Page 1241 of 1393 FirstFirst ... 241741114111911231124012411242125112911341 ... LastLast
Results 43,401 to 43,435 of 48735
  1. #43401
    Tried drilling the heads off. Not happy with that approach.
  2. #43402
    But I thought I heard your camera was not waterproof? Phone is great for ease of use. It's normally nearby. Unlock. Touch the camera icon. Point and shoot. Open Tapatalk and post here.
    I intend to buy a waterproof one. It's not just taking the shot that's fiddly with a phone. It's all the photo processing etc. I'd rather just put a memory card into the computer, download the photos and use decent software to manage image size, cropping etc.
  3. #43403
    With bronze screws, I'd definitely persevere with drilling the heads off. Use a centreing bit - you know those ones that fit in a lathe? Make a decent hole in the screw with that then use a bigger bit to shave off the head. If you carve around the screw, you end up damaging the rail too much. I've tried the drilling approach with SS and found it useless but I use it with bronze and it works really well. The bit needs to be sharp so best to buy a new one!
    Alternatively, you can use a small drill bit to form a pilot hole but they tend to be too bendy so the centreing bit is better.
  4. #43404
    Thanks Rick. I don't know those bits but sounds encouraging. Don't have a picture do you? I'll try that before I start cutting divots.
  5. #43405
    I don't have a picture handy but they're basically just a little bit of steel rod with a just a nib of drill at each end.
    Look up centreing bit - I'll do the same and post if I'm quicker.
  6. #43406
    Bunnings list them. Kind of a drill bit inside a guide?
  7. #43407
    I tried a normal small bit and it snagged and broke. Bigger bit gets pushed sideways about when it gets through the head I think. As you say, it tears up the rail a bit and I'm sure it leaves enough of an ear on the screw that the rail won't slide up over it.
  8. #43408
  9. #43409
    There are also self-centreing drill bits that are basically an ordinary drill bit with the nib of a smaller bit - but I don't know where you'd get one. Any tool shop would have the centreing bits.
  10. #43410
    Yep, the starting is the critical and most difficult part. Once you get going with a little pilot hole, it's all easy. Another thing you could try - I haven't but I think it would work, is a good, metal countersink. It would have to be sharp and tough. The centreing bit would be better though, I'm sure.
  11. #43411
    PS Whatever you use, start with a centre punch!
  12. #43412
    Hopefully next week...apart from Monday or Tuesday, what days are you home?
    Wednesday is it Gary. See you ?
  13. #43413
    Now I have to take the outlaws on a city tour ....... good luck!!
  14. #43414
    Ooh can you show me too? My phone memory is almost full. I don't need to carry 10000 photos around in my pocket. Want to move all to the cloud ideally. Or to my laptop. Or both. But don't want to do it one by one or sort them or anything. Just move the lot.
    If your phone is an iPhone you should be able to plug it into the computer via a USB lead. The computer should detect it as an external drive. If the photos are stored on the SD card you can remove it and plug that into the computer if it has a card slot. You can most likely install an app on your phone for your preferred cloud ie Dropbox. If you want to use Dropbox create an account and install it on the computer. Any files you upload will appear in the Dropbox folder on your computer.
  15. #43415
    Once the head is off I came up with a neat way of removing a broken screw in JIM. I took a 3'' length of thin walled stainless tube, from a car aerial I think, cut little teeth in the end, set in the battery drill and ran it down over the screw. When It got to the bottom of the screw the short grain snapped and I pulled the whole lot out then glued a dowel into the hole.
  16. #43416
    Wednesday sounds good to me, I’ll let you know when once I’ve consulted the boss.
  17. #43417
    DAY 122: Susie Goodall 4th at Hobart film gate
    Istvan Kopar ETA at Boatshed.com Hobart Gate Saturday
    Reassuring news from Igor Zaretskiy
    Dateline 12:00 UTC 31.10.2018 – Hobart, Tasmania
    29-year old Golden Globe Race skipper Susie Goodall made good use of her time in Hobart to repair her wind vane self-steering and dive to clear barnacles clinging to the bottom of her Rustler 36 yacht DHL Starlight.Golden Globe news.
    https://goldengloberace.com/day-122-...qu_AEPKlT1khnk
  18. #43418
    Thanks Rick. Thanks Peter. Hoping to pull the rail off once the screw heads are gone. Then I can get te screws out with multigrips. Or cut them off.
