Page 1228 of 1233 FirstFirst ... 228728112811781218122712281229 ... LastLast
Results 42,946 to 42,980 of 43131
  1. #42946
    Or tools and materials
  2. #42947
    Sep 2005
    new zealand
    I don't know about the welders themselves, but my boy (apprentice diesel mechanic) was amazed at the difference using argon, instead of CO2 made, on the industrial strength welder they use for truck chassis repairs.
    The place he works at has just changed hands, and the new owners are happy to spend the $ for argon. He said with CO2, there was a lot of splatter and the weld pool was hard to control, but argon makes all those problems go away.
    My brother had one of the cheapie mig welders on CO2, and it was really carp. Makes me want to try it on argon, not an option now unfortunately.
    Pete
  3. #42948
    I should buy one but my 50 year old 130 amp Comweld stick won't stop working .
  4. #42949
    I have a couple of stick welders, but hoping to make less holes in thin stuff with MIG
  5. #42950
    A heat sink on the back of the thin stuff weld really helps.... a bit of heavy solid section.
  6. #42951
    Jul 2017
    Toodyay, Western Australia
    I've used an industrial type mig for welding new material into an old boat trailer. Very easy to get good welds. The welder was pretty massive, would likely need a crane to get it on the back of a ute. Also have done loads of gas welding. Used gas to build a new petrol tank, and lots of tubes for various structures. Gas is awesome for portability and not as expensive now that bunnings supplies oxy and acetylene. Despite success with these types, I can't create even a farmer quality weld with stick welder. Too unco when I can't see anything before getting the arc going, by which time I'm nowhere near where I wanted the weld.
  7. #42952
    Treating myself to some more episodes of Keep Turning Left.
  8. #42953
    Highest download speed 1.2 mbs/sec, average is around 300-400 kbs/sec.
  9. #42954
    Try an auto darkening helmet. I've just bought one.
  10. #42955
    May 2014
    i've got a small gas/gasless mig, i've never had much success running it with gas, i think because i always use it outside and there's too much airflow. I'm a shocking welder, but the auto-darkening helmets definitely make a big difference in ease of use,
  11. #42956
    Aug 2017
    Melb, Vic, Aus
    Hi Phil. I have done about 8 years of structural welding when I used to live in Darwin. 99% stick welding. I bought a mig welder a couple of years ago. Its a great little welder. It its not the inverter type so weighs probably 45 kgs which makes it awkward to move around. Yeah, I need to build a trolley. I like the stick for its simplicity, point and shoot kinda thing. The mig always seems to have something going wrong with it. Tips clog up, gas runs out, had trigger problems so it's definitely not the point and shoot type. Saying that I've used it heaps for the thin stuff and its great when working well. I think if your looking in the $500 range your going to do fine. And definitely get an auto darkening helmet. One thing I have noticed is the mig is a LOT hotter so you get welding burn on your arms very quickly if not covered up. I'm even thinking of getting a leather vest to cut the radiation down on the torso. Cheers Steve
  12. #42957
    Aug 2017
    Melb, Vic, Aus
    Also, fine adjustments can make a big difference in your results. So you need to tune it on some scrap. Gas pressure, wire speed and amps. Get them all just right and it welds itself
  13. #42958
    Thanks Steve, and others. This being a wooden boat forum, I suppose you will knock up a nice little trolley out of wood. Will you use ply for the base or maybe strip plank it? Pelagos, what size/price is your welder? I'm wondering if those are to some extent issues with the smallest of the breed.
  14. #42959
    Brrrr...back to winter. Got about 8 trees coming down tomorrow so that will increase our winter sun hours...though not in the mornings. I'd have to remove the ridge line for that.
  15. #42960
    Question maybe for Steve, but anyone who has relevant (in)experience. Like others, I am a really bad stick welder. I don't do it enough to develop any fluency. So it's lumpy and bumpy, I blow holes in what I'm welding. Sometimes I do a lovely run of welding and when I take the helmet off and look, the weld is all on one piece of the metal I'd hoped to join together. Am I going to do better with a MIG?
  16. #42961
    Aug 2017
    Melb, Vic, Aus
    Mig is heaps easier. Its going to take some practice to tune it though. If its not melting together with the greatest of ease your tuning is wrong. Wire speed to fast/slow temperature to hot/cold.
    Definitely stip plank. I've got the ceder already
  17. #42962
    Aug 2017
    Melb, Vic, Aus
    Same with the stick welding. Right size rods for the materials right amps and then practice. Just more of it with the stick.
  18. #42963
    I have an ancient stick arc welder, I actually read up some of the theory in a manual for apprentices.
    That and practice just to get your hand/eye coordination right. (My welds are still lumpy however…………)
  19. #42964
    Adelaide, South Australia
    You'll need to use a trunnell to fix the strips to the gunnell, it will keep the wooden purists in their seats.
    Paperback E-book
  20. #42965
    Down hand and vertical ups are easy but overheads are beyond me.
  21. #42966
    Perfect, thanks.
  22. #42967
    Aug 2017
    Melb, Vic, Aus
    Its probably to hot
  23. #42968
    Aug 2017
    Melb, Vic, Aus
    if your Amps are right and its still lumpy its the speed at which your laying it down. I just keep a nice little pool going behind the stick. You could just practice going faster and then slower, pull the stick in and out, You will see where it wants to be...
    in a nice state of flow, its pretty forgiving once you get the hang of it.
  24. #42969
    Aug 2017
    Melb, Vic, Aus
    i had to google trunnell
  25. #42970
    A bit like oxy acetylene .
  26. #42971
    Once you get the hang of it. My problem is I might do a 6 inch run of welding once every 6 months or a year. Usually on rusty dirty steel in a difficult position. And probably in a hurry.
  27. #42972
    Aug 2017
    Melb, Vic, Aus
    Yeah, that can be a propblem.
    Years ago I landed a job laboring for an Italian steel worker In Darwin. I asked how to weld and he said "you just stick the two bits of steel together".
    Every lunch time I would scoff my lunch and grab his helmet and spend 20 mins each day (the rest of my lunch time) welding bits of scrap. A couple of weeks later he said, "you better go buy yourself a helmet, he started giving me little welding jobs and I got the hang of it.
    20 mins a day for a couple of weeks and you will be stickin bits of steel together for sure
    Im not sure what you mean Peter?
  28. #42973
    Aug 2017
    Melb, Vic, Aus
    Oh, with the pool you mean? Yeah definitely.
  29. #42974
    We dropped around 8 trees today. Really increased the sunlight on the panels and I can see so much more night sky.
    He had to go up this one and remove some of the downhill weight.
    And one of the house.
  30. #42975
    Jul 2017
    What type of trees are they?
  31. #42976
    The white trunks are probably e. grandis, flooded gum.
    Is that Loz climbing Gary ?
  32. #42977
    Jul 2017
    My place is covered in wandoo, kind of similar bark to Gary's trees, but Gary's lot look to be seriously big... whatever they are. Is flooded gum usable for anything boatish?
  33. #42978
    Yes it is Loz and isn’t he bloody good at, every tree where we wanted it, of course the chain block helped. Love the sling shot he uses to get a line up high.
    the trees are blue gums. I put a video on Facebook of dropping the big one. Turn up the volume for full effect.
  34. #42979
    I built Redwing out of Flooded gum, it will rot if fresh water gets into it.
  35. #42980
    Jul 2017
    Your experience has prompted me to be ultra vigilant sealing everything in sight (and out of sight) with about a thousand coats of epoxy. Hopefully keeps the rot at bay.
