Page 1161 of 1302 FirstFirst ... 161661106111111151116011611162117112111261 ... LastLast
Results 40,601 to 40,635 of 45548
  1. #40601
    Adelaide, South Australia
    This heat is oppressive. Maybe being 65 does that to a hobo. Anyway, thanks to Phil I've tried a different brand and size of eyelet on the new boat cover. These are smaller, are Carr Fastener brand brass eyelets, and were put in using a proprietary tool. They look much, much better.
    Size SP3. The tool is a long steel deforming/rolling type, rather than a crush and pray type. I've used a hardwood backing block, and a small nylon mallet as the manufacturer reccomends. I don't know which way round to put the washer so I've done one each way and both look good.
    Sent from a phone.
    Paperback E-book
  2. #40602
    You get Big George to sidle up the them, lien over them, and fretten to do bad fings unless they coughs up the doe.
    Sent from a phone.
    Years ago in a new venture I had occasion to chase a commercial debt. The debtor blankly refused to pay, "Sue me' he said. But Barry, old friend, Painter and Docker, dressed sharply, carried a chrome painted varnished handled sledge, persuaded him otherwise.
  3. #40603
    A local bloke refused to pay our local fencing contractor for a new post and rail stock yard, "Not a problem", said the contractor,"I'll take it away''..... and started his chainsaw. The bloke paid.
  4. #40604
    Oct 2006
    Livin' in the Golden Triangle
    An unexpected visitor or two called by while I was scrubbing the bottom.
    Attachment 9908
    Just so long as the tail flukes go horizontally...
    I've always wondered whether scrubbing the bottom is akin to burleying up the big ones?
  5. #40605
    Sometimes all you see is the dorsal fin ,that gives a few seconds of blind panic!
    That happened to me about 53 years ago at Port Noarlunga, spear fishing for squid, I looked up, saw the fins coming towards me . I can't quite remember what I said ....but I was sh!t scared for a few seconds.
  6. #40606
    My one and only attempt at hooka diving was trying to scrub the bottom of a 46 footer in Sydney harbour. All I could think of was that the debris clouds and scrubbing sounds would be likely to attract the attention of anything resembling a bull shark in the vicinity of Rushcutters Bay. I talked myself up into a state where I couldn't breathe and had to abandon the job. I've never gone back for a second go at it since then, around 1982.
    Paperback E-book
  7. #40607
    Re the eyelets above, I saw a youtube instruction video where the advice about acrylic and polyester fabrics was to apply 'resin' into the cut fabric edges of the hole before sealing the grommet down. The so called resin bottle was labelled 'super glue'... Any thoughts?
    Paperback E-book
  8. #40608
    Oct 2006
    Yep, they hunt via scent, typically urine, but I would expect that a strong bio trail would interest them
  9. #40609
    Because of the local seal and penguin colonies we get Tigers in our bit of Bass Strait but so far the only sharks I've seen were at a distance along the reef, though one passed under me in the 'yak in the mouth of a local river.
    We see more young seals than we used to though, in the mangroves at high tide.
  10. #40610
    Super glue is pretty inflexible, maybe not the best choice.
  11. #40611
    Glad those eyelets are working for you Bruce. I remember now I also,used them on the front of the addition to my sail cover. They seem to be doing fine. Have you tried making the hole with a soldering iron as we discussed?
  12. #40612
    Of of course most of the Sharks around here are White Pointers, but I've never seen one in the marina. I'm feeling more comfortable with the Hookah each time I go down. Very happy with it. The first time there was massive growth on the bottom, I was scraping it off with a smallish plastic gyprock smoothing scraper. Hard work and kept breaking the scraper. Then Imtried a metal painters scraper. Better but still hard work. And too close to the action. Pretty gross to have your head right in the middle of clouds of marine yuck. Then I went for a straightened garden hoe, on about a 3 foot handle. Wonderful tool. Each thrust was much longer, wider, and just the right pressure. Powered through all sorts of crap. Since then I've done 2 rounds with those big scotchbright pads. Yesterday was about an hour and a half, not too bad for a 50 foot hull with 2 big keels and skegs and rudders I reckon. I think the antifoul is pretty well spent, it's 2 years old now, so I think I'll be getting in plenty of practice with the hookah. But now that it's just a quick once over to remove a bit of slimy stuff and the odd angel hair ( I don't know what it is, some bloody seagrass which grows so fast that as Bruce says, if you stand in the water for more than 5 minutes you have to scrub it off your legs), it's not too much of a chore. Next job is to replace the zincs, which look about half gone so are probably pretty well done.
