Page 1 of 9 12 ... LastLast
Results 1 to 35 of 312
Thread: Sailing With No Engine?
    Oct 2001
    Flattop Islands
    Default Sailing With No Engine?
    Sailing with no engine?
    Don raised a question in the restoring Carlotta thread regarding the recent presentation by Stephen and family here in Silva Bay. Stephen has built two 18’ sweeps for Carlotta and they plan (at least for now) on having no propulsion engine or internal combustion generator. Carlotta is a 50’ heavy displacement pilot cutter, no small thing to row! But she has been sailing for many years with no engine, also with no through hull fittings. The concept of cruising and full time living aboard a fairly large vessel with minimal systems causing minimal impact has continued to generate much discussion here.
    As a designer I thoroughly enjoy re-examining the givens, throwing out our foregone assumptions. Most folks contemplating larger vessels assume inboard diesel power, perhaps a generator for battery charging, and numerous through hulls to service various systems. What happens when you decide to sail without all that?
    The obvious immediate positives to leaving out the propulsion engine……
    1)More interior space…..elimination of the awkward engine box and fuel tanks, often positioned in the best (central) part of the boat.
    2)Less weight up high in the boat, possibly more weight in the ballast keel.
    3)Less drag…..no prop or strut hanging under the boat.
    4)No nasty hole in the rudder (for the full keels in the crowd).
    5)No drips from the stuffing box…perhaps even a dry bilge.
    6)No concerns about where to route the exhaust pipe and worries about cooling system through-hull fittings.
    7)Far less expense in first cost and in long term maintenance.
    8)Elimination of reliance on a system that may quit at an awkward moment.
    9)Elimination of visits to the fuel dock….more money for other things.
    10)Elimination of noise, vibration, smoke, and stink, etc. created when running the engine.
    11)Lowering of concern over your use of irreplaceable fossil fuels and your addition to global warming (smaller footprint?).
    12)Elimination of expectations about meeting a schedule….you now have a good excuse for being a month late!
    The obvious immediate negatives to having no main engine…….
    1)Safety…..if I get into trouble how do I get out?
    2)Fewer battery charging options.
    3)Less ability to meet any schedule.
    4)Limited mobility….there may be places that become hard or impossible to get to.
    I'll look at some of these in more detail in my next posting.....
    Tad
    cogge ketch Blackfish
    cat ketch Ratty
    http://www.tadroberts.ca
    http://blog.tadroberts.ca/
    West Boothbay Harbor, Maine
    Default Re: Sailing With No Engine?
    The advantage of a dry bilge is one that really appeals to me. Taliesin and Seraffyn each had dry bilges and it was an eye-opener for me.
    "It's a pirate's life for me. Savvy??"
    May 2006
    Spirit, Sistership to our Black Spirit, sailed the west coast, San Francisco Bay, Multiple Transpacs, thru the Panama Canal, accross to the UK, Fastnet, and much more without any motor or mechanical systems to speak of. All this in a 33' 14K pound sloop.
    "The desire to build a house is the tired wish of a man content thenceforward with a single anchorage. The desire to build a boat is the desire of youth, unwilling yet to accept the idea of a final resting place." -Arthur Ransome
    Dec 2004
    vancouver, british columbia
    Thanks TR - I'm all ears...
    Wow-Ming
    I've never had an engine of any sort, but then I've never owned a boat longer than 15 ft. Paddles or oars have been my auxiliary power, but about 90% of my sailing is daysailing, with a trailer as home port.
    As the size/displacement of the boat increases, and the time/space involved in your cruising ambitions, so does the need for an engine. There's more chance of having to fight a foul wind or current, or push on through bad sailing weather. Yacht harbours are no longer set up for pure sailing. If you're going to be using short-term slips and other congested facilities, you'd better have an engine.
    Mar 2005
    Toronto, Canada
    I'm looking forward to your thoughts on this TR. I'd like to hear your opinion on yawl boat set-ups as a viable alternative.
    - Norm
    Apr 2004
    Toronto
    All over the Indian ocean one can still see sailing dhows, some quite large, 60ft or so, with no engines, just one huge lateen sail.
