Page 1311 of 1391 FirstFirst ... 31181112111261130113101311131213211361 ... LastLast
Results 45,851 to 45,885 of 48671
  1. #45851
    I often use just flat discs rather than flappers. With flat discs, as long as the nut doesn't protrude, you can sand with the disc flat on the surface and avoid any dig-ins. It's easy with a small grinder. You often have to cut little slots from the hole in the disc to get it to lay flat.
    I pretty much always use flat discs. I have a fitting which has a flat "nut," and a slightly flexible rubber backing. Only thought I'd try a flapper because Gary suggested it. Yesterday I was using the random orbital because it seemed like the best tool to lightly scuff large flat areas, and because I could attach a vacuum cleaner and put very little dust in the water and the neighbours boat.
  2. #45852
    If the RO sander is getting the runs off then that'd have to be the best one to use. And you can use 40 or 60 grit because the high-build primer will fill the rougher sanding. It won't fill dig-ins or repair flat spots.
    At home, I'd use the grinder. On the water, the RO for sure.
  3. #45853
    I think 80 might have been the coarsest I could find in Bunnings. Not sure now. I just may get down to the boat later today, and will help Mr Bunning with his turnover on the way. Not entirely sure my arms and back are up for it.
    Today I mainly have a final tidy up of a property I manage before the owners arrive for their annual family holiday. It's quite the performance. Lovely 50 acre place near us. Huge lawn, lots of garden beds, lots of rural plumbing always requiring attention, 10 or so cows, 30 odd sheep, some chickens and a veggie patch.
    If that goes well, then I get to do some more sanding as a reward. Also patch a few small spots where the glass cloth was raised up from the deck. About 20c piece size. I've sanded those out, just need to put some glass and epoxy in, let it go off and sand it before the paint goes on.
  4. #45854
    Thanks team for the wise counsel against sloth. I got me some 40 grit discs for the random orbital and cleaned up those runs quick smart. Fresh discs, fresh arms and a fresh day, easy done. You can still see where the runs were but it feels reaonably smooth. Patched the 4 or 5 spots that needed patching. Not sure of my method on that. I've left the edges of the new glass unstuck so I can just feather old into new with the loose stuff flying away in the sanding process. I saw a proper boatbuilder do it like this, so it should work. I added some peel ply because I had some and I like the stuff. Painting tomorrow. Woo Hoo. After that I'm going to get drunk.
  5. #45855
    Feb 2014
    Sunshine Coast, QLD
    Superb! :-D
  6. #45856
    Looks good Phil.
    The social contract that bestows authority — both moral and legal — on our political leaders is struck on the trust that they know what they are doing and will always act in our best interests:
  7. #45857
    Thanks, hopefully even better tomorrow. Perfect weather forecast now, 23 and slightly cloudy. I knew the rain forecast was just a joke.
  8. #45858
    Well, not a total success today. The Pengaurd went onto glass which had not had peel ply on it quite well, but where I had used peel ply, tended to settle with lots and lots of pinholes in the texture left by the peel ply. I was able to get rid of most of the pinholes by putting the paint on extra thick. Maybe they still lurk underneath. The worst of it though is that I always measure out epoxy by weight. This stuff is 4 to 1. So I did batches of 800 part A, 200 Part B. Problem is I got to the end with a lot if part A leftover. So I got to thinking. Part A must contain a whole lot of lightweight easily sanded solids. But then that would use more volume for a given weight. So I'm buggered if I know. Maybe it contains lead. And I didn't end up with enough paint to finish the job. Come Monday I'll see if the local distributor will sell me some Part B to mix with my Part A. Otherwise just buy more of both. The paint seems to be hardening off OK, so I don't think I have to get it all off and start again. It looks about as good as a first coat of undercoat over a dark base usually looks.
  9. #45859
    Feb 2014
    Sunshine Coast, QLD
    Looks amazing! Don't go reinstalling all that hardware. Keep the decks nice and clear. ;-D
    Did you check the Penguard ratio by weight is the same as by volume?
    Botecote epoxy (the only one I've used) mixes 2:1 by volume but the parts are different densities so it's 100:44 by weight.
  10. #45860
    No I didn't. Obviously. Even though I know to do so.
  11. #45861
    Definitely don't mix Penguard by weight! Mix the white part, Part A really well as it has all the solids in it that make it a high-build primer. Sand the first coat to get rid of bumps.