  13. #40613
    Inflexible shouldn't matter in this application, they should be firmly clamped between the 2 parts of the grommet. But we were thinking, make the hole with a soldering iron, that will give a good edge. I don't have a punch so when I've used them I've just cut a small cross and pushed the tool through. It works.
  14. #40614
    Or heat a bit of metal tubing of the correct diameter with a torch and cut the hole with that.
  15. #40615
    Oct 2006
    I got back onto a boat up on the Barrier Reef after snorkelling out from a cay and this lovely lass came up to me and said "did you see that Tiger Shark that swam behind you?"
    Um... nope. Thankfully.
  16. #40616
    I remember sitting about 3m from a tiger shark at 25 m depth on a dive course off Byron Bay, Julian Rocks. It wasn't even a bit interested in divers who look unlike any food known to a shark.
  17. #40617
    Oct 2006
    Tell that to the surviving fisherman, of three, who was on a trawler that went down off Queensland a few years back. A big Tiger came in and took one of the three in the water, came back the next day and took the second. Then he got rescued.
  18. #40618
    My point was that scuba gear makes us look like nothing on their menu. Tanks , masks, bubbles , bright colours.
  19. #40619
    Well, there was Priscilla, the gay seal who was taken by a tiger shark ......
  20. #40620
    Where to begin...
    Priscilla taken by a tiger shark? Sounds like bull shark to me.
    I haven't used a soldering iron or a heated tube to make the grommet holes yet. I did use a gas lighter to try to melt some furry edges but it was too brutal for the material. I used the suggested cross cut and push the grommet sleeve through technique, which is ok. I'd like the addition of a melted or glued edge under the washer, but as you say it's firmly clamped between two brass flat rings so probably not an issue.
    Massive growth on the bottom... some kind of angel hair... Priscilla... straightened hoe... Wonderful tool... So much scope, so little time. I'll leave those alone though, apart from to say I did tell you not to sit in that water for any length of time.
    Paperback E-book
  21. #40621
    Henry gets s good laugh. Dads going down to the boat with his Hookah.
  22. #40622
    Last bit of known rot in the cabin top is now repaired. I would of had the new grabrail back as well but I've gone and bevelled the base the wrong haven't I. Oh well a quick run through the sawbench will fix it.
    We did a couple of hard drops off the backs of a couple of waves on the bar in PD30 yesterday. I knew the second one was going to hurt before we even punched into the top of the wave. Hate it when they are steep with no back slope like that.
  23. #40623
    Oct 2006
    Oh well... it's off to the boat. Pumping out every fifteen minutes. Ugh.
  24. #40624
    Sounds as if there is a bit of work to be done Ian.
  25. #40625
    Oct 2006
    It's likely to get a chainsaw session, unfortunately
  26. #40626
    I came so close to that myself in July.
  27. #40627
    True but a real pity, you've put a lot of work into her.
  28. #40628
    Gold Coast Australia
    WB sailing up near Chinderah with Mount Warning in the background. The only thing missing from the anchorage is Paul’s little 25 footer.
    [IMG][/IMG
    After a lovely sail I ran into Paul a genuine disabled pensioner who suffered a stroke many years ago ,now homeless and living in his car at Fingal.
    I first met Paul at the TVSC where despite being paralized on the left side of his body he always managed somehow,and then went on to purchase his boat becoming a live aboard at Chinderah for the last two years.
    That was until NSW Maritimes gave him 24 hours to get of his boat with the threat of $98 daily fines for non compliance. Presently Paul is hoping to find reasonable accomodation in our area as his mother is living in a nursing home down in Pottsville.
  29. #40629
    Sad. But if you have rules about liveaboards I guess you have to apply them to everyone. He shouldn't be homeless though.
  30. #40630
    There's very little rental accommodation around here after the floods, it won't be easy for him.
  31. #40631
    We were going to move our Tuesday sail forward to today, because Felicity has to work tomorrow, but last nights weather forecast included a strong wind warning for today. So we wimped out. The rest of the week is going to be stupid hot, so sailing is postponed to maybe some time next week.
  32. #40632
    What there is is frighteningly expensive. There's quite a lot of homeless living in cars and vans up around Tweed.
  33. #40633
    My son and his GF have just been on holiday in their van. Spent a few days around Byron. They say they are very down on anyone trying to sleep in a van other than in a formal camping ground, which of course are all fully booked and expensive. I think they said they found a footy club which was allowed to take campers. But lots of signage on streets, car parks etc saying we don't want you here, bloody tourists, get lost. Or something like that.
  34. #40634
    Local showgrounds usually allow some camping.
  35. #40635
    Byron is so full of tourists it's just not worth visiting !
