Results 1 to 27 of 27
Thread: need a little help here...building a farm gate
    May 2002
    North West Arkansas
    Default need a little help here...building a farm gate
    all I need is a pic of one I like and I can use that to build a 14 foot gate...after searching for a while, all I can find is businesses wanting to sell me gates or gate kits...not what I want
    anybody got any ideas?
    The doctrine of nonresistance against arbitrary power, and oppression, is absurd, slavish, and destructive of the good and happiness of mankind.
    Personal failures are too important to be trusted to others.
    The land of reefs
    Default Re: need a little help here...building a farm gate
    Jim Ledger did a nice one a few years ago.....
    May 2002
    North West Arkansas
    I think I remember it...
    what I'm looking for is function and nothing decorative...I'm just trying to beat the price of a steel gate and I like wood better...my labor will be free on this
    will use treated lumber except the top rail (some horses tend to crib and I don't want them chewing the treated stuff)
    Oct 2003
    Hell
    Quote Originally Posted by Phillip Allen View Post
    did you do a google image search?
    May 2002
    North West Arkansas
    I've never done that...give me a hint
    all I think I need is a line drawing on a napkin
    The land of reefs
    Why pressure treated? I'd use Pine with a White Oak cap rail.
    May 2002
    North West Arkansas
    Quote Originally Posted by Mrleft8 View Post
    pressure treated keeps me from having to replace it in a few years
    The land of reefs
    Pine won't rot if you keep it off the ground. PT is heavy and ugly
    Oct 2003
    Hell
    try this search engine:
    http://images.google.com/imghp?clien...l&hl=en&tab=wi
    Oct 2003
    Hell
    Quote Originally Posted by Fred Z View Post
    Noooo! Why did you tell him?
    you can lead a horse to water. . .
    May 2002
    North West Arkansas
    thanks, Paul (I'll talk to you later, Fred)
    Dec 1999
    Eagan, Minnesota, USA
    Oct 2003
    Bright's Grove, ON, Canada
    here are some
    Allan of the Grove
    "never send a ferret to do a weasel's job.."
    52 50 w
    you could try searching 'farm gate' and see how it goes ..
    May 2002
    North West Arkansas
    thanks all...I just couldn't seem to get it together this morning and ran out of patients
    52 50 w
    .. ran out of patients
    patience
    Jan 2005
    Deepest Darkest Wales
    Gates are easy once you've learned to weld.
    Nov 2006
    The problems with a wide farm gate are twofold, hinging and diagonal support. With this in mind, the first problem to tacle is finding suitable hinges. The diagonal support is usually a solid metal rod with nuts on each end running from the top of the hinge side stile to the bottom of the opposite stile. If you can make the hinge post and hinge stile taller than the gate itself, you will have given the structure a better configuration to resist sagging, as the hinges can be spread apart and the diagonal is steeper.
    CCA is just fine for makeing a utilitarian gate, through bolting would be the best method of joining. It doesn't always have to be a work of art.
    First, find some suitable hinges and a steel rod. The hinges have to be pretty heavy and the rod about a half inch diameter.
    Aug 2004
    Cantão - Brazil
    This one would make for a good weekend project:
    Anyway, you are supposed to be writing about submarines, not farm gates.
    I love Popeye's pic especially because it shows the value of square section end, top and bottom beams and it has fascinating engineering.
    The big challenge in a large gate is to prevent warping. On Dad's gates, we put a brace wire in between paired down diagonal planks on each side of the horizontals. This enabled us to make non-warping 16' gates with lighter planks.
    Lotta ways to skin this cat.
    G'luck
    52 50 w
    you could probably come up with a simple bracing rig without too much effort
    coupla tangs , cable and turnbuckle
    you guys are sailors , right ?
    Dec 2006
    Tuckahoe
    Maybe you should advertise, Dr. Allen.
    Or Dr. Phil.
    Steve Martinsen
    May 2002
    North West Arkansas
    Quote Originally Posted by Popeye View Post
    patience
    I can never remember the spelling of some words no matter how hard I try
    "You can bath em and bath em and they still stinks"
    New Zealand's Far North
    http://www.theshedmag.co.nz/cms/imag..._09/gate_2.jpg
    The traditional Kiwi farm gate is all made from roughsawn 5"x1" or so, and the components are bolted together. Short doublers are added where the hinges bolt through on the top and bottom rails. a 4"x1" is nailed on its flat across the top to add stiffness.
    Jul 2004
    coastal BC
    Damn Canadian Socialists giving away free gate plans !
    http://www.cps.gov.on.ca/english/pla...8364/8364L.pdf
    Jesus would be alive if he had a gun .... just not as famous
    Use an upside down wine bottle for the bottom bearing. It will work like a jeweled watch...
