Page 1301 of 1394 FirstFirst ... 30180112011251129113001301130213111351 ... LastLast
Results 45,501 to 45,535 of 48781
  1. #45501
    I'm slightly paused at the moment. Waiting for my next order of peel ply to arrive. I'd hoped to see it yesterday, but today is possibly more realistic. Ordered it on Monday. So I'm going to start dismantling the foredeck. I think I'll remove the anchor winch first. Which is going to require removing the anchor. Not quite sure how I will do that. It's quite heavy. I guess one option is to just lower it on an expendable piece of rope-it will come up pretty foul after a few weeks. Or maybe take the weight on a halyard and try to swing it onto the berth. Or slew the boat around so the bow overhangs the berth. That sounds like a plan.
  2. #45502
    For sale, suit handyman.
    Attachment 33561
    A tube or two of 5200 and some ratchet straps should bring those planks back up to the transom. No worries.
  3. #45503
    I'm considering 5200 one side and butyl tape the other.
    You'll develop a list.
  4. #45504
    No, Felicity does those. I'm trying to ignore them while I do the deck.
  5. #45505
    You already have two on yours.
  6. #45506
    Aug 2017
    Melb, Vic, Aus
    Jeez.. that's sad news about the father and son. Such experience too.
  7. #45507
    Well I finally took the genoa off the forestay. I think it might be about a year since it's been unrolled, and 3 years since it's been lowered.I did take it down to check it over before we sailed up from Tassie.
  8. #45508
    And I got the anchor off. The controller on a leash was very handy, I worked the winch from the dock as I guided the anchor down. Even the galvanised shackle which was last undone about 6 years ago came apart without complaint or swearing.
  9. #45509
    And dismantled the anchor winch. Turns out the manual says to do that 3 times a year. Ive actually never done it. Bad man. Releasing the clutch took a bit of work but everything else unscrewed and came apart like a new one. Nothing stuck, no stripped screw slots, no sheared bolts. No hidden Springs going sproing bounce splash. Just easy.
  10. #45510
    The bad news, there had to be some, is that a bunch of bubbles appeared in the last bit of deck we did. Some air bubbles, between the glass and the peel ply I think, and some look like solid raised epoxy. Oh well, I see some sanding in my future.
  11. #45511
    Yep. Got a bit more info on that this morning. Apparently the dad's not been put in coma but the son has while they do all the surgery etc. that he needs. The story currently is that if you turn a petrol engine in a boat over and over trying to start it, vapour and fuel (or perhaps just vapour) builds up in the bilge (rather than dropping out onto the road in a car). Hence the explosion. And the fireball itself only lasted a second or so before extinguishing itself, so all the human damage was done in that instant. It's frightening.
  12. #45512
    Having had a decent 2nd degree burn to one hand it is indeed.
    The social contract that bestows authority — both moral and legal — on our political leaders is struck on the trust that they know what they are doing and will always act in our best interests:
  13. #45513
    That's a bugger Phil...bet when you started you thought it was going to be a much smaller job?
  14. #45514
    Blaxland, NSW, Australia
    At least it isn’t between the plywood and the glass, Phil. That really would be annoying.
    Awful news about the father and son. Lesson for us all. Fingers crossed for full recoveries for both.
  15. #45515
    Aug 2017
    Melb, Vic, Aus
    Would a carbon monoxide alarm worked in that situation?
    im not sure if it turns to carbon monoxide without burning it??
  16. #45516
    Always. I was hoping to remove the teak, replace the odd bit of ply and glass over it. Deep down I probably knew I'd be doing a new deck, which is why I've out it off for 8 years or so and brought the boat here to do it.
  17. #45517
    Aug 2017
    Melb, Vic, Aus
    are you going over it with a squidgie (spelling) after its rolled?
  18. #45518
    I didn't use a roller at all in the end. Just a squeegee. Left it all nice and smooth. Was very happy with it when I left the boat.
  19. #45519
    Aug 2017
    Melb, Vic, Aus
    so the areas you did roll came out ok? Maybe a roller is the go?
  20. #45520
    I don't know anything about peel ply so ignore this at your leisure, but wondering if maybe you're applying it too soon after epoxy?
    Maybe the epoxy should off gas a little more (and then perhaps another rolled on coat) and apply the peel while it is sticky, but not wet?
  21. #45521
    No. Didn't use a roller. Used a squeegee. I think it got too hot in the midday sun.
  22. #45522
    That's not what YouTube tells me. It needs to be able to float a bit to flatten out. The variable between success and less success seems to be the time of day. 30C direct sun not so good.
  23. #45523
    I literally weighed anchor when I got home. 40kg. And the winch is 40 kg too.
  24. #45524
    No great drama with the deck bubbles. A few minutes with a sander will fix the lumps. And kiwigrip.
  25. #45525
    Are you going to use a primer between the glass and the Kiwigrip? I've only used it over a two-pack primer. I'm too lazy to go out to the shed and read the tin or look up the website. The website's pretty good though - maybe I'll look it up.
  26. #45526
    I think I saw somewhere that a primer is recommended, so yes I will.
  27. #45527
    Okay, they reckon you don't need primer over fibreglass. https://www.pyiinc.com/KiwiGrip/applyingkiwigrip.html
  28. #45528
    I love this time of year. Days are still warm but not hot, mornings are just starting to crisp up, evenings are cooler, and we get wonderfully still mornings and evenings across the water. I like those calm grey autumn days but they're still a few weeks off.
  29. #45529
    Excellent. I guess no primer then. Can it go on smooth where I want it smooth? A margin around cabins and hatches and everything else? I'm already having nightmares about masking tape.
  30. #45530
    OK, I went to their website. Looks like the shiny bits have to be done first with something else. Probably a primer and some sort of 2 pack. Suggestions? Favourite flavours?
  31. #45531
    This is the time of year for sailing in our part of the world. It's one of the reasons I dislike Christmas. One is kind of obliged to have the big annual holiday at Christmas time. And usually the weather is pretty awful for sailing. It takes a huge effort of will to do any significant cruise around now rather than trying over Christmas. Hopefully this time next year.....
  32. #45532
    Weeeeell ...., I used Awlgrip and I just love the stuff. Purely by chance, the Awlgrip colour I use is identical to a Kiwigrip colour. It's a light beige - I'll find the name of it and post it. There are other paints that are just as tough as Awlgrip and possibly not quite as expensive .... but I don't know what they are. Awlgrip has amazing coverage. A 1 litre kit would be more than enough for your trim, cockpit and cabinsides etc. It's tricky stuff to use but easy once shown how. For primer, I use Jotun Penguard. It's a two-pack epoxy high-build primer. I like it because it really is high-build and it's easy to sand to a very smooth finish.
  33. #45533
    Aug 2017
    Melb, Vic, Aus
    Have you used norglass Rick? I'm thinking of using them.
  34. #45534
    Tricky to apply until shown how doesn't sound quite like my kind of paint! Although I'm open to a little tutoring.
  35. #45535
    I really like the company and many of their products but I've had no luck with their two-pack paints. I hate to say it but I really hate their two-pack primer, and I haven't been able to achieve a good finish with their two-pack poly finish coat. It could be just my technique.
    I spoke to a painter who rolled another paint onto a big cat in December and that came up really well. I could find out the name of that paint but it'll take me a while to find out.