  19. #43419
    Of course it might be best to just go in from the side with one of those little jiggly saws. Hmmm.
  20. #43420
    Feb 2014
    Sunshine Coast, QLD
    Phil, have you got one of those old-skool impact drivers that you tap the handle with a hammer, so they impact downwards on the screw at the same time as twisting it out? I had success with quite a few bronze and brass screws that wouldn't come out any other way. A drop of penetrating oil around each screw head an hour before might help too.
  21. #43421
    Feb 2014
    Sunshine Coast, QLD
    That is really clever!
  22. #43422
    I do have an impact driver. Might try that too. Finished for now. Tool shops are a long way away and I have a sore pinky finger from a disagreement with a gate the other day. It's starting to complain. Off to Tassie tomorrow night so deck work will have to wait. We had quite a bit of rain in the hills last night. Not sure how much down here. Not too much came in. I know this won't be anywhere near perfect but it should reduce the water ingress a bit further on the event of more rain.
  23. #43423
    If you have a Gmail account you can use Google Pics app. It does all that automagically - and will even delete the saved images form your phone.
    Download the app, sign in with your Gmail email and off it goes.
  24. #43424
    I've used electric impact drivers and manual ones. Again, they're particularly good with SS screws, and what I usually use. Success with bronze, though, is mixed. If the bronze is good and strong, great. But if the bronze isn't, then the driver can just break the head. Which would be okay if it broke the head right off but it usually just breaks half the head off or just scrapes out the slot. Certainly the best method to try first though because it's simple and fast. I have more success with the electric driver and it's also easier to find driver bits for that one. Manual driver kits typically come with bits that are too big for most screws in a boat. You can modify them, of course.
  25. #43425
    Feb 2014
    Sunshine Coast, QLD
    I find the manual one works better because it's being driven down against the head along with the twist. The electric one is too brutal. I even got out some particularly stubborn brass screws inside the boat with heads that wanted to disintegrate. Gentle work with the manual impact driver after a bit of oil on the screw worked. If you push and hold a manual impact driver down to the end of its travel, then light hammer taps transfer directly to torsion and you can be quite gentle.
  26. #43426
    Feb 2014
    Sunshine Coast, QLD
    It's not all magic unicorns of course. When attempting a bunch of old brass screws there are plenty of lost causes where the screw head is almost powder already. Bronze isn't as bad.
  27. #43427
    Sounds good, Ill try that I think
  28. #43428
    I hope not to find any brass screws.
  29. #43429
    Feb 2014
    Sunshine Coast, QLD
    You should certainly hope not.
    I wasn't that lucky with Pixie, even outside.
    Inside, whatever crazy person replaced all the furniture (in maybe the late 80's or early 90's) decided it was okay to use steel screws when he ran out of brass ones. If I ever meet him I'm going to slap him.
  30. #43430
    Yep. But electric drivers are not all the same. I use a Bosch one that doesn't have that brutal kick. It takes off quite slowly and softly so you have good control. A hammer drill with the clutch wound back also works well.
    There are plenty of ways to skin this cat and plenty of variables.
  31. #43431
    Feb 2014
    Sunshine Coast, QLD
    Exactly, on the plenty of ways to skin a cat.
    I prefer a driver drill with the clutch wound back too. I haven't tried any impact driver other than the cheap and nasty ones.
  32. #43432
    So, bear with me please. I've downloaded Google pics onto my phone, and it's picked up all my photos and videos. But they are still on the phone photos icon too. How do I delete the whole lot from the phone memory, and is it safe to do so? Like it won't sync with google pics and delete from there too will it? That would be annoying. There's 3000 odd photos, and at least 10 worth keeping.
  33. #43433
    Jul 2017
    Toodyay, Western Australia
    Skinning cats with electric drills brings to mind bits of flesh spinning at high speed. Could be a messy way to do it.
  34. #43434
    Feb 2014
    Sunshine Coast, QLD
    You can also bash the cat over the head with the cheapo impact driver drill when the crappy battery dies.
  35. #43435
    I've found a way around the RMS stupidity and rule changing. I've sold the trailer to a good mate in Queensland who has registered it there..... with no trouble at all. He's going to sell it back to me and I'll transfer the rego to NSW.
