Page 1299 of 1423 FirstFirst ... 299799119912491289129812991300130913491399 ... LastLast
Results 45,431 to 45,465 of 49773
  1. #45431
    I think that's what I used, yes. One roller lasted the distance no worries and no hairloss as far as I could tell.
  2. #45432
    Feb 2014
    Sunshine Coast, QLD
    I lay down a couple of pieces of masking tape face up and run the rollers back and forth on that a few times to remove loose fluff. I had a roll of book covering contact which I used for the same purpose.
  3. #45433
    Feb 2014
    Sunshine Coast, QLD
    The deck does look good sealed up. Looks nice and fair too.
  4. #45434
    Haha, yes I took a photo of the nice fair bit!
  5. #45435
    Sep 2005
    new zealand
    Looking really good, Phil. As an alternative to sanding lumpy bits and raised grain prior to glassing, I'd offer this http://www.linbide.co.nz/product.php?c=26
    They are way quicker than sanding (seriously way quicker), produce shavings instead of dust, take of high spots more effectively, don't clog like sandpaper does with epoxy, the blades are solid carbide and last ages (you might need three or four on a job that big), and you dont need masks and goggles and ear defenders. And they cost maybe $15. I wish I could say I had shares in the company, I don't.
    After the you've knocked the worst of the lumps off with one of these, a quick whiz with a sander to matt the surface, and you're done.
    Pete
    I have seven trolls on ignore
  6. #45436
    Pete
    Lumps? Pffft.
  7. #45437
    A bit of protection on my deck. It's a nice feeling. Turned out I had to go over it with a brush asI rolled it on as the roller raised lots of bubbles. I only had 1 inch chip brush. Slow and frantic combined.
    That looks much better.
  8. #45438
    Cheers. It will look even better with some glass and primer and kiwigrip and toerails and jib tracks and cleats and fairleads and winches and.......beer.
  9. #45439
    Phil, how are you going to seal the chainplates - temporarily and permanently?
  10. #45440
    Have you made a map of beam locations etc. so that after you add paint you'll know where things go? Combined with photos, it can be very helpful.
  11. #45441
    That's a good idea. No I haven't.
  12. #45442
    I'm not going to seal them temporarily because it's not going to rain until mid May. In the original build they were a close fit and always leaked. I don't know what if any goop was used. I've left a CM or so clearance. I plan to fit a close fitting plate underneath, squish in as much butyl tape as I can and then screw down some sort of plate on top to create a compressed gasket.
  13. #45443
    Adelaide, South Australia
    The new owners of Arawana came for a sailing arvo today prior to settlement to make sure they are ok with how she behaves in the waves and wind. Two adults, two kids and an old pirate. Very relaxed tutoring from me and everything seemed to go very well.
    I'm happy to say that I'm happy. The new owners have taken ownership. The landlady at the berth is happy to have them there. Next weekend will be a sorting out of all the stuff that is stored onboard and in the shed.
    Arawana is in very good hands.
  14. #45444
    Now's the best time, while you can still see the screws.
  15. #45445
    Well done Bruce, lovely afternoon for a sail yesterday.
  16. #45446
    New Zealand's Far North
    That's good to hear Bruce. Well done!
    Money may not buy happiness, but it can buy a boat that will pull right up next to it!
  17. #45447
    +1
  18. #45448
    Feb 2014
    Sunshine Coast, QLD
    Excellent, Bruce. Well done!
  19. #45449
    Aug 2017
    Melb, Vic, Aus
    I'm happy your happy with the outcome Bruce.
    You had your fair share of internal debate going into this.
    You must like them. Good to see.
  20. #45450
    Feb 2014
    Sunshine Coast, QLD
    No Pixie work today. It's my wife's birthday and the kids and I have been tasked with building a pair of wicking garden beds out of this:
  21. #45451
    I wouldn't put anything on underneath. I'd slightly bevel the top of the slot in the ply/glass. Then make up a plate from phenolic or fibreglass that's about 20mm bigger than the slot all round and with a close-fitting slot for the chain plate. Bevel the underneath of the slot in this plate. Fill the void with Sika or Fixtech and fasten down the plate. The Sika will form a sort of o-ring where you've bevelled the ply and the slot in the plate.
