Results 1 to 35 of 67
Thread: Cruising Plywood Trimaran Design max 24/26ft
    Nov 2006
    Edinburgh Scotland
    Default Cruising Plywood Trimaran Design max 24/26ft
    Anybody got suggestions for a decent small cruising Trimaran design?
    Feb 2004
    Downingtown Pa (S/V UTOPIA down in Somer's Point, NJ)
    Default Re: Cruising Plywood Trimaran Design max 24/26ft
    Cross, Piver, The constant camber guy...
    I have a good friend with a Cross 42, and have sailed on a Piver 30, I believe. These are old school tris, not like like the new production tri's. Some where I have a book of cruising trimarans from the 70's. it lists tons of specific designs in that size range.
    Feb 2004
    The book is called "Racing and Cruising Trimarans" by Robert B. Harris. 1970. Charles Scribner and Sons
    in it are:
    Tchetchet 24
    Piver 30
    Piver 25
    Gougeon 25
    Dick Newick 36
    Brown 25
    Norm Cross 26
    Joseph Dobler 25
    Texas Trimaran 30
    Westell 30
    Nielson 24
    Tempest 33
    mentioned in the first 50 pages. I'm sure you can buy a cop cheap. I got mine on ebay for 5 bucks or so.
    -Thad
    northern new jersey, usa
    Buccaneer 24
    Scarab has some more modern designs in that range, for plywood
    “The difference between an adventurer and anybody else is that the youthful embrace of discovery, of self or of the world, is not muted by the responsibilities or the safety-catches of maturity.” Jonathan Borgais
    Sep 2005
    Nation of NJ
    What Thad said....I have a copy as well and, in addition to the various designs, there's a lot of practical TRI advice and some great background on the history and hotbed of creativity mid 20th century in the development of TRIs.
    Live and let live
    Duncan, Vancouver Island
    I would seriously like to see some of Matt Layden's new Nugget 22s on the water:
    http://smalltrimarans.com/blog/?p=6071
    Don't know anything about these but they might be worth a look:
    http://trimarankit.com/
    Dec 2011
    I live aboard a plywood trimaran. It is specifically a cruisiing tri--although some folks have extended the masts and raced them.. It is a Pivor--and while I think a trimaran under sail is a wonderful vessel, low speed manouvering into a marina in a cross wind is very difficult, the big problem faced by Trimaran owners in Australia (don't know about the US or elsewhere) is the reluctance of insurance companies to provide cover. I have been iunable to insure mine for some years, which makes a marina berth unobtainable and I have to use a fairly large tender to go and collect fuel and water, not to mention supplies.
    If I was to go for a trimaran of the size you mention--I would choose a Farrier (or some other similar design) trailer-tri. Problem solved--especially the one where the unattended vessel gets looted or set adrift, something that happens here from time to time.
    Good luck with the project
    Mike Banks
    Nov 2006
    Edinburgh Scotland
    Yeah, Thanks for these responses.
    Certainly want to find a cruising design that will allow extensive coastal and a bit offshore sailing.
    Main criteria, apart from ease of build is headroom of course.
    I appreciate all those comments so far and issues regarding marinas and insurance
    I've been looking at the photos http://svfarsouth.weebly.com/index.html of Kevin in South Africa who has recently built himself a Hartley Lively 28.
    Very simple looking chine hull and outriggers, although I cant see any centreboard ?
    Any comments on this I wonder?
    Thanks so far guys.
    I bought Jim Browns The Case for Cruising Trimarans and waiting on post for The Cruising Multihull by Chris White.
    Would like to buy a more technical book which contains designs and construction details
    and discusses the maths behind the main design and scantling issues...
    Feb 2004
    doesnot Jim Brown have a 26 he named scrimshaw... I seem to recall an article in good old boat about it...
    Dec 2008
    Salish Sea
    Absolutely a ton of usable space and ideas on this Horstman trimaran. And there is a trailerable version.
    http://www.yachtsnet.co.uk/archives/...tristar-24.htm
    Apr 2011
    St-Hippolyte, Qc
    I've own, live, rebuild and cruised in a Piver 36ft trimaran build out of Mahogany plywood.
    The space is great, the stability excellent (I remember throwing all the canvas she can take in 30 knots of wind, going 10 to 12 knots with ...5 degrees of heel over). Excellent space for living aboard and to repair easily.
    There was 2 things I didn't like at all about it, upwind it does not worth a damn, simply forget it. I was without engine and I do know the feeling of tacking 2 to 3 days in front of a inlet waiting the wind to change direction.
    Second the outside hull (Ama I think in english), was fastened with copper nails and were fine, the main hull with Galvanize nail you could not find any nails anymre only the rust spot where they use to be some...
    That trimaran needed 5 gallons of Antifooling for only 1 coat... So prepare your wallet
    http://www.peacefuljourney.ca/
    BEWARE: I am a native french speaker
    The budget is a big issue. By the foot, tris are the most expensive type. I had a Brown Searunner 25, and now sail an F27 -- both great boats. But both were bought as older fixer-uppers because that's where the value is.
    The Gougeon Brothers on Boat Construction is a great resource. Also, don't miss Kurt Hughes' designs -- in my mind the best choices for a home build.
    Feb 2004
    I noticed quite a few tri's down in the keys.... maybe that's a place to find a fixer upper.
    oh...wait... your on the wrong side of the pond... that won't help you.
