Page 1247 of 1259 FirstFirst ... 2477471147119712371246124712481257 ... LastLast
Results 43,611 to 43,645 of 44043
  1. #43611
    Feb 2014
    Sunshine Coast, QLD
    I want to know what knot is used. Whatknot?
    Here is the Colligo Marine writeup on how they do the lashings:
    http://www.colligomarine.com/s/Colli...ev-13-max8.pdf
  2. #43612
    Pixie's deadeyes are from Peter Kerr's pattern, which he made for Pixie and the new dhow which Tom posted photos of. I don't want anyone copying them directly.
    But honestly there aren't many different shapes they can be, as they are essentially based on a thimble. They are similar to the Colligo aluminium ones, though solid other than the lashing holes, so they look more like a traditional deadeye than the Colligo version.
    Peter, your photo a couple of posts back would work fine as a solid part with lashing holes for the lanyards. Some rigs even use a simple thimble as you've pictured and allow the lashings to just stack in the thimble. The thing to be concerned about is the radius you are putting the dux around, and radiusing the lashing holes so they run smooth, and are large enough radius if the lanyard is also dux, which Pixie's are not.
    If you send me or post a drawing of what you need I'll see what I can do.
    or is this it ?
  3. #43613
    Feb 2014
    Sunshine Coast, QLD
    They are basically like that, yes. Mine don't have the triangular cutout.
    The size depends on what size line is being spliced onto them. If you look up Colligo's info on their "Terminator", you will find dimensions and sizing guides based on line thickness.
    On Pixie (and the dhow), there is no deadeye at the bottom of the lashing. The lashing goes onto a large smooth eye which is part of the chainplate. Have a look at Tom's photos of the dhow back a few pages. Colligo's bottom deadeye as in that last photo above is so they can retrofit them to existing chainplates with a pin.
    Tom is the one needing parts, so check with Tom.
  4. #43614
    I'm just learning about various people preferred options .Here's an interesting image from my files.
  5. #43615
    Feb 2014
    Sunshine Coast, QLD
    That's exactly the kind of thing to shoot for. The only change needed to that example is a nice smooth radiused run all the way through the lashing holes.
  6. #43616
    That would be work for a Dremel or a lot of filing.
  7. #43617
    Nice sail today both up and down the river. Light winds with the occasional slightly stiffer breeze that got me up around 4 knots. Beating back against the tide was a relaxed challenge and I only used the outboard a few times to get me through the short stretches where it was right on the nose. The transom mount depth sounder was bloody annoying though.
  8. #43618
    Gold Coast Australia
    Hey Peter yes I would love to buy some of those of you should you decide to proceed in that direction.
    I believe there could be a niche market for such fittings as new ways of rigging using Dyneema are embraced by more traditionalists and mainstream riggers.
  9. #43619
    Saw this rather Interesting mooring design at Boyd’s Bay Bridge today designed by an engineer, I like it. The placement of the mooring went relatively smooth. Placed inside an alloy skiff with some flotation attached to one side,then the bungs where opened and the mooring just rolled out of the skiff before it hit bottom.With some additional flotation attached to the 200kg pipe a diver was able to turn it right sideup in about 3m of water.
    [IMG][/IMG]
  10. #43620
    It looks like a pretty light mooring Tom?
  11. #43621
    The bottom has welded slats and believe the owner went down with scuba and probably bedded it using air pressure.,once filled with sand it would in my opinion far outweigh my one ton block on the seabed surface.
  12. #43622
    I'll make a pattern. What size lines are used with it, your WB anyway?
  13. #43623
    Adelaide, South Australia
    Default Antipodean Boats Connection
    Currently fire warnings for the area north of Newcastle including Tanilba, Mallabula and LTP. Fingers crossed for Rick Tracey Woody and the property, and all the good people there 😞 😞
    Paperback E-book
  14. #43624
    Likely, I'd like a well bedded in one ton concrete block with a length of 25mm chain protruding.
  15. #43625
    Currently fire warnings for the area north of Newcastle including Tanilba, Mallabula and LTP. Fingers crossed for Rick Tracey Woody and the property, and all the good people there  
    They had fire last year didn't they? It's looking like being a cruel year.
  16. #43626
    This time it's very close to Rick and Tracey's place. Still not controlled/contained.