    Have you ever used shadow coat? It's a black or get paint or dust that you spread or spray over areas you want smooth. You sand it off until you can only see white primer. The shadow coat exposed any hollows so when it's gone, you know you've got a flat, smooth finish.
    I'm a bit surprised about the pinholes - what sort of roller are you using?
  12. #45862
    Feb 2014
    Sunshine Coast, QLD
    Yes. It was obvious. Sorry. I didn't read properly.
  13. #45863
    Adelaide, South Australia
    Well it looks great from Largs North. I'm tempted to go have a decko but I'm a bit bushed after driving up to the bush to rescue some bees that had all fallen over all at the same time.
  14. #45864
    I did at least mix the A well. The data sheet or website or somewhere talks about pinholes being a problem when rejuvenating old fibreglass, but as this is new I was a bit surprised. No I haven't tried magic fairy dust. Just not that much of a perfectionist.
    Using a Bunnings gloss microfiber roller. It did well with epoxy. I will sand the first coat and go again.
    I'm sure it's all good.
    Nearly drinking time even though I didn't get the whole deck done.
  15. #45865
    Yeah the deck looks huge all white and bare. I reckon I might put a tennis court on it.
  16. #45866
    Bay of Islands,N.Z.
    Billiards! What could go wrong.....
  17. #45867
    You'd need a lot of balls.
  18. #45868
    I couldn't even keep a screwdriver on mine.
  19. #45869
    Sailing all day today in dodgy wind shifts that only settled around 5pm. Lost the pin that holds the boom to the mast, capsized but got it up and was towed to the beach……. where I found an old piece of drift wood with a rusty nail and resumed sailing.
  20. #45870
    Rusty Nail. I'm sure that's an old yacht club drink. Rum and something.
  21. #45871
    Drambuie and Scotch. No sailing after that.
  22. #45872
    Gold Coast Australia
    Enjoy you’ve earned it.
  23. #45873
    Aug 2017
    Melb, Vic, Aus
    Are you saying to sand all the dimples out of te first coat of primer Rick?
    I got the first coat on the Comet today. Trying to get it painted before winter.
    It makes since so as to get an even adhesion. I've used the black spray method before.
    new rub rails as well.
  24. #45874
    Jul 2017
    Toodyay, Western Australia
    I've been using penguard for at least 20 years, and in that time screwed up the ratios somewhat on some occasions. Never had any issues with the paint though so it must be quite tolerant of the ratio being dodge. On my new boat I measured with a notched stick. In my case the stick was notched every 5 mm, so it is easy to add 4 notches of base and 1 of hardener, or 8 of base and 2 of hardener, or whatever. The advantage of the notch is they are still visible even when covered with paint, so no need to re mark the stick for every batch.
  25. #45875
    Good plan. My mixing pots are slightly tapered, but I don't see that mattering.
  26. #45876
    The main thing to sand off the first coat is any high spots as the second coat just compounds them.
    I use 3M shadow coat. It makes sanding primer a lot easier as it provides a good visual guide. Rubbing shadow coat onto any paint job takes less than a minute usually.
  27. #45877
    Aug 2017
    Melb, Vic, Aus
    Thanks Rick. Your a real treasure being here. Like a boat maintenance rep for everything!!!
    I really appreciate it.
  28. #45878
    Aw shucks! I just pass on what actually knowledgeable friends have shown me and hope it's helpful.
    This morning I'm off to the cable shop to buy battery cable so I can start rewiring Masina tomorrow. I quite like wiring. First job once I get to the boat is to put one more coat of Awlgrip on the front end of the cockpit.
  29. #45879
    What he said.
  30. #45880
    Good luck. I reckon electricians have very high level OCD. Nicely laid electrical wiring is like beautiful sculpture.
  31. #45881
    Ouch
  32. #45882
    Thanks. I don't have OCD but I often wish I used to.
  33. #45883
    Ouch
    Saturday I dropped a small block over the side. At low tide the water on the landward side is very shallow so it was quite visible. My logic went...if I use the boat hook I might be able to push it over to the rocks and thereby not have to get wet.
    Reality went...okay you have managed to hide it between two rocks now you have to get in the water, which I did. Stirred up the slit and I never saw it again.
  34. #45884
    Aug 2017
    Melb, Vic, Aus
    Haha, bad luck Gary
    The easy way is often harder.
  35. #45885
    Feb 2014
    Sunshine Coast, QLD
    Pixie was re-launched a few hours ago.
    I accidentally went straight out for a quick sail to make sure I'd put the rig back together properly. I had. She didn't leak!