    However I've also seen some of these large dhows with outboard engines that are lowered and raised amidships and held in place with a variety of lines fore and aft. I wish I had some photos, quite ingenious and seemed to work quite well.
    Dec 2006
    Upwest, Maine
    Quote Originally Posted by TR View Post
    No through-hulls implies a lot more than no engine. Large sump/ holding tanks for head, sinks, shower, icebox, bilge pumps, etc? Or hoses hanging over rail? Salt water pumped aboard into day tank?
    No depth sounder, log...
    Interested to hear how those systems work.
    One of the things that spooks me about no engine is that it also means no brakes. When the traffic gets dense in close quarters, I'll leave the engine on idle just in case. Once in awhile, it's more than handy.
    Auckland ,N.Z.
    We sailed Waione for 7 years without a motor.. using her regularly every weekend and holiday. 41 ft about 8.5 tons.
    It suits a boat kept on a mooring more than a marina berth .. we'd periodically go into marinas but that was on special occasions for work or hauling etc and we'd gear up a bit more that. An anchor is your brake and handbrake turn.
    Mooring fields are are lot tighter now than they were in the good ole days.
    Negatives.. getting there? not so bad , the breeze would always fill in at some stage during the day or evening.
    Lee shore. You plan for that but even having said that my most frightening time was rounding cape Brett in 15knots with some big Northerly swells .. as we rounded the breeze dropped away to nothing and the swells began to wash us in.
    storm anchoring... you have to get that right because you don't have many options for moving in 50 knots.
    Best addition , best thing I ever did when sailing no motor was fit a depth sounder because you could keep good way on as you sussed out an anchorage .
    Depending on where you're going and what you're doing. Donald Street certainly had a lovely pian to no engine which I found true when Goblin's engine died. I really suck as a mechanic so I took it out and removed the prop. Added a knot to her speed. Granuaile also eventually had no engine. So I couldn't legally go through the Cape Cod Canal?
    It's true that seamanlike use of power, often with sail, can make a difference in certain storm and survival situations and - most here know that I routinely brought Goblin (12 ton 43' Alden schooner), Granuaile (20 ton 55' Marco Polo) on and off docks, moorings and anchors when their engines had died, and of course it's easy with Marmalade though her engine works and I do it under sail to stay sharp. I am convinced that on average power gets more people deeper into trouble than if they learned - perhaps with some minor contratemps along the way - to do it under sail.
    Nonetheless, I at this time think I'll keep Marmalade powered becasue I'd like to sail around New England Plus - Down East, up the St Lawrence, the canal to Champlain and on to the Hudson, up the Sound and home. A good deal of that absolutely means a motor and any chance of doing it in a season with a slow catboat pretty much means motor sailing whenever the wind's light or against.
    What it comes down to - living without the motor has many huge advantages financial, lifestyle, and at one with the sea. Having the motor may or may not be the right thing, depending.
    G'luck
    Aug 2004
    Florida
    Here is a link to a website called www.furledsails.com , with an interesting discussion (audio) on enginless sailing http://www.furledsails.com/article.php3?article=773
    Barry
    Oct 2006
    Some of the issues could be compensated for with a tender and motor. I do think the idea of independence is a little false. In this day if you leave for long term cruising with no power you will be doing so depending on the motorised help of others at some point. maybe no more than those with power but independent no. This is fine but the idea of skipping across the water on little "green" slippers is sort of false, especially when the 50hp 2 stoke belching panga is pulling you off the unmarked channel to the lagoon. We have some notable and one "notorious" engine-less cruisers and it all seems to work. As to the no thru hulls, ice box bottled water the big ones, and comp head.
    So Tad, If the criteria was
    long term cruising for a small fam
    2 staterooms
    head
    main cabin
    what rig?
    How big would it have to be to be comfortable?
    What type of construction?
    How much?
    It would be a amazing feat to come up with a design that could meet the determined criteria and be safely home built for a reasonable cost. Maybe spur a new generation like the late 70's.
    "Go cruising for under $$ ?????? !!!"
    Jake
    Nov 2002
    Whidbey Island
    Peter Tangvald was one of the more famous anti engine sailors. His books are excellent. Unfortunately he is not with us. He didnt have an engine when he needed it.
