Page 1297 of 1416 FirstFirst ... 297797119712471287129612971298130713471397 ... LastLast
Results 45,361 to 45,395 of 49539
  1. #45361
    Smaller sections and do it as late in the evening as you can so it's cooling as it cures? Might minimize the outgassing.
  2. #45362
    You're limited in size by what you can reach. Do it in manageable sections as the day begins to cool. Use the roller to get the resin on and then roll the peel ply on. Use weights wrapped in plastic if it's windy. Have someone mixing the resin in smallish batches as you don't want it starting to go off as you roll it on. Test the rollers beforehand as some will leave hairs etc. in the resin. I think you can get mohair in 3/4 roller size - they're a bit expensive though. Have you already filled and faired all the joints etc.? Since you're using peel ply, you should be able to put primer straight onto the glass now, so it'd be good to have the surfaces fair from the start. Easier to fair it now with an angle grinder than later over glass.
  3. #45363
    New Zealand's Far North
    I have seen tarps held down by four litre bottles filled with water hung from every eyelet. Dunno if that could work for you.
    Money may not buy happiness, but it can buy a boat that will pull right up next to it!
  4. #45364
    Sanding and fairing today and tomorrow, thanks. I had left old deck around the starboard shrouds, thinking the deck was OK there. Well, hoping really. I did have a boatbuilder replace all the rot he could find there a few years ago. Turns out he missed a bit. This was early on when I thought I might be repairing more than replacing. Hahaha, if I knew then what I know now I'd have just ripped it clean out. Now I have a little more deck work to do. Still, I have other obligations in the evening next few days so can't really do any glass until probably Saturday.
    Tarps on sticks held down by bottles. Just no.
  5. #45365
    So I says to the boat, hey boat I says, you don't want to fcuk with me today cos I'm not in a very good mood, know what I mean? And the boat says sorry boss, I really am sorry. And I says Sorry, it's too late for sorry, that bit of rotten deck is a gonner. And so I did the fcuker. It's gone.
  6. #45366
    Feb 2014
    Sunshine Coast, QLD
    Clever.
  7. #45367
    Feb 2014
    Sunshine Coast, QLD
    Phil, Excellent to see that bit gone too. Is that the whole deck now?
  8. #45368
    Fhavent touched the foredeck yet.
  9. #45369
    Feb 2014
    Sunshine Coast, QLD
    I'm pleased with Pixie progress now, after getting only half of last week free and missing Monday this week.
    On Monday I had the box trailer on the car for a different errand so I took my outdoor work table to the boatyard. It's really high tech: a stack of six pallets topped with half a sheet of form ply, and it's awesome. Three or four of them are hardwood so it's heavy as hell and really stable. When part of it rots off I just get another pallet.
    On the boat, The Good Part is all glued up, roughly shaped and waiting for final shaping with longboard. The Less Good Part is 90% chopped out. It's down to the shape I want at one end and a couple of inches to go at the other end to get to good timber. I had to drive out a couple of long bolts, etc. I'm clearing out the amazing variety of gunge between ribs along the bottom edge of the planking as I go. I forget what that stuff's called, but the stuff that fills the hollows so water can run out, ya know. Some of it's tar. Some chalky white filler crap. Some straight resin which is almost like glass. It's a mess.
    I'm not going to spring a pair of planks and repair with a single piece because it would require far too much demolition (half the fasteners I'd need to get to are under the mast step) and shaping a piece like that for retrofitting is just horrible anyway. I'm going to put two pieces inside (so I can get them in through the gap, which is smaller than the required timber) and another on the face of those, overlapping the plank edges. It'll be plenty strong, and infinitely stronger than the missing piece of timber that wasn't there before.
  10. #45370
    Feb 2014
    Sunshine Coast, QLD
    Is the foredeck part of the program?