    Last edited by Thad Van Gilder; 12-04-2011 at 07:42 AM. Reason: oops... wrong continent
    I should also have mentioned the winner of our host's Design Challenge III -- the Marples DC-3 trimaran. Lots of nice features, and designed to keep the construction labor and cost from getting out of control. It also folds for trailering and docking in slips very easily. The negative is that the plans aren't complete so you'd have to work with the designer on that point.
    Here's a link to the write-up in Professional Boatbuilder.
    May 2007
    http://www.westsystem.com/ss/assets/...ook 061205.pdf
    Mar 2006
    CO
    Another option: Mike Leneman's L-7. Pasted a link to a website with some pics of the one I built. There's another link at the site which contains a document of all the construction details / photos while I built her in my garage (3.5 year project).
    http://home.comcast.net/~ritakend/site/
    Oct 2000
    Padanaram, MA USA
    Damfino, to Dick Newick's Spark design is 28'+ and is conceived as a gent's daysailer, with good performance, easy to sail, limited accommodations and good looks. It's not plywood and was not a quick or inexpensive build.
    Oct 2011
    I am currently building the first Nugget, Matt Layden's 22 foot trimaran. His plans are coming together quite well and this week I temporarily fitted the cabinsides to determine locations of ports. There are quite a few photos available of the build, should anyone be interested.
    Mike Monies- The Boat Palace- Eufaula, OK
    Nov 2007
    Quote Originally Posted by MMonies View Post
    We would love to see photos. Perhaps loaded up onto Picasa for general viewing, batch uploading is very quick, or on your Sail Oklahoma Yahoo site. Thanks Mike for offering to post them, there will be a lot of interest in this new Matt Layden design, and in your build.
    Brian
    Ditto interest in seeing the build photos.
    Also, Brent, your boat looks great. How does she sail?
    St. Charles, IL
    You should head over to www.smalltrimarns.com and check out the options Joe has put together on his blog. You might want to be specific about what small cruising trimaran means though as you're likely to get suggestions to camp cruise on a Trinado or buy a used Corsair 31 and everything in between.
    Dan
    May 2007
    Is Matt going to be offering plans for this design?
    Oct 2011
    The boat was commissioned by Katie and Lee Martin of Texas and plans belong to them. If the boat turns out as planned they will offer plans for sale but not until it is completed and they have had the opportunity to sail it.
    I will try to get photos into an album on Sail Oklahoma! this week and will post a notice here when I have done so.
    Mike Monies/http://groups.yahoo.com/group/SailOklahoma/
    Good to hear, Mike. Looking forward to pics.
    Quote Originally Posted by tomfindlay View Post
    Any comments on this I wonder?....
    Not typical for a tri. Looks big and deep inside. 6'3" headroom:
    I wonder about the effect on heeling that the shape of the outriggers have. The deep vee shape of the Hartley design I would expect to heel more than the teadrop shape of a Scarab http://www.teamscarab.com.au/scarab8/design.html
    Hartley vs. Scarab is all about comfort vs. speed. The builder has to decide where his priorities lie. But even a slow tri in this category is fast by mono standards. It's also important to distinguish between boats that can be taken apart and trailered in pieces and those that easily fold up for trailering.
    That Hartley seems to do away with centerboard in favor of stub keels on the amas. Pretty much all its features speak to space and comfort. And tris, despite their speed image, do have a very comfortable motion for their length and weight.
    May 2007
    Is this typical of how this process works? You commission a design for yourself, you own all rights to the design and then you could sell the plans yourself if you want to?
    Oct 2011
    Depends on arrangements with the designer. In this case the plans do belong solely to Lee and Katie Martin. In some cases the agreement is that the designer retains right to sell the design to others if he thinks it might sell well. It costs more to own plans outright by the person who does commissioning.
    The Scamp is a good example of another boat I built recently that was commissioned. Small Craft Advisor magazine had it designed by John Welsford and they own the rights to the plans (Small Craft Advisor Magazine Project- SCAMP)
    Mike Monies
    Mar 2006
    CO
    Thanks! She sails quite well. Rated PHRF about on par with the Farrier F31/F28 boats, but the mostly plywood construction makes for a fast build. The Colorado mountain lake winds make it tense sometimes, lot of sail area combined with wind shifts and fast storm fronts.
    France & Viet Nam
    Quote Originally Posted by Mike Banks View Post
    Sorry for responding late to this thread.
    I can only wholeheartedly second that, Mike! And also: why systematically go for fifty over years old designs???? The book mentioned by Thad only cites designs over half a century old, where multihulls were the ugly ducklings, whose performance (and safety!!!) was miles below that of modern ones.
    "Homme libre, toujours tu cheriras la mer" (Charles Baudelaire)
    Waterbury, Connecticut
    Did I miss mention of the new Brown/Marples small cruising tri that won the Wooden Boat design competition last year? -- Wade
    I posted a link to the Marples boat higher up -- but I still don't know if the design is being completed to the point construction plans are available. Somebody needs to build this boat!
    Sep 2011
    atascadero, ca.
    If I were building, I'd go for a suitable modern design; If I were looking for an already built tri, I would look for a Brown Searunner 25 or 32 footer with folding amas and a trailer. These were good designs for the day, and sailed pretty well. They can be found in various states of need for much, much less than their material cost, and can be easily repaired, and "turbo'd".
