Page 1257 of 1303 FirstFirst ... 2577571157120712471256125712581267 ... LastLast
Results 43,961 to 43,995 of 45579
  1. #43961
    Certainly good to have an escape pod.
  2. #43962
    There's a Steel boat up near the quarry, about 10 m above present sea level………………..
  3. #43963
    Jul 2017
    Toodyay, Western Australia
    Near the quarry... taking in ballast maybe?
  4. #43964
    Feb 2014
    Sunshine Coast, QLD
    Maybe global warming and rising sea levels are starting to alarm some people. Hold onto your boat for a few more years, the price may go into orbit.
    If the sea level keeps rising, and Arawana keeps rising relative to sea level, Arawana will eventually go into orbit.
  5. #43965
    There's a Steel boat up near the quarry, about 10 m above present sea level……………&hell ip;..
    Waiting for the quarry to hit the water table?
  6. #43966
    Feb 2014
    Sunshine Coast, QLD
    Does anyone here want, or know someone who could use, a small set of lifelines?
    The stantions are 500mm high. Six per side. The bases are separate, and most have some slight angle to match the deck. Bases are 100x50mm with four bolt holes.
    The total length including the drops each end (see photo) is around 5m.
    Everything is still together, including a full set of mounting bolts.
    In my opinion the mounting bolts aren't adequate, being pieces of threaded rod which were glued into the deck, with cap nuts holding the stantion bases. It's all there, though.
  7. #43967
    Feb 2014
    Sunshine Coast, QLD
    Also, anyone want 4x Barlow #15 winches that need cleaning up, regreasing and reassembling?
  8. #43968
    Jul 2017
    Why don't you want your lifelines and winches? Is the boat dead?
  9. #43969
    Feb 2014
    Sunshine Coast, QLD
    The boat has been reborn without lifelines, and with different winches. (she's this boat now)
    I'm cleaning out the garage, and these things aren't particularly saleable but will almost certainly be useful to the right person. :-)
  10. #43970
    Feb 2014
    Sunshine Coast, QLD
    All the old standing rigging is sitting around here too, but I figured it's not much good for a boat, being really old, so I figured I'd offer it locally on Gumtree or Freecycle or something.
  11. #43971
    That's a stunning transformation
  12. #43972
    Jul 2017
    Oh I did see the pic of what she is now, just hadn't connected that with what she was. What a transformation!
  13. #43973
    Feb 2014
    Sunshine Coast, QLD
    She could be seen trying to get out. Just had to squint a bit:
  14. #43974
    Feb 2014
    Sunshine Coast, QLD
    Wow. I had not looked at those two photos side-by-side until just then!
  15. #43975
    Gold Coast Australia
    Just as well you rescued her Matt she would have had a permanent mud berth had she stayed in that location .last time we visited Kangeroo Pt the whole basin was completely silted.
  16. #43976
    Bloody marvelous !
  17. #43977
    Jul 2017
    Just noticing your standing rigging... synthetic?
  18. #43978
    Feb 2014
    Sunshine Coast, QLD
    Yes.
    I was almost going to chime in on your thread asking about this, but I don't have enough experience with the other options.
    Add my voice to the others who have said "You'll never look back once you try it." It's SO easy to work with even I can do it.
  19. #43979
    Feb 2008
    Berlin, Germany
    I second that. She looks like a real sailing vessel now!
  20. #43980
    What are your new winches Matt?
  21. #43981
    Years ago I almost bought Resolution a 48’Gaffer that leisurely sailed around the world with Horst and Susan Oltjen aboard.
    The only winch aboard Resolution was the anchor windlass.
  22. #43982
    Bloody marvelous !
    I like the before and after...particularly the after, nice work.
  23. #43983
    Matt I think you've been seriously delinquent in your obligation to post photos and updates here.
  24. #43984
    Feb 2014
    Sunshine Coast, QLD
    They're old, not new :-) Some little bottom-handle bronze snubbers found in the spare parts box at the slipway. I forget the name on them. There are no winches on the mast now.
    I'm finding that I don't really use them as sheet winches much. The loads aren't very high, and I sheet in by pulling athwartships on the sheet between the winch and cleat, then taking up on the cleat. The runners are set up to go onto the winch, so they are used for that when I'm feeling keen..
    I know. Sorry! :-) Still no photos sailing, but I haven't missed a week.
    I went out on Thursday for a quick look and resolved (afterwards) to sail in and out of the creek even when single handed (which I was at the time) because the chop at the creek mouth in a NE'er is crap with no sails up, and the motor is hopeless in the chop too. Low tide made it worse. I have to keep reminding myself: There's room inside to head up and drop sails!
    Trying to hoist and hand sails with one arm around the mast to hold on is just silly when there's all that flat water inside.
  25. #43985
    Sounds like you have an ideal location!
  26. #43986
    I was quietly thinking that motor is a bit of a travesty
  27. #43987
    Feb 2014
    Sunshine Coast, QLD
    Yep. It's a good little harbour.
    I sail in when I have someone to steer while I drop sails, but I'm going to start doing it single handed too. If the wind is on the nose going in, then it's from the SE and the sea outside isn't as bad so I can motor in.
    I don't have a quick way to lash the tiller, so I think that'll be the next thing to tweak. That'll get me another thirty seconds sometimes. :-)
  28. #43988
    Feb 2014
    Sunshine Coast, QLD
    I speak that thought loudly and frequently. If the motor was actually any good then I could almost tolerate the extraordinary ugliness. But it's barely any @#&* use either!
    Once I'm more confident sailing in and out, and have that yuloh working...
  29. #43989
    Feb 2014
    Sunshine Coast, QLD
    My long term plan is for a little inboard electric motor. I already have a 15" Gori 2-blade folding prop I got on eBay. It's going to be installed offset.
  30. #43990
    Jul 2017
    Yes.
    Yep, I'm going to give it a whirl. Bought some Dynice dux. If you are willing to post more photos I would be keen to see any details of your rig.
  31. #43991
    Have you looked at this thread on setting up a Dyneema rig? http://forum.woodenboat.com/showthre...Served-Dyneema
  32. #43992
    Feb 2014
    Sunshine Coast, QLD
    That's one of my favourite threads. :-)
  33. #43993
    Jul 2017
    Yes, read it cover to cover at least a hundred times (so far). Initially I had been thinking to copy, but have some reservations, the biggest being that dyneema's weak point is high temperature... apparently over 70 degrees is enough to damage it. So bearing in mind that my part of the world sometimes hits 50 degrees in the shade, what do you reckon are the chances for a rig made from dyneema, wrapped in mat black serving, sitting in the sun in summer?
  34. #43994
    Toast! I wasn't aware of Dyneema's temperature sensitivity! Here in the NW US we don't have that heat problem...hypOthermia tends to be more of an issue. Thanks for the heads-up...I'll obviously have to do more research before I think Dyneema for rigging as we do see 30-32 C fairly often in the summer... and sub-zero C in the winter.
  35. #43995
    Jul 2017
    There are some strength by temperature data published by DSM which should be easy to locate with some googling. Dyneema is supposed to be excellent for cold temperature, so depends where you're going. I suspect bare dyneema, or dyneema with a pale coloured cover may be ok even in a hot climate. A black cover, however, might get too hot in some parts of the world. Having said that, Spectra is essentially the same material and has been around for decades, yet I've not heard of temperature related failures even though some ropes have quite dark coloured covers. All a bit confusing really.