    The plate doesn't really need to be fastened because the goop will hold it but you need good pressure to form the o-rings so I do screw them down. Use a West system for the screws.
    I use phenolic sheet (Tufnol/Auspeton/generic) for the plates. I can help with a source if necessary.
  22. #45452
    Thanks Rick. I'll put up a pic of the clearance I've left, it's quite large.i mistrust fixtech and sika. They don't seem to reliably hold a bond, particularly to stainless. Hence my thought of using butyl. Down here with Bruce now having boat coffee before we tackle the glass on the aft deck.
  23. #45453
    It's been that way on Pipsqueak for about 15 years without any leaking. The Sika goes off and remains a flexible pad, always being pushed against the edges due to the bevels, like an o-ring.
    If you use butyl, I'd recommend butyl mastic in a tube rather than the tape for your application.
  24. #45454
    Glass and peel ply on the aft section of the aft deck. Looked truly awful for a few minutes with wrinkles everywhere. Some more epoxy and peel ply and some squeegee work seemed to flatten it out. There's one white bit, forward, centre. Tried to wet that out but finally decided to leave it alone rather than risk making it worse. That will be cut our for the lazarette one day anyhow. A fair success I think.
  25. #45455
    Nice to get that on! Looks good!
  26. #45456
    Feb 2014
    Sunshine Coast, QLD
    Brilliant!
  27. #45457
    That fibreglass on Balia looks better in real life than in the photo.
  28. #45458
    From there we jumped forward to the side deck. We couldn't continue with the aft deck as we would have nowhere to stand.
  29. #45459
    All good!
    Just about to motor Masina down to Oyster Cover for another haulout. Some idiot's cleaned up the starboard side overnight a few weeks ago so I'm getting it fixed through insurance this week. We've no idea who did it, they hit two boats. There isn't much damage but she needs to come out for repair. The weather's looking pretty rainy so it might be a wet trip! Good run for the new gearbox anyway.
  30. #45460
    That's annoying, to say the least, hope the repair is as good as new
  31. #45461
    Bay of Islands,N.Z.
    Ah, catching up.
    Fantastic job there Phil. I'd even say awesome, but it's a bit overused.
    Even so ,its fair to say that I have watched progress with some awe..
  32. #45462
    Thanks JB, and everyone. I appreciate the encouragement. It is a huge job with scary bits around every corner. I genuinely wasn't sure I could do it when I started. Feeling more confident now.
  33. #45463
    Thanks. It'll be okay. I'd do it myself but by the time you pay haulout charges etc. you've spent as much as the insurance excess and you still have to do all the work! The guy doing it will do a good job.
    It was a bit wet getting going
    but we ended up having a really nice run down to Oyster Cove without much rain
    Some bad news though. While we were doing that, there was an explosion on a boat at Lemon Tree, apparently. A guy I know a little and his son are severely injured with burns. They've been helicoptered to hospital. That's all I know at this stage. They're really nice people with a long association with Lemon tree and all the boats. Craig is a shipwright. I'll learn more later but of course we're all really hoping the injuries are not as bad as it seems they might be. We don't know how the accident happened yet.
  34. #45464
    I'm not very proud of how I've fitted the deck around the shroud plates. The gap is deliberate, but could be tidier and better aligned as between the 2 layers. It's tricky to measure and fit due to the angle of the shroud plates, and fixed objects such as the cabin. Mostly I'm just a slob. Anyway my plan involves a support plate below and a compression plate above a large filling of goop, to allow plenty of room for the tiny bit of movement which seems to be inevitable. It's worked well where I've done repairs this way before. Yes Rick a source of tuffnol would be good.
  35. #45465
    Nice looking deck there Rick. I'm jealous. That's awful about the explosion. Scary.