  11. #45371
    Feb 2014
    Sunshine Coast, QLD
    Oh, and the worms appear to have followed the rules and not crossed the seam into the knee above their civilisation, so I'm thankful to them for that courtesy at least.
  12. #45372
    Good work Matt. Sounds like a sensible approach.
    Yes the foredeck is definitely part of the program. Plenty of rot there. It's complex. Forehatch sits on its own structure the size of a small cabin. Anchor winch. Samson post. Stem fitting. With forestay and anchor rollers. Inner forestsay. Some mystery bronze fitting in the deck. Pulpit. Big job all on its own.
  13. #45373
    Excellent job Phil.
    Finally finished the batten pockets on the sail. The last one was the hardest. I think the big problem was trying to feed the sail through the machine. Friction and weight made it very frustrating.
    I am almost convinced it was harder to fit the batten pockets than it was to make the sail.
    I've been thinking about how to attach the batten parrels aft of the mast and I'm thinking of using stainless steel saddles.
    Now for the new sail cover which should be an absolute doddle after that job.
  14. #45374
    Sail cover. Now you have my attention!
  15. #45375
    I have some light blue awning canvas for it which is quite soft and manageable. My present sail cover is made from a couple of banners and the plastic material folds like cardboard.
  16. #45376
    Put up two 1964 Kombi headlight glass on ebay last night...and they are sold.
  17. #45377
    Blaxland, NSW, Australia
    Are you going to try simplifying the hatch structure or leave it as it is, Phil?
  18. #45378
    Good news on the worm front, Matt.
  19. #45379
    Quote Originally Posted by Alex1N View Post
    I'll leave it as it is.
  20. #45380
    Fixed that rotten bit by the shrouds. Would have liked to get more done today, but there you go. Working tomorrow and back to deck work Saturday.
  21. #45381
    Here's the underside of the forehatch and some top views. Much work still to do.
  22. #45382
    I suppose that there’s no reason to think that the stuff under the remaining bit of teak is going to be any different to the rest?
  23. #45383
    Correct!
  24. #45384
    Foredeck is 100% cactus
  25. #45385
    I had my first tool overboard event yesterday. I broke my little jemmy bar a week or two ago, and bought a replacement which just wasn't quite right. Slightly wrong angles and slightly shorter. So I wasn't too upset when the replacement slipped overboard and found the gap between the boat and the berth. More exciting was the belt sander, which thankfully didn't go for a swim. The power sockets on the berth are a bit tricky. Often the cord doesn't go in far enough. Yesterday I plugged in the cord and squeezed the trigger on the belt sander. Nothing. No life. Hopped off the boat and pushed the cord firmly home and ziiinnnng, away she goes! The sander took off across the deck, luckily ricocheted off the shroud and headed back inboard, as I pulled the plug. Seems I have a nasty habit of locking the trigger when I use the belt sander.
  26. #45386
    I lost a screwdriver over the side last weekend but as I have lots now I wasn’t too fussed.
  27. #45387
    Sydney Australia
    Stormy in Sydney last night, lots of hail, big ones.
  28. #45388
    I went out and covered our car but not to that extent.
    We had a clap of thunder that shook the house from the shockwaves but no hail.
  29. #45389
    I'm sure it's staged. I can't imagine anyone in Australia with a black 4wd ever doing anything sensible.
  30. #45390
    Feb 2014
    Sunshine Coast, QLD
    Staged. They have at least seven air mattresses, so they can't fit in one of those Jeep things. They need a people mover.
  31. #45391
    Sydney Australia
    Im sure youre prob right. who has that many air mattrsses?? even if the passenger side isnt covered.
    its off the ABC news site - could even be a stock photo from the interweb.
  32. #45392
    News coming through from Christchurch. Really sad and sorry to see this - kindest regards to all our friends in NZ.
  33. #45393
    Surely it would have been easier to put it in the garage?
  34. #45394
    The garage is full of all his other air mattresses.
  35. #45395
    Yes, awful.
