Results 36 to 42 of 42
Thread: Bolger's Resolution and St. Valery designs
    Default Re: Bolger's Resolution and St. Valery designs
    The boat balances well with main and foresail. The jib is on a retractable bowsprit, which makes tacking easier. The main staysil is a good addition in light to moderate air. The bronze plates on bottom and lead internal ballast make a total of 2000 lbs. This makes the boat adequately stiff. 2nd reef in each of sails make comfortable rig in 25-30 kt breeze. Boat built to specs except addition of bowsprit designed by Phil Bolger for me and permanently mounted footwell to avoid leaks.
    Position of masts and booms no more a problem in tacking than in any of the other many cruising boats I've had. Comfortable cruising for 2 people. Despite the flat bottom, pounding in a chop is not really a problem as long as the boat is heeled 10 degrees or more. With the outboard the boat can be motored in 2 ft of water and sailed in 3 feet.
    Happy sailing to you!
    John
    Dec 2000
    Thanks, John, and welcome aboard.
    Wakan Tanka Kici Un
    Wooden Boat mag 157 has an article on the St Valery.
    Anyone interested in plans can get them here. Boat Design Quarterly No 10
    http://www.daltonyoung.co.uk/index.p...istPageIndex=3
    Sep 2006
    Eugene OR / Coupeville WA
    I just happened upon this thread twelve years later, and I thought you all might interested to see that the Devlin-built St. Valery is for sale in Olympia:https://www.yachtworld.com/yacht/199...olger-8374435/
    Mar 2021
    Oriental, NC ,usa
    Quote Originally Posted by Peter Keyes View Post
    There are usually reasons why so few ever build some designs, even if Bolger did design them. I thought St Valery was a flawed design and interesting only that it did show how an off the wall concept can work sometimes. Why risk money and effort when equivalent performance can be had with a proven concept. Devlin built it and seemed to make it sound good but I notice that he has not built any more of them.
    Thanks for the information! I enjoy seeing old threads come back to life.
    (I don't need another boat. Repeat as necessary.)