    Concerned. Watching the RFS map and reports, updates 15 mins. The fire is moving up the peninsula their place is on, not moving into Tanilba built up area but right up to it. They are on the far side of the built up area from the fire front, except that a smaller fire seems to have broken out ahead of the front, further along the peninsula from their place.
    Paperback E-book
  17. #43627
    Got a message from Rick. They are in Newcastle so not near the fire.
    Paperback E-book
  18. #43628
    But their house is .
  19. #43629
    Thanks Bruce! Yep, stuck in Newcastle. The fire is close but not very close. The wind has eased and the fire has gone from Emergency to Watch and Act. Our neighbours are watching out for spotfires. Really early in the year for this! No property damage as far as I know but, as always, wildlife will be devastated. I'll go home once the road opens. The wind's supposed to be strong tomorrow and through to Wednesday.
  20. #43630
    I hear what you are saying Peter. My one ton block has 3m of barge chain shackled to the 9 m of 13 mm chain.The depth around my block is just over three meters and the vessels are tightly positioned at Boyd’s Bay.
    The block will be covered before long courtesy of the recent dredger leaving a prominent beach behind , that is now slowly eroding our anchorage.
  21. #43631
    Sep 2005
    new zealand
    Mr Sibley, how many times on this forum have people asked for a supplier of cranse irons, that they don't have to sell a kidney for? I've lost count, over the years.
    They look like a relatively simple casting (what would I know), and something that perhaps could be patterned and cast to order, given an inside diameter and number of tangs.
    Oarlocks are the other one that crops up time after time.
    Good luck with the fires :-/
    Pete
  22. #43632
    Pete
    Speaking of cranse irons I recently pulled Wee Barkie’s design drawings and found this interesting version of a masthead fitting possibly drawn by WB designer Wilf OKell.
    I am not suggesting you cast these Peter.
    [IMG][/IMG]
  23. #43633
    Good luck with the fire Rick, hope it stays well away from you. On moorings, old train wheels are a favourite in SA and Tassie. They have plenty of weight and because of their shape sink well into mud or sand to get a good grip on the bottom. That one Tommhas pictured looks like a truck rim with a bit of pipe across it? Probably OK for a 20 footer?
  24. #43634
    Pete
    Cranse irons appear to be quite custom, every boat 's requirements seem to vary in diameter and number of tangs. Is there a likely standard? 100 mm diameter and 4 tangs ?
    Rowlocks are on the list.
  25. #43635
    Thanks everyone re the bushfire. Looks like it's pretty much burnt out now. The wind is pretty strong but the fire's burnt up to all the settlement areas so nowhere else to go, I think. Horrible to see everything burnt again but otherwise, all okay here.
  26. #43636
    Sep 2005
    new zealand
    That is my point - as a low volume producer, you a perhaps in a really good position to do the pattern making and casting to order? The more you do, I suppose the more likely it becomes that you'll have a pattern that suits.
    Pete
  27. #43637
    A good point .
  28. #43638
    Bugger. Seems like it's seagull nesting season. I have no regard for seagulls.
  29. #43639
    Sydney Australia
    Maximum sympathy to you.
    I have suffered the seagulls nesting on my foredeck more than once. between the forestay and the anchor windlass.
    First time, i came on board to find a nest with a some eggs. And hovering noisy parents. I didnt feel too good doing it but i knew i had to drop the lot overboard.
    The next time, after being away for 6 weeks, i returned to the boat and found two chicks. And hovering noisy parents.
    Daughter was with me so I had zero chance of doing anything but swear and row back to shore.
    Two weeks later, they'd moved aft to the shelter of the boom awning and covered the cockpit floor with sh!t. Very angry parents doing good impressions of kamikaze seagulls.
    Rowed back to shore.
    Two weeks later returned to a seagull-less but sh!t-filled cockpit. Very unpleasant job cleaning it out. Daughter uninterested in helping.
    Moral: get rid of any nests at earliest opportunity.
  30. #43640
    My only comment on seagulls is they are better than cormorants.
  31. #43641
    Thanks, glad I'm not the only nest wrecker.
  32. #43642
    Had the wind almost on the nose here so I was motoring.
  33. #43643
    Calvin and Hobbes expressing their opinion of my new hat.
  34. #43644
    Looks like you just sailed in from Cuba, watch out for our Border Farce……………..
  35. #43645
    and all that cocaine in your hollow keel.