    "Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." - Mark Twain
    The Pardeys are and seem to have been quite succesful in their venture .
    washington
    its a boat they been around with no engine far longer than engines been around.
    no amount of power in the worlds gonna make up for bad seamenship; and you are not gonna get real good if you dont have to IMO.
    Southern Maine
    What kind of sailing does Stephen intend to do with Carlotta?
    For long distance stuff an engine is nice. I remember reading something by the wife of the builder of the Spray replica Scud, about how painful it was to sail past beautiful Pacific atolls because they would have needed an engine to get in or out.
    I've witnessed "Screechy" Donn Street many times warp IOlare into the docks, always an imposition on those around him.
    Dec 2000
    I did 2 circumnavigations with NO engine...the dink had a 2-4 hp that was never used with the big boat...(boats were 31 and 38 feet).....and many times I have sailed the 44 footer down the channel ( Herrington Harbor, Md.) and parked her in her slip by throwing the helm over and backwinding the sails.....and never a bump on the hull (although it did get some attention and folks waiting for the crash..)
    Wakan Tanka Kici Un
    The former owner of Carlotta used a skiff alongside regularly with a decent sized OB. The Pardys have accepted tows. That not being engineless, it's using someone elses engine.
    I sail a boat with no through-hulls (not a cruising boat though) and feel much safer. Tacktick has come out with wireless solar powered instruments that monitor the usual things a sailor can use. There's alot of simplicity and flexibility inherent in that approach. They are becoming more widely spec'd now that they are proving out: http://www.tacktick.com/page.home
    As I recall his son's account, Tangvald's death was not due to having no engine. He may have had a stroke or seizure. Whatever, the wind was fine and the big boat with Tangvald and his daughter was towing the son's boat.
    Having more sail is certainly a good idea. I've been playing with the notion that if I ever break Marmalade's mast I'll make the new one enough larger that I can pick up about 100 square feet and sail 95% of the time at new first reef (the current 550 sq ft) or less. But then, is it worth it. Marmalade is not so under-rigged.
    The main problem with light air sailing, at least for us, is not sail area but other boat wakes. A couple of weeks ago Marmalade and I went out in a genuine drifter. As in so slow that on a broad reach the sheet was in the water and the clear still water showed no wake. But we were moving as a good 1/10th knot. It was really fun. After a while we got up some real speed and managed a half mile across behind the Hyannis Port breakwall in about 3/4th of an hour. Can't do anything like that in the summer when boat traffic leaves constant motion that shakes the air out of the sails.
    New Bern, NC
    A boat of the general size under discussion would be very hard to row. I can see the scene: USCG doing a routine inspection asks, "What is your alternate means of propulsion?" Skipper of engineless sailboat holds up a paddle. USCG folks glance at the rather humongous multi-ton sailboat and double over in laughter.
    It is being engineless when you aren't being towed .That would seem reasonably obvious .Perhaps 99.99% of the time ?
    ..and many times I have sailed the 44 footer down the channel ( Herrington Harbor at Deal, Md.) and parked her in her slip by throwing the helm over and backwinding the sails.....and never a bump on the hull (although it did get some attention and folks waiting for the crash..)
    Chuck -- that's getting home. But how did you get back out into the bay if the wind was coming straight down the channel? Among other things, sailing without an engine requires time and patience. Sometimes, lots of time.
    I sailed and cruised a 26' yawl rigged Friendship for several years in LI Sound. I enjoyed the challenge and the romance. But many of the "harbors" on the Connecticut side are small rivers, lined with moorings. Not a place to sail into for the first time. It does restrict your sailing destinations, also your days. Light breezes tend to fail completely. I occasionally had to row that four ton boat, maybe up to a mile. I wouldn't want to row it seven miles, or drift all night in mid-sound, or try to anchor in 200' depths. On light air days I stayed ashore or close to shore. I didn't mind the few times I was becalmed for hours. I also didn't go out much on weekends, due to boat traffic in a narrow inlet. Coastal cruising is more demanding of an engine than offshore. Inlets, canals, tight mooring fields are where you need power. Had my current boat (a sixteen ton ketch) been engineless, she'd still be in the south.
    Still, I miss the other boat too, and smile when I read the log.
    Are you thinking of going engineless with the Cogge?
