Page 1312 of 1315 FirstFirst ... 312812121212621302131113121313 ... LastLast
Results 45,886 to 45,920 of 46012
  1. #45886
    Excellent!
    As for the rolling bevel edge, I'd be looking at getting it within a close margin with any sharp blade you are comfortable with then running an electric planer along it freehanding the bevel, then belt sanding it in. How far over the edge is the glass going to wrap?
    That would work. To get a topside cutting edge guide line on top of the ply a used a scrap with a slot cut deep enough to clear the rough edge of the ply. And held a pencil against the top inboard edge of the scrap and marked a line on the deck. Does that make sense?
  2. #45887
    Yes, great idea, thanks!
  3. #45888
    Adelaide, South Australia
    And a bit of foredeck work.
    I don't get on well with electric planes.
    I reckon I'm pretty much on schedule so far.
    Great progress!
    Paperback E-book
  4. #45889
    Thanks Rick but not sure I understand. I bought that edge trimmer thing but haven't really found a use for it yet other than letting in hinges on a door at home. The angle between deck and topside varies and is mostly more than 90 degrees, except forward where it's less.
    Actually, you don't need to bevel the edge of the block for what you're doing, nor do you need a bearing bit, although it can be a good safety measure (to prevent accidental dig ins.).
    This is a guide that used to come with Makita trimmers. I've set it up on a steel tank here as it's the only thing I could find with an obtuse angle:
    It's easy to make the same thing with a couple of bits of scrap wood, if you don't have this guide. To use it, you simply run the guide flat against your sheer plank. Just make sure the bit is long enough so it doesn't miss the ply edge you're trimming. It's actually pretty easy and you'll get a much better finish than you would with a belt sander. The base of the trimmer doesn't sit flush on the deck but that doesn't matter. You just have to make sure that you get the guide flush with the sheer plank. Obviously the guide has to be set so that the bit is flush with it.
    When I did Pipsqueak's deck, I used the trimmer for almost everything! I use it all the time on Masina too. It's a tool that's well worth getting familiar with.
    Only use the trimmer to finish the edge - you don't want to be taking more than about 2-3mm at a time, so cut the edge off fairly close with a sabre saw or jigsaw before you run the trimmer along.
  5. #45890
    So, today on Masina, I cut out part of a shelf that sits under the sink as I'm changing the outlet and ball valve, and the new setup won't fit above the shelf. I cut a big cavity with a jigsaw, chisel and handsaw, then frigged around for ages trying to fit some trim bits so that things won't slide into the new cavity. All this in 200% humidity with my head and shoulders jammed into the cupboard and my knees screaming for mercy. Then I worked out that by removing just four screws I could easily take the shelf out and take it home to work on in the shed ........
  6. #45891
    Hmmmm. I dunno.
  7. #45892
    It really is simple. The trimmer base doesn't need to be flush with the deck. It's inner edge just rides along on the deck. You can't dig in. You get a perfect edge. It doesn't work with acute angles but where the angle is obtuse, it's foolproof. Did your trimmer come with that guide?
  8. #45893
    I think it came with some sort of a guide. I'll try it. Maybe.
  9. #45894
    If you do have the trimmer guide, as above, you can also use it for acute angles, as I had to do on Pipsqueak - memory's returning! You have to be more careful to keep the guide flush with the sheer plank as you can get a dig in. Make finer cuts to reduce the risk.
  10. #45895
    Use a long, straight bit, at least 8mm dia.
    Another method, also easy. Fasten (hot glue, 2-sided tape) two bits of ply to the base of your planer; one forward of the blade, one behind. The bits of ply should only cover about 2/3 the width of the base. Lower the blade so that it's flush with the ply. Then just run the planer along the sheer plank with the ply resting on the plank and the bit of blade beside the ply cutting off your deck edge. Fine cuts until you get used to it.
  11. #45896
    I wonder if anyone took any photos at this year's AWBF??
  12. #45897
    Oct 2007
    A quick heads up for those in the Tweed region, Sibbo maaaayyy be having a pre-painted boat splash/sea trial/test rigging with Jim on Wednesday at Fingal. Two mates Nick and Keith have been providing the labour at El-Sibbo's direction and Nick thinks they might get stuff sorted to get some saline action happening.
