Page 1319 of 1448 FirstFirst ... 319819121912691309131813191320132913691419 ... LastLast
Results 46,131 to 46,165 of 50673
  1. #46131
    Rick yes Im thinking much the same. More goop. I don't actually understand how they can leak. But there you go. One of life's mysteries.
  2. #46132
    Jul 2017
    Toodyay, Western Australia
    Two rudders! Sounds interesting. I thought that was the stuff of high tech go fast boats.
  3. #46133
    I've got a hatch that leaks and I just can't see how. I helped a friend seal windows on his cruiser and I reckon it's impossible for them to leak but a couple do. Leaks are tricky!
    My chain plates don't leak Yours won't either. I think you can get little seams when you squish that butyl tape and water seeps through when it pools on the deck. That's my guess.
  4. #46134
    2 keels also. The steering mechanism is complicated.
  5. #46135
    Yes, maybe like puff pastry. The stuff sticks to itself like you wouldn't believe though. Maybe it hasn't quite squished into a corner. Either way a bit more kneading on a warm day may help too.
  6. #46136
    Feb 2014
    Sunshine Coast, QLD
    There's some metal work to do between here and there. I'll just have to find a way to do that. I have a big mig welder I have never used and a friend has a plasma cutter which sounds like a cool tool.
    Sounds like the universe is telling you it's time to learn to weld. Then I'll visit and you can teach me.
  7. #46137
    It's a deal
  8. #46138
    Anyone know offhand what the beam of Jim is?
  9. #46139
    Feb 2014
    Sunshine Coast, QLD
  10. #46140
    Thanks.
    LOD 18’4’’ (5.60m); Beam 5’6’’ (1.68m); Draft 11’’/3’5’’ (.29/1.05
    love the fact Peters boat is featured.
  11. #46141
    May 2000
    Conway, MA
    Water is a very small molecule.
  12. #46142
    Which can infiltrate astonishingly tiny openings.
  13. #46143
    I know. It sucks.
  14. #46144
    Feb 2014
    Sunshine Coast, QLD
    No, gravity is what sucks. That's why the water gets in.
  15. #46145
    Adelaide, South Australia
    Capillarity actually. But gravity helps.
  16. #46146
    Feb 2014
    Sunshine Coast, QLD
    Yeah, okay. I know, but the joke wouldn't have worked properly, and that's important.
  17. #46147
    Never let facts get in the way of a good story.
  18. #46148
    Feb 2014
    Sunshine Coast, QLD
    Exactly!
  19. #46149
    May 2000
    Conway, MA
    Gravity is important.
  20. #46150
    Jul 2017
    Do you have pictures of her on the hard? You've probably already posted something but it seems easier to ask than to scan through the 47000 previous posts in this thread.
  21. #46151
    I do. On an old phone that died. Photos are ephemeral things.
  22. #46152
    The he rudder is actually off in that third one, that's just the skeg
  23. #46153
    Jul 2017
    Nice arrangement! Stands on her own feet, shallow draft, leaves undisturbed water for that prop to work in, and redundancy by having two rudders. Fantastic! Where is the boat yard? I don't see marine rail much anymore. Everyone in the west has converted to travel lift.
  24. #46154
    Tassie. Down south from Hobart. It's the yard where she was built. For sale last time I checked so probably not to be available much longer, sadly.
  25. #46155
    You didn't mention the massive wetted area of those keels, which was nice! The rudders seem tiny for the boat, and way forward, but she steers well, turns tightly, never felt under done for steering power. I think she's technically a yawl, as the rudder posts are probably just forward of the mizzen mast. I suppose there's 10 or 12 feet of boat behind the rudders. Makes her feel like a little 40 footer from the helm.
  26. #46156
    Jul 2017
    I wonder how the wetted area would compare to a boat with just one, but deeper keel. Probably not too different. In any case I'm sure her advantages make for a fine cruising boat.
  27. #46157
    There's a bit of history to the design. A Lord Riverdale had a fascination with twin keels and built a succession of boats called Bluebird of Thorne. Lots of tank testing and weird ideas about lift and roll and stuff. Mine is the final iteration of the process. Designed by Arthur Robb. Her original was built in riveted steel plate. I know of one other of the design, built of steel, which happens also to be in Adelaide.
  28. #46158
    Jul 2017
    Getting the final iteration is surely better than getting the first.
  29. #46159
    Well it's made of wood, so yes, clearly.
  30. #46160
    One toerail with two coats of Cetol, if it doesn’t rain tomorrow I’ll get more on. I’m also hoping for zero wind in the morning so I can get the rest of the batten parrels on. I managed three this afternoon before the rain started to dampen my enthusiasm....well that and the light northerly that would have made raising the sail problematic.
  31. #46161
    Beautiful day. Third coat of Cetol on the toe rail. Fixed the scarf that let go on the port toe rail and got the rig sorted to the point it needs to go sailing. Just need to clean the carby on the outboard and I can go and see how she handles.
  32. #46162
    Good job
  33. #46163
    I have packed up my two dinghies for the winter, but I have the sailing canoe and sea kayak and the local bay if I feel I need a fix. But it's a bit weird, first time in 5 years that I have not got a boat needing fixing in the shed.
    OTOH I have been asked to rig an antique model pond yacht, circa 1907. They bought it on line, it arrived with all the rigging and sails in a bundle and have no idea where to start.
    Very similar rig to this, they even offered to pay. Of course I refused, but it will be interesting to see if all the parts necessary are there.
  34. #46164
    Feb 2014
    Sunshine Coast, QLD
    Excellent! I await the sailing report.
  35. #46165
    I have a small collection (13) of unrestored pond yachts. I like them that way.
