Page 1335 of 1369 FirstFirst ... 3358351235128513251334133513361345 ... LastLast
Results 46,691 to 46,725 of 47911
  1. #46691
    Spotted gum is quite commonly used in boat building.
    My boat is framed with it.
  2. #46692
    Quote Originally Posted by HS View Post
    The Bay of Biscay where it worked must be one tough bit of water!
    How did they coax those planks around the bow?
    Attachment 39891
    The Bay of Biscay has the same topological challenge as the Bass Straights.
    Deep ocean suddenly getting shallow - the big north atlantic swell squeezed up into high steep waves.
    Looks like the planks run out at the sheer. They seem to get considerably thinner above that rub strip (possibly deck level) - it's like the flare is added on top of an otherwise straight stemmed 'normal' bow.
  3. #46693
    The flare is an extension of the bulwarks, if you expand the first photo you can see the frames above deck. Still, it's a mother of a curve to get those upper planks around!
    Oh yeah!
  4. #46694
    Feb 2012
    Sorrento Australia
    What brand was the beer...we need to know so we can work out if it was a bargain or not?
    Coopers Green
    Coopers Pale Ale
    ORIGINAL PALE ALE
    Australian Pale Ale
    Our 'Pale' is naturally conditioned in the bottle or keg. This traditional Coopers brewing method produces the trademark sediment that gives our ales a distinctive, fine cloudy appearance.
    This beer is a deep golden colour and pours with a generous level of foam. To unlock its full flavour potential, make sure to roll before pouring. No additives. No preservatives.
  5. #46695
    I've been fortunate in my life to have had plenty of close encounters with whales, from surfboards, boats, beaches and headlands. This morning I'm watching a pod of whales breaching off Newcastle Beach, right at the heart of the city. They're too far out for photos or knowing how many are up to it but there are at least several launching themselves right out of the water, over and over. Beautiful.
  6. #46696
    Gold Coast Australia
    Our East Coast whale migration is fantastic.
    And just to think that the meat works in Byron Bay where still slaughtering these beautiful creatures until the early sixties..
  7. #46697
    Aug 2017
    Melb, Vic, Aus
    I have fond memories of laying in my bunk listening to the whale songs amplified by the plywood hull. Great way to fall asleep
  8. #46698
    Aug 2017
    Melb, Vic, Aus
    Phil. I have gone with the parchment colour from the international chart for cabin side and will match the deck paint to suit.
    It goes really well with the serpentine green
  9. #46699
    Apr 2019
    Aust
    Spotted Gum is good then! Thanks for feedback.
    Anyone has sailed in/out of Port Hacking?
  10. #46700
    Thanks. Much less choice of colour in the 2 pack perfection. I'm going very white on hull and cabins to keep the heat out as much as possible. Snow White. And probably Matterhorn white on the deck. My boat is not so traditional, so that's not so much a consideration. I imagine I will find the deck too bright, but there you go.
  11. #46701
    Apr 2019
    Aust
    I heard chainsaws and heavy bangs this morning... She sank last week and they got her afloat. No more oceans for her
  12. #46702
    Aug 2017
    Melb, Vic, Aus
    You may be able to score yourself a few bit of good timber out of there Jorge?
  13. #46703
    Sydney Australia
    Quote Originally Posted by JorgeR View Post
    You're in Yowie Bay, correct? or ios it Dolans bay... Whatever, Port hacking itself is fine, but the channels between those bays and the open area off South Cronulla are best done at high tide. Very silted up. you will need to motor thru - even if no other traffic theyre too narrow for any sort of tacking.
  14. #46704
    Turns out they can tint the 2 pack. Which is a bugger because now I have 100 colours to choose from. Probably Snow White topsides and cabins and maybe off white or the slightly yellower vanilla white for the deck. I'll sleep on it. Not the deck, the colour choice. Buying and applying paint tomorrow. 20C and fine.
  15. #46705
    Apr 2019
    Aust
    Yeah, we're motoring anyhow as the forestay is off. Seems like high tide is just around sunset so leaving 1h early it is. Thanks for advice, going to Botany Bay for haul out
  16. #46706
    That sand bar north of Maianbar can be shallow. I'd say high tide for that spot for sure.
    You may be able to duck into Buraneer bay and get to the channel on the far side if you're in doubt.
