Page 37 of 37 FirstFirst ... 273637
Results 1,261 to 1,289 of 1289
Thread: Restoring a 1929 Stephens Cruiser
  1. #1261
    Nov 2003
    Rio de Janeiro, BRAZIL
    Default Re: Restoring a 1929 Stephens Cruiser
    I think Epifanes is ordinary enamel. Certainly not a two part paint.
    You can see a few plank joints and such. It is mostly a matter of prep work..
    Many thanks ! First-class prep work, though !
  2. #1262
    NH, USA
    Wow. She looks incredible!
    There are few issues in life that cannot be worked out with a sharp chisel and a bit of time
  3. #1263
    Petaluma, CA
    So, with the days growing longer, and the rain finally abating, I am making boat work plans.
    First up is to rebuild the aft bench. When I first did this, now 5+ years ago, I kept the seating part of the bench somewhat narrow. This was, in part, because the sole framing gave me two choices: here, or there.. I chose here, and the result was two small (8 inch wide) sole panels right in front of the bench, and a bench that was somewhat shallow (maybe 15-18 inches deep).
    Over the past few years, we have found that this is not only not very comfortable, but it creates a space between the aft bench and the mid-ship bench that is uncomfortably large. You can put a table in that space, but it is just a little too far to reach easily.
    So, I plan to dismantle the aft bench, and move the front to "there"...This will involve some surgery on the sole, and a little re-work of the front panel of the bench, but mostly it will involve rebuilding the storage lockers inside the bench. This is a good thing, since I was a little sloppy when I built these originally. They are nice, but the covers (which are also the bottoms of the bench) are just ever so slightly non-square, and they are the same, top and bottom. This means that if you take them out (which we do to access stuff in the lockers), you have four possible ways they can go back, and that's assuming you didn't take both of them out...
    I also am planning to FINALLY redo the wheelhouse interior. This is mostly sanding and varnishing, but there will be a little teak cabinetry, and some trim replacement.
    I'll start planning this over the next few weeks.
    Cheers!
    Scott
    Now is a good time!
  4. #1264
    Petaluma, CA
    So, mystery for the day.. Why on earth would Scott start drilling 1 inch diameter holes part way through his beautiful teak bunks?
    Hint: There are eight of these holes...
    Now is a good time!
  5. #1265
    Juneau, Alaska
    Um... he likes buying teak?
    -Jim
    Sucker for a pretty face.
  6. #1266
    Cabinet style hinges?
    Slots for pipes for a berth?
    There are people who don't groan & wince when buying teak?
  7. #1267
    Mar 2008
    Devonport, Auckland NZ
    I'm with Garret - pipes for a super king size berth :-)
    "Old boats are like teenage girlfriends: there is a certain urgency to their needs & one neglects them at one's peril"
  8. #1268
    Petaluma, CA
    Bingo!
    Since the houseboat is out of commission, we are planning on spending a lot of time bar MAKOTO this summer. We're a little tired of the narrow separate bunks, so we decided to try filling the space between the bunks with ply panels, and sleeping crosswise instead of lengthwise. I had some bronze tubes left over from the grab rails, so rather than make more teak supports, I decided to use the tubes.
    I'm off to the boat this weekend to cut the tubes and make some templates for the ply panels.
    Everything can then be stored inside the bunks with the bedding when it is not in use!
    Sorry I don't have nay extra LBPC caps, or Garrett would be the winner!
    Scott
    Now is a good time!
  9. #1269
    Petaluma, CA
    Quote Originally Posted by snow(Alan H) View Post
    And Alan wins too!!
    Now is a good time!
  10. #1270
    LPBC, SC USA
    I didn't get here in time to give my guess of an extra large honeymoon suite. Drats! Foiled by the hand of time again. LOL
  11. #1271
    Petaluma, CA
    I had two of these bronze tubes left over from the grab rail project several years ago. So today I cut them to length. Port Townsend Foundry sent me another tube to complete the set. After I fitted these, I decided to make the wood bunk filler one piece, so the pair of tubes in the photo will just be a single tube, and the forward tube will go way forward to the other end of the bunk. I'll either plug the wood beam, or, maybe just varnish it and leave the cutout.
    Now is a good time!
  12. #1272
    Petaluma, CA
    Been a while since i last posted. Susan and I were cruising back from the Island (Grindstone Joe's) a few months ago when I noticed the temperature on the Yanmar climbing fast. I found a private dock on Georgianna Slough, and shut her down just as the warning light came on. The dock owner was ver gracious (helps when you tie up with a 91 year old boat!). Vessel Assist got there from Bethel Island in about 30 mins (amazing!), and towed us the rest of the way to Oxbow Marina.
