Page 1268 of 1384 FirstFirst ... 268768116812181258126712681269127813181368 ... LastLast
Results 44,346 to 44,380 of 48427
  1. #44346
    So...... where is it?
    Last week Auspost told me the gearbox would arrive yesterday. Then this week they told me it would arrive next week, so I've been whingeing about it all week. But it arrived today! Tomorrow morning I'll go out and see if it works. Expect lots of asterisks and stuff if it doesn't.
  2. #44347
    Adelaide, South Australia
    Bruce will remember this spot
    Nice spot. My berth is still reserved there for my return, I see. What do they know that I don't?
  3. #44348
    Thanks a lot!
  4. #44349
    Weeeeell, I'd definitely go with Peter's advice to put a roof over the deck if we could, but we can't. So, today I ordered 6 x 1 hardwood (a mix of tallow wood, ironbark and grey gum) planks to recover the deck. Not quite the 30 mm but better than 19. I will talk to the mill again and see if we can take it up to 30mm though. I'll space the planks about 12mm apart and leave gaps of about 5mm where lengths are butted together. No punching! Joists will be covered in plastic capping. I'm not sure yet whether we'll coat the new wood with anything yet - have to look into that. The 6 x 1 is $5.70 pm. 6 x 1.5 would be $8.60 pm. I'm not sure what 30mm will cost if they're prepared to do it but I think costing is roughly per m3 so I can work it out easily enough.......
    So that's going to be roughly $6.50 pm. i need about 175m sooooo .... about $150 more. That's okay!
  5. #44350
    Aug 2017
    Melb, Vic, Aus
    You could always coat the end grain with bitumen paint.
  6. #44351
    Reckon that would work? Might make it pretty goopy to walk on on hot days. Maybe something similar that stays hard?
  7. #44352
    I noticed a board walk down at Robe is done with that recycled plastic stuff. Looks OK..
  8. #44353
    Aug 2017
    Melb, Vic, Aus
    You can get a water based one. Dries hard
  9. #44354
    Surprising number of wooden boats at Port Fairy. You can buy the black one for $40,000. Or less.
  10. #44355
    Feb 2014
    Sunshine Coast, QLD
    Oooh, I like that (predictably).
  11. #44356
    Okay, I'll have a look - thanks! Decided to change the order to 1.5" thick boards. Dearer than the 1", of course but actually cheaper than 30mm as the mill would have high setup costs to mill a non-standard thickness.
    Port Fairy is nice.
  12. #44357
    Sep 2005
    new zealand
    Well?
    Pete
  13. #44358
    All good! A bit of a fiddle to get the shaft coupling back on and I had to make some new cover plate studs so I could fit the control cable bracket but ..... it works! I ran the boat against the mooring in forward and reverse for a while just to be sure but, it all seems fine. I'll head out on a calmer day just to make sure it's all smooth etc. but it seems really good at this point.
    I've posted this on the Nanni thread but apparently the selector fork was shot and so were some of the clutch plates. The guy's replaced the fork, cover plate and gearing and assures me that it's all really good now. Seems so to me. I'm really pleased to be past this hurdle!
    I hope Gypsie is making some progress with his engine issues. This engine I have is great. I hadn't run it for about 2 weeks. When I turn the ignition on, I can't even hear it turning over - it just starts instantly. I'm so pleased with it!
  14. #44359
    Woo hoo!
  15. #44360
    Feb 2014
    Sunshine Coast, QLD
    Excellent and yay!
  16. #44361
    Apr 2011
    Brisbane, Australia
    Sounds very good. My advice is not to paint with anything, because it will need refinishing often. If you really feel the need to, water based stain but not an oiled based finish. Water based is simply retreated by applying more coats but you'll hide the wood grain. At least you don't have to sand or scrape before the next coat though. With an oil based finish you need to sand and scrape. Yuck. However turps and linseed oil every now and then will keep it water repellent. Not too much linseed oil though or it will encourage mould.
  17. #44362
    Aug 2017
    Melb, Vic, Aus
    New toy. It had a fair old wobble so I modified the base.
    Its not sideways in real life.
    First time owning a band saw. Sooooo much easier the a jig saw I'm finding out
    I purchased it for all this type of stuff on Comet.
  18. #44363
    A new tool is always good.
  19. #44364
    A properly set up bandsaw is a great thing to have, that's for sure!
  20. #44365
    Good looking cleats too.
  21. #44366
    Boating
  22. #44367
    Sometimes a capsize is a good thing:
    https://www.abc.net.au/news/2019-01-...sland/10730366
  23. #44368
    This was on our boat today
  24. #44369
    Feb 2014
    Perth, Western Australia
    Yeah. Six people aboard, and they weren’t able to right it. Didn’t even make it out if the river mouth.
  25. #44370
    Been working on unlocking the two iPads I have, well today I managed one and got the other to the point of being able to install apps. One I came across is GpsNauticalCharts-LITE. I've only downloaded the charts for my area but the detail for the Tweed River up to just past Stott's Island is impressive, and it's free.
  26. #44371
    Quote Originally Posted by suzyj View Post
    Fortunately!
  27. #44372
    Sydney Australia
    Two metre waves?? That must be an exaggeration, but some big wakes are definitely possible judging by the boats charging thru the channel behind.
  28. #44373
    Pleased to report sea trials in the restored International Cadet were exceedingly successful. Fore and aft watertight compartments I restored or refurbished (new transom) are just that. Cockpit (unrestored) leaked at first but settled down. Jolly Roger sails well but I'm not used to a jib, and it's set up for two. Some adaptions to be made.
  29. #44374
    Sydney Australia
    I'm guessing it's a Bugatti Atlantique replica, but some people there cars have crept in too. Bit of XK120, even a bit of Morris Minor around the cabin.
    Whatever, it looks long. And not ideal for touring tassie either.
  30. #44375
    Yeah not ideal. Shoulda got a Hyundai I guess.
  31. #44376
    Sep 2009
    Sydney OZ.
    Yep a replicar, maybe a Jag engine. BTW the Bugs at Mulhouse are rather flash, the Esders in particular. I have some pics of Lydia with an Atlantique at the musee. I was car-ried out after 4 hours.
    Xanthorrea
  32. #44377
    Were there any boats?
  33. #44378
    Bump. GpsNauticalCharts-LITE
  34. #44379
    Sydney Australia
    Clearly none worth a photo.
    But if it were made from wood? it may qualify.
  35. #44380
    Sep 2009
    Sydney OZ.
    perhaps an amphicar and a Schwimmwagen. Happy?
    Xanthorrea
