Page 1334 of 1400 FirstFirst ... 33483412341284132413331334133513441384 ... LastLast
Results 46,656 to 46,690 of 48987
  1. #46656
    What thickness would you use of that tuffnol? I'm thinking 5 mm for my big plates.
  2. #46657
    That bostik looks good if it's as good as they claim. I don't like Sika. I E used various flavours in various applications and it's always failed. I had some fixtech on one shroud plate which is better than sika, but it had let go one side of the shroud plate.
  3. #46658
    That's why I thought I'd use tape, squished into a blob. It's pretty much like Blu tac. I tried the selleys butyl mastic on a couple of my decklights. Didn't like it. It dries out in our climate. Everything dries out in our climate. You still don't think I'm serious when I say it won't rain until May. I am.
    I agree Phil, and then maybe not much, Saturday's papers had predictions of a strong El Nino into winter caused by warm seas. Vic. Govt has just made a very large order of water from the Desal down our way. Add about $10 to the yearly bill. Our tanks are holding well but we'll likely buy some in next week. Down here it will come from an aquifer about 50M down. Perfect water, but we run a filter system anyhow.
  4. #46659
    5mm is what I use.
  5. #46660
    Laying the Glass on dry deck is much easier than laying over a coat of wet epoxy. Going great guns this morning.
  6. #46661
    Looks great Phil, congratulations.
    The back is broken, yer on the homeward stretch now. (as long as your motor works........)
  7. #46662
    I'm not very proud of how I've fitted the deck around the shroud plates. The gap is deliberate, but could be tidier and better aligned as between the 2 layers. It's tricky to measure and fit due to the angle of the shroud plates, and fixed objects such as the cabin. Mostly I'm just a slob. Anyway my plan involves a support plate below and a compression plate above a large filling of goop, to allow plenty of room for the tiny bit of movement which seems to be inevitable. It's worked well where I've done repairs this way before. Yes Rick a source of tuffnol would be good.
    Interesting problem hey.
    What did it used to look like?
    I wonder if the top cover plate should be held on with goop too - not screwed, so it too can move those tiny fractions.
  8. #46663
    Aug 2017
    Melb, Vic, Aus
    Thinking out loud.
    What if you make the hole a little bigger to allow room to get 3 wraps of butyl tape on the nice and tight then just fill the gap with thickened epoxy and glass over the lot of it? Once its all painted up to the chain plates put you choice of goop around that?
    looking a million bucks.
  9. #46664
    Anyone watching the Coast NZ show on SBS?
  10. #46665
    Blaxland, NSW, Australia
    Phil, what about 3M 5200 bedding compound? E.g., here.
  11. #46666
    Adelaide, South Australia
    Spot the boat builder.
    Paperback E-book
  12. #46667
    Quote Originally Posted by Alex1N View Post
    Yeah I've never tried it. I don't know if it's any different/ better than Sika or fixtech. Good to kniwt you can get it here though. Thanks for that.
  13. #46668
    Thinking out loud.
    Thanks. Actually wrapping would be really difficult. Angles are all wrong. I'm planning to just kludge it in there in an amorphous glob. I think it will work.
  14. #46669
    The original build was a beautiful tight fit, where there was still any evidence to be found. The worst rot was around the chain plates. I'd actually like to bolt the chain plates to the outside of the hull. That would get rid of 14 deck protrusions.
  15. #46670
    Haven't started the motor in a while, but it should be fine. It's a thing of beauty.
  16. #46671
    That shouldn't be too hard to do and you could do it later. Patching up the holes in the deck will be easy.
    By the way, sort of testing the Kiwi Grip in the rain yesterday, I decided I'd like a slightly more aggressive finish. That's achievable with the standard roller you buy with the Kiwi Grip so I'll try that soon and let you know how it seems.
  17. #46672
    Thanks, would be good to know.
  18. #46673
    I wouldn't use the 5200 on anything you want to remove. Ever. I'm pretty sure future archaeologists will find old galvanized cleats bonded to chunks of deck with 5200.
  19. #46674
    Auckland, NZ
    Great work Phil.
    Very light handed rolling with the special KiwiGrip roller will help determine the finish texture.
    Suggest removing the masking tape within about 30 minutes of applying the KiwiGrip . This will give a sharp edge to the margins
  20. #46675
    That is precisely why I’m using it to bed in the Sooty’s centreboard case. I thought that Phil’s situation was at least a little bit similar .
    But I spose not if he is wanting to put the chainplates on the outside of the hull at some point in the future.
    Alex.
  21. #46676
    I think Phil should get some Fixtech, Sika 291, Buty tape, Butyl Mastic, Bostik stuff, 5200 and Ormonoid, stick it in the blender and then, when it's all nicely mixed, ram the whole lot in with the blunt end of a crowbar, and sail to Tasmania.
  22. #46677
    Feb 2014
    Sunshine Coast, QLD
    You left out "stand back 200 feet" before blending all that.
  23. #46678
    To update the incident at Lemon Tree a couple of days ago. Craig and his son were working on the petrol engine of an old GRP cruiser they've been given and are doing up to sell, I think. They also have a big, flash cruiser.The son's only about 12. Anyway, there must have been petrol and vapours below the engine and that ignited, severely burning both of them. They jumped into the water and others around helped them while waiting for the ambulance. Craig was coptered to Royal North Shore in Sydney where he's now in an induced coma. The son was coptered to Westmead Children's, also in Sydney, and he'll undergo surgery for burning to his airways. I'm guessing that's from gasping when the blast occurred. Each of them have burns to around 30-40% of their bodies, facial burns etc. There's no upside to this story, unfortunately. Craig's a shipwright, by the way, and is very experienced with engines etc.
    A week or so ago, a guy was found dead on his boat at Lemon Tree, out on a mooring, and apparently had been there for a couple of weeks. On the same day, a guy was found dead in his car in the marina carpark, and another two locals were found dead in separate houses just last week. So Lemon Tree hasn't been quite the happy little backwater lately.
  24. #46679
    Feb 2014
    Sunshine Coast, QLD
    :-( Sad stories, all.
  25. #46680
    Horrific. Serious burns are the injury I fear most.
  26. #46681
    Yeah, just a moment while I ask Felicity if it's OK to use the Thermomix for that.
  27. #46682
    I just thought of a worse injury. I think I won't ask, and won't use the Thermomix.
  28. #46683
    I'm considering 5200 one side and butyl tape the other.
  29. #46684
    Feb 2014
    Sunshine Coast, QLD
    Sounds like that'll hold the Thermomix together nicely.
  30. #46685
    For sale, suit handyman.
  31. #46686
    I'm slightly paused at the moment. Waiting for my next order of peel ply to arrive. I'd hoped to see it yesterday, but today is possibly more realistic. Ordered it on Monday. So I'm going to start dismantling the foredeck. I think I'll remove the anchor winch first. Which is going to require removing the anchor. Not quite sure how I will do that. It's quite heavy. I guess one option is to just lower it on an expendable piece of rope-it will come up pretty foul after a few weeks. Or maybe take the weight on a halyard and try to swing it onto the berth. Or slew the boat around so the bow overhangs the berth. That sounds like a plan.
  32. #46687
    A tube or two of 5200 and some ratchet straps should bring those planks back up to the transom. No worries.
  33. #46688
    You'll develop a list.
  34. #46689
    No, Felicity does those. I'm trying to ignore them while I do the deck.
  35. #46690
    You already have two on yours.