    Stay tuned...
    Jarndyce and Jarndyce
    The Mighty Pippin
    Mirror 30141
    Looe
    Dragon KA93
  13. #45898
    Thanks Rick
  14. #45899
    Stay tuned...
    Here's hoping.
  15. #45900
    Stay tuned...
    I want to be there for that.
  16. #45901
    Weather wise tomorrow is going to be awful.
    Wednesday 13 February
    Summary Min 22Max 38Hot and sunny.Chance of any rain: 20% Northern Rivers area
    Hot. Sunny day. Slight (20%) chance of a shower in the evening. Winds north to northwesterly 15 to 25 km/h shifting south to southeasterly during the afternoon and evening. Overnight temperatures falling to the low 20s with daytime temperatures reaching 36 to 42.
    Sun protection recommended from 8:50 am to 5:00 pm, UV Index predicted to reach 13 [Extreme]
  17. #45902
    Cold, windy and rainy here. That was supposed to be tomorrow. Not even visiting the boat today. I hope its stays from the South as theres nothing much to tie up to at the back end of the boat at the moment.
  18. #45903
    Over 38 C here and blowing about 20 knots, although there are some heavy gusts and it seems to be picking up. Real bushfire weather, except that after two fires in late 2018, there's not much left here to burn. There's supposed to be a cool change coming through tonight.
  19. #45904
    Oct 2006
    Livin' in the Golden Triangle
    Care to enlighten me on good spots of particular note . In theory the camper should be self-contained, but I need to get a handle on paid and freedom camping options over that way. We mostly pay our way over here, even though the caravan is all set up and certified.
    Freedom camping is becoming a bit of a hot button issue over here, with some places literally becoming covered in chit .
    Pete
    I found some of that chit of which you speak not too far from this free camping spot the other day
    The missus wasn't too impressed with me telling her we were camping there... "see, free blanket and a pumpkin". We went on a bit further and paid for a room - also with a view
  20. #45905
    I'd use 6 oz. plain weave. I can't see any advantage in going heavier in plain weave and biaxial/stitched stuff is murder to lay over large areas, and expensive. 6 oz will easily wrap over your edges.
    I saw this West video where they use a thin foam roller to wet out glass onto dry ply. I've always used a squeegee and brush but I think the roller would work really well.
    https://www.youtube.com/watch?v=5gcut7RLho8
    That was a good video tutorial. I continue to appreciate all the great advice Im getting here from everyone, thanks.
  21. #45906
    Seriously warm and very still here, it's not going to be a nice night...however looking forward to seeing Jim on the water tomorrow.
    Busy charging up various cameras.
  22. #45907
    Fantastic. Fair winds Peter! Lots of photos please. Wish I could be there.
  23. #45908
    As above!! Hope it all goes really well but I'm sure it will!
  24. #45909
    Blaxland, NSW, Australia
    All the very best for the launch, Peter.
    Alex.
  25. #45910
    Launch day! How frabulous!
    Buy a bottle of very good rum and notify me of the bill.
  26. #45911
    I've just posted a thread over in building and repair about peel ply. Never used the stuff. Any thoughts or experience welcome, as usual. Thanks. In particular, the video Rick posted suggests you can leave it in place for months while finish off the rest of your boat. I wonder if that's a good approach, wrt UV.
  27. #45912
    Important day today, cameras are fully charged.
  28. #45913
    Seems like a good idea to me. Better than mucking around with tarps etc.
  29. #45914
    I like it ,a perfect finish, no sanding at all.Do an experiment first.
  30. #45915
    Feb 2014
    Sunshine Coast, QLD
    Have a great day today, Peter and helpers!
  31. #45916
    I didn't know you could leave peel ply on for so long. Good to know!
  32. #45917
    Got the idea from that video you posted
  33. #45918
    I'd better watch more of it ...
  34. #45919
    It's about like watching paint dry, but some good info.
  35. #45920
    A friend who has built wrc racing sculls in NSW uses and swears by peel ply. I've never used it but I'm assured that my scull would have had a far better interior glassing outcome weight wise had I used it.
    Paperback E-book