    Tide pulls through there pretty fast too - slack water time would be best.
  17. #46707
    Jorge, Dunno whether it was on this thread or the other one, but heres the link to the bow fitting on gumtree.
    https://www.gumtree.com.au/s-ad/glen...ing/1221408236
  18. #46708
    Sunset or sunrise? I think with no functioning rig and a few doubts about the motor, I'd rather leave before sunrise than sunset, especially crossing unfamiliar water. I'm guessing you meant sunrise?
  19. #46709
    Finished sanding back all the teak strips, now I have to work out how to fill all the screw holes without them being obvious.
    Option 1 is to drill them all to the same size as my plug cutter then use some of the teak for plugs.
    Option 2...well I don't have one.
    As for fitting the strips I'm figuring on mastic and screws, which will make it easier to replace them should I need to sometime down the track.
  20. #46710
    I'd go with Option one. I think.
  21. #46711
    Mar 2015
  22. #46712
    Apr 2019
    Aust
    Sunrise sunrise! Misspelling, my bad. Got OpenCPN and the oeSENC aussie charts up to date. Impressive how it runs nicely and smoothly on an Android tablet!
    P.s: Phil, thanks for the link, got it on the other thread too
  23. #46713
    Phew!
    I do know one experienced sailor who reckons he prefers entering ports at night. I reckon he's off his head! I don't mind leaving at night but I much prefer coming in in daylight, especially into unfamiliar places.
    Actually, the first time I ever entered a `port' from the sea, under sail, was at night. I was just a passenger, happily! It was in Tonga and local fishermen from a little island about 7 miles off the Tongatapu coast took me from Nukualofa to their island in a small, wooden, open sailboat. We arrived at 2am and entered the lagoon through a narrow break in the fringing reef. All I could see was the shadow of the island and the foam of breaking waves on either side of us. We'd been sailing and bailing and paddling since midday so it was great to arrive. The next morning I paddled out through the break in the reef to surf a really nice left that ran into the gap. I surfed there every day except Sundays, then, and it was always good. We had good breeze for the return trip so that only took a few hours.
  24. #46714
    May 2014
    Who tints the two pack?
  25. #46715
    Bay of Islands,N.Z.
    I tint my two pack because my old paint has faded a bit. Pharmacy syringe and a drop or two of white into the blue.
    Sometimes I'm good, sometimes I ain't.
    We were just having the night pass navigation discussion here about Navula pass ,Fiji.. The distances are so great over giant reefs and patches it's hard to get the picture without bearings and or your nav plotter. But its well lit and has leading lights, a good one for night time.
  26. #46716
    Quote Originally Posted by pelagos View Post
    The local International agent I buy it from.
  27. #46717
    Picking up my sheet of plywood today. Then it’s off to the boat for the weekend and it looks like it’s going to be a wet one.
  28. #46718
    Bugger. It was 20 and dry here yesterday and I got a nice gloss coat of paint on my topsides above the rub rail. But forecast to rain later today and the next couple of days, so progress will halt. Getting 2 pack on at the moment is tricky. Got to start late enough that the surface is dry, and finish early enough that it's hardened up enough before dew forms and dulls the gloss.
  29. #46719
    I guess the days of waiting for a clear morning and climbing up to the spreaders are on the way out. Having said that I don't like night time entrances, it's obviously a good idea to get used to doing them! I don't like them but, thinking it through, I've actually done more night time entrances than daylight ones, if I exclude Port Stephens. I haven't done any night time bar crossings in swell and I'd try to avoid that.
  30. #46720
    I came out of the Gold Coast Seaway at night one time, pitch black night. We knew when we finally got outside because the yacht stopped going up and down.
  31. #46721
    Aug 2017
    Melb, Vic, Aus
    Gold Coast is probably the only bar I would think of doing that "if" the swell is low.
    Some of those smaller bars though. ~~~shudder~~~
  32. #46722
    BOM cancelled the rain, so I'm painting
  33. #46723
    Tweed can be less than fun.
  34. #46724
    Adelaide, South Australia
    I once entered Crowdy Head in a squally blow in the middle of the night. Not exactly a bar entrance, more like a hell's gate experience. But we survived.
  35. #46725
    Rembrandt.
