, glossy and tough? That's kind of the way I'm leaning at the moment. It's already epoxied, and in places where I left the bottom layer of the original deck it's painted or varnished.
  9. #46874
    Aluminium corrosion usually occurs where you have SS fastenings. There are a few solutions. One is to use monel fastenings but they can be hard to find. I have some so if you only need a few and I have the right size, I can send you some. Another way is to isolate the SS fastenings from the aluminium by making or buying little dish-shaped washers. Ronstan supply these with their track. Another way is to set the screws through the aluminium with Tefgel or Duralac. If you use bigger screws and Duralac, the track should be okay for a few more years at least. Don't use bronze screws - they're worse than SS with aluminium.
  10. #46875
    I used garage floor paint in the engine bay.
    I have some Toplac that's nice to use and good for interiors. I think any quality enamel or poly should be fine. I wouldn't use anything water-based under the deck.
  11. #46876
    You got enough dinghies there Phil?
  12. #46877
    Define chilly
    Not by any stretch was it THAT cold! Didn't even have a light frost.
    Waaaay back in the 80s I bought a double cassette recording of Blue Water- Seagoing Australians by Peter Fry. It's the only cassettes I've kept. Well I bought a little cassette recorder that converts cassettes to MP3 files...it arrived today and I've started recording them. Sadly it looks like one side is corrupted, which doesn't bode well for the other 3.
  13. #46878
  14. #46879
    I was just about to post this myself. Very sad.
  15. #46880
    The boat looks a lot like the cat standing next to us when we were last out at Oyster Cove. I'm hoping it's not that one but I'm worried it might be. The owner's a really nice guy and I know the shipwright who'd been working on it for a very long time.
  16. #46881
    That's a thing that worries me about cats. Sad indeed.
  17. #46882
    I keep a couple outside as well.
  18. #46883
    Thanks Rick. They were and will again be bolted through the deck beams. Stainless bolts until now. I'll probably reuse them because they have specially made flat heads.
  19. #46884
    I'd be making up some little fibre washers and using plenty of the goop, as above. I reckon they'll be okay. If not, make some bigger washers from tufnol or fibreglass to span corroded areas.
  20. #46885
    Auckland, NZ
    Phil, on my mainsheet traveller track I cleaned the corroded areas around each bolt hole with one of those scotchbrite disks that fit on an angle grinder, then a thin coat of 2 part Altex etch primer on each bolt hole. A few wraps of plumbers teflon thread tape under the head of each bolt , some lanacoat or tefgel for good measure and then plenty of Sika SBN butyl sealant on the bolt and under the track. Try not to turn the bolt once its through the deck.
  21. #46886
    Thanks, the bolts have square heads so they won't be turning. So that's good. Got some Rustoleum gloss white enamel while I was looking at Jeff's new boat at Paint Supplies SA. Painting the underside of the deck starts tomorrow.
  22. #46887
    Gold Coast Australia
    Spectacular day for all aboard Wee Barkie, surrounded by whales.
    [IMG][/IMG]
  23. #46888
    Jeff, I wouldn't buy it, but I'm not you. Several cracked ribs and planks. Transom has been replaced sometime with ply and is not wholly intimate with the planks. Boat has sat on its keel for 50 years or so, and the bilges have quietly settled down to ground level. It doesn't show so well in the photos but the centre thwart is actually bowed up an inch or two in the centre. It's maybe not complete wreck but it's a significant rebuild.
  24. #46889
    And more
  25. #46890
    And even more
  26. #46891
    [IMG][/IMG]
    Cool.
  27. #46892
    Great Tom!
  28. #46893
    The little one on top would look good on Redwing, what is it?
  29. #46894
    Jul 2017
    Toodyay, Western Australia
    Some time back I borrowed that recording from the local library, actually come to think of it that was maybe 25 years ago and it was pretty ancient then, but nevertheless, see what you can dig up in your library to regain the stories not working on your cassettes.
  30. #46895
    Feb 2012
    Sorrento Australia
    A bit of damage at Robe......and a H28 dragged its mooring and met with a couta boat's bow sprit in Sorrento. Damage to the bow sprit and H28 transom. I decided thismorning it was time to get my boat out of the water and into the yard at WBS.
    Bruce Cockburn
  31. #46896
    Nutshell pram.
  32. #46897
    Nutshell pram.
    Thought it might be.
  33. #46898
    Quote Originally Posted by Hallam View Post
    Better wait a few days for the weather to settle. We are sending more over.
  34. #46899
    PS, Jeff I'm not sure of the practicalities of collecting that boat. It's heavy, not on a trailer and quite fragile. I wouldn't want to turn up at your place with a bundle sticks.
  35. #46900
    Feb 2012
    Sorrento Australia
    The wind went west for an hour or so yesterday morning and that provided the shelter i needed to take her out. I'll post the rest up on my thread in Building and Repair : Warana 11 Blairgowrie Victoria
    Bruce Cockburn