    Steven
    Mar 2005
    Albany, NY
    I love my engine, almost as much as my sails. Of course, my professional career is 99% power craft which may be one reason why I enjoy being one of them when conditions don't favor sailing. I never was much good at sitting around as you can tell from my cruise tracks.
    Roger Long
    Sep 2009
    /dev/null (Delaware)
    This is something I want to learn. At this point not planing on doing any long distance cruising. Maybe someday a spin around the Delmarva Peninsula. Here in Delaware sail and oar boats don't require registration.
    How does that work if you sail to a place that requires boats like yours to be registered?
    Nov 2002
    Whidbey Island
    I read that also. Whatever happened we will never know. His son said he saw Peter standing in the companionway as the boat went on the reef.
    We dont know for sure an engine would have save them, but its possible that if Peter was too disabled to handle the sails an engine might have helped.
    He was definately quite a character.
    To me an engine gives more in the way of peace of mind than it takes away with all of its faults.
    And some marinas have a no sailing in the marina rule.
    On a daysailer where you can pick and choose your conditions Id be fine without an engine. For a world cruise I think I want all the options I can get.
    washington
    At one time there was a way to move these big boats around in a handy way. they did have sculls you could drive the boat and it didnt take three men and a boy to do so.
    I dont like an inboard engine; i loved my thrust masters and will stick to something i can get out of the water when not in use and when in use i have 360 deg rotation. if i must have fixed then i dont want it in the boat either. seen and fought too many engine room fires to ever want one in my house again. only time for the motor is in the tight quarters we have now, but dont kid yourselves that you cant sail rivers those ports way up the creeks are not new and they had ship traffic in there day. we had sail boats sailing to myrtle point to pick up logs and they had to fight a heavy fast current. the coquille river is not exactly wide.
    so my question would be what did our great great grand fathers know about sailing that we dont? they sailed up the rivers what did we loose when the engine became king?
    Our Great Grandfathers sailed in a world with far far fewer vessels in it. They took the time to wait for favorable conditions because they had to.
    Waterbury, Connecticut
    Perhaps I missed it, but is an electric motor (lowered like outboard, not through-hull) and option if a boat carries a generator anyway? But perhaps you are talking about a heavy reliance on the 19th century? (and that's fine with me, I am not questioning anyone's philosophy of life).
    Perhaps it is a problem, that you only need a small generator to charge a few things, and that would not be large enough to power an electric motor of any use to a boat larger than 20 feet or so? And a large generator for only occasionally elevtric motor use would be a big annoyance? I do not know much about electricity issues.
    I was told once than even a 2 horse-power motor is more powerful than even a couple of human rowers. A 4-stroke Honda 2 hp with integral fuel tank seems small enough to be hardly an annoyance, and could be broken out when approaching marinas?
    (I confess I own a 2 hp Honda bought to power my outrigger up rivers, but I bought it out of ignorance that the laws changed since I first used an outboard when I was young, and now you need all this crap such as a license and a hull-number and title (my boat is home-built), all complications that have kept the motor in my basement so far! :-( -- Wade
    washington
    no insult mate but that waiting may be something we might want to learn again.
    days of the butter fly fleet there where a whole lot more boats then these days. Empire, winchester, newport, cushmen. etc. where packed with boats far more than i have seen in my life and the fleet was not exactly small when i was a kid.
    Nov 2002
    Whidbey Island
    Quote Originally Posted by wtarzia View Post
    I have a 2 hp Honda on a removable bracket like this
    The only problem with this setup is once the waves get about 4' the outboard has a tendency to be out of the water as much as in.
    May 2006
    Florida
    I sailed a no engine 26ft. sloop into the fuel dock here in Ft. Myers fl. one summer to get fuel for the dink outboard.
    The frantic waving, yelling, and screaming from the Dock Master as I dropped the sail and ghosted into the dock right behind a powerboat was a sight to behold.
    He came unglued about sailing into " his" dock, and " just what the hell did I think I was doing". blah blah blah.
    The fact that it was a perfect landing as I backed the sail .didn't impress him any.....
    " He who works with his hands is a laborer.
    He who works with his hands and his head is a craftsman. He who works with his hands and his head and his heart is an artist".
    St. Francis of Assis (1181-1226)