    I suspected the impeller, since there was no water coming from the exhaust. Boy was I right!
    The impeller housing is almost impossible to get to on MAKOTO, since the engine is in a tidy insulated box. I managed to get my bearings using my phone to take some blind pics, and then got the impeller cover off.
    Here's what I found...
    YIKES! No wonder nothing was coming out of the exhaust!
    20 minutes working blind through a little gap between the motor and the box, I got the impeller out.
    And then spent 20 minutes wrestling the new one back in, some detergent helped...
    And then this happened! WHEW!!!
    http://www.mv-makoto.com/makoto/IMG_4357.m4v
    Now is a good time!
  13. #1273
    Petaluma, CA
    Now is a good time!
  14. #1274
    That impeller was almost due for replacement! Nice there was a dock handy.
  15. #1275
    Mar 2008
    A wee tip - compress the impeller with a cable tie, when 1/2 in, cut the tie and push it all the way in :-)
  16. #1276
    I had about the same thing happen a couple of years ago, ...... only for me it was all four impellers just about at once.
    The only thing you might think about is "where are the missing veins?"..... They have a habit of finding their way into places like oil coolers and getting stuck in elbows.
  17. #1277
    Petaluma, CA
    Yeah, I am worrying about that...
    S
    Now is a good time!
  18. #1278
    Petaluma, CA
    THAT'S a brilliant idea!!! I'll remember it for the next time!
    Thanks
    S
    Now is a good time!
  19. #1279
    Nov 2003
    Thanks
    S
    Rightly so ! There is a ITT tool that retails for 150 dollars, specifically for this purpose.
    Pulling out a knackered impeller is reasonably easy. Putting a new one in isnīt !
    Try out 'Globe' impellers, they may lose their 'punch', but rarely fall to bits and spread havoc around the raw-water circuit
  20. #1280
    Petaluma, CA
    Well, it's been nearly a year with lots of hours on the boat since the impeller incident. She runs cool and sweet, so I guess whoever became of the impeller bits didn't do any harm.
    I am still planning to rebuild the aft salon bench to make it wider. I'll probably start that project in the spring, once the shanty boat is done.
    Here is a pic from Thanksgiving week. We spent 5 nights aboard MAKOTO berthed next to the shanty boat, working on it every day. Thanksgiving morning I woke up to find us surrounded by water hyacinth. By noon, it had all departed on the tide..
    Here was the view of the Island from MAKOTO as we arrived. A very "seasonal" image!!
    Scott
    Now is a good time!
  21. #1281
    Sep 2017
    omaha, ne. usa
    Quote Originally Posted by carioca1232001 View Post
    I love Epifanes. Full disclosure, I have only restored one wooden boat. It took 7 years, so I re-refinished many parts of the boat with just a clearcoat(bright). I liked the way you could sand the Epifanes with Festool Granat sandpaper.
  22. #1282
    Sep 2017
    omaha, ne. usa
    Here is a pic from Thanksgiving week. We spent 5 nights aboard MAKOTO berthed next to the shanty boat, working on it every day. Thanksgiving muring I woke up to find us surrounded by water hyacinth. By noon, it had all departed on the tide..
    Scott
    As the kids say, "nature is metal as fuck".
  23. #1283
    Petaluma, CA
    Quote Originally Posted by jonesmatt1957 View Post
    LOL!!
    Now is a good time!
  24. #1284
    Jul 2002
    Good to see you and the old girl again. She looks like she appreciates your care.
  25. #1285
    Petaluma, CA
    She is super stable, and has been out a lot this year! The covered slip with a roll down screen helps a lot!!
    Now is a good time!
  26. #1286
    Petaluma, CA
    Here are a couple of more up to date photos.
    Now is a good time!
  27. #1287
    Petaluma, CA
    Been a long year of lockdowns and no travel.
    We have been out a lot in MAKOTO, mostly to the Island, and only just the two of us. Managed to avoid getting COVID, and did a lot of work on the houseboat.
    MAKOTO's hull paint and brightwork are holding up amazingly well (going on 3 years on both!). We plan to have the brightwork done in the spring, and while we are at it we will finally re-varnish the inside of the wheel house. It's the only part that has not really been done.
    I'll keep y'all posted.
    Stay safe out there!
    S
    Now is a good time!
  28. #1288
    it's good to hear from you and to hear Makato is doing well too! Stay warm out there on the other side.
  29. #1289
    May 2000
    St. Louis, MO
    Thanks for the update!!! What a journey. Fantastic boat!
